C Appendix - Activity Codes
Activity Code Mappings
The tables below shows a summary of how certain inventory history codes from WMS Cloud are mapped to Merchandising. In some cases, activity codes are only conditionally updating Merchandising, based on various factors in processing in WMS Cloud.
For all mappings below, in cases where more than one purchase order number is present in an activity code record (comma-delimited list) from WMS and is to be used in processing in the integration with Merchandising, the first purchase order number listed in the record will be used.
Table C-1 Receipts (PO and Stock Order)
WMS Cloud | Merchandising | Comments | ||
Lock Code | Qty Used | Update SOH? | Update Unavail? | |
Activity Code 1 - Container Received |
No |
Adj Qty |
Yes |
No |
Receipt into available inventory |
Current/Previous ERP Buckets |
Adj Qty |
Yes |
Yes |
Receipt into unavailable inventory |
Activity Code 4 - Inventory Adjusted pre-verification |
Adj Qty |
Yes |
Yes |
If the reason code is RUA and there is a PO number in the transaction, this will be mapped as a receiver unit adjustment. Otherwise, it will be mapped as an inventory adjustment. |
Table C-2 Stock Order Status
Activity Code 10 - Container Detail Packed |
Orig Qty |
No |
No |
Increases distro quantity on transfer/allocation only. No impact to inventory in Merchandising. If a customer order, no update to Merchandising, only Order Broker (or 3rd party OMS). |
Activity Code 11 - Container Packed |
Orig Qty |
No |
No |
Activity Code 12 - Order Detail Shorted |
Adj Qty |
No |
No |
Increases cancel quantity on transfer/allocation only. No impact to inventory in Merchandising. If a customer order, no update to Merchandising, only Order Broker (or OMS). Note: if the activity code has a ref value 2 = 91, this is ignored by the integration; this is used for internal WMS processing only. |
Activity Code 27 - Order Cancellation |
Adj Qty |
No |
No |
Activity Code 31 - OB Container Modified |
Adj Qty |
No |
No |
Decreases distro quantity on transfer/allocation only. No impact to inventory in Merchandising. If a customer order, Order Broker will move the order line back to Accepted status based on this status update. |
Activity Code 32 - OB Container Cancelled |
Adj Qty |
No |
No |
Activity Code 54 - Container Detail Picked |
Orig Qty |
No |
No |
Increases distro quantity on transfer/allocation only. No impact to inventory in Merchandising. If a customer order, no update to Merchandising, only Order Broker (or OMS). |
Activity Code 85 - Order Detail Status Change |
Adj Qty |
No |
No |
Increases selected quantity on transfer/allocation only. No impact to inventory in Merchandising. If a customer order, no update to Merchandising, only Order Broker (or 3rd party OMS). |
Table C-3 Inventory Adjustments
Activity Code 2 - Container Consumed |
Adj Qty |
Yes |
Adj Qty |
Yes |
Yes |
If the reason code is RUA and there is a PO number in the transaction, this will be mapped as a receiver unit adjustment (see Receipts above). Otherwise, it will be mapped as an inventory adjustment. |
Activity Code 17 - Inventory Adjusted post-verification |
Adj Qty |
Yes |
Activity Code 19 - Inventory Adjustment Cycle Count Active |
Adj Qty |
Yes |
Activity Code 22 - Lock Container - Before ASN Verification |
Orig Qty |
Increase |
Activity Code 23 - Lock Container - After ASN Verification |
Orig Qty |
Increase |
Activity Code 24 - Unlock Container - Before ASN Verification |
Orig Qty |
Decrease |
Activity Code 25 - Unlock Container - After ASN Verification |
Orig Qty |
Decrease |
Activity Code 29 - Create Allocatable Container |
Adj Qty |
Increase |
Only processed if the Inventory History reason code is not RMA and the order number is null. If there is a value in the order number, then this will be mapped to the "Table C-2" message (see above). |
Activity Code 30 - Create Unallocatable Container |
Adj Qty |
Increase |
Increase |
Only processed if the order number is null. If there is a value in the order number, then this will be mapped to the "Table C-2" message (see above). |
Activity Code 49 - Lock Active |
Orig Qty |
Yes |
Activity Code 50 - Unlock Active |
Orig Qty |
Yes |
Activity Code 53 - Cycle Count - Reserve SKU Counted |
Adj Qty |
Yes |
Activity Code 65 - Lock OBLPN |
Orig Qty |
Yes |
