Merch API Data Rebuild Request Wrapper Script (merchapidatarebuildrequest)
Module Name
merchapidatarebuildrequest.ksh
Description
Wrapper shell script to submit data refresh requests.
Functional Area
Foundation and Inventory tracking.
Module Type
Business Processing
Module Technology
Ksh
Catalog ID
TBD
Runtime Parameters
N/A
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
This wrapper batch program is used to make an entry in the MERCHAPI_ASYNC_REQUEST table for data refresh requests. There are two data refresh types: one is TRUNCATE_AND_LOAD and the other one is REBUILD.
  • TRUNCATE_AND_LOAD will be used for severe data corruption.
  • REBUILD is used to build the JSON message for all the records.
The LAST_UPDATE_DATETIME update is dependent on the value of REFRESH_UPDATE_TIMESTAMP_IND. The silent update (REBUILD with no timestamp update) is applicable when a new field is added or removing the deprecated fields and don’t want to force-publish these changes. REBUILD with timestamp update is used in case of data discrepancies within Merchandising and Cache table or Merchandising and consuming system.
Restart/Recovery
N/A
Design Assumptions
N/A
