15 Sales History
Merchandising maintains sales history at a variety of levels. Item level sales history drives Merchandising replenishment, ratio build, and is exported to planning applications. Sales history rolled up to levels of the merchandise hierarchy is used by Oracle Retail Allocation. Rolled up sales history is also useful for custom reporting.
Monthly Sales History Rollup By Department, Class And Subclass (hstbldmth)
Module Name
hstbldmth.pc
Description
Monthly Sales History Rollup by Department, Class, and Subclass
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS241
Wrapper Script
rmswrap_multi.ksh
Schedule
Oracle Retail Merchandising Batch Schedule
Design Overview
The monthly sales history roll up routine will extract sales history information for each item from the ITEM_MASTER and ITEM_LOC_HIST_MTH (item location history by month) tables. The history information will be rolled up to the subclass, class and dept level to be written to: subclass_sales_hist_mth (subclass/location/month/sales type), class_sales_hist_mth (class/location/month/sales type) and dept_sales_hist_mth (department/location/month/sales type).
This program may be run in parallel with hstbld since they both read from HIST_REBUILD_MASK. The table HIST_REBUILD_MASK table must not be truncated before both programs finish running.
Restart/Recovery
The logical unit of work for the hstbldmth module is department, location, sales type and end of month date with a recommended commit counter setting of 1,000. Processed records are committed each time the record counter equals the maximum recommended commit number.
Design Assumptions
N/A
Monthly Sales History Rollup By Diffs (hstbldmth_diff)
Module Name
hstbldmth_diff.pc
Description
Monthly Sales History Rollup by Diffs
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS242
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
The sales history rollup routine will extract sales history information for each ITEM_PARENT from the ITEM_LOC_HIST_MTH table and rolls the data to month level. The history information will be rolled up to the item differentiator level to be written to: item_diff_loc_hist_mth and item_parentloc_hist_mth. For each item, data to be retrieved includes sales quantity and stock. This data must be collected from several tables including ITEM_LOC_HIST_MTH, ITEM_LOC, and ITEM_MASTER.
Restart/Recovery
N/A
Locking Strategy
The package HSTBLD_DIFF_PROCESS locks the following tables for update:
ITEM_DIFF_LOC_HIST_MTH
ITEM_PARENTLOC_HIST_MTH
Design Assumptions
N/A
Monthly Stock on Hand, Retail and Average Cost Values Update (hstmthupd)
Module Name
hstmthupd.pc
Description
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS158
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
This batch program runs monthly to update the stock on hand, retail values and average cost for each item/location on the ITEM_LOC_HIST_MTH (item location history by month) table. If the item/location does not exist on the ITEM_LOC_HIST_MTH table, then the new record is written to a comma delimited file which is later uploaded to ITEM_LOC_HIST_MTH table using SQL*Loader (hstmthupd.ctl).
Restart/Recovery
The logical unit of work for this program is the item/location record. Threading is done by store using the v_restart_store_wh view. The commit_max_ctr field on the RESTART_CONTROL table will determine the number of transactions that equal a logical unit of work. Table-based restart/recovery is used.
I/O Specification
Integration Type
Download from Merchandising
File Name
Determined by runtime parameter
Integration Contract
IntCon000175
hstmthupd.ctl
Purge Aged Sales History (history_purge_job)
Module Name
history_purge_job
Description
Functional Area
Sales Posting
Module Type
Admin - Ad hoc
Module Technology
Background Processing
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Design Overview
This background job is composed of two steps processing. It will have a threading assignment and a business logic processing.
Thread assignment program will filter eligible records from department, class, subclass sales history tables based on its purge criteria from system parameter settings. The Item History Months parameter will determine record which is older than the specific number of retention months of fashion style history. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from sales history tables by department, class and subclass tables. It will also invoke a call to a new program specific for handling historical tables that are considered partitioned tables. PARTITION_SQL.PURGE_INTERVAL_PARTITION is called passing each target table names "ITEM_LOC_HIST", "ITEM_LOC_HIST_MTH", and "DAILY_SALES_DISCOUNT". This called program will execute the proper deletion/purging of records from target table by exercising table partitioning handling such as Dropping Interval Partition (same as truncate or delete from table). There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
The decision to insert or not to insert the records into the history tables is based on the Archive Indicator and Archive Job Indicator from the Background Process Configuration table.
  1. If both the Archive Indicator and Archive Job Indicator values are Y, then the data from the base tables are inserted into the history tables.
  2. If both indicators are set to N, then the records are deleted from the base tables without inserting into the history tables.
For more information on how to configure this process for archiving, see the Merchandising Implementation Guide section entitled “Background Process Configuration”.
Restart/Recovery
N/A
Key Tables Affected
Table 15-1 Key Tables Affected
Table Select Insert Update Delete
PERIOD
Yes
No
No
No
PURGE_CONFIG_OPTIONS
Yes
No
No
No
SYSTEM_OPTIONS
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_HIST_PURGE_STG
Yes
Yes
No
Yes
ALL_PART_TABLES
Yes
No
No
No
ALL_TAB_PARTITIONS
Yes
No
No
No
ITEM_LOC_HIST
No
No
No
Yes
ITEM_LOC_HIST_MTH
No
No
No
Yes
SUBCLASS_SALES_HIST
No
No
No
Yes
CLASS_SALES_HIST
No
No
No
Yes
DEPT_SALES_HIST
No
No
No
Yes
No
No
No
Yes
DAILY_SALES_DISCOUNT_PRG_HIST
No
Yes
No
No
ITEM_LOC_HIST_PRG_HIST
No
Yes
No
No
Purge Aged Sales History (hstprg)
Module Name
hstprg.pc
Description
Functional Area
Sales Posting
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS244
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
Deletes records from ITEM_LOC_HIST, SUBCLASS_SALES_HIST, CLASS_SALES_HIST, DEPT_SALES_HIST and DAILY_SALES_DISCOUNT tables, where data is older than the specified number of months. Number of months for retention of fashion style history is specified by system_options.ITEM_HISTORY_MONTHS.
Restart/Recovery
N/A
Design Assumptions
N/A
Purge Aged Sales History by Diff (hist_diff_purge_job)
Module Name
hist_diff_purge_job
Description
Functional Area
Sales History
Module Type
Admin - Ad hoc
Module Technology
Catalog ID
N/A
Wrapper Script
b8dwrap.ksh
Schedule
Design Overview
Thread assignment program will filter eligible records from item-parent-location history by diff and item-location history by diff tables based on its purge criteria from system parameter settings. The Item History Months parameter will determine old sales history differentiator data on a specified system set date. These records are chunked and Thread ID is assigned for each. They will be stored temporarily in a staging table.
The Business logic program will process all records from the staging table. Using bulk processing, this program will delete the records from sales history differentiator and item-parent-location history tables. It will free up and clean the staging table afterwards. There is a STOP ON NEXT feature in bulk processing (through a loop) where Administrators can stop this batch with a flip of this indicator.
Restart/Recovery
N/A
Key Tables Affected
Table 15-2 Key Tables Affected
Yes
No
No
No
PERIOD
Yes
No
No
No
RMS_BATCH_STATUS
Yes
No
No
No
B8D_PROCESS_CONFIG
Yes
No
No
No
JOB_AUDIT_LOGS
No
Yes
No
No
B8D_HIST_DIFF_PURGE_STG
Yes
Yes
No
Yes
ITEM_DIFF_LOC_HIST
No
No
No
Yes
ITEM_PARENT_LOC_HIST
No
No
No
Yes
Purge Aged Sales History by Diff (hstprg_diff)
Module Name
hstprg_diff.pc
Description
Functional Area
Sales History
Module Type
Admin
Module Technology
ProC
Catalog ID
RMS245
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
The tables, ITEM_DIFF_LOC_HIST and ITEM_PARENT_LOC_HIST are purged of sales history differentiator data, which is older than a specified system set date. This date is stored in the purge_config_options.ITEM_HISTORY_MONTHS column.
Restart/Recovery
N/A
Design Assumptions
N/A
Weekly Sales History Rollup by Department, Class, and Subclass (hstbld)
Module Name
hstbld.pc
Description
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS239
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
The sales history rollup routine will extract sales history information for each item from the item and item location history tables. The history information will be rolled up to the subclass, class, and dept level to be written to history tables.
The rebuild program can be run in one of two ways:
First, if the program is run with a run-time parameter of ‘rebuild', the program will read data (dept, class, and subclass) off the manually input HIST_REBUILD_MASK table, which will determine what to rebuild.
Secondly, if the program is run with a run-time parameter of ‘weekly', the program will build sales information for all dept/class/subclass combinations only for the current end of week date.
Restart/Recovery
The logical unit of work for this program is set at the store/dept/class level. Threading is done by store using the v_restart_store view.
Design Assumptions
N/A
Weekly Sales History Rollup by Diff (hstbld_diff)
Module Name
hstbld_diff.pc
Description
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS240
Wrapper Script
rmswrap.ksh
Schedule
Design Overview
The sales history rollup routine will extract sales history information for each item_parent from the ITEM_LOC_HIST table. The history information will be rolled up to the item differentiator level to be written to: item_diff_loc_hist and item_parent_loc_hist.
For each item, data to be retrieved includes sales qty and stock. This data must be collected from several tables including ITEM_LOC_HIST, ITEM_LOC, and ITEM_MASTER.
Restart/Recovery
N/A
Design Assumptions
N/A
Key Tables Affected
Table 15-3 Key Tables Affected
No
Yes
Yes
No
ITEM_DIFF_LOC_HIST
No
Yes
Yes
No
ITEM_LOC
Yes
No
No
No
ITEM_LOC_HIST
Yes
No
No
No
ITEM_MASTER
Yes
No
No
No
SYSTEM_VARIABLES
Yes
No
No
No
PERIOD
Yes
No
No
No
Weekly Stock on Hand and Retail Value Update for Item/Location (hstwkupd)
Module Name
hstwkupd.pc
Description
Functional Area
Sales History
Module Type
Business Processing
Module Technology
ProC
Catalog ID
RMS159
Wrapper Script
rmswrap_multi.ksh
Schedule
Design Overview
This program runs weekly to update the current stock on hand, retail values and average cost for each item/location on ITEM_LOC_HIST is using SQL*Loader (hstwkupd.ctl). The program must be run on the last day of the week as scheduled.
Restart/Recovery
The logical unit of work for HSTWKUPD is item/location. The program is threaded by location using the v_restart_store_wh view.
I/O Specification
Integration Type
File Name
IntCon000176
hstwkupd.ctl
Design Assumptions
N/A
