Locale
The store’s locale-related information is displayed and entered in the Locale section. If information has already been entered in the section, it will display in a read-only format upon entering the page. To edit the information, click the Edit button in the upper right corner of the section. This will display the section in an input state where the fields are enabled for entry and edit. After changes are made to return to the read-only state, click the Update button to save changes or the Cancel button to discard all edits.
Figure 3-24 Locale
Table 3-4 Locale - Fields and Description
| Fields | Description |
| Language |
Enter, select or search for the language code for the store. This field is a required field. |
| Time Zone |
Enter, select, or search for the time zone of the store. This field is a required field. |
