Store Services
Services that are provided by the store, such as Gift Wrapping, Engraving, and Curbside Pickup, are displayed and selected in the Store Services section. The list of services is configurable using the STSV code type, which can be maintained through the Codes and Descriptions foundation data spreadsheet template. If information has already been entered in the section, it will display in a read-only format upon entering the page. To edit the information, click the Edit button in the upper right corner of the section. This will display the section in an input state where the fields are enabled for entry and edit. After changes are made to return to the read-only state, click the Update button to save changes or the Cancel button to discard all edits.
Figure 3-30 Store Services
Store Services
Table 3-10 Store Services - Fields and Description
Fields Description
Store Service To indicate if the store offers the service, set the switch to ON. Your application administrator determines which services are displayed.
