6 RTLog Generator On-Premise
This chapter describes how to install, deploy, and configure the on-premise RTLog Generator application. The On Premise RTLog Generator application can be used with both the cloud or on premise Merchandising/Pricing applications.
RTLog Generator is a Java and XML based web application that exposes a Spring-JAXWS implemented SOAP web service. It is distributed as a web archive along with a configuration .zip file ready to be deployed on an Oracle WebLogic Server 14c.
This chapter uses Microsoft Windows path format as the example for paths.
Configuration
The RTLog Generator application is shipped with a configuration .zip file (rtlog-gen-config.zip) which should be used to externally configure and extend the RTLog Generator's functionality.
Bounce the WebLogic server after making any configuration level changes.
Starting from release 20.0, the RTLog generator is shipped with one rtlog-generator-config.zip, which is used to integrate with Sales Audit and ReSA On-premise.
To set up the external configuration features:
Extract the configuration file's content into the C:\<rtlog-generator-config> directory if installing on Microsoft Windows or /usr/local/<rtlog-generator-config> on Linux OS. These directories are the default locations where the RTLog Generator application will look for the configuration files. These default locations can be overridden/changed by using one of the following ways:
Pass a JVM argument to the server startup script and bounce the server:
-Drtloggen.config.dir=C:/<custom_directory>/
If the WebLogic domain is created with a Node manager, the same argument can be passed from the Administration Console in the Arguments field. See Figure 6-1.
Figure 6-1 Administration Console Configuration Page
Specify the context-param field in the RTLog Generator WAR file. This requires opening up the WAR file and making the required changes. Update the web.xml file as shown in the following example:
<context-param> <param-name>rtlog.generator.config.home</param-name> <param-value>C:/<custom_directory>/</param-value> </context-param>Figure 6-2 Example of context-param Field Update
The JVM argument takes the precedence over the default location, that is, C:\<rtlog-gen-config>. If either of the two does not exist, the context parameter is used. If nothing is specified, the RTLog Generator application will fail on startup with error messages in the server logs.
Once the configuration file is extracted to the configured directory, verify the following files:
rtlogconfig.properties:This file contains the following properties (key value pairs):
processingDir: This directory path specifies the location that RTLog Generator will use to build its RTLog files as it receives data from Xstore Office. This directory needs to be created manually. -
resaFileDropDir: This directory path specifies the destination for the RTLog files this system is producing. It should be configured to the location where Sales Audit is looking to receive the RTLog files. This directory needs to be created manually. -
clusterNodeNumber: This property should only be enabled when running in a clustered environment. For more information, see "WebLogic Cluster Setup". -
deliveryTarget:This property specifies the RTLog delivery target. The two possible values are resa-cs or resa-onprem. If resa-cs is specified, the RTLog files generated are in format compatible with Sales Audit; otherwise the files generated are in format compatible with ReSA On-premise. -
spring.profiles.active:This property is by default commented out. Uncomment it in the following two scenarios.-
Enable FTS delivery of RTLog files.
Set it to “fts,archive” without quotes to send RTLog files to ReSA CFS object storage through FTS (File Transfer Service).
Set it to “fts,zip,archive” without quotes to send RTLog zip files to ReSA CFS object storage through FTS (File Transfer Service).
Set it to “zip” without quotes to zip up RTLog files placed in the directory specified by property “resaFileDropDir”.
Following is an example of the properties. No spring.profiles.active property is specified in this case.
processingDir = C:/RTLOG_Weblogic/Output/Store/RTLOGS resaFileDropDir = C:/RTLOG_Weblogic/Output/ReSA clusterNodeNumber = 1 deliveryTarget = resa-cs -OR- deliveryTarget = resa-onprem
Following is another example to enable zipping of RTLog files.
processingDir = C:/RTLOG_Weblogic/Output/Store/RTLOGS resaFileDropDir = C:/RTLOG_Weblogic/Output/ReSA clusterNodeNumber = 1 deliveryTarget = resa-cs -OR- deliveryTarget = resa-onprem spring.profiles.active = zip
Additional properties and configuration have to be specified if FTS delivery of RTLog files is enabled. Skip this section if it is not enabled.-
cloud.fts.endpointUrl:This property specifies the ReSA FTS endpoint URL to deliver the RTLog files to.
RTLog Generator supports two forms of RMS FTS endpoints.
RMS Platform FTS wrapper API: This API is the new FTS endpoint supported in RMS. The customer is advised to use this endpoint for FTS integration. Its URL takes the following format: https://xxxx/xxxx/RmsPlatformServices/services/private/FTSWrapper
RMS FTS API (deprecated): This API is deprecated but still supported in RMS. The customer is advised to switch to use the new platform FTS wrapper API. The deprecated API may no longer be available in RMS in the future. Its URL takes the following format: https://xxxx/xxxx/RmsReSTServices/services/private/fts
To invoke ReSA FTS endpoint URL secured in Oauth, IDCS client ID, secrete, and scope are required. They are captured in Xcenter DB. The following properties must be specified for RTLog generator to request them through Xcenter on premise REST APIs.-
xcenter.protocol: http or https -
xcenter.host: Xcenter on premise host name -
xcenter.port: Xcenter on premise port -
xcenter.db.user: encrypted basic auth username for Xcenter on premise REST apis -
xcenter.db.pwd: encrypted basic auth password for Xcenter on premise REST apis -
dtv.location.organizationId: Xcenter organization id to request for IDCS client id/secret/scope -
dtv.CustomerId: customer ID used in decryption of username and password -
dtv.CustomerId.salt: salt used in decryption of username and password
Following is an example rtlogconfig.properties with FTS delivery enabled.
processingDir = C:/RTLOG_Weblogic/Output/Store/RTLOGS resaFileDropDir = C:/RTLOG_Weblogic/Output/ReSA clusterNodeNumber = 1 deliveryTarget = resa-cs spring.profiles.active = fts,zip,archive -OR- spring.profiles.active = fts,archive cloud.fts.endpointUrl=https://xxxx/xxxx/RmsPlatformServices/services/private/FTSWrapper xcenter.protocol=https xcenter.host=<xcenter onprem host> xcenter.port=<xcenter onprem port> xcenter.db.user=<encrypted xcenter onprem basic auth username> xcenter.db.pwd=<encrypted xcenter onprem basic auth passowrd> dtv.location.organizationId=1000 dtv.CustomerId=xxx dtv.CustomerId.salt=xxxx
Cipher Keys: for rtlog-generator to decrypt xcenter.db.user and xcenter.db.pwd, cipher keys must be copied from xcenter-config/res/keys to rtlog-generator-config/res/keys. This includes all key files of the following naming patterns.
config.cip–
config.*.cip (for example config.2022-02-07.cip)Truststore: certificate to communicate to Xcenter must be placed in .truststore file under rtlog-generator/res/ssl
Multiple log4jx.xml files: These files configure the logging levels for the RTLog Generator application.
rtlog-generator-log4j2.xml
rtlog-generator-log4j2-loggers.xml
rtlog-generator-log4j2-appenders.xml
spring-scheduler.xml:It is the most commonly modified file in the RTLog Generator application. It is used to configure the scheduled interval for publishing the RTLog files. In the case of trickle polling, the default interval should be 15 minutes, however, keeping a larger interval (at least greater than or equal to 15 minutes) is recommended as configuring with a smaller interval might affect the performance.
Figure 6-3 spring-scheduler.xml Example
Customization ouf of box configuration
To customize RTLogMappingConfig.xml and RTLogFormatConfig.xml, you can obtain your out-of-box version in the rtlog-generator.war file under WEB-INF\lib\config.jar\resources\resa-cs for Sales Audit integrations (deliveryTarget = resa_cs) or WEB-INF\lib\config.jar\resources\resa-onprem for ReSA On-premise integrations (deliveryTarget = resa_onprem).
Customized copies of RTLogMappingConfig.xml and RTLogFormatConfig.xml are placed in the configuration directory defaulting to C:\<rtlog-generator-config> on Microsoft Windows or /usr/local/<rtlog-generator-config> on Linux OS.
RTLogFormatConfig.xml:This file specifies the format of the RTLog record as specified by Sales Audit. You can modify this file.
RTLogMappingConfig.xml:The RTLog Generator application relies heavily on the XML-based mapping which provides extensibility and a way to maintain/upgrade features for the application. This file can be used to override all the field values for either mapping strategy:
FieldMapperThenValueMapping:The
RecordValueattribute values as shown in the following example can be changed:<MAP sourceField="tenderId" targetRecord="TransactionHeaderTotal" targetField="ReferenceNumber1" mappingStrategyOrder="FieldMapperThenValueMapping" fieldMapper="trnHeaderTotalMapper"> <VALUE_MAPPINGS handleNotFound="success"> <VALUE_MAPPING sourceValue="GIFT_CERTIFICATE" RecordValue="GIFTCERT" /> <VALUE_MAPPING sourceValue="HOUSE_ACCOUNT" RecordValue="HACCNT" /> <VALUE_MAPPING sourceValue="ISSUE_STORE_CREDIT" RecordValue="ISTCRDT" /> <VALUE_MAPPING sourceValue="ISSUE_MERCHANDISE_CREDIT_CARD" RecordValue="IMCCARD" /> <VALUE_MAPPING sourceValue="ISSUE_XPAY_GIFT_CARD" RecordValue="IXPAYGC" /> <!--For e.g above given value can be changed as shown here.--> <VALUE_MAPPING sourceValue="ISSUE_XPAY_GIFT_CARD" RecordValue="SAMPLE_IXPAYGC" /> <VALUE_MAPPING sourceValue="MALL_CERTIFICATE" RecordValue="MALLCERT" /> <VALUE_MAPPING sourceValue="MERCHANDISE_CREDIT_CARD" RecordValue="MCCARD" /> <VALUE_MAPPING sourceValue="PAYPAL" RecordValue="PAYPAL" /> <VALUE_MAPPING sourceValue="COUPON" RecordValue="QPON" /> <VALUE_MAPPING sourceValue="ROOM_CHARGE" RecordValue="ROOMCHAG" /> <VALUE_MAPPING sourceValue="RELOAD_XPAY_GIFT_CARD" RecordValue="RXPAYGC" /> <VALUE_MAPPING sourceValue="RELOAD_MERCHANDISE_CREDIT_CARD" RecordValue="RMCCARD" /> <VALUE_MAPPING sourceValue="STORE_CREDIT" RecordValue="STCRDT" /> <VALUE_MAPPING sourceValue="XPAY_GIFT_CARD" RecordValue="XPAYGC" /> </VALUE_MAPPINGS> </MAP>
No
mappingStrategyOrderandfieldMapperattributes are defined.The
RecordValueattribute values shown in the following example can be changed or a new value can be added:<MAP sourceField="reason" targetRecord="TransactionHeader" targetField="ReasonCode"> <VALUE_MAPPINGS handleNotFound="nextMapping"> <VALUE_MAPPING sourceValue="PI1" RecordValue="PI1"/> <VALUE_MAPPING sourceValue="PI2" RecordValue="PI2"/> <VALUE_MAPPING sourceValue="PI3" RecordValue="PI3"/> <VALUE_MAPPING sourceValue="PO1" RecordValue="PO1"/> <VALUE_MAPPING sourceValue="PO2" RecordValue="PO2"/> <VALUE_MAPPING sourceValue="PO3" RecordValue="PO3"/> <VALUE_MAPPING sourceValue="PO4" RecordValue="PO4"/> <VALUE_MAPPING sourceValue="PO5" RecordValue="PO5"/> <VALUE_MAPPING sourceValue="SAMPLE" RecordValue="SAMPLE_VALUE"/> </VALUE_MAPPINGS> </MAP>
on how to customize the RTLog Generator, see the Retail Xstore
- RTLog Generator Extension Guidelines (Doc ID 2174095.1) on https://support.oracle.com.
Deployment
If you are deploying in a cluster, first set up a WebLogic cluster. For more information, see "WebLogic Cluster Setup".
This section covers the deployment in both a clustered and non-clustered environment.
To deploy the RTLog Generator application:
Log in to the WebLogic 12 Server Administration Console (http://<hostName>:<port>/console).
Click the Deployment link from the left navigation menu.
Click Install.
Figure 6-4 Administration Console Control Page
Navigate to the rtlog-generator.war file directory. Select the rtlog-generator.war option.
Figure 6-5 Administration Console Install Application Assistant Page
Click Next and then Finish. Once deployed, RTLog Generator should be listed as one of the deployed applications as shown in Figure 6-6.
Figure 6-6 Administration Console Summary of Deployments
Once the deployment is complete, following are the next steps:
To deploy on a cluster, see "Deployment of the RTLog Generator Application on a Cluster".
To enable security for the RTLog Generator application, see "Security Configuration". When deploying in a non-clustered environment, continue at this section.
WebLogic Server 14c must be installed on all the clustered machines and the exact same installed directory location must be used on all the machines.
To set up the cluster to use RTLog Generator:
Start the WebLogic configuration wizard on one machine where the Administration server needs to reside.
On the Configuration Wizard Configuration Type page, select Create a new domain. Enter or browse to the location for the domain. Click Next.
Figure 6-7 Configuration Wizard Configuration Type Page
On the Templates page, select the supported products and click Next. It is recommended to select the following:
WebLogic Advanced Web Services for JAX-WS Extension
Figure 6-8 Configuration Wizard Templates Page
On the Administrator Account page, enter the Administrator user name and password. Enter the password a second time to confirm. Click Next.
Figure 6-9 Configuration Wizard Administrator Account Page
On the Domain Mode and JDK page, select either Development or Production mode. For production mode, you need to manually create the boot.properties file. Click Next.
Figure 6-10 Configuration Wizard Domain Mode and JDK
On the Advanced Configuration page, select the Administration Server, Node Manager, and Managed Servers, Clusters and Coherence options. Click Next.
Figure 6-11 Configuration Wizard Advanced Configuration Page
On the Administration Server page, enter the values to configure the administration server. The administrator server controls all the managed servers that are part of the cluster.
Enter the server name, select Enable SSL, and enter the listen ports. For the listen address, enter the Machine_1 IP address. Machine_1 will be part of the cluster and will have the administrator server running on it. Click Next.
Figure 6-12 Configuration Wizard Administration Server Page
On the Node Manager page, do not change the default node manager settings. For the credentials, enter weblogic as the user name and enter the password. Click Next.
Figure 6-13 Configuration Wizard Node Manager Page
On the Managed Servers page, add and configure each managed server:
For the listen address, enter the IP address of the managed server. Do not select All local Addresses.
rtlog_ManagedServer_1 will be running on Machine_1 in this configuration. Enter the Machine_1 IP address for the server.
rtlog_ManagedServer_2 will be running on Machine_2 in this configuration. Enter the Machine_2 IP address for this server.
oracleProxy is running on Machine_1, but is not a part of the cluster. It is an Oracle proxy HTTP cluster servlet used for failover and load balancing purposes. Enter the Machine_1 IP address for this server.
Enable SSL for all the managed servers.
Click Next.
Figure 6-14 Configuration Wizard Managed Servers Page
On the Clusters page, add and configure the cluster. Enter the cluster name followed by the cluster address, that is, IP address1:port1, IP address2:port2, so on. Click Next.
Figure 6-15 Configuration Wizard Clusters Page
On the Assign Servers to Cluster page, assign the managed servers to the cluster. and click Next.
Do not include the Oracle Proxy as part of the cluster.
Figure 6-16 Configuration Wizard Assign Servers to Clusters Page
On the HTTP Proxy Applications page, select Create HTTP Proxy and then select the server from the drop-down list. By default, it should have already been selected. Click Next.
Figure 6-17 Configuration Wizard HTTP Proxy Applications Page
On the Machines page, add and configure each machine. To add Machine_1 and Machine_2, click Add and enter the respective IP addresses. This configuration is for setting up the Node managers on both the machines. Since these node managers are physically separated, you can select the same host. Click Next.
Figure 6-18 Configuration Wizard Machines Page
On the Assign Servers to Machines page, assign the servers to the machines. In this example, Oracle proxy (load balancer), Administration server, and one managed server are configured on Machine_1. Another managed server is configured on Machine_2. Click Next.
Figure 6-19 Configuration Wizard Assign Servers to Machines Page
On the Configuration Summary page, verify the selected configuration. Click Create. The domain is created.
Figure 6-20 Configuration Wizard Configuration Summary Page
To complete the configuration of the cluster:
Start and stop the node manager. You can find the start up script inside the newly created domain, that is, the <rtlog_clust_domain>\bin directory.
In the nodemanager.properties file, set SecureListener=false. This file is found in the <rtlog_clust_domain>\nodemanager directory.
Edit the <rtlog_clust_domain>\config\config.xml file. Use plain communication for the node managers by updating the communication type for the node managers as shown in the following example:
<machine> <name>Machine_1</name> <node-manager> <name>Machine_1</name> <nm-type>Plain</nm-type> <listen-address>xxx.x.xxx.xx</listen-address> </node-manager> </machine> <machine> <name>Machine_2</name> <node-manager> <name>Machine_2</name> <nm-type>Plain</nm-type> <listen-address>xxx.x.xxx.xxx</listen-address> </node-manager> </machine> -
If the <rtlog_clust_domain> is created with the production mode option:
Run <rtlog_clust_domain>\startWeblogic.cmd for the first time. This creates the servers folders under the domain. Enter the administration user name and password.
Create a folder named security under the <rtlog_clust_domain>\servers\Admin server.
Create the boot.properties file with the following entries under the security folder:
password=%admin_server_password% username=%admin_server_username%
%admin_server_password% and %admin_server_username% are the administrator password and user name.
After making these changes, if there are any running processes, shut down all the processes.
Pack the created domain:
Stop both the Node manager and Admin Server if not already stopped. Use the packing utility to pack the domain on the machine. This utility is found in the following location:
<WL_HOME>\wlserver\common\bin\pack.cmd
Run the following command:
pack.cmd -domain=<WL_HOME>\user_projects\domains\rtlog_cluster_domain -template=<WL_HOME>\user_projects\domains\rtlog_cluster_domain\rtlog_cluster_domain.jar -template_name="RTLog C domain"
This command creates a jar named rtlog_cluster_domain.jar by packing the complete domain into it. Copy the rtlog_cluster_domain.jar to Machine_2 and unpack it.
Create a <user_templates> directory on the remote machine and copy the rtlog_cluster_domain.jar file to this location. Run the following command:
unpack.cmd -template=<WL_HOME>\user_projects\domains\<user_templates>\rtlog_cluster_domain.jar -domain=<WL_HOME>\user_projects\domains\rtlog_cluster_domain
Start the Administration server and node manager on Machine_1.
To enroll the remote (Machine_2) node manager:
Run the WebLogic scripting utility. This utility can be found at the following location: <WL_HOME>\wlserver\common\bin\as wlst.cmd
Start the node manager on this machine, in this example, Machine_2. The node managed must be started before connecting to the Machine_1 Admin server.
connect ('adminServer_username', 'adminServer_password','t3://Machine_1_IPAddress:Admin_server_unsecured_port')
Once the connect command shows the connection completed successfully, run the following command:
nmEnroll ('<WL_HOME>/user_projects/domains/<rtlog_cluster_domain>','<WL_HOME>/user_projects/domains/<rtlog_cluster_domain>/nodemanager')
When the command completes successfully, run exit ().
Repeat Step 6 for all the remote machines that will be in the cluster on which managed servers will be running. This step used Machine_2 as the example.
Log in to the Administration Server console and make sure all the node managers are reachable. This can be found under Machines. Repeat this step for all the clustered machines to ensure all of them are reachable.
Figure 6-21 Administration Console Settings Page
For each managed server, select the Server Start tab. In the Arguments text box, add the following if it does not already exist:
-Xms512m -Xmx512m -XX:CompileThreshold=8000 -XX:PermSize=512m -XX:MaxPermSize=512m
Figure 6-22 Administration Console Configuration Page
If you want to configure the non-default external RTLog configuration directory, include an additional JVM argument:
-Drtloggen.config.dir=C:/<rtlog-gen-config_1>/
The server-start arguments only work when you are using a NodeManager. If you do not have a NodeManager, specify the JVM argument in the start up scripts. You can also configure the same ext directory location in the RTLog Generator WAR's context-param. For more information, see "Configuration".
Start all the managed servers including the Oracle proxy. Figure 6-23 shows an example of the list of managed servers.
Figure 6-23 Administration Console List of Servers
To deploy the application:
Oracle proxy creates a web application by creating the web.xml and weblogic.xml files which can be found in the following directory:
<WL_HOME>\user_projects\domains\<rtlog_cluster_domain>\apps\OracleProxy4_rtlog_Cluster_1_oracleProxy\WEB-INF
You can modify the configurations provided in these two files and redeploy the application from the console by pointing it to this directory, that is, WEB-INF.
Navigate to the Administration Console home page and click Deployments in the left navigation menu. Figure 6-24 shows an example of the page before deploying the RTLog Generator application.
Figure 6-24 Administration Console Deployments Page
Click Install. The Install Application Assistant page appears. Select the path to the RTLog Generator WAR directory. Select the rtlog-generator.war option. Click Next.
Figure 6-25 Administration Console Install Application Assistant Page
Select only the managed servers and click Next to finish the deployment.
Figure 6-26 Install Application Assistant Select Deployment Targets Page
After it is successfully deployed, the RTLog Generator application appears in the Summary of Deployments page.
Figure 6-27 Summary of Deployments Page
To enable container and transport level security, see "Security Configuration".
To enable the WebLogic Plugin Enabled parameter from the cluster domain:
Click the <rtlog_cluster_domain> link in the left navigation menu. Navigate to the Web Application tab.
Figure 6-28 Administration Console Settings Page
Scroll down the page and select WebLogic Plugin Enabled. Click Save.
Figure 6-29 WebLogic Plugin Enabled Parameter
The RTLog Generator application is secured by leveraging two levels of security:
Container level security: Basic HTTP authentication by setting up the security realm in WebLogic. To configure this security, see "Container Level Security".
Transport level security: SOAP requests are sent over the secured protocol (HTTPS) by configuring the keystore/truststore in the WebLogic domain and importing the public certificate into Xstore Office's (client) truststore. To configure this security, see "Transport Level Security".
The following steps assume that a domain has been created with secure port (HTTPS) enabled. To configure container level security:
Start the WebLogic server and log in to Administration Console.
Click Security Realms in the left navigation menu.
Figure 6-30 Administration Console Summary of Security Realms Page
In the list of realms on the Summary of Security Realms page, select myrealm.
Select Users and Groups and then the Groups tab. To create a new group, click New. Enter a group name, for example RTLogUserGroup, and click OK.
Figure 6-31 Create a New Group Page
Select the Users tab and click New. Enter a user name and password and click OK.
Figure 6-32 Create a New User Page
In the list of users, click the newly created user.
Figure 6-33 Users Page
Select the Groups tab. Assign this user to the same group created in Step 4.
Figure 6-34 User Settings Page
Enter the same user name and password created in Step 5 into Xstore Office's broadcaster configuration for the RTLog Generator Web service.
You should try the MrJaxWsPortProxyFactoryBean bean and create the encrypted values for the user name and password using the String Encryption Utility. For more information, see the Oracle Retail Xstore Point of Service Implementation Guide.
Figure 6-35 Example of MrJaxWsPortProxyFactoryBean Update
To configure transport level security:
Create keystore.jks using a keytool utility. For information on keytool utilities, see the Oracle Retail Xstore Point of Service Implementation Guide.
Export the public certificate into a truststore.jks file. These files are needed to configure the custom key and trust store for Step 3.
In a clustered environment, import all the public certificates into one truststore file and configure all the instances of the server, including HttpClusterServlet proxy, to use the same truststore file.
Log in to the WebLogic console. Click Environment and then the Servers link from the left navigations menu.
Figure 6-36 Administration Console Servers Page
Click Change. Select Custom Identity and Custom Trust. Click Save.
Figure 6-37 Keystores Settings
Click the linked name for the Administration Server. The page containing the settings for the Administration Server appears. Select the Keystores tab.
Figure 6-38 Settings for the Administration Server
Enter the path to keystore.jks, including the file name, and enter the custom Identity Keystore passphrase you created for the keystore. Repeat this for trustore.jks, but enter the appropriate passphrase for the truststore. For an example, see Figure 6-38.
Switch to the SSL tab. Enter the alias name and private keyphrase as created during the certificate generation. To save the changes, click Save.
Figure 6-39 Save Settings for Administration Server
For a clustered environment, disable the non-SSL port for the HttpClusterServlet proxy.
Complete the Security Configuration
Test both the container and transport level security using SOAPUI.
To set up the unlimited strength JCE files:
Download and install the correct version of the unlimited strength JCE files. For more information, see the Oracle Retail Xstore Point of Service Implementation Guide.
Configure Oracle WebLogic Server 14c with the Xstore suite of product's supported cipher suites. To configure it, update the <domain>\<domain_name>\config\config.xml file and add the following inside the ssl block:
<ciphersuite>TLS_RSA_WITH_AES_128_GCM_SHA256</ciphersuite> <ciphersuite>TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384</ciphersuite> <ciphersuite>TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384</ciphersuite> <ciphersuite>TLS_ECDH_ECDSA_WITH_AES_256_GCM_SHA384</ciphersuite> <ciphersuite>TLS_ECDH_RSA_WITH_AES_256_GCM_SHA384</ciphersuite> <ciphersuite>TLS_RSA_WITH_AES_256_GCM_SHA384</ciphersuite>
Disable the schema validation in WebLogic by passing the JVM argument in the WebLogic startup script:
-Dweblogic.configuration.schemaValidationEnabled=false
Xstore Office's RTLog Generator broadcaster end point should be configured to use the secured (HTTPS) URL for configuring the container level security section:
<property name="endpointAddress" value="https://<hostname>:7002/rtlog-generator/service" />The endpoingAddress property is defined at xcenter-spring-beans.xml under Xcenter external configuration directory\xcenter-config. There are two required modifications:
Modify broadcasterManager bean in the file by uncommenting the line below.
<ref bean="ReSA_Broadcaster"/>
Configure endpointAddress of the ReSA_Broadcaster_jaxws bean.
