Editing an Address
To edit an address, follow the steps below.
- In the Addresses list, choose Edit from the Overflow menu next to the address you wish to edit. The Address drawer appears.
- The Address Type field displays the type of address. You cannot edit this field.
- Select the Primary Address checkbox to set the current address as the primary address for the selected address type. If the address is already designated as the primary address, the Primary Address field is disabled.
- Edit the address and contact fields as necessary.
- Then choose one of the following options.
- Click Save to save the your changes and close the drawer.
- Click Cancel to reject all entries and close the drawer.
