2 Administration Batch
This chapter contains information about a number of batch processes perform administrative processes in Merchandising. These processes range from incrementing the current business date for transactions (known in Merchandising as vdate) to purging unused data.
Program Summary
The batch programs covered in this section include the following:
Additionally, this chapter contains details on some background processes that can be run as an alternative to jobs that run during the nightly batch cycle:
Archive and Truncate Purge History Tables (batch_archive_purge_hist.ksh)
Module Name
Description
Functional Area
Administration
Module Type
Admin
Module Technology
ksh
Catalog ID
RMS477
Wrapper Script
N/A
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
The purpose of this program is to archive and truncate purge history tables regularly in Merchandising.
When you 'delete' a record in the Merchandising user interface, information is generally not immediately deleted at the database level; instead, data is marked as being in deleted status and also inserted into the DAILY_PURGE table. Next the purge processes will delete the data from Merchandising transaction tables. Before deleting data from these tables, transaction data will be archived by inserting into purge history tables by the transaction purge processes.
The batch_archive_purge_hist.ksh will export the purge history table data as a dump file using Oracle Rest Data Services (ORDS) data pump export service and move the dump file to Object Storage site for customer pick up. And after successful export of the transaction data, purge history tables are truncated.
This script has the below functions:
  1. check_archive_dates - checks for the archive last run date. Based on the last archive date and the archive frequency input parameter, decides whether to archive and truncate the purge history tables or not. This ensures that even though this batch job is scheduled to run daily, the actual archiving and purging of the purge history tables will only occur every X number of days based on the input parameter.
  2. truncate_prg_hist_tables - Truncates purge history tables after successful export of the transaction data.
  3. update_rms_archive_date - update the Merchandising archive date, after the successful archiving and truncation of purge history tables.
Restart/Recovery
This program does not contain restart/recovery logic.
I/O Specifications
N/A
Design Assumptions
N/A
Daily Purge of Foundation Data (daily_purge_job)
Module Name
daily_purge_job
Description
Functional Areas
Administration
Module Type
Admin - Adhoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
When you 'delete' a record in the RMFCSS user interface, information is generally not immediately deleted at the database level; instead, data is marked as being in deleted status and also inserted into the daily purge table.
A thread assignment program will filter eligible records from daily purge table wherein all entities ready for purging aside/except from Item-Location records. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete specific Foundation Data entities from the respective RMFCS tables. Complex referential integrity relationships determine whether data can actually be deleted from the database (for example, a store cannot be deleted if any transactions related to the store are still on current transaction tables). This program checks these complex rules. If the deletion request passes the rules, this job will continues to delete the data. If it is not able to delete the data, it writes a record to the daily purge error log table for further investigation. This program will continue to attempt to delete marked data until all references have been purged from the system and the deletion of the foundation data entity finally succeeds. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart Recovery
N/A
Key Tables Affected
Table 2-1 Key Tables Affected
Table Select Insert Update Delete
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_DAILY_PURGE_STG
Yes
No
No
No
DAILY_PURGE
Yes
No
No
Yes
DAILY_PURGE_ERROR_LOG
Yes
Yes
No
Yes
LOC_LIST_DETAIL
No
No
No
Yes
MONTH_DATA_BUDGET
Yes
No
No
Yes
HALF_DATA_BUDGET
Yes
No
No
Yes
VAT_DEPS
Yes
No
No
Yes
SKULIST_CRITERIA
Yes
No
No
Yes
DOMAIN_DEPT
Yes
No
No
Yes
FORECAST_REBUILD
Yes
No
No
Yes
SUP_DATA
Yes
No
No
Yes
DEPT_SALES_HIST
Yes
No
No
Yes
DEPT_SALES_FORECAST
Yes
No
No
Yes
DEAL_ITEMLOC
Yes
No
No
Yes
DEPS
Yes
No
No
Yes
STOCK_LEDGER_INSERTS
Yes
No
No
Yes
STAKE_SCHEDULE
Yes
No
No
Yes
DEPT_CHRG_DETAIL
Yes
No
No
Yes
WH_DEPT
Yes
No
No
Yes
DEPT_CHRG_HEAD
Yes
No
No
Yes
SUP_BRACKET_COST
Yes
No
No
Yes
SUP_REPL_DAY
Yes
No
No
Yes
SUP_INV_MGMT
Yes
No
No
Yes
FILTER_GROUP_MERCH
Yes
No
No
Yes
IB_RESULTS
Yes
No
No
Yes
WEEK_DATA
Yes
No
No
Yes
DAILY_DATA
Yes
No
No
Yes
MONTH_DATA
Yes
No
No
Yes
TRAN_DATA_HISTORY
Yes
No
No
Yes
HALF_DATA
Yes
No
No
Yes
PARTNER
Yes
No
No
Yes
SHIPMENT
Yes
No
No
Yes
COST_ZONE_GROUP_LOC
Yes
No
No
Yes
COST_ZONE
Yes
No
No
Yes
COST_ZONE_GROUP
Yes
No
No
Yes
UDA_ITEM_DEFAULTS
Yes
No
No
Yes
DOMAIN_CLASS
Yes
No
No
Yes
CLASS_SALES_HIST
Yes
No
No
Yes
CLASS_SALES_FORECAST
Yes
No
No
Yes
CLASS
Yes
No
No
Yes
DOMAIN_SUBCLASS
Yes
No
No
Yes
OTB
Yes
No
No
Yes
DIFF_RATIO_DETAIL
Yes
No
No
Yes
DIFF_RATIO_HEAD
Yes
No
No
Yes
SUBCLASS_SALES_HIST
Yes
No
No
Yes
SUBCLASS_SALES_FORECAST
Yes
No
No
Yes
SUBCLASS
Yes
No
No
Yes
MERCH_HIER_DEFAULT
Yes
No
No
Yes
WH
Yes
No
No
Yes
WH_ADD
Yes
No
No
Yes
STORE_SHIP_DATE
Yes
No
No
Yes
LOC_TRAITS_MATRIX
Yes
No
No
Yes
COST_ZONE_GROUP_LOC
Yes
No
No
Yes
ITEM_EXP_DETAIL
Yes
No
No
Yes
ITEM_EXP_HEAD
Yes
No
No
Yes
EXP_PROF_DETAIL
Yes
No
No
Yes
EXP_PROF_HEAD
Yes
No
No
Yes
STORE_GRADE_STORE
Yes
No
No
Yes
DAILY_SALES_DISCOUNT
Yes
No
No
Yes
LOAD_ERR
Yes
No
No
Yes
STORE
Yes
No
No
Yes
EDI_SALES_DAILY
Yes
No
No
Yes
COMP_STORE_LINK
Yes
No
No
Yes
SEC_GROUP_LOC_MATRIX
Yes
No
No
Yes
LOC_CLSF_HEAD
Yes
No
No
Yes
LOC_CLSF_DETAIL
Yes
No
No
Yes
SOURCE_DLVRY_SCHED
Yes
No
No
Yes
SOURCE_DLVRY_SCHED_DAYS
Yes
No
No
Yes
SOURCE_DLVRY_SCHED_EXC
Yes
No
No
Yes
COMPANY_CLOSED_EXCEP
Yes
No
No
Yes
LOCATION_CLOSED
Yes
No
No
Yes
POS_STORE
Yes
No
No
Yes
STORE_HIERARCHY
Yes
No
No
Yes
ADDR
Yes
No
No
Yes
TIF_EXPLODE
Yes
No
No
Yes
WALK_THROUGH_STORE
Yes
No
No
Yes
SKULIST_DETAIL
Yes
No
No
Yes
INV_STATUS_QTY
Yes
No
No
Yes
REPL_ATTR_UPDATE_LOC
Yes
No
No
Yes
REPL_ATTR_UPDATE_HEAD
Yes
No
No
Yes
REPL_ATTR_UPDATE_ITEM
Yes
No
No
Yes
COST_SUSP_SUP_DETAIL
Yes
No
No
Yes
ITEM_HTS_ASSESS
Yes
No
No
Yes
ITEM_HTS
Yes
No
No
Yes
REQ_DOC
Yes
No
No
Yes
ITEM_IMPORT_ATTR
Yes
No
No
Yes
TIMELINE
Yes
No
No
Yes
COND_TARIFF_TREATMENT
Yes
No
No
Yes
ITEM_IMAGE
Yes
No
No
Yes
ITEM_SUPP_UOM
Yes
No
No
Yes
DEAL_SKU_TEMP
Yes
No
No
Yes
DEAL_DETAIL
Yes
No
No
Yes
ITEM_SUPP_COUNTRY
Yes
No
No
Yes
ITEM_SUPP_COUNTRY_DIM
Yes
No
No
Yes
RECLASS_ITEM
Yes
No
No
Yes
SUP_AVAIL
Yes
No
No
Yes
ITEM_SUPPLIER
Yes
No
No
Yes
ITEM_MASTER
Yes
No
No
Yes
PACK_TMPL_DETAIL
Yes
No
No
Yes
SUPS_PACK_TMPL_DESC
Yes
No
No
Yes
PACK_TMPL_HEAD
Yes
No
No
Yes
UDA_ITEM_LOV
Yes
No
No
Yes
UDA_ITEM_DATE
Yes
No
No
Yes
UDA_ITEM_FF
Yes
No
No
Yes
ITEM_SEASONS
Yes
No
No
Yes
ITEM_TICKET
Yes
No
No
Yes
COMP_SHOP_LIST
Yes
No
Yes
Yes
TICKET_REQUEST
Yes
No
No
Yes
PRICE_HIST
Yes
Yes
No
Yes
PACKITEM_BREAKOUT
Yes
No
No
Yes
PACKITEM
Yes
No
No
Yes
POS_MERCH_CRITERIA
Yes
No
No
Yes
ITEM_CHRG_HEAD
Yes
No
No
Yes
ITEM_CHRG_DETAIL
Yes
No
No
Yes
RECLASS_COST_CHG_QUEUE
Yes
No
No
Yes
ITEM_PUB_INFO
Yes
No
No
Yes
ITEM_MFQUEUE
Yes
No
No
Yes
ITEM_XFORM_HEAD
Yes
No
No
Yes
ITEM_XFORM_DETAIL
Yes
No
No
Yes
DEAL_ITEM_LOC_EXPLODE
Yes
No
No
Yes
ITEM_APPROVAL_ERROR
Yes
No
No
Yes
I/O Specification
N/A
Daily Purge of Foundation Data (dlyprg)
Module Name
dlyprg.pc
Description
Functional Areas
Administration
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS218
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
The purpose of this program is to delete specific Foundation Data entities from Merchandising.
When users ‘delete' a record in the Merchandising user interface, information is generally not immediately deleted at the database level; instead, data is marked as being in deleted status and also inserted into the DAILY_PURGE table.
Complex referential integrity relationships determine whether data can actually be deleted from the database (for example, a store cannot be deleted if any transactions related to the store are still on current transaction tables). Dlyprg.pc checks these complex rules. If the deletion request passes the rules, dlyprg.pc deletes the data. If dlyprg.pc is not able to delete the data, it writes a record to a log table for further investigation. Dlyprg will continue to attempt to delete marked data until all references have been purged from the system and the deletion of the foundation data entity finally succeeds.
Restart Recovery
This program has inherent restart ability. Records that have been successfully purged are deleted from the DAILY_PURGE table. This ensures that if the program is restarted, it does not attempt to delete records that have been previously processed.
I/O Specification
N/A
Design Assumptions
N/A
Increment Virtual Business Date (dtesys)
Module Name
dtesys.pc
Description
Functional Area
Administration
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS220
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
This batch program updates the PERIOD table for various dates required in Merchandising such as vdate, end-of-month and end-of-week dates.
Vdate (short for virtual business date) is used by Merchandising to maintain a consistent ‘virtual' business date (without regard for actual date changes at midnight or different dates in different timezone) for accounting purposes. Sysdate from the database is used to capture audit time and date stamps on transactions.
Vdate is used to determine the business date for the financial impact of transactions.
Generally, dtesys is run without additional input parameters and increments the data by one day. However, if a specific date is passed into the program as a parameter, the system date will be updated to that date.
Special processing also occurs:
  • Weekly
    When vdate = next_eow_date_unit, the program increments the last_eow_date_unit and next_eow_date_unit columns on system_variables. The last_eow_date_unit is updated to the current next_eow_date_unit and the next_eow_date_unit is updated to the next end-of-week date (calculated).
  • Monthly
    When vdate = next_eom_date_unit, the program updates the last_eom_date_unit and next_eom_date_unit columns on system_variables. The last_eom_date_unit is updated to the current next_eom_date_unit and the next_eom_date_unit is updated to the next end-of-month date (calculated).
Restart/Recovery
N/A
I/O Specification
N/A
Design Assumptions
N/A
Load Spreadsheet Templates (ld_iindfiles.ksh and loadods.ksh)
Module Name
ld_iindfiles.ksh, loadods.ksh
Description
Functional Area
Item Maintenance
Module Type
Install
Module Technology
ksh
Catalog ID
RMS199
Wrapper Script
N/A
Schedule
N/A
Design Overview
These scripts are used to load data from template files to the Merchandising template tables as part of installation. They load templates used by induction processes for Merchandising and Pricing, as well as templates used for spreadsheet load of foundation data. They may also be run ad hoc in situations where the base files need to be reset.
There is no wrapper script for these programs. They are invoked directly by the installer.
Restart/Recovery
N/A
Design Assumptions
N/A
Merch API Cache Refresh Wrapper Script (merchapirefreshwrap)
Module Name
merchapirefreshwrap.ksh
Description
Wrapper shell script to process all the refresh requests present in MERCHAPI_ASYNC_REQUEST table.
Functional Area
Foundation and Inventory Tracking
Module Type
Business Processing
Module Technology
Ksh
Catalog ID
TBD
Runtime Parameters
N/A
Schedule
Design Overview
This wrapper batch program is used to process all the requests present in the MERCHAPI_ASYNC_REQUEST table. This table captures requests at an API level for the following scenarios:
  • API Enablement - When the API is enabled through the UI when an entry is made into the MERCHAPI_ASYNC_REQUEST table. This wrapper will do the initial load of the respective merchapi cache table and set the enable flag in the merchapi_config table.
  • API Disablement - When an enabled API is disabled through the UI, an entry is made into the MERCHAPI_ASYNC_REQUEST table. This wrapper will clear the respective merchapi cache table and disable the API in merchapi_config table.
  • Data Refresh – The data refresh request can be submitted using merchapidatarebuildrequest.ksh, which makes an entry in the MERCHAPI_ASYNC_REQUEST table. Depending on the type of data refresh (truncate/load or rebuild) the merchapi cache table is rebuilt.
Each API has a separate cache table and respective PLSQL package for API enable, disable and rebuild, which is maintained in the MERCH_BATCH_PARAM table. This wrapper script scans through the MERCAPI_ASYNC_REQUEST table, picks the request ID, completes the processing, and continues with the subsequent request. Duplicate or Invalid requests are ignored during processing. If the API is multi-thread enabled in the merch_batch_param table, this wrapper will spawn multiple threads to process the data.
Restart/Recovery
N/A
Design Assumptions
N/A
Pre/Post Helper Processes for Batch Programs (prepost)
Module Name
prepost.pc
Description
Functional Area
Administration
Module Type
Business Processing
Module Technology
ProC
Catalog ID
N/A
Individual pre/post jobs have Catalog IDs
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
The pre/post module facilitates multi-threading by allowing general system administration functions (such as table deletions or mass updates) to be completed after all threads of a particular program have been processed.
This program will take three parameters: username/password to log on to Oracle, a program before or after which this script must run and an indicator telling whether the script is a pre or post function. It will act as a shell script for running all pre-program and post-program updates and purges (the logic was removed from the programs themselves to enable multi-threading and restart/recovery).
Pre/Post contains the following helper functions, which are should be individually scheduled with the related main programs.
Table 2-2 Pre/Post Helper Functions
Catalog ID Prepost Job Related Main Program Catalog ID Related Main Program
RMS400
prepost rpl pre
RMS315
rplext
RMS401
prepost salweek post
RMS346
salweek
RMS402
prepost salmth post
RMS343
salmth
RMS403
prepost rplapprv pre
RMS300
rplapprv
RMS404
prepost rplatupd pre
RMS313
rplatupd
RMS405
prepost rplatupd post
RMS313
rplatupd
RMS406
prepost rilmaint pre
RMS311
rilmaint
RMS407
prepost rilmaint post
RMS311
rilmaint
RMS408
prepost supmth post
RMS369
supmth
RMS409
prepost sccext post
RMS355
sccext
RMS410
prepost hstbld pre
RMS239
hstbld
RMS411
prepost hstbld post
RMS239
hstbld
RMS413
prepost edidlprd post
RMS47
edidlprd
RMS414
prepost edidlprd pre
RMS47
edidlprd
RMS417
prepost cntrordb post
RMS232
cntrordb
RMS418
prepost fsadnld post
N/A
N/A
RMS419
prepost btchcycl
N/A
No related main process. Is used to enable DB policies that might have been disabled in order to run batch.
RMS421
prepost poscdnld post
N/A
poscdnld
RMS423
prepost htsupld pre
N/A
htsupld
RMS425
prepost reclsdly pre
RMS302
reclsdly
RMS426
prepost reclsdly post
RMS302
reclsdly
RMS427
prepost ibcalc pre
RMS249
ibcalc
RMS428
prepost fcstprg pre
RMS227
fcstprg
RMS429
prepost fcstprg post
RMS249
fcstprg
RMS430
prepost reqext pre
RMS310
reqext
RMS431
prepost reqext post
RMS310
reqext
RMS432
prepost stkupd pre
N/A
Stkupd
RMS433
prepost replroq pre
RMS308
Replroq
RMS434
prepost rplext post
RMS315
Rplext
RMS438
prepost saleoh pre
RMS337
Saleoh
RMS440
prepost salweek pre
RMS346
salweek
RMS441
prepost dealinc pre
RMS211
Dealinc
RMS442
prepost dealday pre
RMS208
dealday
RMS443
prepost dealday post
RMS208
dealday
RMS444
prepost dealact_nor pre
RMS206
Dealact
RMS445
prepost dealact_po pre
RMS206
Dealact
RMS446
prepost dealact_sales pre
RMS206
Dealact
RMS447
prepost dealfct pre
RMS209
Dealfct
RMS448
prepost dealcls post
RMS209
Dealcls
RMS449
prepost hstbldmth post
RMS241
hstbldmth
RMS450
prepost vendinvc pre
N/A
vendinvc
RMS451
prepost vendinvf pre
N/A
vendinvf
RMS452
prepost vendinvc post
N/A
vendinvc
RMS453
prepost vendinvf post
N/A
vendinvf
RMS454
prepost docclose pre
RMS219
docclose
RMS455
prepost stkprg post
RMS360
stkprg
RMS456
prepost wfordupld pre
RMS392
wfordupld
RMS457
prepost wfretupld pre
N/A
wfretupld
RMS458
prepost replsizeprofile pre
RMS309
replsizeprofile
RMS459
prepost supsplit pre
RMS370
supsplit
RMS461
prepost batch_ordcostcompupd pre
RMS190
RMS462
prepost batch_ordcostcompupd post
RMS190
RMS463
prepost batch_costcompupd post
RMS190
RMS465
prepost dlyprg post
RMS218
dlyprg
RMS466
prepost tsfprg pre
RMS380
tsfprg
RMS467
prepost tsfprg post
RMS380
tsfprg
RMS468
prepost fcexec pre
RMS223
fcexec
RMS469
prepost start_batch pre
N/A
Sets the batch running ind to ‘Y' to limit front end use of the system.
RMS470
prepost end_batch post
N/A
Sets the batch running ind to ‘N' to reenable all front end use of the system.
This should be the last job in the batch cycle.
RMS488
prepost btchcycl post
N/A
This job reenables all policies in the Merchandising owning schema.
RMS489
prepost dealfct post
RMS209
Dealfct
prepost sitmain pre
RMS357
sitmain
prepost sitmain post
RMS357
Sitmain
prepost ediupack post
ediupack
Restart/Recovery
N/A
Purge Aged Competitive Pricing Data (cmpprg.pc)
Module Name
cmpprg.pc
Description
Functional Area
Competitive Pricing
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS198
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
This program deletes from the competitive price history table and the competitive shopping list table based purge criteria based on system parameter settings. The Competitive Pricing Months parameter will determine how many months competitive price history should be maintained before deletion. The Competitive Pricing List Days parameter will determine how long a requested shopping list should remain on the shopping list table if it is not complete by the requested shop date.
Restart/Recovery
N/A
Design Assumptions
N/A
Purge Aged Competitive Pricing Data (comp_pricing_purge_job)
Module Name
Description
Functional Area
Competitive Pricing
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
Thread assignment program will filter eligible records from competitive price history and competitive shipping list tables based on its purge criteria from system parameter settings. The Competitive Pricing List Days parameter will determine how long a requested shopping list should remain on the shopping list table if it is not complete by the requested shop date. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from competitive price history and competitive shipping list tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 2-3 Key Tables Affected
PERIOD
Yes
No
No
No
PURGE_CONFIG_OPTIONS
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_COMP_PRICING_PURGE_STG
Yes
Yes
No
Yes
COMP_PRICE_HIST
Yes
No
No
Yes
COMP_SHOP_LIST
Yes
No
No
Yes
Design Assumptions
N/A
Purge and Archive Old Files in Batch Server (archivelogs)
Module Name
archivelogs.ksh
Description
Purge and Archive Aged files in RMS Batch server
Functional Area
Administration
Module Type
Admin – Ad hoc
Module Technology
ksh
Catalog ID
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This ad hoc job archives 7-day-old files from the following folders:
  • ${RETAIL_HOME}/data/processed,
  • ${RETAIL_HOME}/log,
  • ${RETAIL_HOME}/log/sqlloader
  • ${RETAIL_HOME}/error
This job also purges 189-day-old files from the following folders:
  • ${RETAIL_HOME}/data/processed/archive
  • ${RETAIL_HOME}/log/archive
  • ${RETAIL_HOME}/log/sqlloader/archive
  • ${RETAIL_HOME}/error/archive
  • ${RETAIL_HOME}/data/archive
Restart/Recovery
N/A
Key Tables Affected
N/A
Design Assumptions
N/A
Purge Asynchronous Job Tables (async_job_status_retry_cleanup.ksh)
Module Name
Description
Functional Area
Administration
Module Type
Admin
Module Technology
ksh
Catalog ID
RMS180
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This batch job cleans up the Merchandising asynchronous jobs tables. The asynchronous job management tables (RMS_ASYNC_STATUS and RMS_ASYNC_RETRY) track each asynchronous call that is made. These tables are used to see error information and help with retrying failed calls.
This program will be run ad hoc and will accept a parameter of # days of information that will be deleted.
Restart/Recovery
N/A
Key Tables Affected
Table 2-4 Key Tables Affected
RMS_ASYNC_STATUS
No
No
No
Yes
RMS_ASYNC_RETRY
No
No
No
Yes
Input/Out Specification
N/A
Purge Dashboard Working Tables (rms_oi_purge.ksh)
Module Name
rms_oi_purge.ksh
Description
Purge data from the dashboard working tables
Functional Area
Operational Insight Dashboard Reports
Module Type
Admin
Module Technology
Ksh
Catalog ID
RMS490
Runtime Parameters
$UP (database connect string)
Design Overview
This batch program calls OI_UTILITY.PURGE_RMS_OI_TABLES to truncate the data in the Merchandising Operational Insight Dashboard staging tables. During normal operation, the staged data for the session are deleted when a user closes the report window. This program provides a way to clean up and control the size of the staging tables if data failed to be deleted due to abnormal termination of the session.
Scheduling Constraints
Schedule Information Description
Processing Cycle
Ad Hoc
Frequency
Daily
Scheduling Considerations
When no user is on-line using the OI dashboard reports.
Pre-Processing
N/A
Post-Processing
N/A
Threading Scheme
N/A
Restart/Recovery
N/A
Key Tables Affected
Table 2-5 Key Tables Affected
RMS_OI_BUYER_EARLY_LATE_SHIP
No
No
No
Yes
RMS_OI_BUYER_ORDERS_TO_APPROVE
No
No
No
Yes
RMS_OI_INV_ANA_OPEN_ORDER
No
No
No
Yes
RMS_OI_INV_ANA_VARIANCE
No
No
No
Yes
RMS_OI_INV_CTL_NEG_INV
No
No
No
Yes
RMS_OI_INV_ORD_ERRORS
No
No
No
Yes
RMS_OI_INV_ORD_ITEM_ERRORS
No
No
No
Yes
RMS_OI_MISSING_STOCK_COUNT
No
No
No
Yes
RMS_OI_OVERDUE_SHIP_ALLOC
No
No
No
Yes
RMS_OI_OVERDUE_SHIP_TSF
No
No
No
Yes
RMS_OI_OVERDUE_SHIP_RTV
No
No
No
Yes
RMS_OI_STK_ORD_PEND_CLOSE
No
No
No
Yes
RMS_OI_STOCK_COUNT_VARIANCE
No
No
No
Yes
RMS_OI_TSF_PEND_APPROVE
No
No
No
Yes
RMS_OI_UNEXPECTED_INV
No
No
No
Yes
RMS_OI_DATA_STWRD_INCOMP_ITEMS
No
No
No
Yes
Design Assumptions
N/A
Purge Export Data (data_export_purge_job)
Module Name
Description
Purging of all the extracted records (week old) for Xstore.
Functional Area
Foundation1
Module Type
Admin - Ad hoc
Module Technology
Background processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This background job is composed of one step processing only. It will retain the business logic processing from original KSH script algorithm.
The Business logic program will removed all old/aged records from the following staging tables related to data exported information which are considered week old regardless if data is extracted or not.
Restart/Recovery
N/A
Key Tables Affected
Table 2-6 Key Tables Affected
MERCHHIER_EXPORT_STG
No
No
No
Yes
ORGHIER_EXPORT_STG
No
No
No
Yes
STORE_EXPORT_STG
No
No
No
Yes
DIFFS_EXPORT_STG
No
No
No
Yes
DIFFGRP_EXPORT_STG
No
No
No
Yes
ITEM_EXPORT_STG
No
No
No
Yes
VAT_EXPORT_STG
No
No
No
Yes
RELITEM_EXPORT_STG
No
No
No
Yes
DATA_EXPORT_HIST
No
No
No
Yes
Integration Contract
N/A
Design Assumptions
N/A
Purge Export Data (export_stg_purge.ksh)
Module Name
Description
Functional Area
Foundation
Module Type
Integration
Module Technology
Ksh
Catalog ID
RMS265
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This batch job will be used to remove records that are a week old from the following staging tables.
  • Merchandise Hierarchy Export Staging
  • Organizational Hierarchy Export Staging
  • Store Export Staging
  • Differentiator Export Staging
  • Differentiator Group Export Staging
  • Item Export Staging
  • VAT Export Staging
  • Related Item Export Staging
  • Data Export History
Batch will purge all the records (Week old records) from its respective staging table whether data get extracted or not.
Restart/Recovery
N/A
Design Assumptions
N/A
Purge Forecast Data (fcstprg)
Module Name
fcstprg.pc
Description
Purge Forecast Data
Functional Area
Interface - Planning
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS227
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
This program deletes data from the Merchandising forecast information tables. This program serves to delete data by domains so that they can re-loaded with new forecast information from a forecasting system such as Demand Forecasting.
Restart/Recovery
N/A
Design Assumptions
N/A
Purge Forecast Data (forecast_data_purge_job)
Module Name
Description
Purge Forecast Data
Functional Area
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
Thread assignment program will filter eligible records from RMS forecast information tables based on passed Domain ID. By default, all domains are captured and considered for purging criteria. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from their respective RMFCS forecast information tables. Data deletion is performed by partition truncation, table truncation or deletion by domain. The method of deletion is dependent on whether or not the table is partitioned. This program serves to delete data by domains so that they can re-loaded with new forecast information from a forecasting system such as Demand Forecasting.. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
Yes
No
No
No
B8D_FORECAST_DATA_PURGE_STG
Yes
Yes
No
Yes
ITEM_FORECAST
No
No
No
Yes
DEPT_SALES_FORECAST
No
No
No
Yes
No
No
No
Yes
No
No
No
Yes
Design Assumptions
NA
Purge Job Auditing Logs (job_audit_logs_purge_job)
Module Name
Description
Purge Old Job Auditing Logs
Functional Area
Administration
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This background job is composed of one step processing only. This new program/job will use the newly created support program maintain for purging records where affected table is partitioned.
The Business logic program will invoke a call to a new program specific for handling historical logging table that is considered a partitioned table. A package function is called passing the target table name and will execute the proper deletion/purging of records from target table by exercising table partitioning handling such as Dropping Interval Partition (same as truncate or delete from table). There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop job with a flip of this indicator.
The purge program considered the system parameter setting, Job Logging History Months (job_log_hist_months) to determine those records that are older than a predetermined number of months.
Restart/Recovery
N/A
Key Tables Affected
Table 2-7 Key Tables Affected
SYSTEM_OPTIONS
Yes
No
No
No
PERIOD
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
ALL_TAB_PARTITIONS
Yes
No
No
No
ALL_PART_TABLES
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
Yes
Design Assumptions
N/A
Purge Manage Admin Records (admin_api_purge.ksh)
Module Name
admin_api_purge.ksh
Description
Purge Manage Admin records
Functional Area
Administration
Module Type
Admin
Module Technology
ksh
Catalog ID
N/A
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This script purges data from tables used for uploading Foundation Data from spreadsheets based on the retention days specified in the system parameter- PROC_DATA_RETENTION_DAYS for both Merchandising and Sales Audit and will help in keeping the size of these tables controlled.
Restart/Recovery
N/A
I/O Specifications
N/A
Purge Notifications (raf_notification_purge.ksh)
Module Name
Description
Purge notifications from the Retail Application Framework table
Functional Area
Notifications
Module Type
Admin
Module Technology
Ksh
Catalog ID
RMS80
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This batch program calls RAF_NOTIFICATION_TASK_PKG.DEL_NOTIF_PAST_RETENTION to delete notifications that are generated by Merchandising and Sales Audit and have passed the preconfigured number of retention days. This program provides a way to clean up and control the size of the RAF notification tables.
Restart/Recovery
N/A
Design Assumptions
N/A
Refresh Materialized Views (refreshmview.ksh)
Module Name
refreshmview.ksh
Description
Refreshes dept_sales_forecast, class_sales_forecast, subclass_sales_forecast, dept_sales_hist, class_sales_hist subclass_sales_hist, mv_subclass_loc_hist and mv_restart_stock_count materialized views
Functional Area
Financials
Module Type
Ad hoc
Module Technology
ksh
Catalog ID
N/A
Wrapper Script
rmswrap_shell.ksh
Design Overview
This is a batch job that will refresh the specified materialized view. The materialized views that are refreshed are dept_sales_forecast, class_sales_forecast, subclass_sales_forecast, dept_sales_hist, class_sales_hist, subclass_sales_hist, mv_subclass_loc_hist and mv_restart_stock_count.
This program can be run ad hoc and will accept the materialized view name as the parameter. Nested refresh of the materialized view can be controlled using the optional parameter (Valid values: Y - True and N - False). By default, the refresh is nested.
Schedule
Restart/Recovery
N/A
I/O Specification
N/A
Retail Business Metrics Calculation (rbm_metrics_calc_job)
Module Name
Description
Retail Business Metrics Calculation job
Functional Area
Module Type
Admin – Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This job is a background job that computes the business metric for all metrics marked as enabled (active_ind = ‘Y’) in the rbm_master table. The purpose of each metric is detailed in the metric_desc and comments columns in rbm_master table.
RBM_ID METRIC_NAME METRIC_DESC COMMENTS
100
active_item_locs
Count of transaction-level item locations where the status is active, and the item status is approved
Count of item location records where the item/location status is A (active) and the item status is A (approved). Only transaction-level items should be considered.
101
gross_active_item_locs
Count of all item locations where the status is active
Count of item location records where the item/location status is A (active) should be considered.
110
sales_audit_trans
Count of sales audit transaction header records
Count of sales audit transaction header records, across all stores.
111
sales_audit_tran_line_items
Count of sales audit transaction item records
Count of sales audit transaction item records, across all stores.
120
po_receipts
Count of the purchase orders
Count of the shipments by receipt date where the order number is not null, across all locations.
121
po_lines_recieved
Count of purchase order lines received
Count of transaction data records, for transaction code 20, by receipt date, where the adjustment code is null, across all locations.
130
stock_order_receipts
Count of stock order (transfer or allocation) receipts
Count of the shipments by receipt date where the BOL number is not null, across all locations.
131
stock_order_lines_recieved
Count of stock order lines received (transfer or allocation)
Count of shipment transaction data records for transaction code 44 by day across all locations.
140
cost_changes
Total number of cost changes executed
Sum by effective date the cost change header records with a status of Extracted (E) .
141
cost_change_details
Total number of cost changes executed at detail level
Sum by effective date the cost change detail records with a status of Extracted (E) .
142
cost_change_details_loc
Total number of cost changes executed at detail location level
Sum by effective date the cost change detail location records with a status of Extracted (E) .
500
price_changes
Total number of price changes that have been executed
Sum of count of the price changes by effective date where the status is Executed (5).
510
Clearances
Total number of clearance events (both markdowns and resets) executed
Sum of count of the Executed events (clearances) by effective date where the status is Executed (5).
600
Allocations
Total number of allocations sent to Merchandising for execution
Sum of count of allocations (ALC_ALLOC) in Approved or PO Created status by last update date.
601
allocation_line_items
Total number of allocation lines sent to Merchandising for execution
Sum of count of allocation details (ALC_ITEM_LOC) for allocations in Approved or PO Created status by last update date.
700
Invoices
Total number of merchandise invoices posted to AP
Sum of count of documents of type Merchandise Invoice (MRCHI) with a status of Posted (POSTED) by posted date.
701
invoices_line_items
Total number of invoice lines posted to AP
Sum of count of detail lines for merchandise invoices in Posted status by posted date.
710
other_documents
Total number of documents posted to AP, excluding merchandise invoices
Sum of count of documents that are not type Merchandise Invoice (MRCHI) with a status of Posted (POSTED) by posted date.
The data will be computed at the frequency indicated by calc_freq in the rbm_master table wherein D stands for daily, W stands for weekly, and M stands for monthly. The weekly metrics are calculated on the day indicated in the calc_weekday column. The monthly metrics are calculated on the day of the month indicated by the calc_day column.
The aggregate_method column indicates whether the calculated metric will be averaged or summed across the data points collected. Do not change the aggregate_method because data collected up until the date of change will have a different meaning after the change. rbm_id is a pre-populated ID with dependencies in the rbm_values table and therefore should not be changed.
The metrics can be enabled or disabled using the Retail Business Metric Data Induction Template.
The computed data is stored in the rbm_values table. This data can then be used for reporting. For example, the aggregated active item locations data is consumed by Subscription Metrics Update (subscription_metrics_update_job), which in turn writes subscription metrics to the platform table to be used in reports in Retail Home.
Restart/Recovery
N/A
Key Tables Affected
RBM_MASTER
Yes
No
No
No
RBM_VALUES
Yes
Yes
Yes
No
Design Assumptions
N/A
Retain Item Forecast History (rms_oi_forecast_history.ksh)
Module Name
Description
Retain 4 weeks of Item Forecast History
Functional Area
Item Forecast, Inventory Analyst Report
Module Type
Admin
Module Technology
Ksh
Catalog ID
RMS491
Wrapper Script
rmswrap_shell.ksh
Design Overview
This batch program preserves 4 weeks of weekly forecasted sales data from ITEM_FORECAST in the ITEM_FORECAST_HISTORY table before ITEM_FORECAST is truncated and refreshed by the load_item_forecast.ksh weekly batch program. The data in ITEM_FORECAST_HISTORY is used to support the Inventory Variance to Forecast report in the Inventory Analyst dashboard. If the system is not configured to use this report (for example, rms_oi_system_options.ia_variance_to_forecast_ind is N), then running this batch job will NOT copy any data to ITEM_FORECAST_HISTORY.
To support potentially large volume of data on ITEM_FORECAST and ITEM_FORECAST_HISTORY, ITEM_FORECAST_HISTORY is interval partitioned by EOW_DATE with a partition interval of 7 days and an interval high value of EOW_DATE+1. EOW_DATE must be a valid EOW_DATE based on calendar type – (4) 454 or (C) Standard Calendar.
Frequency
Weekly
Before load_item_forecast.ksh weekly runs that truncates the data in ITEM_FORECAST table.
Pre-Processing
N/A
Post-Processing
N/A
Threading Scheme
N/A
Restart/Recovery
N/A
Key Tables Affected
ITEM_FORECAST
Yes
No
No
No
ITEM_FORECAST_HIST
No
Yes
No
Yes
Design Assumptions
N/A
Module Name
Description
Functional Area
Module Type
Admin – Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
This job is a background job that executes after rbm_metrics_calc_job. First, the rbm_metric_calc_job aggregates the number of active item locations for the current month. After that, subscription_metrics_update_job reads the aggregated value, converts to Metrics UOM, and writes to the Platform tables. Retail Home displays the dashboard graph using the values populated in the Platform tables.
Restart/Recovery
N/A
Key Tables Affected
RAF_SUBS_METRIC_USAGE
Yes
Yes
No
No
RAF_SUBS_METRIC_QTY
Yes
Yes
Yes
No
Design Assumptions
N/A
Tax Event Purge (tax_event_purge_job)
Module Name
tax_event_purge_job
Description
Tax Event Purge
Functional Area
Purchase Order
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Scheduling
Design Overview
Thread assignment program will filter eligible records from tax calculated event table based on its purge criteria (retention number of days) with default value of 90 days and its tax event result defined as "C"ompleted Successfully. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from tax calculated event table. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 2-8 Key Tables Affected
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_TAX_EVENT_PURGE_STG
Yes
Yes
No
Yes
TAX_CALC_EVENT
No
No
No
Yes
PERIOD
Yes
No
No
No
Input/Output Specification
N/A
Tax Event Purge (taxevntprg)
Module Name
Taxevntprg
Description
Tax Event Purge
Functional Area
Purchase Order
Module Type
Admin
Module Technology
PROC
Catalog ID
RMS373
Wrapper Script
N/A
Schedule
Design Overview
This batch purges the tax events from the tax calculation event table. The records to be purged are based on its last update timestamp along with the tax event result.
Restart/Recovery
N/A
Design Assumptions
N/A
Truncate Table Script (trunctbl.ksh)
Module Name
trunctbl.ksh
Description
Functional Area
Foundation
Module Type
Admin
Module Technology
KSH
Catalog ID
RMS475
Wrapper Script
rmswrap_shell.ksh
Schedule
Design Overview
This program performs truncate operations on a Merchandising table or a specific partition. It accepts an input table name and an optional partition name. If no partition name is passed, then the truncate is applied on the entire table.
This program must be run as either the Merchandising schema owner, or be run by a user that has been granted the following system privileges:
  • drop any table
  • alter any table
Currently, the following action and tables are processed by the batch. For the runtime parameters, refer to the Oracle Retail Merchandising Batch Schedule.
Table 2-9 Actions and Tables Processed by Batch
Table Partition
NIL_INPUT_WORKING
N/A
Restart/Recovery
N/A
Design Assumptions
N/A
