8 Cost Changes
Suppliers often change the cost of items.
Cost is an important factor in individual transactions and many financial calculations in Merchandising. Changes in cost must be reflected in the information stored in Merchandising and pending transactions.
Cost Change Purge (ccprg)
Module Name
ccprg.pc
Description
Purge Aged Cost Changes
Functional Area
Cost Change
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS476
Wrapper Script
rmswrap.ksh
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
This program is responsible for removing old cost changes from the system. Cost changes are removed from the system using the following criteria:
  • The status of the cost change is either Delete or Canceled.
  • The status of the cost change is Rejected and the effective date of the cost change has met the requirement for the number of days that rejected cost changes are held.
  • The status of the cost change is Extracted and the effective date of the cost change has met the requirement for the number of days that extracted cost changes are held.
The number of days that rejected cost changes are held is determined by the system parameter Retention of Rejected Cost Changes (RETENTION_OF_REJECTED_COST_CHG). The number of days that extracted cost changes are held is determined by the system parameter Retention of Extracted Cost Changes (RETN_EXTRACTED_COST_CHG).
Restart/Recovery
N/A
Design Assumptions
N/A
Cost Change Purge (cost_change_purge_job)
Module Name
Description
Functional Area
Cost Change
Module Type
Admin - Ad hoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Oracle Retail Merchandising Schedule
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from cost change header table based on its purge criteria from system parameter settings. The Retention of Rejected Cost Changes parameter will determine the number of days that rejected cost changes are held. The Retention of Extracted Cost Changes parameter will determine the number of days extracted cost changes are held. It also should meet the following criteria:
  • The status of the cost change is Extracted and effective date of the cost change has met the requirement for the number of days that extracted cost changes are held.
These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from cost change header and other related cost change tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 8-1 Key Tables Affected
Table Select Insert Update Delete
PERIOD
Yes
No
No
No
PURGE_CONFIG_OPTIONS
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Ys
No
No
B8D_COST_CHANGE_PURGE_STG
Yes
Yes
No
Yes
COST_SUSP_SUP_HEAD
Yes
No
No
Yes
COST_SUSP_SUP_DETAIL
Yes
No
No
Yes
COST_SUSP_SUP_DETAIL_LOC
Yes
No
No
Yes
Design Assumptions
N/A
Process Scheduled Ownership Change Data (ownership_change_process)
Module Name
ownership_change_process.ksh
Description
Processes scheduled ownership change records from the Ownership Change related tables.
Functional Area
Foundation Data
Module Type
Business Processing
Module Technology
Ksh
Catalog ID
N/A
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This batch program process scheduled and approved ownership change transaction records that are set to go into effect the next day. It updates costing and ownership attributes of item/supplier/country or item/supplier/country/location combinations.
Additionally, primary supplier and country is updated for item/location records. This process will also trigger creation of PO and RTV depending on ownership change type along with relevant tran data postings to account for financial impacts of such transactions. There will not be any tran data entries if non-inventoried consignment items are involved. In case the item on the ownership change has child items, then the children will also be updated with the same changes as the parent item. On successful completion of the batch, overall status of the Ownership transaction will be updated to 'Processed'.
To account for changes in the item and other transactions that can happen between the time the ownership change was approved and it's picked by the batch for processing; following validations are performed at the time of batch execution. The batch program will fail to process for the ownership change transaction if any of the item/supplier/country/location fails the following validations.
  1. The item should not be part of any pack; the exception being when its component of sellable only complex pack or an orderable (non-sellable) buyer complex pack
  2. The location should not be included in any other approved Ownership Change transaction for the similar Item/Supplier/Country combination
  3. Item should be associated with supplier site and country as specified in the items table.
  4. Current Primary supplier site of the location should be same as the one specified in Items table (When the change type is Update Primary Supplier)
  5. The item/supplier/country/location combination should not exist on any approved and not closed Purchase Order
  6. The item/supplier/country/location combination should not exist on any open Return to Vendor
  7. Any replenishment attribute should not be active for item/supplier/country/location combination
  8. The item/supplier/country/location combination should not exist on any Cost Change scheduled on or after the effective date of the ownership change
  9. Item/supplier/country/location should currently have a purchase type that corresponds to the ownership change type. For example: If Change Type is 'Owned to Consignment' then allow those locations with Purchase Type at Item/Supplier/Country/Location as 'Owned'. Similar treatment for other Change Types.
  10. The item/supplier/country location should have a purchase type of either consignment or concession (When the change type is Update Primary Supplier).
    The item/supplier/country/location should have the same purchase type for the current and new supplier/country; either both are consignment or both are concession. (When the change type is Update Primary Supplier).
Restart/Recovery
N/A
Design Assumptions
N/A
Purge Processed and Aged Ownership Change Data (ownership_change_purge)
Module Name
ownership_change_purge.ksh
Description
Purges old processed ownership change records from the Ownership Change related tables.
Functional Area
Foundation Data
Module Type
Admin
Module Technology
Ksh
Catalog ID
N/A
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This batch program purges old and processed records from the ownership change related tables based on the Ownership Change Purge Days system parameter.
This process also supports archiving, if desired. For more information on how to configure this process for archiving, see the Merchandising Implementation Guide section titled "Background Configuration Process".
Restart/Recovery
N/A
Design Assumptions
N/A
Supplier Cost Change Extract (sccext)
Module Name
sccext.pc
Description
Apply Pending Cost Changes to Items
Functional Area
Cost Change
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS355
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
The sccext module selects supplier cost change records that are set to go into effect the next day and updates the Merchandising item/supplier/country tables with the new cost. The item/location tables are also updated with the new cost if the cost change impacts the primary supplier/country for an item/location, as this is considered a base cost change. The process also triggers a recalculation of cost and deal application for pending purchase orders.
Restart/Recovery
The logical unit of work for the program is a cost change. The program is also restartable from the last successfully processed cost change record.
Design Assumptions
N/A
