Regenerate a Translation
To regenerate a translation, follow the steps below.
Select Actions > Translate or use the Translate button, if available. The Translations drawer appears.
Figure 3-5 Translations Drawer
Select the Generate option from the Overflow Menu in the Action column. The Edit Translation drawer appears.
Figure 3-6 Edit Translation Drawer
The system’s primary language and your current language are displayed at the top of the page along with the primary language values for the fields that can be translated.
- The Language field shows the selected language. This field cannot be edited.
- To regenerate a previously translated value, click the Generate button to obtain an AI-generated translation.
- Review and refine the translation as desired.
- Then choose one of the following options.
- Click Update to save the changes and close the drawer.
- Click Cancel to reject all changes and close the drawer.
- To exit the Translations drawer, click the X at the top of the drawer.
