Creating an Address from Existing
To create a new address from an existing address, follow the steps below.
  1. In the Addresses list, choose Copy from the Overflow menu next to the address you wish to copy. The New Addresses drawer appears.
  2. In the Address Type field, select the type of address you wish to create using the information from the copied address.
  3. Select the Primary Address checkbox to indicate that the current address is a primary address for the selected type. The field is enabled if a primary address already exists for the selected address type, allowing you to choose a new primary address. If no primary address exists, the Primary Address field is automatically selected and disabled.
  4. The Copy Address to all Required Address Types checkbox, indicates that the current address information is added to each required address type that does not yet have an address defined. This checkbox will be hidden if all required address types already have an address. When displayed, this checkbox is selected by default.
  5. The address and contact fields enable and display the copied data from the selected address. Change the entries as necessary.
  6. Then choose one of the following options.
    • Click OK to save the current address and close the page.
    • Click OK and Add Another to save the current address and add additional entries.
    • Click Cancel to reject all entries and close the page.
