4 Item Maintenance
This chapter contains information about the batch processes that relate to item maintenance.
Program Summary
Table 4-1 Item Maintenance - Program Summary
Program Description
gtsbuilder
Global Tax Solution Builder
item_loc_purge_job
Daily Purge of Item-Location Data
itm_indctn_purge.ksh
Purge Item induction staging tables
sitmain.pc
Scheduled Item Maintenance
vatdlxpl.pc
Mass VAT Updates for Items/Locations
Daily Purge of Item-Location Data (item_loc_purge_job)
Module Name
item_loc_purge_job
Description
Functional Area
Administration
Module Type
Admin - Adhoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
When users 'delete' an item-location record in the Merchandising user interface, information is generally not immediately deleted at the database level; instead, data is marked as being in deleted status and also inserted into the DAILY_PURGE table.
Thread assignment program (ITEM_LOC_PURGE_THREAD) will filter eligible records from daily purge (DAILY_PURGE) table wherein all entities ready for purging are exclusively related to Item-Location (ITEM_LOC table) records. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table B8D_ITEM_LOC_PURGE_STG.
The Business logic program (ITEM_LOC_PURGE) will process all records from the staging table. Using bulk processing, this program will delete item-location data from item-location related and associated tables. Complex referential integrity relationships determine whether data can actually be deleted from the database. This program checks these complex rules. If the deletion request passes the rules, this job will continues to delete the data. If it is not able to delete the data, it writes a record to the DAILY_PURGE_ERROR_LOG table for further investigation. This program will continue to attempt to delete marked data until all references have been purged from the system and the deletion of the item-location data finally succeeds. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 4-2
Table Select Insert Update Delete
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
Yes
No
No
No
DAILY_PURGE
Yes
No
No
Yes
Yes
Yes
No
Yes
REPL_RESULTS
Yes
No
No
Yes
BUYER_WKSHT_MANUAL
Yes
No
No
Yes
SUB_ITEMS_DETAIL
Yes
No
No
Yes
SUB_ITEMS_HEAD
Yes
No
No
Yes
REPL_ATTR_UPDATE_EXCLUDE
Yes
No
No
Yes
MASTER_REPL_ATTR
Yes
No
No
Yes
REPL_DAY
Yes
No
No
Yes
REPL_ITEM_LOC
Yes
No
No
Yes
REPL_ITEM_LOC_UPDATES
Yes
Yes
No
Yes
REPL_ITEM_LOC_SUPP_DIST
Yes
No
No
Yes
COST_SUSP_SUP_DETAIL_LOC
Yes
No
No
Yes
FUTURE_COST
Yes
No
No
Yes
ITEM_LOC_MFQUEUE
Yes
No
No
Yes
ITEM_LOC
Yes
No
No
Yes
ITEM_LOC_SOH
Yes
No
No
Yes
ITEM_LOC_TRAITS
Yes
No
No
Yes
ITEM_LOC_CFA_EXT
Yes
No
No
Yes
ITEM_SUPP_COUNTRY_BRACKET_COST
Yes
No
No
Yes
ITEM_SUPP_COUNTRY_LOC_CFA_EXT
Yes
No
No
Yes
Yes
No
No
Yes
I/O Specification
N/A
Global Tax Solution Builder (gtsbuilder)
Module Name
gtsbuilder.ksh
Description
GTS Builder Processing
Functional Area
Foundation
Module Type
Business Processing
Module Technology
Ksh
Catalog ID
TBD
Runtime Parameters
rmswrap_shell.ksh
Schedule
Design Overview
This batch program is used to process new, modified or expired rules of the global tax solution. The criteria to find these rules are based on the rule status and the field END_DATE.
Any rule with status UPDATED or APPROVED will be considered to be processed. Rules in status ACTIVE but with the field END_DATE filled with a date older than the tax builder execution date will also be picked for processing.
The processing logic in each of the above scenarios will be:
  • Processing rules in status UPDATED: rules can be updated exclusively in the field END_DATE. In this case the date informed in the rule will be updated in GTS_MERCHT_TAX and GTS_ITEM_TAX tables. Once these updates are done, the status of the rule will be changed back to ACTIVE.
  • Processing rules in status APPROVED: rules in this status are basically new rules included in the system. The GTS builder process will also identify rules with conditions at parent level regions or higher level of merchandise hierarchy (dept or class) and will store new records into GTS_MERCH_TAX and GTS_ITEM_TAX table for the lowest level of region (child regions) and merchandise hierarchy (subclass). Once these updates are done, the status of the rule will be changed to ACTIVE.
  • Processing rules in status ACTIVE: the process will look for the field END_DATE in active rules. If this field is filled with a date older than the execution date, the process will simply change the rule status to CLOSED. No updates will be performed at merchandise level tax tables nor item level tax tables.
Restart/Recovery
In case of failure, the GTS builder batch will continue picking new or updated rules to process. During activation if any rule fails an error will be stored and the rule will have it status modified to "worksheet" for further review.
Design Assumptions
N/A
Mass VAT Updates for Items/Locations (vatdlxpl)
Module Name
vatdlxpl.pc
Description
Functional Area
Item Maintenance
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS384
Runtime Parameters
rmswrap_multi.ksh
Schedule
Design Overview
This batch program updates VAT information for each item associated with a given VAT region and VAT code.
Restart/Recovery
This batch program performs commits to the database for every commit max number of rows.
Design Assumptions
N/A
Purge Item Induction Staging Tables (itm_indctn_purge.ksh)
Module Name
Description
Purge item induction staging tables
Functional Area
Foundation-Items
Module Type
Admin
Module Technology
Shell Script
Catalog ID
RMS498
Runtime Parameters
N/A
Design Overview
The purpose of this module is to remove old item records from the staging tables. Records that are candidates for deletion are:
  • Processes that have successfully been processed or processed with warnings that have been uploaded to Merchandising or downloaded to S9T
  • Processes that have status = 'PE', processed with errors and have no linked data
  • Processes in error status where all other related records containing the process ID have been processed successfully
  • Processes that have errors and are past the data retention days (system_options.proc_data_retention_days)
  • All item records within a process where all related records for the item in the other staging tables are successfully uploaded to Merchandising. The process tracker record for that process should not be deleted if there are other item records that are not uploaded to Merchandising.
Scheduling Constraints
Table 4-3 Scheduling Constraints
Schedule Information Description
Processing Cycle
Ad Hoc
Frequency
Daily
Scheduling Considerations
N/A
Pre-Processing
N/A
Post-Processing
N/A
Threading Scheme
N/A
Restart/Recovery
Restart ability is implied, because the records that are selected from the cursor are deleted before the commit.
Scheduled Item Maintenance (sitmain)
Module Name
sitmain.pc
Description
Functional Area
Item Maintenance
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS357
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
Scheduled item maintenance is a method of performing mass changes on item/location information. Scheduled item maintenance uses item and location lists to make the process of changing lots of information very easy for end users.This program explodes the intersection of these items and location lists to make the scheduled changes at the specific item/location level.
Restart/Recovery
This program has inherent restart ability because records are deleted from the scheduled item detail table as they are processed. The logical unit of work is an item/location combination.
Design Assumptions
N/A
