5 Purchase Order
Purchase orders can be created through the Merchandising UI or through integration with third-party systems. Once purchase orders are created in Merchandising, there are a number of batch processes that manage PO data.
Program Summary
The following batch designs are included in this functional area:
See also the Merchandising Operations Guide Volume 2 for details on the following purchase order related integrations:
  • Download of Purchase Order from Merchandising to Suppliers (edidlord)
  • Upload Purchase Order and Purchase Order Change Acknowledgements from Suppliers to Merchandising (ediupack)
  • Upload of PO induction data through batch (poindbatch.ksh)
Apply Deal Discounts to Purchase Orders (orddscnt)
Module Name
orddscnt.pc
Description
Functional Area
Purchase Orders
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS283
Wrapper Script
rmswrap_multi.ksh
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
This module applies deals to a purchase order by calculating the discounts and rebates that are applicable to a purchase order. It will fetch orders that need to be recalculated for cost from the DEAL_CALC_QUEUE table. Using the dealordlib shared library, it will update the unit cost and populate the ORDLOC_DISCOUNT and ORDHEAD_DISCOUNT tables.
Restart/Recovery
This program has inherent restart ability, since records are deleted from deal_calc_queue as they are processed. Recommended maximum commit counter is low.
Design Assumptions
N/A
Auto Close Purchase Orders (ordautcl)
Module Name
ordautcl.pc
Description
Functional Area
Purchase Orders
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS282
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
This batch program is used to process POs that need to be deleted or closed that meet certain conditions. The criteria are as mentioned below:
Category 1
  • The order is not in ‘C'ompleted status and was previously approved.
  • The number of days between the latest ship date and the current date is greater than the ‘Approved PO Close Delay' system parameter.
  • There are no open shipments for the order.
  • End of week date should not be null.
Category 2
  • A specified amount of time (‘Approved PO Close Delay' system parameter) after the not after date of the PO has passed.
  • A specified amount of time (‘Partially Received PO Close Delay' system parameter) after the not after date has passed.
  • A specified amount of time (‘Partially Received PO Close Delay' system parameter) after the expected receipt date (or shipped date if the expected date has not been captured) has passed.
  • There are no open appointments in the system for the order.
Category 3
  • The order has a status of worksheet or submitted, and the order has never been previously approved.
  • The number of days between the current date and the order creation date is greater than the ‘Worksheet PO Clean Up Delay' system parameter.
  • The order is a manual order (not created by replenishment).
Retrieved orders are subsequently processed based on their category:
  1. Category 1 orders will be closed. Closing an order involves adjusting the order quantities, shipment quantities and OTB. Any allocation associated with the order will also be closed if it is released ‘X' number of days before vdate. The ‘X' number of days is defaulted from an external system and set on the Merchandising codes table for code_type ‘DEFT'.
  2. For Category 2 orders, orders will be closed if there are no pending receipts or if the ‘Auto Close Partially Received' system indicator is set to ‘Y'.
  3. Category 3 orders will be deleted from the system.
Restart/Recovery
Restart recovery is implicit since the program purges and cancels records in the database one order at a time.
Design Assumptions
N/A
Auto Close Purchase Orders (order_auto_close_job)
Module Name
Description
Functional Area
Purchase Orders
Module Type
Admin - Ad hoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from order header table based on defined criteria. This program is used to process POs that need to be deleted or closed that meet certain conditions. The criteria are as mentioned below:
Category 1
Category 2
Category 3
These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will process retrieved records based on their category:
  1. Category 1 orders will be closed. Closing an order involves adjusting the order quantities, shipment quantities and OTB. Any allocation associated with the order will also be closed if it is released ‘X' number of days before vdate. The ‘X' number of days is defaulted from an external system and set on the RMFCS codes table for code type ‘DEFT'.
It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 5-1 Key Tables Affected
Table Select Insert Update Delete
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_ORDER_AUTO_CLOSE_STG
Yes
No
Yes
Yes
ORDHEAD
Yes
No
Yes
Yes
SHIPMENT
Yes
No
Yes
No
APPT_HEAD
Yes
No
No
No
APPT_DETAIL
Yes
No
No
No
SHIPSKU
Yes
No
Yes
No
ORDLOC
No
No
Yes
Yes
ALLOC_DETAIL
No
No
Yes
Yes
OBLIGATION_COMP
No
No
No
Yes
WO_DETAIL
No
No
No
Yes
WO_HEAD
No
No
No
Yes
WO_SKU_LOC
No
No
No
Yes
WO_WIP
No
No
No
Yes
ALLOC_CHRG
No
No
No
Yes
ALLOC_HEADER
No
No
No
Yes
ORDLOC_DISCOUNT
No
No
No
Yes
TIMELINE
No
No
No
Yes
ORDSKU_TEMP
No
No
No
Yes
ORDLOC_TEM
No
No
No
Yes
ALLOC_CHRG_TEMP
No
No
No
Yes
ALLOC_DETAIL_TEMP
No
No
No
Yes
ALLOC_HEADER_TEMP
No
No
No
Yes
ORDLOC_EXP_TEMP
No
No
No
Yes
ORDSKU_HTS_ASSESS_TEMP
No
No
No
Yes
ORDSKU_HTS_TEMP
No
No
No
Yes
ORDLOC_DISCOUNT_TEMP
No
No
No
Yes
TIMELINE_TEMP
No
No
No
Yes
REQ_DOC_TEMP
No
No
No
Yes
WO_DETAIL_TEMP
No
No
No
Yes
WO_HEAD_TEMP
No
No
No
Yes
ORDLOC_WKSHT
No
No
No
Yes
ORDLOC_REV
No
No
No
Yes
ORDSKU_REV
No
No
No
Yes
ORDSKU
No
No
No
Yes
ORDCUST
No
No
No
Yes
ORDHEAD_REV
No
No
No
Yes
ORDLC
No
No
No
Yes
DEAL_COMP_PROM
No
No
No
Yes
DEAL_ITEMLOC
No
No
No
Yes
DEAL_THRESHOLD
No
No
No
Yes
DEAL_DETAIL
No
No
No
Yes
DEAL_QUEUE
No
No
No
Yes
DEAL_CALC_QUEUE
No
No
No
Yes
DEAL_HEAD
No
No
No
Yes
ORD_INV_MGMT
No
No
No
Yes
REPL_RESULTS
No
No
No
Yes
REV_ORDERS
No
No
No
Yes
REQ_DOC
No
No
No
Yes
ORD_PREISSUE
No
No
No
Yes
Design Assumptions
N/A
Build Purchase Orders for Vendor Generated Orders (vrplbld)
Module Name
vrplbld.pc
Description
Functional Area
Purchase Orders
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS387
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
This purpose of this module is to continue the process started by the batch program ediupack.pc of building purchase orders that reflect the vendor-generated orders as received through the EDI 855. This module will process records from the temporary EDI order table and create the purchase orders on the PO tables.
The post-processing function of this batch on the prepost batch truncates the EDI temporary order table.
Restart/Recovery
The logical unit of work for the program is a vendor order number, department and supplier combination. The program's restartability is dependent on the value of the Department Level Orders system parameter. Allowing multi-department orders (that is, the indicator is set to 'N') will restart the program from the last successfully processed vendor order number and supplier. If the system requires a department on the orders (that is, the indicator is set to 'Y'), then the program will restart from the last successfully processed vendor order number, department, and supplier.
Design Assumptions
N/A
Generate Pre-Issued Order Numbers (genpreiss)
Module Name
genpreiss.pc
Description
Functional Area
Purchase Orders
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS237
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
Based on records on the SUPP_PREISSUE table, this batch program reserves order numbers for suppliers that do Vendor Managed Inventory (VMI) by placing these pre-generated order numbers on the ORD_PREISSUE table.
Restart/Recovery
The logical unit of work for this program is set at thesupplier level, based on a single record from the SUPP_PREISSUE table. It uses v_restart_supplier to achieve restart/recovery.
The changes will be posted when the commit_max_ctr value is reached and the value of the counter is subject to change based on implementation. The commit_max_ctr field should be set to prevent excessive rollback space usage, and to reduce the overhead of file I/O.
Design Assumptions
N/A
Purge Aged Open To Buy Data (otb_purge_job)
Module Name
otb_purge_job
Description
Functional Area
Open To Buy
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This background job is composed of two-step processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from open-to-buy (OTB) table based on calculated End-of-Week purge date as derived from the current date which is at least one half old. The current and previous half's OTB data is retained and kept in the system. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from open-to-buy (OTB) table. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 5-2 Key Tables Affected
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_OTB_PURGE_STG
Yes
Yes
No
Yes
OTB
No
No
No
Yes
Design Assumptions
N/A
Purge Aged Open To Buy Data (otbprg)
Module Name
otbprg.pc
Description
Functional Area
Open To Buy
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS291
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
This batch program runs at the end of the half to delete rows from the OTB table that are at least one half old. The current and previous half's OTB data is retained. The number of days that OTB records are retained by Merchandising is not configurable via a system parameter.
Restart/Recovery
There is no restart/recovery in this module. Up to 10,000 records are deleted and committed at a time to avoid excessive rollback space in usage.
Design Assumptions
N/A
Purge Aged Purchase Orders (order_purge_job)
Module Name
order_purge_job
Description
Functional Area
Purchase Orders
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
Thread assignment program will filter eligible records from order header and other associated and order-related tables based on its conditions below:
  1. If importing is not enabled in the system (as defined by the import system indicator = 'N') and if invoice matching is not installed, then all details associated with an order are deleted when the order has been closed for more months than specified in 'Order History Months' purge parameter. Orders will only be deleted if all allocations associated, if any, have been closed.
  2. If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge parameter. Orders are deleted only if allocations associated have been closed, shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
  3. If importing is enabled in the system (as defined by the import system indicator = 'Y') and if invoice matching is not installed, then all details associated with the order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge option. This action presupposes that all ALC records associated with an order are in 'Processed' status, specified in the ALC header and allocations associated to the order, if any, have been closed.
  4. If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the 'Order History Months' purge parameter. This action presupposes that all ALC records associated with an order are in 'Processed' status, specified in ALC head, all allocations associated to the order, if any, have been closed, all shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
  5. If the order to be purged is an import PO and it doesn't have a letter of credit (LC) then purge the related records related to obligations, ALC and ICB transfers.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from order header and other associated and order-related tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 5-3 Key Tables Affected
PURGE_CONFIG_OPTIONS
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_ORDER_PURGE_STG
Yes
Yes
No
Yes
ORDHEAD
Yes
No
No
Yes
ORDLC
Yes
No
No
No
ALLOC_HEADER
Yes
No
No
Yes
SHIPMENT
Yes
No
No
Yes
SHIPSKU
Yes
No
Yes
Yes
INVC_HEAD
Yes
No
No
Yes
ORDLOC_REV
No
No
No
Yes
ORDHEAD_REV
No
No
No
Yes
ALLOC_REV
No
No
No
Yes
ALC_HEAD
Yes
No
No
Yes
ALC_COMP_LOC
No
No
No
Yes
OBLIGATION_COMP_LOC
No
No
No
Yes
OBLIGATION_COMP
No
No
No
Yes
OBLIGATION
No
No
No
Yes
TRANSPORTATION
Yes
No
No
Yes
MISSING_DOC
No
No
No
Yes
TRANS_PACKING
No
No
No
Yes
TRANS_DELIVERY
No
No
No
Yes
TRANS_CLAIMS
No
No
No
Yes
TRANS_LIC_VISA
No
No
No
Yes
TRANS_SKU
No
No
No
Yes
CE_ORD_ITEM
Yes
No
No
Yes
CE_LIC_VISA
No
No
No
Yes
CE_CHARGES
No
No
No
Yes
CE_SHIPMENT
No
No
No
Yes
CE_PROTEST
No
No
No
Yes
CE_FORMS
No
No
No
Yes
CE_HEAD
v
No
No
Yes
APPT_HEAD
Yes
No
No
Yes
APPT_DETAIL
Yes
No
No
Yes
DOC_CLOSE_QUEUE
No
No
No
Yes
DAILY_PURGE
No
Yes
No
No
ORDSKU
Yes
No
No
Yes
ITEM_MASTER
Yes
No
No
No
PACKITEM
Yes
No
No
No
PACK_TMPL_HEAD
Yes
No
No
No
RTV_DETAIL
No
No
No
Yes
WO_DETAIL
No
No
No
Yes
CARTON
No
No
No
Yes
WO_HEAD
Yes
No
No
Yes
ALLOC_CHRG
No
No
No
Yes
ALLOC_DETAIL
No
No
No
Yes
TIMELINE
No
No
No
Yes
ORDLOC
No
No
No
Yes
ORDLOC_DISCOUNT
No
No
No
Yes
ORDLOC_EXP
No
No
No
Yes
ORDSKU_HTS_ASSESS
No
No
No
Yes
ORDSKU_HTS
No
No
No
Yes
REQ_DOC
No
No
No
Yes
ORDSKU_REV
No
No
No
Yes
ORDLOC_INVC_COST
No
No
Yes
Yes
ORDCUST
Yes
No
No
Yes
ORDCUST_DETAIL
No
No
No
Yes
ORDCUST_CUSTOMER_DETAIL
No
No
No
Yes
ORD_XDOCK_TEMP
No
No
No
Yes
INVC_XREF
No
No
No
Yes
INVC_MATCH_WKSHT
No
No
No
Yes
ORDLOC_WKSHT
No
No
No
Yes
SUP_VIOLATION
No
No
No
Yes
REV_ORDERS
No
No
No
Yes
LC_ORDAPPLY
No
No
No
Yes
ORDHEAD_DISCOUNT
No
No
No
Yes
RUA_RIB_INTERFACE
No
No
No
Yes
ORDLOC_TEMP
No
No
No
Yes
ALLOC_CHRG_TEMP
No
No
No
Yes
ALLOC_DETAIL_TEMP
No
No
No
Yes
ALLOC_HEADER_TEMP
No
No
No
Yes
ORDSKU_TEMP
No
No
No
Yes
ORDLOC_EXP_TEMP
No
No
No
Yes
No
No
No
Yes
ORDSKU_HTS_TEMP
No
No
No
Yes
No
No
No
Yes
TIMELINE_TEMP
No
No
No
Yes
REQ_DOC_TEMP
No
No
No
Yes
WO_DETAIL_TEMP
No
No
No
Yes
WO_HEAD_TEMP
No
No
No
Yes
REPL_RESULTS_TEMP
No
No
No
Yes
DEAL_COMP_PROM
No
No
No
Yes
DEAL_HEAD
Yes
No
No
Yes
DEAL_THRESHOLD
No
No
No
Yes
DEAL_DETAIL
No
No
No
Yes
DEAL_QUEUE
No
No
No
Yes
ORD_INV_MGMT
No
No
No
Yes
REPL_RESULTS
No
No
No
Yes
INVC_DETAIL
No
No
No
Yes
INVC_NON_MERCH
No
No
No
Yes
INVC_MERCH_VAT
No
No
No
Yes
INVC_DETAIL_VAT
No
No
No
Yes
INVC_DISCOUNT
No
No
No
Yes
INVC_TOLERANCE
No
No
No
Yes
INVC_MATCH_QUEUE
No
No
No
Yes
TSFHEAD
No
No
No
Yes
TSFDETAIL
No
No
No
Yes
TSFDETAIL_CHRG
No
No
No
Yes
DEAL_ITEMLOC_ITEM
No
No
No
Yes
DEAL_ITEMLOC_DCS
No
No
No
Yes
DEAL_ITEMLOC_DIV_GRP
No
No
No
Yes
DEAL_ITEMLOC_PARENT_DIFF
No
No
No
Yes
ORDHEAD_L10N_EXT
No
No
No
Yes
ORD_TAX_BREAKUP
No
No
No
Yes
ORDHEAD_CFA_EXT
No
No
No
Yes
DEALHEAD_CFA_EXT
No
No
No
Yes
TSFHEAD_CFA_EXT
No
No
No
Yes
SHIPSKU_LOC_PRG_HIST
No
Yes
No
No
SHIPSKU_PRG_HIST
No
Yes
No
No
SHIPMENT_PRG_HIST
No
Yes
No
No
ALLOC_CHRG_PRG_HIST
No
Yes
No
No
ALLOC_DETAIL_PRG_HIST
No
Yes
No
No
ALLOC_HEADER_PRG_HIST
No
Yes
No
No
ORDLOC_REV_PRG_HIST
No
Yes
No
No
ORDSKU_REV_PRG_HIST
No
Yes
No
No
ORDHEAD_REV_PRG_HIST
No
Yes
No
No
ORDCUST_DETAIL_PRG_HIST
No
Yes
No
No
ORDCUST_PRG_HIST
No
Yes
No
No
ORDLOC_CFA_EXT_PRG_HIST
No
Yes
No
No
ORDLOC_PRG_HIST
No
Yes
No
No
ORDLOC_DISCOUNT_PRG_HIST
No
Yes
No
No
ORDLOC_EXP_PRG_HIST
No
Yes
No
No
ORDSKU_HTS_ASSESS_PRG_HIST
No
Yes
No
No
ORDSKU_HTS_PRG_HIST
No
Yes
No
No
ORDSKU_CFA_EXT_PRG_HIST
No
Yes
No
No
ORDSKU_PRG_HIST
No
Yes
No
No
ORDHEAD_DISCOUNT_PRG_HIST
No
Yes
No
No
ORDHEAD_L10N_EXT_PRG_HIST
No
Yes
No
No
ORD_TAX_BREAKUP_PRG_HIST
No
Yes
No
No
ORDHEAD_CFA_EXT_PRG_HIST
No
Yes
No
No
ORDHEAD_PRG_HIST
No
Yes
No
No
Design Assumptions
N/A
Purge Aged Purchase Orders (ordprg)
Module Name
ordprg.pc
Description
Functional Area
Purchase Orders
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS285
Runtime Parameters
N/A
Schedule
Design Overview
The purpose of this module is to remove old purchase orders from the system.
If importing is not enabled in the system (as defined by the import system indicator = ‘N') and if invoice matching is not installed, then all details associated with an order are deleted when the order has been closed for more months than specified in ‘Order History Months' purge parameter. Orders will only be deleted if all allocations associated, if any, have been closed.
If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the ‘Order History Months' purge parameter. Orders are deleted only if allocations associated have been closed, shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
If importing is enabled in the system (as defined by the import system indicator = ‘Y') and if invoice matching is not installed, then all details associated with the order are deleted when the order has been closed for more months than specified in the ‘Order History Months' purge option. This action presupposes that all ALC records associated with an order are in ‘Processed' status, specified in ALC_HEAD (status) and allocations associated to the order, if any, have been closed.
If invoice matching is installed, then all details associated with an order are deleted when the order has been closed for more months than specified in the ‘Order History Months' purge parameter. This action presupposes that all ALC records associated with an order are in ‘Processed' status, specified in ALC_HEAD (status), all allocations associated to the order, if any, have been closed, all shipments from the order have been completely matched to invoices or closed, and all those invoices have been posted.
Restart/Recovery
Restart ability will be implied, because the records that are selected from the driving cursor will be deleted before the commit. Restart library functions will still be included to ensure that rollback segments are not exceeded (by committing at intervals) and to perform basic record keeping functionality.
Design Assumptions
N/A
Purge PO Induction Staging Tables (po_indctn_purge.ksh)
Module Name
po_indctn_purge.ksh
Description
Purge PO induction staging tables
Functional Area
Purchase Orders
Module Type
Admin
Module Technology
Shell Script
Catalog ID
RMS499
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
The purpose of this module is to remove old purchase order records from the staging tables. Records that are candidates for deletion are:
  • Processes that have successfully been processed or processed with warnings that have been uploaded to Merchandising or downloaded to S9T
  • Processes that have status = 'PE' processed with errors and have no liked data
  • Processes in error status where all other related records containing the process ID have been processed successfully
  • Processes that are passed the data retention days (system_options.proc_data_retention_days)
  • All order records within a process where all related records for the order in the other staging tables are successfully uploaded to Merchandising. The process tracker record should not be deleted if there are other orders that are not uploaded to Merchandising.
Restart/Recovery
Restart ability will be implied, because the records that are selected from the cursor will be deleted before the commit.
Design Assumptions
N/A
Scale Purchase Orders Based on Supplier Constraints (supcnstr)
Module Name
supcnstr.pc
Description
Functional Area
Purchase Orders
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS368
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
This batch program will process all orders eligible for scaling during the nightly replenishment run. The purpose of this program is to select all of the orders created by the replenishment programs which are eligible for scaling. Once selected, the program will serve as a wrapper program and send each order number into the supplier constraint scaling library to actually perform the scaling on the order.
The orders which will be eligible for scaling are as follows:
If due order processing was used, only orders with a written date of today, origin type of zero (0) (replenishment order), due order processing indicator of Yes, due order indicator of Yes and a scale order to constraint indicator of Y will be processed. This encompasses all due orders created by replenishment which have constraints associated with them.
If due order processing was not used, only orders with a written date of today, origin type of zero (0) (replenishment order), order approve indicator of Yes, status of 'W'orksheet, due order processing indicator of No, due order indicator of Yes, and a scale order to constraint indicator of Yes will be processed. This encompasses all approved orders created by replenishment which have constraints associated with them.
For Franchise POs, their associated Franchise Orders will be updated when quantities of the franchise POs are changed due to supplier constraint.
Restart/Recovery
The logic unit of work for this program is an order number.
Locking Strategy
This batch locks order inventory management and order header tables during day runs.
Design Assumptions
N/A
Update Retail Values on Open Purchase Orders (ordupd)
Module Name
ordupc.pc
Description
Functional Area
Purchase Orders
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS287
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
This program will be used to automatically change all retail prices on purchase orders when a retail price change is implemented for an item on the order with the status of 'Worksheet',' Submit' and ‘Approve'.
Open to buy is updated to give a more accurate picture of the retail value of open orders if the order is ‘Approved' and if the department calculate the OTB as retail.
Restart/Recovery
This program does not contain restart/recovery logic.
Design Assumptions
N/A
Write Purchase Order Information to Purchase Order History Tables (order_revision_job)
Module Name
order_revision_job
Description
Functional Area
Purchase Orders
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
Order changes made by the client that may need to be sent to the vendor. The order changes should always be referred to as 'versions' and kept clearly distinct from order 'revisions' which are vendor changes uploaded via the ediupack program.
Thread assignment program will filter eligible records from order revision history and order header tables based on its order status ('A'pproved or 'C'losed) and supplier that exists from supplier table. When orders are approved or when approved orders are modified, this program selects order numbers from the order revision history table. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will writes versions of approved orders and its current order information to the order/allocation revision history tables. After the new version has been written to the order revision tables, all records will be deleted from the order revision history table for that order record. If an order is not in approved status at the time the batch program runs, then none of the above processing will occur. These records will stay on the order revision history table until the PO is approved or deleted. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 5-4 Key Tables Affected
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_ORDER_REVISION_STG
Yes
Yes
No
Yes
REV_ORDERS
Yes
No
No
Yes
ORDHEAD
Yes
No
Yes
No
SUPS
Yes
No
No
No
ORDHEAD_REV
Yes
Yes
No
No
ORDSKU
Yes
No
No
No
ORDLOC
Yes
No
No
No
ALLOC_HEADER
Yes
No
No
No
ALLOC_DETAIL
Yes
No
No
No
ORDSKU_REV
No
Yes
No
No
ORDLOC_REV
No
Yes
No
No
ALLOC_REV
No
Yes
No
No
Design Assumptions
N/A
Write Purchase Order Information to Purchase Order History Tables (ordrev)
Module Name
ordrev.pc
Description
Functional Area
Purchase Orders
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS286
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
Ordrev.pc will write versions of approved orders to the order revision history tables. When orders are approved or when approved orders are modified, this program selects order numbers from the REV_ORDERS table and writes current order information to the order/allocation revision tables. After the new version has been written to the order revision tables, all records will be deleted from the REV_ORDERS table for that order_no.
This program processes order changes made by the client that may need to be sent to the vendor. The order changes should always be referred to as ‘versions' and kept clearly distinct from order ‘revisions' which are vendor changes uploaded via the ediupack program.
If an order is not in approved status at the time the batch program runs, then none of the above processing will occur. These records will stay on the REV_ORDERS table until the PO is approved or deleted.
Restart/Recovery
Restart ability will be implied because the records that are selected from the driving cursor will be deleted before the commit. Restart library functions will still be included to ensure that rollback segments are not exceeded (by committing at intervals) and to perform basic record keeping functionality.
Design Assumptions
N/A
