Brokered Backorders
Purpose: If the Send B/O to OROB (K08) system control value is selected, you can use the Order Orchestration Integration to send backordered order lines to Order Orchestration for fulfillment.
If the Use OROB for Fulfillment Assignment (M31) system control value is unselected, the system sends eligible backordered items to Order Orchestration for fulfillment. Order Orchestration will choose the best store location to fulfill and ship the item to the customer. Items that are in stock follow normal reservation and fulfillment processing.
If the Use OROB for Fulfillment Assignment (M31) system control value is selected, the system bypasses reservation and places all eligible items on backorder, even if the item is available in an Order Administration warehouse. Order Orchestration will choose the best store location or Order Administration location to fulfill and ship the item to the customer.
If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, the system bypasses reservation in order to send eligible items on a ship-for-pickup order to Order Orchestration for fulfillment assignment. In this situation, the fulfilling location may be a store location or an Order Administration warehouse and the merchandise is shipped to the customer’s selected store for pickup. See Creating a Ship-for-Pickup Order in Order Administration for more information on how to create a ship-for-pickup order.
If the item is flagged as a active PO item the system does not submit it to Order Orchestration for fulfillment using the standard process described here; instead, it uses the process described under Enterprise Order Integration (Future Receipts and Active PO/Pre-Order Processing).When using Order Orchestration for fulfillment assignment, the fulfilling location can be a store location or an OACS warehouse location. In addition, for ship-for-pickup orders, the fulfilling location ships the order to the customer’s selected store for pickup.
In this topic:
Brokered Backorder Processing Overview
Order Orchestration assignment: Assigning a backordered item to Order Orchestration can occur through:
order entry or order API: When you create an order that includes a backordered line, Order Administration assigns the line, if eligible, to Order Orchestration for fulfillment, and withholds it from normal fulfillment processing within Order Administration.
If the Use OROB for Fulfillment Assignment (M31) system control value is selected, the system bypasses reservation for all eligible items on an order and places them on backorder so that Order Orchestration can determine the fulfilling location.
If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, the system bypasses reservation for all eligible items on a ship-for-pickup order and places them on backorder so that Order Orchestration can determine the fulfilling location.
batch process: A periodic function finds eligible backordered lines and assigns them to Order Orchestration.
Eligibility rules: Order Administration determines whether an order line is eligible for Order Orchestration fulfillment based on certain basic criteria, such as whether it is fully backordered and authorized; also, you can use related system control values to further restrict Order Orchestration assignment based on your business rules, such as omitting items you are due to receive soon on open purchase orders. Also, the item must be flagged as OROB eligible. See Rules for Submitting Backorders to Order Orchestration for details.
If the authorization for the order line has expired, the system obtains a new authorization.
Does each line create a separate order in Order Orchestration? Each eligible backordered line on an order is sent to Order Orchestration:
as a separate order if the Use Split Order (L56) system control value is unselected. In this case, the fulfillment of each line is tracked individually. Order Orchestration does not attempt to assign multiple order lines from the same fulfilling location.
as part of a single order if the Use Split Order (L56) system control value is selected. In this case, Order Orchestration attempts to assign all lines on the same order to the same fulfilling location; however, it notifies Order Administration about multiple assigned fulfilling locations if the order or lines are split. If a single backordered item is unfulfillable through Order Orchestration, that line returns to standard backorder processing, but additional lines on the order can still be fulfilled through Order Orchestration.
What information is sent to Order Orchestration? Order Administration sends the following information to Order Orchestration:
sold-to and ship-to customers’ names and addresses.
details on the requested item.
It does not send payment information, although only fully paid and authorized items are eligible for Order Orchestration fulfillment. If the Payment at POS for Ship for Pickup Orders (L60) system control value is selected, ship-for-pickup orders are authorized for verification only and payment is collected when the customer picks up the items at the store.
If the authorization for an order line has expired, the system obtains a new authorization.
For more information on the information sent to Order Orchestration, see Sample Order Orchestration Messages in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Brokered Backorder Fulfillment: Initial Order Creation
| # | Step |
1. |
The process begins when you create an order in Order Administration. If the Send B/O to OROB (K08) system control value is selected, the system sends eligible backordered items to Order Orchestration to determine the fulfilling location. In addition:
The order creation can occur through interactive order entry, batch order entry, or the order API. You can also use the BROKER periodic function to submit existing backordered lines to the Order Orchestration for fulfillment; see Additional Order Orchestration Setup in Order Administration for more information. |
2. |
If the order line meets the Rules for Submitting Backorders to Order Orchestration, the BROKER_ORD process in Order Administration generates a request message to Order Orchestration and creates an Order Orchestration record. Note: Order lines that meet the Rules for Submitting Backorders to Order Orchestration do not sell out initially, even if the items are flagged with soldout control codes. See Brokering Items with Soldout Control Codes for more information.If the order includes multiple backordered lines and the Use Split Order (L56) system control value is selected, the request message includes all eligible backordered lines; otherwise, each backordered item is submitted as a separate order. Each Order Orchestration record has a status of R (ready) at creation. Also, the order line is updated to restrict it from standard backorder processing in Order Administration:
Note: Order Orchestration status is not displayed in Streamlined Order Inquiry (DORI). |
3. |
If the BROKER_ORD
process in Working with Integration Layer Processes
(IJCT) is active, it immediately generates the submit
order request message to Order Orchestration to request order
creation and assignment in Order Orchestration. At this time, it also
changes each Order Orchestration record’s status to W (waiting)
and creates an Order Orchestration History record for each line
to track the order submission ( See the Sample Order Orchestration Messages in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Note: Although the BROKER_ORD process generates the submit order requests (and cancellation requests, if needed), the BROKER process handles other requests to Order Orchestration. |
4. |
The Routing Engine module in Order Orchestration receives the submit order message. If Order Administration sent each line separately, Order Orchestration creates each order line as a separate order in its database; otherwise, if you use the split order option, Order Orchestration creates a single order including all of the order lines that were eligible for submission as brokered backorders. Order Orchestration assigns each order or line to a location for fulfillment based on inventory availability and the business rules you have defined in Order Orchestration. At this point, the order status in the Order Orchestration database is new_order. |
5. |
Order Orchestration sends a response message to Order Administration indicating each assigned fulfilling location and the unique request ID it uses to identify each order. See the Submit Order Response Message Sample in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Note: The message version is specified in the Order Orchestration Properties; this property must be set to16.0 or higher in order to use
brokered backorders for fulfillment assignment and to use ship-for-pickup
processing.
6. |
If Order Orchestration successfully created an order and assigned it to one or more fulfilling locations, Order Administration:
Split line? If the Allow Split Line? preference in Order Orchestration is selected, Order Orchestration might split the quantity of a single brokered backorder line across more than one fulfilling location. For example, you create an order for item AB100 with a quantity of 10. There is no single location that has a quantity of 10 available. Order Orchestration assigns 8 units to location 100, and 2 units to location 200.
Order Orchestration splits order lines or line quantities only if you have selected the Allow Split Order? and Allow Split Line? preferences in Order Orchestration, and if there is not a single location that can fulfill the entire order or line quantity. See the Use Split Order (L56) system control value for examples, and see the Order Orchestration Operations Guide or online help for background.
If Order Administration is the fulfilling location: If the Use OROB for Fulfillment Assignment (M31) system control value is selected or the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, Order Orchestration may determine that a warehouse in Order Administration is the best location to fulfill the order, or some portion of the order. In this situation:
Order Orchestration assigns the Order Administration location to the order in Order Orchestration as the Fulfilling location.
When the order in the fulfillments response message is received:
If the original order is not a ship-for-pickup order, it creates a new delivery order and assigns the order type defined in the Order Type for Delivery Orders Originating in OROMS (M33) system control value to the order.
If the original order is a ship-for-pickup order, it creates a new retail pickup order and assigns the order type defined in the Order Type for Retail Pickup Orders Originating in OROMS (M35) system control value to the order.
In order to tie the originating order (the original order sent to Order Orchestration for fulfillment assignment) with the new fulfilling order (the delivery or retail pickup order created to fulfill the original order), Order Administration:
stores the originating order number in the E-commerce order number field in the Order Header Extended table for the newly created sourcing order. For example, the system updates the E-commerce order number with
ORIG#: 9999-001, whereORIG#:indicates the order has been created as a result of OROB fulfillment assignment,9999is the order number, and001is the ship-to number. -
assigns the Request ID defined for the originating order to the newly created sourcing order.
See Retail Pickup (including Ship-for-Pickup) or Delivery Orders for more information on how Order Administration processes a delivery or retail pickup order.
If the assigned fulfilling location rejects the order: The location assigned to fulfill an order or line can reject it if, for example, it does not have sufficient inventory. In this situation, Order Orchestration uses the rules set up at the Preferences screen in Order Orchestration to select another location to fulfill the order. If the location where the order is currently assigned changes, Order Administration updates this information the next time it sends a status inquiry to Order Orchestration, typically through pick slip generation, and receives the new information in the response.
An order normally remains in Rejected status in Order Orchestration only for a moment. If for any reason Order Orchestration receives a status inquiry request when the order’s status is Rejected, Order Administration does not update the order until the next time it sends a periodic status inquiry.What if Order Orchestration cannot find a location to
fulfill the order or line? In some cases, Order Orchestration
cannot assign an order to a location because there are no locations
with sufficient inventory that are eligible based on the business
rules set up in Order Orchestration at the Preferences screen. In this situation, Order Orchestration assigns
the order to the Default Unfulfillable Location specified
in Order Orchestration, which should match the setting of the OROB Default Location Code for Unfulfillable Orders
(K56) system control value. When Order Administration receives
a response message indicating that the order was assigned to the unfulfillable
location and has a status of Unfulfillable, it:
Clears the Drop ship flag and the Printed quantity on the Order Detail line.
If the Use OROB for Fulfillment Assignment (M31) system control value is selected or the original order is a ship-for-pickup order, unselects the Bypass reservation flag and updates the Backorder reason to
Not enough avail in whse. -
Changes the status of the Order Orchestration record to U (unfulfillable).
Writes an Order Transaction History record (for example,
Ln#: 2 Unfulfillable by Broker). -
Returns the line to standard backorder or soldout processing, including updating the Backorder quantity for the Item Warehouse and updating the PO Layering record.
An order might be flagged as unfulfillable when Order Orchestration first receives the request message, or after one or more locations have rejected the order for fulfillment; in this case, Order Administration receives notification the next time it sends a periodic status inquiry, as described below.
Notifying the customer of fulfillment assignment through Order Orchestration: The order confirmation email indicate a status of Store Ship for order lines assigned to Order Orchestration. See the Order Confirmation Email Sample and Contents for more information.
Fulfillment Process: After Order Creation and Status Updates
Status list inquiry request and response process: The BROKER IJCT job no longer calls the OOCS Status List request message for the latest status where the brokered status is still considered open. Instead, a web service is used to accept status updates from OOCS real-time. After each status update is complete in OOCS, a new Status Update message is sent immediately to OACS giving the current Quantity and Status of every line that was sent in the Status Update request.
If status has not changed: Once the order line is in Accepted status, Order Administration does not write a history record for the status list inquiry response as long as the record remains in this status.
| Activity | Status in OOCS | Status in OACS | Updates to Order Orchestration and Order Transaction History |
Order Administration sends the submit order message to Order Orchestration and restricts the order line from standard processing in Order Administration by setting the Drop ship flag and the Printed quantity. |
not yet created |
Waiting (W) |
Order Administration receives the submit order response from Order Orchestration |
new_order |
Acknowledged (K) |
If there is a single fulfilling location:
Otherwise, if there are multiple fulfilling locations, Order Administration sends a status inquiry request to Order Orchestration and performs the above activities when it receives the response. |
Polling: Each fulfilling location is responsible for polling Order Orchestration periodically to check for new orders. Once Order Orchestration receives a polling request from a location, it sends a polling response, listing the details of all new orders assigned to the location for fulfillment. |
polled |
Polled (P) (after receiving status inquiry response) |
Order accepted? If the assigned location can fulfill the order or line, it sends a status update message accepting the order or line to Order Orchestration. |
accepted |
Accepted (A) (after receiving status inquiry response) |
Note: Once the order line is in Accepted status, Order Administration does not write a history record for the status inquiry response as long as the record remains in this status. |
Order rejected? If the assigned fulfilling or sourcing location cannot fulfill the order or line, or the pickup location for a ship-for-pickup order indicates that the inventory for the item was not received or was damaged in transit, it sends a status update rejecting the order or line to Order Orchestration. Order Orchestration then: |
new_order |
Acknowledged (K) (after receiving status inquiry response) |
new_order |
unfulfillable (U) (after receiving status inquiry response) |
In Transit (ship-for-pickup, retail pickup): The location assigned to fulfill a ship-for-pickup order has sent the inventory to the location where the customer will pick up the order. Once the fulfilling location has shipped the order or line, it sends a status update message to Order Orchestration, providing the ship via and tracking number if available. Order Orchestration changes the status to In Transit and stores the ship via and tracking number so that it can send this information to Order Administration. The tracking number is not available as a live link on screens. |
In Transit |
intransit |
Create invoice? If the Invoice Ship For Pickup Order Once Intransit (M73) system control value is selected, Order Administration may create the invoice for the originating order when it receives a status inquiry response from Order Orchestration indicating that order lines on a ship-for-pickup order are now in transit. See that system control value for more information. Note: OACS no longer tries to combine Order Orchestration fulfillments into a single invoice but rather it is based on how the fulfilling system sends the request to OOCS. Therefore, for integrating systems, if you send status updates, you need to consider if you send them together or one at a time. |
Intransit Polled (ship-for-pickup): The pickup location for a ship-for-pickup order:
In Transit Polled |
intransit polled |
Create invoice? If the Invoice Ship For Pickup Order Once Intransit (M73) system control value is selected, Order Administration may create the invoice for the originating order when it receives a status inquiry response from Order Orchestration indicating that order lines on a ship-for-pickup order are now in transit polled, if the invoice was not already created. See that system control value for more information. Note: OACS no longer tries to combine Order Orchestration fulfillments into a single invoice but rather it is based on how the fulfilling system sends the request to OOCS. Therefore, for integrating systems, if you send status updates, you need to consider if you send them together or one at a time. |
Received (ship-for-pickup, retail pickup): The transferred inventory has been received at the location where the customer is picking up a ship-for-pickup order. |
Received |
received |
Create invoice? If the Invoice Ship For Pickup Order Once Intransit (M73) system control value is selected, Order Administration may create the invoice for the originating order when it receives a status inquiry response from Order Orchestration indicating that order lines on a ship-for-pickup order are now received, if the invoice was not already created. See that system control value for more information. Note: OACS no longer tries to combine Order Orchestration fulfillments into a single invoice but rather it is based on how the fulfilling system sends the request to OOCS. Therefore, for integrating systems, if you send status updates, you need to consider if you send them together or one at a time. |
Order shipped (delivery) or picked up (ship-for-pickup, retail pickup): Once the fulfilling location has shipped the order or line (delivery) or the customer has picked up the merchandise at the store location (ship-for--pickup), it sends a status update message to Order Orchestration. For delivery orders, the update message also provides the ship via and tracking number if available. Order Orchestration changes the status to fulfilled and stores the ship via and tracking number so that it can send this information to Order Administration. When Order Administration receives notification, it clears the Drop ship flag and the Printed quantity, and submits the order line to billing. If Order Orchestration provides a valid ship via code and a tracking number, the tracking number is a live link in the shipment confirmation email, although not on screens. See the OrderShipmentLineDetail in the outbound email message for details. For more information see the Web Services Guide on https://support.oracle.com My Oracle Support (ID 2953017.1). |
fulfilled |
completed (X) (after receiving status inquiry or inquiry list response) |
Example:
Note: Generating a single invoice takes place regardless of whether the fulfilled order lines have different Order Orchestration request IDs, provided the updates take place as described above.Note: The billing async job does not complete billing the order until one of the following occurs:
If a large number of orders were submitted in the status list request, there could be a delay of several minutes before the order is billed. Note: If there are multiple order lines confirmed as fulfilled on a single order, but for different ship-tos, this generates separate billing header records and invoice ship-tos. Multiple invoices are created for a single order if not all order lines are included in the same status list response message. |
Order status changes? If the Send Held Orders to OROB (M18) system control value is selected, Order Administration sends held brokered backorders to Order Orchestration, but with the Under Review flag set to Y; also, Order Administration sends an order update to Order Orchestration if the order’s status changes from held to open, or vice versa. |
no change |
no change |
Picked? If the assigned fulfilling location reports that a brokered backorder is in Picked status, the Working with Order Broker (WOBR) option indicates a status of Accepted.
Canceling a brokered backorder: See Canceling a Brokered Backorder Request for a discussion of the updates that take place when you cancel an Order Orchestration request at the Work with Order Broker Screen or in order maintenance.
Reviewing brokered backorders in order inquiry: You can use the Brokered Backorder Summary Screen to review the current status of all brokered backordered lines on a single order. Also, you can select D/S Status for a single brokered backorder line at the Order Inquiry Detail Screen to advance to the Display Order Broker Details Screen, where you can review a single brokered backorder line on the order.
Quantity not indicated in order transaction history
messages: The order transaction history messages
do not specify the quantity affected by the update; however, if you
split orders and lines, the quantity affected may be less than the
total order line quantity. For example, if Order Orchestration splits
an order line across two locations for fulfillment, and one of the
locations fulfills its assigned quantity, the order transaction history
message of Ln#: 2 Store Shipped Order does not
indicate the fulfilled quantity.
To be eligible for submission to Order Orchestration, the backordered item must have the OROB eligible flag selected. Also, the order line must be:
fully backordered
in open status
In addition, if the Use OROB for Fulfillment Assignment (M31) system control value is selected or the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS and the original order is a ship-for-pickup order, the order or order line can include the following; otherwise, the order or order line cannot include the following.
be gift wrapped
have any special handling
only custom special handling instructions are sent to Order Orchestration in the submit order request; however, the system does not prevent items with standard special handling from being sent to Order Orchestration -
have a future arrival date or be flagged as a future order
be for a customer flagged to bypass reservation
If the Use OROB for Fulfillment Assignment (M31) system control value is set to ALWAYS, the originating location passed to Order Orchestration on a delivery order is the location defined in the Originating Location to Pass to OROB (M32) system control value.
Also, if the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, the order line can be on a ship-for-pickup order; otherwise, if this system control value is set to NEVER or blank, order lines on a ship-for-pickup order are not eligible for submission to Order Orchestration to determine fulfillment assignment and instead are sent to Order Orchestration during pick slip generation and drop ship order processing time; see Ship-for-Pickup Orders.
Regardless of the settings of the Use OROB for Fulfillment Assignment (M31) and Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control values, the order line must not be:
Flagged as a drop ship item
A retail pickup or delivery order received from Order Orchestration
A main set item or a set component
A membership item
A stored value card item
A non-inventory item
Order Administration does not consider the item’s Projected returns quantity, if any, when determining whether the item is eligible for fulfillment through Order Orchestration.
Also, the order must be:
Open, if the Send Held Orders to OROB (M18) system control value is unselected; otherwise, the order can be held. In this case, the order’s Under Review flag is selected. See the system control value for more information.
Fully paid and authorized. If the Payment at POS for Ship for Pickup Orders (L60) system control value is selected, ship-for-pickup orders are authorized for verification only and payment is collected when the customer picks up the items at the store.
System control values: If the Use OROB for Fulfillment Assignment (M31) system control value is selected or if the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS and the original order is a ship-for-pickup order, regardless of the setting of the following system control values, the system sends items to Order Orchestration for fulfillment assignment. Otherwise, the following system control values also determine whether an order line is eligible to send to Order Orchestration for fulfillment:
Order Broker Due Date Threshold (K11): the system does not send an item to Order Orchestration if the item is expected on an open purchase order line for the related warehouse with a due date within the threshold defined in this system control value.
Order Broker Include Ship Complete Orders (K12): if this system control value is unselected, the system does not send items to Order Orchestration that are on an order flagged to ship complete.
Order Broker Include Coordinate Grouped Orders (K13): if this system control value is unselected, the system does not send items to Order Orchestration that are coordinate grouped with other items.
Order Broker Include Gift Orders (K14): if this system control value is unselected, the system does not send items to Order Orchestration that are on a gift order.
Sellout prevented: If an order line meets all of the criteria, it is brokered even if the item is flagged with a soldout control code. See Brokering Items with Soldout Control Codes for a discussion.
BROKER Periodic Function
The BROKER periodic function submits orders to Order Orchestration if they were not eligible for submission when they were created. For example, the periodic function submits order lines if:
Your company was not configured to send brokered backorders to Order Orchestration when the order was created.
The order was in held status at initial creation and was subsequently released from hold, and the Send Held Orders to OROB (M18) system control value is unselected.
The order previously included an active PO item (see About Active PO Items for background).
The order line was partially reserved, but then the reserved quantity was shipped and there is still a backordered quantity remaining on the order line. The order line is not eligible to be submitted to Order Orchestration until any reserved quantity is printed and shipped.
This situation occurs only if the Use OROB for Fulfillment Assignment (M31) system control value is unselected; also, this situation does not apply to ship-for-pickup orders sent to Order Orchestration for fulfillment assignment.
When the periodic function submits an order line as a brokered backorder, the function performs all the updates described under Brokered Backorder Fulfillment: Initial Order Creation, but also decreases the Backorder quantity for the Item Warehouse record, since this quantity had been increased when the line was created.If an authorization is required, the BROKER function obtains an authorization for the entire order.
See Additional Order Orchestration Setup in Order Administration for background on setting up the BROKER periodic function.
Items that are OROB eligible and flagged with a S/O control code are still eligible for brokering rather than selling out, provided they meet the Rules for Submitting Backorders to Order Orchestration.
In addition, the following applies if the Use OROB for Fulfillment Assignment (M31) system control value is unselected and the order is not a ship-for-pickup order.
If the soldout control status is:
sell out immediately: the item is eligible for brokering even if there is an available quantity in an allocatable warehouse.
include on-order: the item is eligible for brokering if it is backordered. There cannot be an open purchase order that could fulfill the order that is due within Order Orchestration Due Date Threshold (K11), if specified. If no Order Broker Due Date Threshold (K11) is specified, the item is eligible for brokering regardless of open purchase orders. The Projected returns quantity, if any, for the item is not evaluated; see Projected Returns for background on how you can use the Projected returns quantity to prevent selling out items in certain situations.
exclude on-order: the item is eligible for brokering if it is backordered, regardless of whether there are any open purchase orders.
If the item is unfulfillable: If Order Orchestration is unable to fulfill an order line, the line returns to standard backorder or soldout processing. The process flow is:
An item is assigned a soldout control value and would be sold out on the order if the item were not OROB eligible. Order Administration submits the order line to Order Orchestration, but there is no store location that can fulfill the item, so Order Orchestration returns a status of Unfulfillable.
When Order Administration receives the status update from Order Orchestration, it changes the order line status to sold out (S) if the order line is currently eligible to sell out based on the soldout control value and availability.
The next time you use the Processing Auto Soldout Cancellations (MASO) option, the soldout line is listed on the Auto Soldout Register, even though it did not sell out through Process Auto Soldouts and even if it is not assigned a soldout control status of 1 (sell out immediately).
The next time you use the Generating Soldout Notifications (MSON) option, Order Administration generates a soldout notification.
The same processing occurs if Order Orchestration returns an error for the brokered order line.
Gift wrap or special handling: Based on the Rules for Submitting Backorders to Order Orchestration, if the Use OROB for Fulfillment Assignment (M31) system control value is unselected or the order is not a ship-for-pickup order, an order line is not eligible for brokering if it is flagged for gift wrap or special handling. If gift wrap or special handling applies to the item:
When the order line is initially created, then the line does not broker; instead, it sells out or remains backordered, as if it were not flagged as OROB eligible. This is the case when the order API or ecommerce interface creates the order.
After the order line is initially created (for example, by selecting Special Handling for the line in order entry), then if the soldout control status is:
sell out immediately: the line sells out the next time you use Processing Auto Soldout Cancellations (MASO).
include on-order quantity or exclude on-order quantity: the line does not sell out automatically.
You can use a backorder report to identify order lines that could not be brokered because of gift wrap or special handling, and that did not sell out automatically. See Order Status and Activity Reports for more information.
Future orders: If the Use OROB for Fulfillment Assignment (M31) system control value is unselected or the order is not a ship-for-pickup order, future orders are not eligible to be brokered; in this situation, items flagged OROB eligible and assigned soldout control values sell out automatically on future orders, just as they would if they were not flagged OROB eligible. Once an order is no longer considered a future order, OROB eligible items on the order can be brokered through the BROKER periodic function if they meet the Rules for Submitting Backorders to Order Orchestration.
If reserving against a non-allocatable warehouse: Based on the Reserve from Non-Allocatable Warehouse (J25) and Disregard Soldout Controls for Non-Allocatable Warehouses (J27) system control values, you can reserve inventory against a non-allocatable (retail) warehouse for a retail order, and disregard an item’s soldout control assignment. In this case, even if the item’s OROB eligible field is selected, the item reserves against the non-allocatable (retail) warehouse if the order type is associated with that warehouse and there is inventory in that warehouse.
Things to Note About Brokered Backorders
Canceling order lines: It is important to confirm that the remote store location assigned to fulfill the order line has not begun the shipment process before you cancel an order line or Order Orchestration request in Order Administration. Depending on the Order Broker Status Update Interval (K10), the most current information about the Order Orchestration request in Order Administration might be out of date.
Freight charges included? Freight charges for the order are included in the SubmitOrder message only if the Use Split Order (L56) system control value is selected.
Customer address updates: If you change the customer’s name or address in Order Administration after generating the initial Order Orchestration request, the Order Orchestration integration does not send this updated information to the assigned fulfilling location. For ship-for-pickup orders, the system does not allow you to change the store location defined as the one-time ship-to address on the order once the order is accepted.
Held orders submitted? When the Send Held Orders to OROB (M18) system control value is unselected, if an order is initially created in held status and then released from hold, Order Administration does not automatically submit the order to Order Orchestration. To submit the order, you can run the BROKER Periodic Function (program PFR0083). See Order Orchestration Configuration for background.
Order lines not resubmitted: If an order line has previously been submitted to Order Orchestration and the Order Orchestration request was flagged as unfulfillable or put in error status, the BROKER periodic function does not resubmit the order line to Order Orchestration for fulfillment.
Reserve quantity limit: If an order line exceeds the Reserve qty (Reserve quantity limit) specified for an item, Order Administration still submits the order line to Order Orchestration for fulfillment, provided the line is eligible based on the Rules for Submitting Backorders to Order Orchestration.
Inventory transaction history: If the Create Item Transaction History for Non-Inventory Items (E39) system control value is selected, Order Administration writes a NONINVISSU transaction record when the BROKER process receives a status update indicating that the assigned location has shipped the order or line. See that system control value for more information.
Backorder notices: The Generate Backorder Notices (GBOC) option does not generate backorder notices for an order line when it has an Order Orchestration request in process; however, if the status of the Order Orchestration request changes to unfulfillable (U) or error (E), or if you cancel the Order Orchestration request (Z) without canceling the order line itself, the order line returns to standard backorder processing and is eligible to have backorder notices generated.
Tracking numbers in shipment confirmation email: If the fulfilling location supplies information on the shipping agent and a tracking number, Order Orchestration passes this information to Order Administration. If the shipping agent matches a valid ship via code in Order Administration, the shipment confirmation email lists the description of the ship via and the tracking number as a live link. Otherwise, if the shipping agent does not match a ship via set up in Order Administration, then the shipment confirmation lists the shipping agent as it was passed from Order Orchestration, and the tracking number is plain text.
If a brokered backorder ships on the same day as a warehouse shipment, the shipment confirmation email includes just the tracking number for the brokered backorder. This occurs regardless of whether you consolidate invoices.See the Shipment Confirmation Email Sample and Contents for more information, and see the OrderShipmentLineDetail for detailed mapping.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Important:
In Order Management System 21.0 or higher, or Order Administration, you cannot select the Consolidated Invoice system control value if it is not already selected. If the system control value is currently selected (set to Y) and you deselect it (change it to N or blank), you cannot then change it back to selected. The option to consolidate invoices will be removed at a later date.Tracking numbers in customer history API: If Order Orchestration passes the shipping agent and a tracking number, the Detailed Order Inquiry Response XML Message (CWORDEROUT) includes this information provided Order Administration can link the line number, shipping agent, and tracking number from the Order Transaction History messages to the invoice based on date.
Example:
The fulfilling location supplies information on the shipping agent and the tracking number to Order Orchestration, and Order Orchestration passes this information to Order Administration.
Order Administration writes Order Transaction History records such as:
SHIPMENT Ln#: 5 Store Shipped Order
SHIPMENT ----VIA: ABC
SHIPMENT ----TRK#: ABI123
The Order Transaction History records have the same date as the invoice.
The CWORDEROUT message passed through the customer history API includes the tracking information, for example:
<Shipment invoice_nbr="123456" invoice_ship_quantity="1"
invoice_ship_date="11292011" invoice_tracking_nbr="ABI123" invoice_ship_via_desc="ABC"/>
If Order Administration writes the Order Transaction History for the shipment of a brokered backorder on a date that differs from the invoice date, then no tracking information is included in the customer history response. This situation might occur if, for example, Order Administration receives the status update of the shipment before midnight, but the billing async job does not create the invoice until after the job is automatically stopped and restarted, so that the next date is assigned to the invoice.
The tracking information from Order Orchestration is not available as a live link on screens.
Other Order Orchestration orders not eligible: Order Administration does not submit a backordered delivery or retail pickup order to Order Orchestration for fulfillment. In addition, if the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER or blank, Order Administration does not submit a backordered ship-for-pickup order to Order Orchestration for fulfillment.
Line_locate_eligible flag in the CWORDEROUT message: If the Send B/O to OROB (K08) system control value is selected, the Detailed Order XML Response (CWORDEROUT) message used in the generic order API includes a flag for each order line to indicate whether the order line meets the Rules for Submitting Backorders to Order Orchestration. Even if this flag is set to Y, it is possible that the line cannot be fulfilled as a brokered backorder if, for example, Order Orchestration does not find a location that has the item available.
The Generic Customer History API also uses the CWORDEROUT
message. The message includes the line_locate_eligible flag if the order line is still open. In the case of the generic
customer history API, the line_locate_eligible flag
might be set to Y even if, for example, the line was already
submitted to Order Orchestration, and then returned to normal backorder
processing because Order Orchestration did not find a location
to fulfill it.
Order Orchestration requires postal code: If the shipping address on a brokered backorder does not include a postal code, the Order Orchestration Order Orchestration rejects it. The Require postal code? flag for the country determines whether a postal code is required. See Setting Up the Country Table (WCTY) for background.
The OBR status remains on each order line that is fully or partially fulfilled through Order Orchestration as a brokered backorder. This status is displayed on the Order Inquiry Detail Screen.
The original backorder reason remains on the order line after fulfillment through Order Orchestration as a brokered backorder. This reason is displayed on the Display Order Detail Screen (Reviewing Order Line Detail). Typically, the backorder warehouse also remains on the order line as well, and is displayed on the Display Order Detail Screen (Reviewing Order Line Detail); however, if a shipment from the warehouse follows the fulfillment through Order Orchestration, the backorder warehouse field is cleared.
Order Orchestration Originating Location, Fulfilling Location, and Pickup Location
The screens in the Working with Order Broker (WOBR) menu option display the following types of locations: originating, fulfilling, and pickup.
The Originating location is the location (store or warehouse) where the order originated. This location displays as the Placed location in Order Orchestration.
The Fulfilling location is the location supplying the inventory for the order. This location displays as the Sourced location in Order Orchestration.
The Pickup location is the location where the customer picks up the order; this location does not display for orders that are shipped to the customer. This location displays as the Pickup location in Order Orchestration.
The following table explains how the system determines the originating, fulfilling, and pickup locations for each broker delivery type.
| Broker delivery type | Originating location | Fulfilling location | Pickup location |
blank (brokered backorder for delivery or ship-for-pickup) |
an Order Administration warehouse this is the location_cd in the store_location element of the submit order request message:
the store location or Order Administration warehouse assigned to ship the item to the customer this is the fulfillment_location_cd in the fulfillment_detail element of the submit order response message; when a status request response message is received, the location may update based on the fulfilling_location_cd in the items element |
delivery: N/A; the order is shipped to the customer ship-for-pickup: this is the location_cd in the shipforpickup_location element of the submit order request message: from the store code in the one-time ship-to address |
delivery |
a store location or Order Administration warehouse this is the request_location_cd in the store_location element of the fulfillments response message |
an Order Administration warehouse this is the location_cd in the store_location element of the fulfillments response message |
N/A; the order is shipped to the customer |
store pickup |
an Order Administration warehouse this is the location_cd in the store_location element of the submit order request message: from the OROB Default Location (K51) |
the store location the customer has selected to pick up the order; the inventory is available at this location and does not need to be transferred there this is the fulfillment_location_cd in the fulfillment_detail element of the submit order response message |
the store location where the customer has selected to pick up the order this is the location_cd in the first transaction_detail element of the submit order request message: from the location, selected at the Store Pickup Search Results Screen, where the customer wants to pick up the order |
retail pickup (traditional retail pickup and retail pickup created as a result of a brokered ship-for-pickup) |
the store location where the customer would like to pick up the merchandise this is the request_location_cd in the store_location element of the fulfillments response message |
the store location where the customer has selected to pick up the order this is the location_cd in the shipforickup_location element of the fulfillments response message |
ship-for-pickup (pick gen/drop ship) |
an Order Administration warehouse this is the location_cd in the store_location element of the submit order request message: from the OROB Default Location (K51) if the Send Inventory by Warehouse to OROB (L06) system control value is unselected or for a drop ship item; otherwise, from the OROB location from the warehouse associated with the order |
an Order Administration warehouse this is the location_cd in the transaction_detail element of the submit order request message: from the OROB Default Location (K51) if the Send Inventory by Warehouse to OROB (L06) system control value is unselected or for a drop ship item; otherwise, from the OROB location from the warehouse associated with the order |
the store location where the customer has selected to pick up the order this is the location_cd in the shipforpickup_location element of the submit order request message: from the store code in the one-time ship-to address |
Location description: Even if the location
is a warehouse within your company in Order Administration, the description
of the location is from the cross-reference record set up through Work with Store Cross Reference (WSCR), and is separated from the code by a hyphen. For example, a request
assigned to warehouse 10, East Coast DC, lists a location of 10 - East Coast. Although the location code field in the
Order Administration database is 25 positions, you cannot create
a code that exceeds 10 positions in Order Orchestration.
The location description is stored in the Order Orchestration table. Entering or updating a location cross reference through Work with Store Cross Reference (WSCR) does not update the originating location displayed here.
The location description displayed here is blank if you had not set up the cross reference at the time the response was received from Order Orchestration.
Even if the location is an Order Administration warehouse, the warehouse description is not displayed here; you need to set up the cross-reference through Work with Store Cross Reference (WSCR).
When is the fulfilling location blank? The fulfilling location is blank for:
store pickup orders: if you canceled the order in Order Administration. If another location sent a cancel request to Order Orchestration, which relayed it to Order Administration through a status inquiry request, the Order Orchestration record retains the fulfilling location; however, if a single line on a store pickup order is rejected, the entire order (including any additional lines) is canceled, and in this situation the fulfilling location is blank for all items except the rejected item.
brokered backorders whose status is:
Z: Canceled
C: Closed
J: Rejected
R: Ready
W: Waiting
The field might also be blank for requests in E: Error status, depending on the nature of the error. For example, requests that Order Orchestration did not receive and create successfully are not assigned to fulfilling locations.
Unfulfillable status: If Order Orchestration was unable to find a location to fulfill a brokered backorder, the fulfilling location matches the OROB Default Location Code for Unfulfillable Orders (K56) system control value. In this situation, the current status is Unfulfillable.
Order Orchestration Status Summary Table
The following table summarizes the status codes displayed at the screens in the Working with Order Broker (WOBR) menu option.
| OACS status | OOCS status | Order types | Description |
A (Accepted) |
Accepted or Picked |
brokered backorder (delivery or ship-for-pickup) or store pickup |
The location assigned to fulfill the order has accepted it, or has accepted the order and is preparing it for shipment or pickup. |
C (Closed) |
N/A |
brokered backorder (delivery or ship-for-pickup) |
You canceled the request when its status was R (Ready), before it was submitted to Order Orchestration. |
E (Error) |
N/A |
Any order type |
Order Orchestration has returned an error response. See Troubleshooting the Order Orchestration Integration for information on some possible errors. A record might also be in Error status if another system submitted a status update request to Order Orchestration to cancel the order line. |
F (Picking) |
New_Order or Picked |
retail pickup, delivery, or ship-for-pickup (pick gen/drop ship) |
The pick slip has been printed. |
G (Resend Fulfilled) |
N/A |
delivery |
The Order Status Update request message to change the status in Order Orchestration to fulfilled did not generate a response message from Order Orchestration, possibly because message authentication failed or communication is down. In this case, the BROKER_ORD job re-sends the Order Status Update request the next time it runs. |
H (Resend Intransit) |
N/A |
ship-for-pickup |
The Order Status Update request message to change the status in Order Orchestration to intransit did not generate a response message from Order Orchestration, possibly because message authentication failed or communication is down. In this case, the BROKER_ORD job re-sends the Order Status Update request the next time it runs. |
I (In Process) |
Accepted |
retail pickup or delivery |
The order was received from Order Orchestration and created without error. |
J (Rejected) |
unknown (order reassigned to new fulfilling location) |
The order was sold out after creation in Order Administration. |
K (Acknowledged) |
New_Order |
Order Orchestration has received the order request, assigned a request ID, selected a fulfilling location (brokered backorder), and created the order in its database. |
L (Partial Fulfill) |
Partially Fulfilled |
retail pickup, ship-for-pickup, or store pickup |
The customer has picked up one or more items on the order, but not the complete order. |
N (New) |
Polled |
The order was received from Order Orchestration but is in error. |
O (Posted) |
Posted |
brokered backorder, store pickup, or ship-for-pickup |
Order Orchestration has submitted the order or order line for enterprise fulfillment. See Enterprise Order Integration (Future Receipts and Active PO/Pre-Order Processing) for background. |
P (Polled) |
Polled |
Any order type |
Brokered backorder (delivery or ship-for-pickup) or store pickup: The assigned fulfilling location has polled Order Orchestration for new orders and been notified of this order. Retail pickup or delivery order: Order Administration created the order in held status. |
R (Ready) |
N/A |
brokered backorder (delivery or ship-for-pickup), store pickup |
Brokered backorder: The request is ready to be sent to Order Orchestration, but the BROKER_ORD process has not yet generated the request message. Store pickup: Order Administration attempted to send the order to Order Orchestration, but Order Orchestration has not responded. In this case, Order Administration retains the order information in the Store Pickup tables until communication with Order Orchestration resumes. |
S (Received by Store) |
Received |
brokered backorder (ship-for-pickup), retail pickup or ship-for-pickup |
The order has been received by the store location but not yet picked up by the customer. NOTE: This status is not displayed for ship-for-pickup or retail pickup orders that are actually in this status in Order Orchestration after Order Administration has submitted a status update message to Order Orchestration indicating that the merchandise is in transit to the pickup location; instead, the displayed status is X (Completed). |
T (In Transit) |
Intransit |
Ship-for-pickup: The location fulfilling the order has shipped the merchandise to the store for pickup. NOTE his status is displayed for ship-for-pickup if Use OROB for Ship for Pickup Fulfillment Assignment (M34) is set to ALWAYS; however, it is not displayed for retail pickup orders, or for ship-for-pickup orders if Use OROB for Ship for Pickup Fulfillment Assignment is set to NEVER, if the orders are actually in this status in Order Orchestration after Order Administration has submitted a status update message to Order Orchestration indicating that the merchandise is in transit to the pickup location; instead, the displayed status is X (Completed). |
U (Unfulfillable) |
N/A (brokered backorder) or Rejected (store pickup) |
Brokered backorder: Order Orchestration has not found a location able to fulfill the order based on the rules set up in Order Orchestration. When it receives a response indicating that Order Orchestration cannot fulfill the order, Order Administration returns the order line to standard backorder or soldout processing. Store pickup: the assigned store location has rejected the order. |
V (In Transit Polled) |
Intransit Polled |
brokered backorder (ship-for-pickup), retail pickup or ship-for-pickup (pick gen/drop ship) |
The pickup location for a ship-for-pickup order line:
Only the pickup location for a ship-for-pickup order can update the status to intransit polled. This status applies only to ship-for-pickup orders. NOTE: This Status is not displayed for ship-for-pickup or retail pickup orders that are actually in this status in Order Orchestration after Order Administration has submitted a status update message to Order Orchestration indicating that the merchandise is in transit to the pickup location; instead, the displayed status is X (Completed). |
W (Waiting) |
unknown |
The order request message has been sent to Order Orchestration, but Order Administration has not yet received a response. |
X (Completed) |
Fulfilled |
all order types |
NOTE: This status is also displayed for retail pickup orders, and ship-for-pickup orders if Use OROB for Ship for Pickup Fulfillment Assignment (M34) is set to NEVER, after Order Administration has submitted a status update message to Order Orchestration indicating that the merchandise is in transit to the pickup location, even if the customer has not yet picked up the order. |
Y (Pending Cancel) |
unknown |
brokered backorder (delivery or ship-for-pickup), store pickup, retail pickup, delivery, or special ship-for-pickup |
Brokered backorder: You have canceled the order line (including the Order Orchestration request), or you have canceled just the Order Orchestration request at the Work with the Order Orchestration Screen, but you have not yet received a confirmation of the cancellation from Order Orchestration. Store pickup: You have canceled the order, but you have not yet received a confirmation of the cancellation from Order Orchestration. Retail pickup, delivery, or special ship-for-pickup: You have voided the pick slip through the generic pick in API and the Cancel Reason (Pick In) (L86) system control value specifies a cancel reason, or a backorder cancellation reason code is specified in the CWPickIn XML Message, but you have not yet received a confirmation of the cancellation from Order Orchestration. For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). |
Z (Canceled) |
Canceled |
brokered backorder (delivery or ship-for-pickup), store pickup, special ship-for-pickup, or retail pickup |
You have requested that the Order Orchestration order be canceled, and Order Orchestration has confirmed the cancellation. If the order line itself is not canceled, it returns to regular backorder processing. Note: If a status inquiry list response from Order Orchestration indicates that a brokered backorder line is canceled, the original Order Administration order line is put in error status; as a result, the canceled order line is either reserved, backordered, or sold out in Order Administration. If there is a fulfilling (bounceback) order that was created in Order Administration, it is put in Held status, with an order transaction history note of Order held - line[s] canceled in Order B. |
Overview: Use the retail pickup or delivery options in the Order Orchestration Integration to receive orders from Order Orchestration in order to fulfill the orders in Order Administration.
If the order is a retail pickup order or a retail pickup order that originated as a ship-for-pickup order, Order Administration ships the merchandise to the customer-selected store location for pickup.
If the order is a delivery order, Order Administration ships the merchandise to the customer’s ship-to address.
If the originating location was Order Administration: If the Use OROB for Fulfillment Assignment (M31) system control value is selected or the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, the order may have originated in Order Administration and during Brokered Backorders processing, Order Orchestration determined that Order Administration was the best fulfilling location. In this situation:
Order Orchestration assigns the Order Administration location to the originating order in Order Orchestration as the Fulfilling location. See Brokered Backorders for additional processing information.
At defined intervals, the BROKER process in Work with Integration Layer Processes (IJCT) periodically sends a fulfillments request message to Order Orchestration to poll for newly assigned orders (those whose Fulfilling location is an Order Administration location). See Retail Pickup (including Ship-for-Pickup) and Delivery Order Processing for additional processing information.
When the BROKER process receives the order in the fulfillments response message, it looks at the values in the fulfillments response to determine the type of order to create.
The system creates a new delivery order if the transaction_type_id is DELIVERY.
The system creates a new retail pickup order if the transaction_type_id is RETAILPICKUP or SHIPFORPICKUP.
See Building the Retail Pickup (including Ship-for-Pickup) or Delivery Order for additional information.
In order to tie the originating order (the original order sent to Order Orchestration for fulfillment assignment) with the new sourcing order (the delivery or retail pickup order created to fulfill the original order), Order Administration stores the originating order number in the E-commerce order number field in the Order Header Extended table for the newly created sourcing order and prefixes the order number with the text
ORIG#:. For example, the system updates the E-commerce order number withORIG#: 9999-001, whereORIG#: indicates the order has been created as a result of Order Orchestration fulfillment assignment,9999is the order number, and001is the ship-to number. See Reviewing Retail Pickup (including Ship-for-Pickup) or Delivery Orders in Order Inquiry for additional information.
In this topic:
Retail Pickup (including Ship-for-Pickup) or Delivery Processing after Order Creation
Things to Note about Retail Pickup (including Ship-for-Pickup) and Delivery Orders
For more information: See Reauthorization and Under Review Hold Scenarios for Orders Fulfilled through Order Orchestration.
Poll for orders? If both the Order Type for Orders Brokered for Delivery (K91) and Order Type for Retail Pickup Orders Brokered to OROMS (K92) system control values specify order types, the BROKER process in Working with Integration Layer Processes (IJCT) periodically sends a fulfillments request message to Order Orchestration to poll for newly assigned orders. The polling interval is based on the Outbound delay time specified for the BROKER process.
fulfillments request: Information in the fulfillments request message includes:
requesting location: From the OROB Default Location (K51) if the Send Inventory by Warehouse to OROB (L06) system control value is unselected; otherwise, from the OROB location from each warehouse that has this field populated. The requesting location must match an existing location set up in Order Orchestration.
message source and requesting system: From the OROB System (K50).
destination: From the OROB Account (K49).
See the Fulfillments Request Message Sample (Retail Pickup, Ship-for-Pickup, or Delivery Orders) in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for an example.
The endpoint where Order Administration sends the fulfillments request message is specified in Working with Customer Properties (PROP).
Create order? When the BROKER process receives an order in the fulfillments response message, it:
Checks the setting of the Retain Backordered Lines Brokered to OROMS (K89) system control value. If this value is unselected and there is not a purchase order that might be able to fulfill the order expected within the Order Broker Due Date Threshold (K11), the process rejects the order. The process uses the Send Inventory by Warehouse to OROB (L06) system control value to determine whether to check a specific warehouse, or to check across all warehouses.
Regardless of the setting of the Retain Backordered Lines Brokered to OROMS (K89) system control value, if the only item on the order is sold out, the process rejects the order.
Drop ship items are eligible to be fulfilled on a retail pickup or delivery order regardless of whether any units are currently stocked in the warehouse, provided they are not flagged with a soldout control value.
If a retail pickup or delivery order includes multiple order lines, and one of them is sold out, Order Administration still accepts the order. To avoid this situation, have integrating systems submit each order line as a separate order.
Multiple order lines? Submit each ordered unit to Order Orchestration as a separate order. Sending orders this way prevents any inconsistencies in order status that might occur if, for example, a multi-line order in Order Administration included a soldout item, but the other order lines could still be shipped from the warehouse, or if a multi-unit line was split across different warehouses for fulfillment.
The processing to build a new retail pickup or delivery order from the contents of the fulfillments response message is similar to that used by the generic order API. In addition to the system (company) and location (warehouse) sent in the fulfillments request message, the information used to build the order includes the following.
Header Information
order type: from one of the following system control values:
Order Type for Orders Brokered for Delivery (K91): the system assigns this order type to delivery orders whose originating location is not Order Administration.
Order Type for Retail Pickup Orders Brokered to OROMS (K92): the system assigns this order type to retail pickup orders whose originating location is not Order Administration.
Order Type for Delivery Orders Originating in OROMS (M33): the system assigns this order type to delivery orders whose originating location is Order Administration. The system identifies the originating location as Order Administration if the
request_system_cdin the fulfillments response message matches the system code in the OROB System (K50) system control value. -
Order Type for Retail Pickup Orders Originating in OROMS (M35): the system assigns this order type to retail pickup orders whose originating location is Order Administration. The system identifies the originating location as Order Administration if the
The
transaction_type_idin the fulfillments response message indicates whether the order is a retail pickup or delivery order.-
DELIVERY displays if the order is a delivery order.
RETAILPICKUP displays if the order is a retail pickup order.
SHIPFORPICKUP displays if the order is a retail pickup order that originated as a brokered ship-for-pickup order.
order channel (Internet order): set to C. The
transaction_channelspecified in the fulfillments response message is not used. -
alternate order number: from the order number in the originating system, passed as the
order_idfrom the fulfillments response (the external system’s order number). The system stores this number in the E-commerce order number field in the Order Header Extended table. If the originating location is Order Administration, the system prefaces the alternate order number withORIG#: 1234-001, whereORIG#: indicates the order was created as a result of OROB fulfillment assignment,1234is the order number, and001is the ship-to number.Note:
The system identifies the originating location as Order Administration if therequest_system_cdin the fulfillments response message matches the system code in the OROB System (K50) system control value. -
order date: the current date.
entered date: the current date.
source code:
If the order did originate in Order Administration:
Use the Order Broker Source Code (K93), if specified; otherwise, if this system control value is blank,
Use the source code, if any, specified for the store cross reference record for the originating location, which is based on the Originating Location to Pass to OROB (M32) system control value; otherwise,
Use the source code passed in the fulfillments response message from Order Orchestration, which would be from the originating order.
If the order did not originate in Order Administration:
Use the
source_code, if any, passed in the fulfillments response message from Order Orchestration; otherwise, -
Use the source code, if any, specified for the store cross reference record for the originating location; otherwise,
The order is created in error status because of the missing source code.
Customer Mapping and Updates
If the ORCE Customer ID in OROB Fulfillment (M72) system control value is NOT selected:
customer number:
if the
customer_nopassed in the fulfillments response is a valid customer number, then use this customer. For example, acustomer_noof13827or000013827indicates sold-to customer 13827. Zero-filling the customer number is optional. Otherwise, -
if the
customer_nopassed is invalid, or if nocustomer_nowas passed, then Order Administration uses standard name and address matching. See Customer Sold To Selection, Creation and Update in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more background.Note:
If thecustomer_nois invalid, the error is logged in Order Administration’sAPP.logfile, even though the order can still be created successfully using the name and address information in the message.
If the Sold to Email Update for Orders Brokered to OROMS (K96) or Sold to Address Update for Orders Brokered to OROMS (K97) system control values are selected, Order Administration updates the existing customer record with any changed information. -
email address updated? The Sold to Email Update for Orders Brokered to OROMS (K96) system control value indicates whether to update the customer’s email address with the email address passed for the order.
sold-to phone numbers: the
phone1passed updates the customer’s daytime phone number and thephone2passed updates the customer’s evening phone number if the Sold to Address Update for Orders Brokered to OROMS (K97)Sold to Address Update for Orders Brokered to OROMS (K97)Sold to Address Update for Orders Brokered to OROMS (K97)Sold to Address Update for Orders Brokered to OROMS (K97)Sold to Address Update for Orders Brokered to OROMS (K97)Sold to Address Update for Orders Brokered to OROMS (K97) system control value is selected. Any non-numeric characters passed in the phone numbers are stripped out.
If the ORCE Customer Integration (L37) system control value IS selected and the ORCE Customer ID in OROB Fulfillment (M72) is not selected:
customer number:
Matching customer number: if the
customer_nopassed in the fulfillments response is a valid customer number, then use this customer. For example, acustomer_noof13827or000013827indicates sold-to customer 13827. Zero-filling the customer number is optional.-
If the matching customer based on the customer number has an ORCE customer ID, update the customer and pass the update to Customer Engagement.
If the matching customer based on the customer number does not have an ORCE customer ID, update the customer and pass the update to Customer Engagement, then update the customer with the ORCE customer ID returned from Customer Engagement.
No matching customer number: if the
customer_nopassed is invalid, or if nocustomer_nowas passed, then Order Administration uses standard name and address matching. See Customer Sold To Selection, Creation and Update in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more background. -
Order Administration then passes the customer information to Customer Engagement, and updates the customer with the ORCE customer ID returned from Customer Engagement.
If the ORCE Customer Integration (L37) system control value IS selected and the ORCE Customer ID in OROB Fulfillment (M72) IS ALSO selected:
Matching customer based on ORCE customer ID: If the ORCE customer ID is passed as the
customer_no, and a customer with same ORCE customer ID is found, update the customer record if needed but do not send an update to Customer Engagement. -
No matching customer based on ORCE customer ID: If the ORCE customer ID is passed as the
customer_no, but no matching customer based on the ORCE customer ID is found, call out to Customer Engagement to get the customer information based on the ORCE customer ID, and create the customer in Order Administration based on the response from Customer Engagement. -
No customer_no passed: Order Administration uses standard name and address matching. See Customer Sold To Selection, Creation and Update in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more background.
Additional customer information updates if not matching based on ORCE customer ID:
sold-to name and address: the information passed in the fulfillments response message is used to create or update the customer; however, if the customer number passed in the fulfillments response is valid and the Sold to Address Update for Orders Brokered to OROMS (K97) system control value is unselected, the process does not update the customer information. If the customer does not already exist, the name is created in all upper case even if passed from Order Orchestration in upper and lower case.
apartment or address line 4:
If the apartment tag is passed, the first 10 positions are saved as the sold-to apartment number.
If no apartment tag is passed, but an address line 4 is passed, the first 10 positions of address line 4 are saved as the sold-to apartment number.
If both the apartment tag and address line 4 are passed, then the first 10 positions of the apartment are saved as the sold-to apartment number, as indicated above, and address line 4 is saved as the fourth address line for the sold-to customer.
phone1passed updates the customer’s daytime phone number and thephone2passed updates the customer’s evening phone number if the Sold to Address Update for Orders Brokered to OROMS (K97) system control value is selected. Any non-numeric characters passed in the phone numbers are stripped out.
Ship-to Information
ship complete? from the
ship_completesetting passed in the fulfillments response message; otherwise, from the Ship Complete for Orders Brokered to OROMS (L01) system control value. -
ship via: from the Order Broker Ship Via (K94) system control value if there is not a valid, numeric
ship_viapassed in the fulfillments response message. If the Order Broker Ship Via (K94) is blank, the Default Ship Via (A77) applies. -
gift order? from the Gift Flag for Orders Brokered to OROMS (L03). This system control value overrides the setting passed in the fulfillments response message.
freight charges: from the
freight_amountspecified in the fulfillments response message, if any; otherwise, Order Administration calculates freight. If an additional freight charge is specified for the ship via, Order Administration adds it to the order. -
tax: the total of the detail-level tax
amountpassed in the fulfillments response message for each item, plus any tax calculated based on freight and handling charges. The order-level tax amount passed in the message is not used to build the order. -
freight tax override: always selected, regardless of the setting of the Tax on Freight (B14) system control value.
purchase order number: from the
ref_transaction_nopassed in the fulfillments response message. Displayed at the Display Order Properties Screen in standard order inquiry and at the Third Streamlined Order Inquiry Screen (Order Summary). -
warehouse: If the Send Inventory by Warehouse to OROB (L06) system control value is selected, this is based on the OROB location for the warehouse sending the fulfillments request message.
delivery type (retail pickup or delivery): from the
transaction_type_idspecified in the fulfillments response message. SHIPFORPICKUP transaction types map to a retail pickup delivery type. -
ship-to name and address: from the
ship_toinformation for the first item on the order; the ship-to information for any additional item(s) is not used. Creates an Order Ship To Address record, which you can review at the Display Alternate Address Screen. The one-time ship-to phone number is from thephone1, if any, for the first item. If nophone1is passed for the first item, then thephone2for the first item is used. For a retail pickup order, the ship-to name and address should specify the name and address of the originating store location. The process creates a one-time ship-to address. If the customer does not already exist, the name is created in all upper case even if passed from Order Orchestration in upper and lower case. -
store location and system:
location_cd: the location fulfilling the order. This is the fulfilling, or sourced, location. For delivery and retail pickup orders, this is always an Order Administration warehouse. This is the Store # for the Store Cross Reference record.
system_cd: Order Administration. This is the OROB System (K50).
request_location_cd: the location generating the order. This is the originating, or placed, location. This can be a store location or an Order Administration warehouse if the original order was from Order Administration and was brokered for fulfillment assignment. This is the Store # for the Store Cross Reference record.
request_system_cd: If the order originated in a store, this is the code identifying your POS system, from the System Code, if any, for the Store Cross Reference record; otherwise, from the Name in OROB for Point of Sale (L09). If the order originated in Order Administration, from the System Code, if any, for the Store Cross Reference record; otherwise, from the OROB System (K50).
ship-for-pickup location and system:
location_cd: the store location where the customer picks up a ship-for-pickup order. This is the pickup location. From the Store # for the Store Cross Reference record.
system_cd: The code identifying your POS system, from the System Code, if any, for the Store Cross Reference record; otherwise, from the Name in OROB for Point of Sale (L09).
Detail Information
The process creates an order detail line for each item passed in the fulfillments response message. Also:
price: the
unit_pricefrom the fulfillments response message. Order Administration does not recalculate the price. -
price override reason code: from the Order Broker Price Override (K95) system control value.
requesting system line number: from the
requesting_system_line_nopassed in the fulfillments response message. Identifies the line number in the originating system. -
quantity: the
qtyfrom the fulfillments response message. -
gift wrap: from the
order_line_gift_wrapflag setting passed in the fulfillments response message. The gift wrap charge specified in the Item Offer, multiplied by the unit quantity, is included in the Handling bucket. -
order line messages: from the
order_line_messagepassed in the fulfillments response message:-
If the message passed exceeds the field length of 60 positions, the message is continued on an additional message line.
The Print flag for the message lines is set to B (both invoices and pick slips).
customization: customization is created for an order line only if:
the Item Offer associated with the source code on the order header specifies an additional charge code for a custom special handling format that includes a single line of customization instructions, and
the
customizationselement in the message specifies acustomization_codeandcustomization_messageIf:
there is no custom special handling format specified for the Item Offer, the information from the customization_code and customization_message are saved as Order Line Messages, with a Print flag of P (Picks), and the order is not suspended with an error.
the special handing format detail specifies any valid responses, and the customization message passed is not one of the responses, the order is suspended with an error of
Input not valid response -
the special handling format detail specifies a Max # characters, and the customization message passed exceeds this length, the order is suspended with an error of
Exceeds max character
Order Administration does not validate that the
customization_codematches the Field label for the special handling format detail. -
Custom special handling formats that include more than one detail line are not currently supported for retail pickup and delivery orders received from Order Orchestration.
Regardless of whether Order Administration creates custom special handling for an order line, any
order_line_customization_chargeis still applied to the Handling bucket on the order. -
The Evaluate Special Handling Charges by Order Line (D67) system control value determines whether to multiply the customization charge passed in the message by the unit quantity.
Tax amount: from the tax
amountpassed for the item in the fulfillments response message. Order Administration does not recalculate tax for items.
Only the tax amounts passed at the detail level are added to the order in Order Administration; thetransaction_tax from the fulfillments response message header level is not
used.
Payment Information
pay type: from the Order Broker Payment Type (K98).
credit card number: From the description of this pay type.
suppress deposit flag: set to Y.
suppress refund flag: set to Y.
The tender information, if any, passed in the fulfillments response message is not used.Order Messages
originating store location: written as an Order Message, for example:
Originating Store: 317. -
request ID: written as an Order Message, for example:
OROB Request ID: 123456. This information is also saved in the Order Orchestration record. -
special instructions: the
special_instructionsat the Order level from the fulfillments response message are written as an Order Message in capital letters, for example:ADD MONOGRAM HEB. -
additional order messages: the
order_messageis written as one or more Order Message lines:-
Special instructions passed at the item level in the fulfillments response message are not retained.See the Fulfillments Response Message Sample in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for an example.
Additional Information on Mapping
If any of the information passed in the fulfillments response message exceeds the maximum field length in Order Administration, the information is truncated.
The system identifies the originating location as Order Administration if therequest_system_cd in the fulfillments response
control value. In this situation, the system prefaces the E-commerce
order number in the Order Header Extended table with ORIG#: 9999-001, where ORIG#: indicates
the order was created as a result of OROB fulfillment assignment, 9999 is the order number, and 001 is
the ship-to number.
Not mapped: The following information is not mapped from Order Orchestration when creating the order in Order Administration:
order additional freight charges
order additional charges
the setting of the Under Review flag
order line extended freight
the setting of the order line Ship Alone flag
order line ship weight
item UPC or EAN codes
Response messages: After receiving the fulfillments response message, depending on whether it was able to create the order successfully:
order creation successful: The BROKER process sends a status update message with a status of Accepted.
order created on hold: The BROKER process sends a status update message with a status of Polled.
order in error: If the Re-Polling for Orders Brokered to OROMS (L04) system control value is:
selected: the BROKER process sends a status update message with a status of Polled
unselected: the BROKER process does not send a status update message
Also, if the order is in error, it is assigned to the Order Broker Error Batch Number (K90).
order cannot be created: If the BROKER process cannot create the order in Order Administration, it sends a status update with a status of Rejected.
Order Orchestration record: The process creates an Order Orchestration record regardless of whether the order is in error. The initial status of the Order Orchestration record is New if there are any errors; otherwise, it is In process.
Canceled by originating system? If the order is initially created in Order Administration in error status and then corrected, Order Administration sends an inquiry request to Order Orchestration before changing the order’s status to open. If the response from Order Orchestration indicates that the originating system has canceled the order, Order Administration then puts the order on hold and writes an order transaction history message, such as: Order held - line[s] canceled in Order B.
Changing the order in batch order entry: If the order is suspended or in error, you can use batch order entry to make changes to the order, although you cannot add an order line. Once the order is in held or open status, the restrictions described under Maintaining Retail Pickup or Delivery Orders from the Order Orchestration apply.
Checking for canceled or under review retail pickup or delivery orders during pick slip generation: Pick slip generation sends an inquiry to Order Orchestration for all retail pickup and delivery orders eligible for pick slips based on their current status, item availability, and the pick slip selection criteria, to determine whether an eligible order has been canceled in the originating system.
When the response indicates that an order is in canceled status, the program does not generate a pick slip for the order; instead, it puts the order on hold using the Order Broker Hold Reason (Cancel) (L02) system control value.
When the response indicates that an order is under review, the program does not generate a pick slip for the order; instead, it puts the order on hold using the AU hold reason (BROKER ORDER UNDER REVIEW).
Otherwise, Order Administration puts the Order Orchestration record into Picking status when the pick slip is printed and sends a status update message to Order Orchestration indicating that the order or line is in Picked status. Note that this occurs regardless of whether communication with Order Orchestration is successful when pick slip generation sends the inquiry.
Pick slip generation does not check that the sourcing location for the order is still set to an Order Administration location. For example, a user in Order Orchestration may have changed the sourcing location for the order to a location other than an Order Administration location. In this situation, Order Administration will still generate a pick slip for the order.Which status request message? Pick slip generation uses the order inquiry status request only if the Use OROB Status Inquiry List Web Service (M05) system control value is set to NO or blank; otherwise, it uses the order status list request. See Use OROB Status Inquiry List Web Service (M05) for details on how Order Administration confirms whether to generate a pick slip for retail pickup and delivery orders.
Streamlined allocation? If there are any retail pickup or delivery orders eligible for pick slip generation, the program can use streamlined allocation only when it uses the status list request. See Use Streamlined Allocation (L63) for background.
Sample messages: See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Shipment confirmation: Once the shipment is confirmed, the Order Orchestration record status changes to Intransit for a retail pickup order, or Completed for a delivery order. The corresponding statuses for the orders in Order Orchestration are Intransit and Fulfilled.
Status updates after shipment of a retail pickup order: Once the Order Orchestration record for a retail pickup is in Intransit Polled status, the order status in Order Administration is X (completed); however the requesting store location still needs to receive the order, notify the customer, and have the customer pick up the order.
Deactivating the payment method: When you ship a retail pickup or delivery order, the billing async job deactivates the payment method. Once the payment method is deactivated, you cannot process a refund against the order unless you add a new payment method.
Sending the ship via and tracking number to Order Orchestration: When you confirm shipment, the BROKER process sends a message to Order Orchestration. The information includes the description of the ship via used (even if it is different from the ship via on the order) and the tracking number, if available.
This information is available for review in Order Orchestration at the Order screen. The actual ship via used and tracking number used are displayed on the History tab.
Status inquiry: The BROKER process includes shipped retail pickup orders in order status inquiry list requests just once a day. The Order Orchestration record might be put in any of the following statuses:
Received: indicates that the originating store has received the transfer.
Completed: indicates that the customer has picked up the order.
Partially fulfilled: indicates that the customer has picked up part of the order.
See Setting the Daily Status Inquiry Time Window (all versions) for more information.
Other status updates after order creation:
Order Orchestration integration supports a business process in which only the originating location cancels a retail pickup or delivery order, since the customer is not necessarily aware that the distribution center can be involved in order fulfillment. As a result:
Sell out: If you sell out an order line, either in order maintenance or through the Process Auto Soldouts option, Order Administration sends a status update to Order Orchestration indicating the order or order line (based on whether you split orders) was Rejected. Order Orchestration then attempts to reassign the order or line to another location for fulfillment. The Order Orchestration record’s status in Order Administration changes to Rejected.
Cancel: If you cancel an order or order line, Order Administration changes the Order Orchestration record’s status to Canceled and sends a status inquiry request to Order Orchestration. If the order’s status in Order Orchestration is:
Canceled: Order Administration does not send a status update to Order Orchestration; otherwise,
If the order’s status in Order Orchestration is anything but Canceled, Order Administration sends a status update to Order Orchestration indicating the order was Rejected. In this situation, if Order Orchestration is configured to “reshop” the order and there are any other possible fulfilling locations, Order Orchestration reassigns the order to the next possible location based on the fulfillment rules set up in Order Orchestration, and the order returns to new order status; otherwise, if Order Orchestration cannot “reshop” the order, the order is assigned to the OROB Default Location Code for Unfulfillable Orders (K56), and the order status is unfulfillable.
You cannot cancel a partial quantity of an order line on a retail pickup or delivery order.
Although Order Administration does not prevent you from canceling a retail pickup or delivery order, some business processes require that only the originating location can cancel an order. In this situation, if the customer contacts the call center to cancel the order, the operator notifies the originating store location and requests that the store perform the cancellation and trigger the status update to Order Orchestration. Using this process, Order Administration receives notification of the cancellation the next time it sends a periodic status inquiry on the order to Order Orchestration, and then holds the entire order (even if only one line was canceled) using the Order Broker Hold Reason (Cancel) (L02). -
Voiding a pick slip for a retail pickup or delivery order: If the Cancel Reason (Pick In) (L86) system control value specifies a valid cancel reason or if a backorder cancellation reason code is specified in the CWPickIn XML Message, and you use the generic pick in API to void a pick slip for a retail pickup or delivery order, then Order Administration cancels the order and sends a status update to Order Orchestration to reject the order. Otherwise, if the system control value is blank, you need to use order maintenance to cancel the order and send the status update to Order Orchestration.
Rejecting the order: If you reject a batch that includes a retail pickup or delivery order, the BROKER process sends a status update rejecting the order; also, it deletes the related Order Orchestration and Order Orchestration History records.
Cancel reason sent? The status update message to reject a retail pickup or delivery order includes a cancel reason code and description if you:
cancel the order in order maintenance: the entered cancel reason is sent
void the pick slip: the Cancel Reason (Pick In) (L86) system control value is sent if a backorder cancellation reason code is not specified in the CWPickIn XML Message,
reject the batch that includes the retail pickup or delivery order: no cancel reason is sent
For more information: See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for a sample of the information sent to Order Orchestration when you cancel a retail pickup or delivery order.
In addition to reviewing information through the Working with Order Broker (WOBR) menu option, you can also use standard order inquiry. Your options include:
Finding the order number: Use the Order cross ref # at the Order Inquiry Scan Screen to find a retail pickup or delivery order based on the order number in the originating system. This number also displays as the Alt ord number at the Display Order Properties Screen. The system stores the originating order number in the E-Commerce order number field in the Order Header Extended table. If the originating system is Order Administration, the system prefaces the originating order number with the text
ORIG#:. For example:ORIG#: 9999-001, whereORIG#: indicates the order originated in Order Administration,9999is the original order number in Order Administration, and001is the ship-to number.Note:
To review all retail pickup and delivery orders whose originating system is Order Administration, you can enterORIG#: in the Order cross ref # field and select OK to advance to the Scan by Order Cross Reference # screen where all orders whose E-Commerce order number in the Order Header Extended table begin withORIG#: display. -
Originating order message: If the E-Commerce order number in the Order Header Extended table begins with the text
ORIG#:, indicating the originating system for a retail pickup or delivery order is Order Administration, the messageThis order is fulfilling another order: 9999-001displays for the sourcing order, where9999is the originating order number in Order Administration, and001is the ship-to number. This message displays on the Order Inquiry Header screen (OIOM), Order Inquiry Detail screen (OIOM), and in Streamlined Order Inquiry (DORI) for the sourcing order. -
Broker detail and history: Use the Display Order Broker Details Screen to review Order Orchestration Detail and Order Orchestration History, as well as other information such as the delivery type and the request ID.
Identifying the Order Orchestration type: In addition to the Display Order Broker Details Screen, you can also review the Broker delivery type at the Display Order Properties Screen and the Display Order Broker Details Screen to determine whether the order originated as a Retail Pickup or Delivery order.
Originating store, request ID, and special instructions: The originating store number and request ID are available for review at the Work with Order Messages Screen, for example:
Originating Store: 317OROB Request ID: 70122Also, if any special instructions were passed for the order, this information is also available for review at this screen.
Order history: The Display Order History Screen displays activity related to sending status updates to and from Order Orchestration, such as:
Ln#: 1 Ready for Fulfillment:Written for each line received on a retail pickup or delivery order when the order is accepted and put into Open or Held status. -
Ln#: 1 Selected for Fulfillment:Written for each line printed on a pick slip. -
Ln#: 1 Fulfilled:Written for each delivery order line when you confirm shipment. -
Ln#: 1 In Transit:Written for each retail pickup order line when you confirm shipment.Note:
After you ship a retail pickup order, Order Administration checks for status updates on a daily basis, and writes a single Order Transaction History message for each status change until the order is fulfilled. See Setting the Daily Status Inquiry Time Window (all versions) for setup information. -
Ln#: 1 Store Received:Written after the originating store location has received a retail pickup order. -
Ln#: 1 Customer Partial Pick Up:Written after the customer has picked up part of a retail pickup order. -
Ln#: 1 Customer Picked Up:Written after the customer has picked up all units of a retail pickup order. -
Ln#: 1 Cancel Acknowledged by Broker:Written when you cancel an order line in order maintenance or through Working with Backorders Pending Cancellation (WBPC). -
Ln#: 1 Rejected for Fulfillment:Written when Order Administration rejects an order line because the item is soldout or backordered; if you reject the order when it is suspended; or when you sell out a line afterward in order maintenance or through Processing Auto Soldout Cancellations (MASO). -
Order held - line[s] canceled in OROB:Written if Order Orchestration responds to a status inquiry indicating that any of the lines on the order were canceled. In this situation, Order Administration puts the order on hold using the Order Broker Hold Reason (Cancel) (L02).
Both system control values required: You need to complete both the Type for Orders Brokered for Delivery (K91) and the Order Type for Retail Pickup Orders Brokered to OROMS (K92) system control values in order for Order Administration to request new orders from Order Orchestration, even if you do not process both order types.
In addition:
if the Use OROB for Fulfillment Assignment (M31) system control value is selected, you need to complete the Order Type for Delivery Orders Originating in OROMS (M33) system control value in order for Order Administration to assign the correct order type to delivery orders created as a result of the Brokered Backorders process assigning an Order Administration warehouse to fulfill a brokered backorder.
if the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, you need to complete the Order Type for Retail Pickup Orders Originating in OROMS (M35) system control value in order for Order Administration to assign the correct order type to retail pickup orders created as a result of the Brokered Backorders process assigning an Order Administration warehouse to fulfill a brokered backorder on a ship-for-pickup order.
if the Send Inventory by Warehouse to OROB (L06) system control value is selected but the OROB location for a warehouse does not specify a valid location in Order Orchestration, the fulfillments request message is not generated.
Discounts: If the customer is eligible for a discount, such as one from a loyalty membership, Order Administration still applies the discount to a retail pickup or delivery order.’
Additional freight: If the ship via on the order is subject to additional freight charges, these charges are added to the order.
Gift flag: The setting of the Gift Flag for Orders Brokered to OROMS (L03) system control value overrides the setting of the gift flag passed in the fulfillments response message.
Outbound invoice message: If you generate the CWInvoiceOut message, the message is generated for retail pickup or delivery orders unless excluded based on trigger rules (for example, not including these order types).
Tax: The tax amount for each order detail line is passed as a tax override amount.
Customer matching: If the fulfillments response message from Order Orchestration does not specify a valid sold-to customer number, Order Administration uses its standard customer name and address matching to either select an existing customer or create a new customer.
Oracle Retail Customer Engagement customer integration: If you use the Customer Engagement Customer Integration, Order Administration may also new customer records in Oracle Retail Customer Engagement as part of creating retail pickup and delivery orders. See Building the Retail Pickup (including Ship-for-Pickup) or Delivery Order for more information.
Order maintenance: The Maintain Brokered Fulfillment Orders (B20) secured feature controls the ability to maintain a retail pickup or delivery order. Even if you have authority under this secured feature, your ability to maintain the order is limited. For example, you cannot add or change an order line. See Maintaining Retail Pickup or Delivery Orders from the Order Orchestration for a discussion.
Creating the invoice for a ship-for-pickup order: The Invoice Ship For Pickup Order Once Intransit (M73) system control value controls whether to create the invoice for a ship-for-pickup order when Order Orchestration indicates that the order is now in transit or received. See that system control value for more information.
If the payment method expires: If the payment method for an order expires, the system sends an update to Order Orchestration indicating to put the order Under Review. Also, if a fulfilling retail pickup order was created for the originating order, the order goes on hold, and any open pick slips are canceled.
Processing returns: If the Suppress Returns for Retail Pickup/Delivery (L88) system control value is:
selected: You cannot process a return against a retail pickup or delivery order, or create a return authorization
unselected: You can process a return against a retail pickup or delivery order or create a return authorization; however, the Order Broker Payment Type (K98) is deactivated when you ship a retail pickup or delivery order. As a result, in order to process a return against the order, you need to add a new payment method.
Regardless of the setting of the Suppress Returns for Retail Pickup/Delivery (L88) system control value, you cannot process an exchange against a retail pickup or delivery order, enter an item with a negative quantity, enter a negative additional charge, or apply a discount to a shipped order line.Order Administration does not send a status update to Order Orchestration when you process a return against a retail pickup or delivery order.
Membership items: You should not set up your Order Orchestration integration to include membership items on retail pickup or delivery orders, since the customer membership would not be created correctly in Order Administration. To prevent Order Administration from sending membership items to Order Orchestration as part of Order Orchestration’s Product, Product Location, and Incremental Inventory Import Process, do not flag them as OROB eligible.
Voiding or reprinting pick slips:
If you use Reprinting and Voiding Pick Slips (WVRP or WSVP) to void or reprint a pick slip for a retail pickup or delivery order, this activity does not produce a status update to Order Orchestration.
If you use the Generic Pick In API (Shipments, Voids, and Backorders) to void a pick slip for a retail pickup or delivery order and the Cancel Reason (Pick In) (L86) system control value specifies a cancel reason code, or if a backorder cancellation reason code is specified in the CWPickIn XML Message, Order Administration cancels the order using the specified cancel reason and sends a status update rejecting the order to Order Orchestration, including the cancel reason from the system control value.
Important:
To prevent inconsistent updates to Order Orchestration for retail pickup and delivery orders:-
Prevent Order Administration from generating multiple pick slips for a single retail pickup or delivery order:
Select the Ship Complete for Orders Brokered to OROMS (L01) system control value.
Do not create retail pickup or delivery orders for ship-alone items.
Do not select the Retain Backordered Lines Brokered to OROMS (K89) system control value.
Do not process void/unreserve transactions or partial backorders for these orders through the Generic Pick In API (Shipments, Voids, and Backorders); confirm or void the entire pick slip.
Retail pickup and delivery orders that originate in Xstore include a single item.Documents for store receiving: In order to support store receiving, you can generate the Pick Message from Order Administration (CWPickOut) or the PO Download XML Message (CWPurchaseOrderOut). Each of these messages includes details on the order, including the Order Orchestration request ID, the order number in the originating system, and the delivery type. See the Generic Pick Out API and the Generic Outbound Purchase Order API in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information.
Ship-for-Pickup Orders
Overview: You can use the ship-for-pickup option in the Order Orchestration Integration to send the merchandise for an order to a designated store, where the customer can pick it up. The Order Orchestration integration facilitates communication between Order Administration and the designated store location, so the store receives notification that the order is in transit, and sends notification back to Order Administration after the merchandise is received and when the customer picks up the order.
The items on the order do not need to be stocked in the store. In addition, the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value controls whether Order Administration fulfills the order or whether the order is sent to Order Orchestration for fulfillment assignment.
If this system control value is set to NEVER, Order Administration fulfills the order and sends the items on the order to the store selected for customer pick up. In this situation, if an item on the order is not in stock, the item is placed on backorder until it can be fulfilled by Order Administration. The order can include up to two locations for processing:
the originating, or placed, location that creates the order. For ship-for-pickup orders, the originating location is always an Order Administration warehouse.
the fulfilling, or sourcing, location that provides the inventory for the order. If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER, this is always an Order Administration warehouse.
the pickup location where the customer picks up the items on the order. For ship-for-pickup orders, this is always the store location the customer selected for pickup.
If this system control value is set to ALWAYS, the system sends the order to Order Orchestration for fulfillment assignment. In this situation, Order Orchestration determines the best location to fulfill the order and the order can include up to three locations for processing:
the fulfilling, or sourcing, location that provides the inventory for the order. If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS, this is the location Order Orchestration selected for fulfillment of the order. This location can be a store location or an Order Administration warehouse.
If Order Orchestration determines that Order Administration is the best location to fulfill the order, the system creates a new retail pickup order in Order Administration to fulfill the ship-for-pickup order; see Retail Pickup (including Ship-for-Pickup) or Delivery Orders
Important:
Regardless of when you send ship-for-pickup orders to Order Orchestration, in order to use ship-for-pickup processing, you must select the Enable Ship For Pickup option on the Organization window in Order Orchestration. Once you enable ship for pickup, the Ship for Pickup Enabled Date displays on the Organization window and this option cannot be changed.Examples: Examples of ship-for-pickup include the following.
Example 1 (three different locations):
The customer places an order on the web site (originating location A, Order Administration) and wants to pick the order up at store location B. Order Orchestration selects store location C as the fulfilling, or sourcing, location. Store location C ships the inventory to store location B, where the customer can pick it up.
Example 2 (fulfilling location and pickup location are the same):
The customer places an order on the web site (originating location A, Order Administration) and wants to pick the order up at store location B. Order Orchestration selects store location B as the fulfilling, or sourcing, location. Once the order is ready at store location B, the customer can pick it up.
Example 3 (originating location and fulfilling location are the same):
The customer places an order on the web site (originating location A, Order Administration) and wants to pick the order up at store location B. Order Orchestration selects warehouse location A, Order Administration, as the fulfilling, or sourcing, location. Order Administration ships the items on the order to store location B. Once the order is ready at store location B, the customer can pick it up.
Example 4 (originating location and fulfillment location are the same; items on the order are shipped to the store during pick slip generation/drop ship processing):
The customer places an order on the web site (originating location A, Order Administration) and wants to pick the order up at store location B. Order Administration fulfills the items on the order and during pick slip generation, ships the items on the order to store location B. Order Orchestration manages communication between Order Administration and store location B. Once the order is ready at store location B, the customer can pick it up.
Version compatibility: Fulfillment assignment and ship-for-pickup functionality is available in release 16.0 or higher of Order Management System, or Order Administration, and release 16.0 or higher of Order Broker, or Order Orchestration. Also, in order to use ship-for-pickup processing, you must select the Enable Ship For Pickup option on the Organization window in Order Orchestration. Once you enable ship for pickup, the Ship for Pickup Enabled Date displays on the Organization window and you cannot deselect this option.
An OROB_MESSAGE_VERSION of 16.0 or higher is required to use the Ship-for-Pickup Orders integration with Order Orchestration. Note that this property cannot be set higher than 19.9 for integration with Order Broker 19.x, or higher than 21.1 for integration with Order Broker 22.2.301.0 or higher, or Order Orchestration.
In this topic:
Creating a Ship-for-Pickup Order in Order Administration
You can create a ship-for-pickup order through interactive order entry, or through the order API.
A ship-for-pickup order should have a single ship-to.Creating a Ship-for-Pickup Order in Order Entry
Ship-for-pickup orders originate in Order Administration, either through order entry or through the generic order API. The order creation process is similar to that of a regular order, except that a ship-for-pickup order includes a one-time ship-to address representing the store location.
To select the store location in order entry:
Select the One Time Ship To option.
At the Create One Time Ship To Address Screen, select Store.
Select a store at the Store Location Screen. This screen displays each store location set up through Work with Store Cross Reference (WSCR) whose Ship for Pickup flag is selected. The description and address set up for the Store Cross Reference default to the Create One Time Ship To Address screen.
Complete entry of the order.
If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER, the system uses existing logic to reserve items in order to fulfill the ship-for-pickup order from an Order Administration warehouse. See Sending a Ship-for-Pickup Order to Order Orchestration during Pick Slip Generation and Drop Ship Order Processing.
If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS and the Send B/O to OROB (K08) system control value is selected, the system bypasses reservation and places all eligible items on backorder, even if the item is available in an Order Administration warehouse, in order to send all eligible items to Order Orchestration for fulfillment assignment; see Rules for Submitting Backorders to Order Orchestration. Order Orchestration will choose the best store location or Order Administration location to fulfill and ship the item to the store location selected by the customer for store pickup. See Brokered Backorders for processing details.
To avoid shipment problems, once you accept a ship-for-pickup order, the system does not allow you to change the store selected as the one-time ship-to address; in order to change the pickup store location, you must cancel the order and create a new ship-for-pickup order.Ship-alone items on ship-for-pickup orders: If an item is flagged as Ship alone, Order Administration does not let you enter an order line on a ship-for-pickup order with a quantity greater than one. If the customer wants more than one unit, enter a separate order line for each unit. This restriction applies even if the item is not flagged as OROB eligible.
Creating a Ship-for-Pickup Order through the Generic Order API
In the Inbound Order XML Message (CWORDERIN):
use the
store_codeattribute to specify the store location code. This needs to be a store location set up through Work with Store Cross Reference (WSCR), as described above for order entry. -
specify a
delivery_typeof S -
use the
ShipToelement in the Inbound Order XML Message (CWORDERIN) to specify the shipping address of the store, or leave the shipping name and address attributes blank in order to use the information set up in the Store Cross Reference record.For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Name and address for ship-for-pickup order: If the ship-to name and address fields are passed for a ship-for-pickup order, these fields should indicate the shipping address of the store selected for pickup; otherwise, if no ship-to name and address is passed, the information defaults from the Store Cross Reference record.
Partial ship-to address? The name or address fields from the Store Cross Reference record default for any fields not passed in the message.
Example: If the CWOrderIn message indicates the ship-to customer’s first and last name, this information defaults to the order, in addition to the company name and address from the Store Cross Reference record.
Communicating with Order Orchestration about a Ship-for-Pickup Order
Submitting the order to Order Orchestration: The setting of the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value controls when the order is submitted to Order Orchestration.
The system submits a ship-for-pickup order to Order Orchestration for fulfillment assignment when the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS and the Send B/O to OROB (K08) system control value is selected, and:
You create an order that contains an eligible item in interactive order entry or through the generic order interface (Order API).
You run the BROKER Periodic Function to find eligible items to send to Order Orchestration.
The system submits a ship-for-pickup order to Order Orchestration during pick slip generation or drop ship purchase order processing in the following scenarios.
When the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER or blank, or
When the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to ALWAYS but the Send B/O to OROB (K08) system control value is unselected.
See Sending a Ship-for-Pickup Order to Order Orchestration during Pick Slip Generation and Drop Ship Order Processing for processing details.
Submitting the order to Order Orchestration: The system submits a ship-for-pickup order to Order Orchestration when you generate the pick slip or drop ship purchase order in the following scenarios.
When the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER or blank.
At this time, the system also creates the Order Orchestration record displayed at the Work with the Order Orchestration Screen.
Which items are included in the Submit Order message? Only items that are flagged as OROB eligible are included in the message to Order Orchestration. However, all items that print on the pick slip or purchase order can be included in the shipment to the store location.
It is important to confirm that including additional items on the pick slip or purchase order and in the shipment will not present a problem to the store receiving the ship-for-pickup order.No items OROB eligible? If you create a ship-for-pickup that does not include any OROB eligible items, Order Administration does not submit the order to Order Orchestration or create an Order Orchestration record; however, you can still generate the pick slip or drop ship purchase order and ship the order to the store location for customer pickup. It is important to note that, in this case, the selected store does not receive advance notification of the order.
For more information on the contents of the message, see theOrder Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Submit separate orders for each order line? If the Create Separate Picks for Ship for Pickup Orders (L89) system control value is selected, Order Administration generates a separate pick slip or drop ship purchase order for each item, and as a result, submits each order line as a separate order to Order Orchestration. Creating separate orders in Order Orchestration can prevent confusion about order status if, for example, a single order line is canceled or fulfilled. See the Create Separate Picks for Ship for Pickup Orders (L89) system control value for more information.
What if Order Orchestration is unavailable? If Order Orchestration does not respond to the submit
order request during pick slip or drop ship purchase order generation,
Order Administration does not print the pick slip or purchase
order. Instead, it writes an order transaction history message: Submit Order Failed - OROB Unavailable. The order is eligible
for selection the next time you generate pick slips or drop ship purchase
orders.
Creating the Order Orchestration record: When the job generates the Submit Order request, it initially creates the Order Orchestration record in In Process status.
Message response: The Submit Order response message indicates whether Order Orchestration was able to create the order:
Order rejected? If Order Orchestration returns an error in the response message, Order Administration puts the order on hold using the Hold Reason for Errored Ship for Pickup Orders (L10). Order Orchestration might return an error if, for example, the order includes an item that does not exist in Order Orchestration or in the point-of-sale system associated with the store location. In this case, the Order Orchestration record in Order Administration is deleted and Order Transaction History indicates:
Submit Order Rejected/Order HeldRsn:PRODUCT NOT STOCKED IN REQUESTED LOCATION. -
Order accepted? If Order Orchestration accepts the order, the generation process sends a status update indicating a status of Picked. The process finishes and the Order Orchestration record remains in Picking status until you confirm shipment of the pick slip or purchase order.
The designated store location cannot reject a ship-for-pickup order.Sample message: See Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for a sample message and more information.
Fulfilling location in Order Administration vs. Order Orchestration:
When order submitted to Order Orchestration:
originating / placed location = the OACS warehouse shipping the merchandise to the store location.
fulfilling / sourced location = the OACS warehouse shipping the merchandise to the store location.
pickup location = the store location the customer selected for store pickup.
When store receives the merchandise or customer picks up the order: Once Order Administration receives a status inquiry response indicating that the store location has received the merchandise on the order, or that the customer has picked the order up, the store location is identified as the fulfilling location.
Excluded from brokered backorder processing: If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER, backordered items on ship-for-pickup orders are not eligible for processing through the brokered backorder integration with Order Orchestration.
Creating ship-for-pickup orders for drop ship items: When you create a ship-for-pickup order for a drop ship item, Order Administration submits the order to Order Orchestration when you use Selecting Vendors for Drop Ship Processing (MDSP).
There is no warehouse associated with a drop ship item, so in this case Order Administration designates the OROB Default Location (K51) as the requesting location. If you are generating ship-for-pickup orders for drop ship items, you need to specify a valid Order Orchestration location in this system control value; otherwise, Order Orchestration returns an error indicating that the requesting location is invalid.Documents for store receiving: In order to support store receiving, you can generate the Pick Message from Order Administration (CWPickOut) or the PO Download XML Message (CWPurchaseOrderOut). Each of these messages includes details on the order submitted to Order Orchestration, including the Order Orchestration request ID, the order number in the originating system, and the delivery type. See the Generic Pick Out API and the Generic Outbound Purchase Order API in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information.
Special Ship-for-Pickup Orders
In order to support processing special ship-for-pickup orders that originated in a retail location and then sent to Order Administration through the order API:
If the order type matches the Order Type for Special Orders (L15), the Submit Order message specifies the e-commerce order number, rather than the Order Administration order number, as the
order_id, so that the originating location can more easily identify and track the order. -
If the pay type matches the Pay Type for Special Orders (L16), the
balance_duespecified in the Submit Order message is the order total, indicating that the customer needs to pay for the order when picking it up. Otherwise, if the pay type on the order does not match this system control value, the Submit Order message does not specify a balance due, even if the order type matches the Order Type for Special Orders (L15).
See the Order Type for Special Orders (L15) and Pay Type for Special Orders (L16) system control values for more information.
If you use the Generic Pick In API (Shipments, Voids, and Backorders) to void a pick slip for a special ship-for-pickup order and the Cancel Reason (Pick In) (L86) system control value specifies a cancel reason code, or a backorder cancel reason is specified in the CWPickIn XML Message, Order Administration cancels the order using the specified cancel reason and sends a status update to Order Orchestration canceling the order.
Important:
To prevent inconsistent updates to Order Orchestration for special ship-for-pickup orders, do not process partial backorders for these orders through the Generic Pick In API (Shipments, Voids, and Backorders); confirm or void the entire pick slip.For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Collect Payment for a Ship-for-Pickup Order at the Store?
You can use the Payment at POS for Ship for Pickup Orders (L60) system control value to indicate that the customer pays for a ship-for-pickup order when picking up the order at the store, rather than billing the order when you ship it to the store from the warehouse. In this case:
The order must include only credit card payment methods; also, each pay type’s Card type must be set to Credit. No other card types, such as stored value cards, can be included.
The payment method’s Suppress deposit and Suppress refund flags are set to Y.
The payment method is authorized for $1.00 only during online authorization.
Authorization is suppressed during pick slip generation.
Order Administration sends the order total to Order Orchestration as the
balance_duein the Submit Order message.
The above restrictions do not apply to ship-for-pickup orders whose order type matches the Order Type for Special Orders (L15).Returns suppressed: Selecting the Payment at POS for Ship for Pickup Orders (L60) system control value suppresses most options for creating a return authorization, processing a return, and creating a refund. See that system control value for details.
Updates to a Ship-for-Pickup Order in Order Administration
Add an item? If you add an item to a ship-for-pickup order, or are able to ship a backordered item once you have generated the pick slip and created the ship-for-pickup order in Order Orchestration, the new item is not added to the original Order Orchestration record or to the order in Order Orchestration. Printing the pick slip for the new order line creates a new Order Orchestration record and a new order in Order Orchestration.
Voiding or reprinting a pick slip: Order Administration sends a status update to Order Orchestration if you void a pick slip for an order line on an existing ship-for-pickup order:
Special ship-for-pickup orders: If the Cancel Reason (Pick In) (L86) system control value specifies a cancel reason or if a backorder cancellation reason code is specified in the CWPickIn XML Message, and you void the pick slip for a special ship-for-pickup order through the generic pick in API, Order Administration cancels the order or line and sends a cancellation to Order Orchestration, including the cancel reason from the system control value. For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Also see Special Ship-for-Pickup Orders for background on these orders.
Regular ship-for-pickup orders: If the Create Separate Picks for Ship for Pickup Orders (L89) system control value is selected and you void the pick slip for a regular (not special) ship-for-pickup order, Order Administration does not cancel the order or line, but it does send a cancellation to Order Orchestration. No cancel reason is included in this case. This status update occurs regardless of whether you use the generic pick in API to void the pick slip, or void it at an Order Administration screen.
If you then reprint the pick slip for a regular ship-for-pickup order in this situation, Order Administration submits a new order to Order Orchestration; however, if you cancel the order after voiding the pick slip, no update is sent to Order Orchestration.
Aside from the two scenarios described above, Order Administration does not send a status update to Order Orchestration when you void or reprint a pick slip.
Canceling a ship-for-pickup order: Aside from the two scenarios, described above, which generate status updates for voided pick slips, Order Administration sends a status update to Order Orchestration when you cancel the order or item. In most cases, this status update includes the cancel reason you enter:
Cancel after voiding pick slip: If you cancel an item or the entire ship-for-pickup order in order maintenance after voiding the pick slip, and Order Administration has not already sent a status update when the pick slip was voided, it sends a status update that includes the cancel reason you enter. This situation can occur if, for example, you void a ship-for-pickup order through the Void/Reprint Picks menu option, or if you void a regular ship-for-pickup order with the Create Separate Picks for Ship for Pickup Orders (L89) system control value unselected.
Cancel drop ship purchase order in purchase order maintenance: If you cancel a drop ship purchase order in purchase order maintenance, Order Administration sends a status update that includes the Auto Soldout Cancel Reason (C20), since you do not have an opportunity to enter a cancel reason in this case.
Cancel drop ship purchase order sent to vendor through drop ship integration: To cancel items fulfilled through the drop ship integration, you need to use the Display P/O Drop Ship Screen in order inquiry. If you cancel a drop ship purchase order at this screen, and the purchase order is successfully canceled through the drop ship integration, it sends a status update that includes the cancel reason you enter.
Canceling single item cancels entire order in Order Orchestration: If you do not split orders and the pick slip creating the order in Order Orchestration included multiple items, canceling a single item in Order Administration results in canceling the entire order in Order Orchestration. This situation might occur if the Create Separate Picks for Ship for Pickup Orders (L89) system control value is not selected.
Canceling before order created in Order Orchestration: If you cancel the order before pick slip generation or drop ship purchase order generation, there is no need to notify Order Orchestration, since the order was never sent.
Cancel after shipment confirmation? Once you have confirmed shipment, it is not possible to cancel the ship-for-pickup order in Order Orchestration.
Ship-for-Pickup Order Processing on or after Shipment
Confirm shipment: When you confirm shipment of the pick slip, Order Administration changes the status of the Order Orchestration record and sends a status update to Order Orchestration with a status of Intransit, indicating that the order is on its way.
Additional processing:
When the assigned location sends a fulfillments request message to Order Orchestration to poll for newly assigned orders, it receives notification of the ship-for-pickup order.
The location assigned to a ship-for-pickup order cannot reject the order. -
The assigned store location sends the following additional status updates:
Received when the merchandise arrives at the store
Fulfilled (Order Administration status = Completed) when the customer picks up the order, or Partially fulfilled if the customer does not initially pick up the entire order
When Order Administration receives a status list inquiry response from Order Orchestration indicating that the merchandise was received at the store or that the customer has picked up the order, the fulfilling location on the Order Orchestration record in Order Administration changes from the warehouse shipping the order to the store location where the customer picks up the order. -
How Order Administration checks for additional status updates: Once you confirm shipment of the ship-for-pickup order to the store location, Order Administration includes the order in a status list inquiry request message once a day to Order Orchestration to check on whether the order has been received or picked up. See Setting the Daily Status Inquiry Time Window (all versions) for more information.
Returning a ship-for-pickup order: Selecting the Payment at POS for Ship for Pickup Orders (L60) system control value suppresses most options for creating a return authorization, processing a return, and creating a refund. See that system control value for details.
Reviewing a Ship-for-Pickup Order in Order Inquiry
In addition to reviewing information through the Working with Order Broker (WOBR) menu option, you can also use order inquiry. Your options include:
Identifying the Order Orchestration type: The Broker delivery type at the Display Order Properties Screen and the Display Order Broker Details Screen identifies a Ship for Pickup order.
Broker detail and history: Use the Display Order Broker Details Screen to review Order Orchestration Detail and Order Orchestration History.
Designated store: The Display Alternate Address Screen displays the store shipping address. You can advance to this screen by selecting the Ship To option from the header screen in order inquiry.
Ln#: 1 Selected for Fulfillment:Written for each line on a ship-for-pickup order printed on a pick slip and sent to Order Orchestration in the Submit Order Message. -
Ln#: 1 In Transit shipment:Written for each printed line when you confirm shipment. -
Ln#: 1 Accepted by Broker:Written when you receive the status inquiry request indicating that the location where the customer is picking up the ship-for-pickup order has been notified. -
Ln#: 1 Cancel Acknowledged by Broker:Written when you receive the status update response message following the cancellation of a ship-for-pickup order. This situation occurs if you void the pick slip after initially notifying Order Orchestration about the order. -
Ln#: 1 Store Received:Written when you receive the status inquiry response message indicating that the order merchandise has been received at the store where the customer will pick up the order. At this point, the fulfilling location on the Order Orchestration record in Order Administration changes from the warehouse shipping the merchandise to the store location where the customer picks up the order. -
Ln#: 1 Customer Partial Pick Up:Written when you receive the status inquiry response message indicating that the customer has picked up some, but not all, of the merchandise on the order. -
Ln#: 1 Shipped by Broker order:Written when you receive a status inquiry response message indicating that the customer has picked up the order in full.
If Order Orchestration returns an error: If Order Orchestration returns an error during pick slip generation, Order Administration writes Order Transaction History messages such as:
Rsn:INVALID ITEM (SYSTEM PRODUCT), ITEM
(PEN BLUE ) DOES NO
T EXIST. PRODUCT NOT STOCKED IN REQU
If the error occurs as a result of Selecting Vendors for Drop Ship Processing (MDSP), the messages might also indicate that the pick slip or purchase order was created, for example:
DROP SHIP PO# 1234567 CREATED.
However, in this situation the process does not produce the pick slip or purchase order.
If you submit a drop ship order and the OROB Default Location (K51) system control value does not specify a valid location in Order Orchestration, Order Orchestration returns an error during drop ship processing. In this case, Order Administration writes Order Transaction History messages such as:
Rsn:INVALID OR MISSING REQUESTING LOCATI
ON LOCATION CODE, (STORE_LOCATION.LO
CATION_CD) IS REQUIRED.
Store Pickup Orders
Overview: You can create a store pickup order if the customer prefers to pick up an order from a retail location where the inventory is already available rather than waiting for a shipment from the warehouse. Unlike ship-for-pickup orders, store pickup orders do not require you to transfer the inventory from a warehouse or other store location; instead, the customer selects a location that already has the ordered quantity of all the items in stock.
In this topic:
Store Pickup Order Creation Overview
Store Pickup option: You can create a store pickup order by selecting the Store Pickup option at the Work with Order Lines Screen (Adding Items to the Order) after entering the items on the order. The Store Pickup option is available only if the Use Merchandise Locator (I38) system control value is selected and the Store Pickup Order Type (L33) system control value specifies an order type. Also, this option is available in order entry only, not in order maintenance.
Requirements: You cannot select the Store Pickup option if the order includes any items that:
are not flagged OROB eligible
are flagged for special handling or have the Gift wrap flag selected
are held
are sold out
Also, the order must:
not include more than one ship-to
not be a ship-for-pickup order
What if the order is held? Order Administration submits a store pickup order to Order Orchestration regardless of whether the order is held; however, if the order is held and the Payment at POS for Store Pickup (M16) system control value is unselected, Order Administration submits the order to Order Orchestration with the Under Review flag selected. This setting indicates that the order should not be picked up until the Under Review flag is cleared, because Order Administration needs to be able to collect payment, but enables the store associates with the opportunity to reserve the inventory and prepare the order in the meantime. When the order is released from hold, Order Administration sends the order status update message, indicating to clear the Under Review flag.
See the Payment at POS for Store Pickup (M16) system control value for a discussion.
Searching for locations: When you select the Store Pickup option on a qualifying order, you advance to the Merchandise Locator Search Window (Store Pickup) so that you can find a store location near the customer’s location where the items are available. Optionally, you can specify a different location or change the search radius. See the Merchandise Locator Search Window (Store Pickup) for more information.
The Order Orchestration Routing Engine supports merchandise locator searches only in the U.S. and Canada.LocateItems request and response messages: Order Administration sends the LocateItems request message to Order Orchestration. This message specifies the items on the order, the customer’s location, and the search radius.
Selecting a location: After you complete the Merchandise Locator Search Window (Store Pickup), you advance to the Store Pickup Search Results Screen. This screen lists locations that:
were included in the LocateItems response message, indicating that the location is flagged as Pickup available in Order Orchestration, it stocks the item(s) on the order, and
have records in the Store Cross Reference table, set up through the Work with Store Cross Reference (WSCR) option.
See the Store Pickup Search Results Screen for more information.
When you select a location at this screen, Order Administration:
flags all Order Detail lines with a Pickup type of SP
updates the Pickup location ID and Location system ID with the selected location code and the System Code, if any, from the Store Cross Reference record; otherwise, from the Name in OROB for Point of Sale (L09).
sets the Delivery type field in the Order Ship To table to P
Requirements to accept the order: When you accept the order, Order Administration verifies that:
the order has a credit card payment method, and no other pay types
all lines on the order are flagged for store pickup and do not include any special handling or gift wrap charges
If you have changed the quantity on an order line or added any new items to the order, you need to select the Store Pickup option again before you accept the order.Also, the customer must have:
an email address, and
the opt-in/out flag for the email address set to O1 (all emails) or O2 (order-related emails).
The email address and opt-in/out setting are required so that Order Administration or Order Orchestration can notify the customer by email when the order is ready for pickup at the designated store location. See Store Pickup Notifications for more information on a notification you can have Order Administration generate; however, the Store Connect module uses a notification email generated by Order Orchestration. See the Order Orchestration online help for more information.
Updates at accept: At acceptance, Order Administration performs additional updates to order-related tables:
Order Detail:
Drop ship flag set to D
Printed quantity set to the ordered quantity
Reserved quantity, Backorder quantity, and Backorder warehouse set to zero
Order Ship To:
Freight and Freight balance, if any, set to zero and the Calculate freight flag set to N if the Calculate Freight for Store Pickup Orders (L32) system control value is unselected
Order Header: Order type set to the Store Pickup Order Type (L33). If the Store Pickup Order Type (L33) is not flagged for online authorization, this change prevents Order Administration from sending the payment method out for authorization
Order Ship To Address: creates a record using the information set up through the Work with Store Cross Reference (WSCR) option; however, if you entered a name or apartment/suite, or selected a permanent ship-to number, this information is retained
Order Payment Method: If the Payment at POS for Store Pickup (M16) is:
selected:
the payment method is authorized for $1.00
the Suppress deposit flag set to Y, so that the deposit is not processed in Order Administration when the order is billed
the
balance_duespecified in the SubmitOrder message is equal to the order total
unselected:
the payment method is authorized for the full amount
the Suppress deposit flag is set to N, so that the deposit is processed in Order Administration when the order is billed
the
balance_duespecified in the SubmitOrder message is zero
Sending the SubmitOrder request to Order Orchestration: When you accept a store pickup order, Order Administration sends a SubmitOrder request to Order Orchestration. See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information.
When Order Administration receives the SubmitOrder response
message from Order Orchestration, it sets the Order Orchestration record
in Acknowledged status and writes an Order Transaction History
message on the order: Submit Order Succeeded. This
message indicates that the order was created successfully in Order
Orchestration, not that the selected location has already accepted
the order. The system also updates the line number(s) in the Order
If the order is not held, or if the Payment at POS for Store Pickup (M16) system control value is selected, Order Administration does not select the Under Review flag when submitting the order, so the order is eligible for pickup.
When a store pickup order is released from hold, Order Administration sends an update to Order Orchestration indicating to clear the Under Review flag. See the Order Update Request sample in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information.
Purpose: Use this window to enter the search criteria when selecting a store location where the customer can pick up all the items on the order. See Store Pickup Orders for background.
How to display this screen: Select Store Pickup at the Work with Order Lines Screen (Adding Items to the Order) after entering the items on the order. The Store Pickup option is available only if:
you are in order entry, and not order maintenance
you are entering the first and only ship-to on the order
have special handling instructions or have the Gift wrap flag selected
are held (however, if the order itself is held after acceptance, Order Administration still submits it to Order Orchestration for fulfillment)
include at least one item that is not sold out
This window is very similar to the Merchandise Locator Search Window (Searching for an Item) you use for informational merchandise locator searches for a single item. See Merchandise Locator API for background on merchandise locator searches.Important:
Order Broker and Order Orchestration support merchandise locator searches only within the U.S. and Canada.| Field | Description |
NOTE
Postal code |
The customer’s U.S. zip or Canadian postal code, to serve as the central point for the search radius. For example, if the Search within field is set to 25 miles, the search includes stores within 25 miles of this postal code. NOTE: Your entry in this field is not validated against the Zip/City/State table. Alphanumeric, 10 positions; required if you do not enter a city and state. |
Address |
The customer’s street address, to serve as the central point for the search radius. Alphanumeric, 32 positions; optional. |
City |
The customer’s city, to serve as the central point for the search radius. Alphanumeric, 25 positions; required if you do not enter a postal code. |
State |
The customer’s U.S. state or Canadian province, to identify the location of the city. Alphanumeric, 2 positions; required if you do not enter a postal code. |
Country |
The customer’s country. The country defaults from the customer address if you advanced to this window from order entry or order maintenance; otherwise, it defaults from the Default Country for Customer Address (B17) system control value. Defined in and validated against the Country table; see Setting Up the Country Table (WCTY) for more information. Alphanumeric, 2 positions; required. |
Search within |
Indicates the search radius, in miles or kilometers, to search within for the selected item. The search radius defaults from the Default Search Within Radius (I40) system control value, but you can override it. NOTE: The distance unit of measure (miles or kilometers) specified with the Merchandise Locator Distance Measurement (I39) system control value is to the right. Numeric, 5 positions; required. |
Completing this window:
Optionally, override the postal code or the city and state to serve as the central point for the search radius.
Optionally, override the Search within radius to a different distance.
Click OK. Order Administration generates the LocateItems request message. When it receives the LocateItems response message, you advance to the Store Pickup Search Results Screen.
Troubleshooting: If you cannot display this window, or if the screen displays an error message after you attempt to search, see Troubleshooting Creation of Store Pickup Orders and Things to Note for help.
Purpose: Use this screen to select a store location for the customer to pick up all the items on the order.
Which locations listed? This screen lists locations that:
Have records set up through the Work with Store Cross Reference (WSCR) option, and
Were returned in the Locateitems response message from Order Orchestration, indicating that:
They are within the search radius specified at the Merchandise Locator Search Window (Store Pickup)
Have the requested quantity of all items on the order in stock
Are flagged in Order Orchestration as Pickup available
Were not eliminated from the search results due to probability rules in Order Orchestration
Were not eliminated from the search results because the number of eligible locations exceeded the Maximum No. Responses specified in Order Orchestration.
A distance of zero indicates that the location is not flagged to Use proximity locator in Order Orchestration. In this case, the location is always eligible to be included in the search results if it is also flagged as Pickup available, if it has the requested quantity of the items on the order, and if there is a Store Cross Reference record set up in Order Administration.Troubleshooting:
Only store locations that have Store Cross Reference records are eligible for display at this screen. See Work with Store Cross Reference (WSCR) for background.
See Troubleshooting Creation of Store Pickup Orders and Things to Note for possible error messages.
Updates when you select a store location: When you select a location, Order Administration updates all Order Detail records:
Sets the Pickup type for each item to SP
Updates the Pickup location ID with the code of the selected location
Updates the Location system ID with the System Code, if any, from the Store Cross Reference record; otherwise, from the Name in OROB for Point of Sale (L09)
For more information: See Store Pickup Orders for an overview, including details on information required before you can accept a store pickup order.
How to display this screen: Complete the Merchandise Locator Search Window (Store Pickup).
Although the information at this screen is from the location record in Order Orchestration, when you accept a store pickup order Order Administration uses the Store Cross Reference record to create the Order Ship To Address for the order.| Field | Description |
Store |
Select the store location where the customer would like to pick up the order. The store information consists of: Store code The code identifying the store location in Order Orchestration and in the Store Cross Reference table. Alphanumeric, 10 positions. Store name The name of the store location from Order Orchestration. If the name exceeds 35 positions, it is truncated. Alphanumeric, 35 positions. Street The street address of the store location from Order Orchestration. If the street address exceeds 40 positions, it is truncated. Alphanumeric, 40 positions. City The city of the store location from Order Orchestration. If the city name exceeds 35 positions, it is truncated. Alphanumeric, 35 positions. State The state of the store location from Order Orchestration. Alphanumeric, 2 positions. Postal code The postal code of the store location from Order Orchestration. Alphanumeric, 10 positions. Country The country of the store location from Order Orchestration. Alphanumeric, 3 positions. Phone number The phone number of the store location from Order Orchestration. If the phone number exceeds 14 positions it is truncated. Alphanumeric, 14 positions. |
Distance |
The number of miles or kilometers, based on the Merchandise Locator Distance Measurement (I39), from the search location. This distance might be approximate, depending on the actual criteria used to search (for example, postal code or city), and does not represent an actual driving distance. No distance is displayed if the location is not set up in Order Orchestration to use proximity rules. In this situation, the location is always considered to be within the specified search radius. Also, no distance is displayed if the store location and the search location are in the same zip or postal code. The distance is rounded down when determining whether to include the location in the search results. For example, if the Search radius is 10 miles, and the location is 10.84 miles away, the location is included in the results. The distance is shown if the location is shown.
The location is shown when:
Numeric, 7 positions with a 2-place decimal. |
Status Inquiry and Updates after Creation
Overview: Once Order Administration submits the order to Order Orchestration, it begins including the order in periodic status inquiry list requests to determine when:
the selected store location polls Order Orchestration for new orders and is notified about the order
the location accepts or rejects the order
the customer picks up the order, either partially or completely
potentially, the customer cancels the order at the store location
How often? The BROKER process in Working with Integration Layer Processes (IJCT) sends periodic status inquiry list request messages to Order Orchestration for store pickup orders:
If the current status of the Order Orchestration record in Order Administration is Acknowledged, Polled, or Accepted, the process uses the Order Broker Status Update Interval (K10) to determine how often to request an update.
If the current status is Partially Fulfilled, the process sends the message once a day. See Setting the Daily Status Inquiry Time Window (all versions) for background.
Updates based on status inquiry responses: Order Administration initially creates the Order Orchestration record in Acknowledged status, indicating that Order Orchestration has received notification of the order and assigned it a request ID. The following table summarizes the updates that take place in Order Administration based on the current status indicated in the response message from Order Orchestration.
| Status in Update Response from OOCS | Status of Order Orchestration record in OACS | Additional Updates |
Polled |
Polled |
None |
Accepted |
Accepted |
None |
Picked |
Accepted |
None |
Partial Fulfill |
Partially Fulfilled |
None |
Fulfilled |
Completed |
Unfulfillable |
Rejected |
Order Administration cancels the order using the Cancel Reason (Rejected Store Pickup Orders) (G11) and writes Order Transaction History messages such as the following:
An Order Transaction History message such as the above is written for each line on the order. |
Canceled |
Canceled |
If the status in Order Orchestration is Verified or Processed, Order Administration does not update the status of the Order Orchestration record.Sample messages: See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Other ways to update store pickup orders? After you create a store pickup order, maintenance to the order is prohibited. The only possible update you can make within Order Administration is to cancel the order; see Canceling a Store Pickup Order.
Notifying the Customer that the Store Pickup Order is Ready
If the order is assigned to a Store Connect location, you can configure Order Orchestration to generate its own pickup notification email. See the Order Orchestration Web Services Guide on https://support.oracle.com (ID 2953017.1) or the Order Orchestration online help for more information.
Your point-of-sale system can use the CWEmailRequest message to request that Order Administration generate Store Pickup Notifications. The notification indicates that the customer’s order is ready for pickup in the designated store location.
See Store Pickup Confirmation Email Program (L48) and the Store Pickup Notification Sample and Contents for more information.
This program is not used for Store Connect. If the order is assigned to a Store Connect location, you can configure Order Orchestration to generate its own pickup notification email. See the Order Orchestration Web Services Guide on https://support.oracle.com (ID 2953017.1) or the Order Orchestration online help for more information.Store Pickup Order Fulfillment
When Order Administration receives a status list response message from Order Orchestration indicating that a store pickup order is in Fulfilled status, it:
Changes the status of the Order Orchestration record to Completed (X).
Submits the order to the BILL_ASYNC job.
Clears the Drop ship flag on the order details.
Deactivates the payment method(s).
If the Payment at POS for Store Pickup (M16) is selected, sets the Suppress deposit flag for the order payment method to Y, so that the deposit is not processed in Order Administration when the order is billed; otherwise, the Suppress deposit flag is set to N, so that the deposit is processed in Order Administration.
Clears the hold reason(s), if any, on the order.
Writes Order Transaction History messages such as:
Ln#1: Shipped by Broker
CC DEPOSIT BYPASSED ON INVOICE # 1234567
Pick# 0000000 Billed on Invoice# 1234567
For more information: See Fulfillment Process: After Order Creation and Status Updates for details on additional updates at fulfillment, including invoice creation.
Creating a Store Pickup Order through the Order API
Overview: You can create a store pickup through the order API by specifying:
a
delivery_typeof P -
the
store_codeidentifying the store location where the customer would like to pick up the order
Other requirements: Creating a store pickup order through the order API is subject to the same requirements described under Store Pickup Orders.
Freight calculation: The Calculate Freight for Store Pickup Orders (L32) system control value does not apply to the order API. To prevent
freight from applying to a store pickup order, the CWOrderIn message
can include the calc_frt attribute set to N;
otherwise, normal freight calculation applies.
Ship-to address: As in interactive order entry, the order API uses the Store Cross Reference record to create the Order Ship To Address for the order. If the CWOrderIn message included any ship-to name and address information, only the name and apartment/suite number (and permanent ship-to number, if any) are retained on the order.
The order API does not prevent the creation of multiple shipping addresses for a store pickup order; however, you should avoid submitting such orders through the order API to prevent errors in order processing.CWORDEROUT message: If the response_type in the CWOrderIn message indicates to
return a detailed response, the CWORDEROUT response message includes
the following information related to a store pickup order:
ShipToelement:-
delivery_typeis Store Pickup -
ship-to name and address is from the Store Cross Reference record for the selected store location
Detailelement:-
pickup_typeis SP -
pickup_system_locationis from the System Code, if any, for the Store Cross Reference record; otherwise, from the Name in OROB for Point of Sale (L09) -
pickup_locationis the selected location’s store code from Order Orchestration and the Store Cross Reference record -
broker_statusis Acknowledged if the SubmitOrder message was successfully processed by Order Orchestration; otherwise, thebroker_statusis not included
Errors: In addition to the normal edits that take place in the order API, the following errors can apply to store pickup orders:
HDR errors:
Invalid Store Code= Thestore_codeis invalid, or nostore_codewas specified. If the message specified an invalid store code that is not in the Store Cross Reference table, additional errors related to the ship-to address are included (such as Invalid Ship To Address, State Blank, City Blank, and so on) -
Invalid Delivery Type= thedelivery_typewas not P (store pickup) or S (ship-for-pickup) -
Email Missing/Ineligible= The customer does not have an email address, or the customer’s opt-in/out setting is not O1 (all emails) or O2 (order-related emails). The email address and opt-in/out setting are required so that Order Administration can generate the store pickup notification email when the order is ready for pickup at the designated store location. See Store Pickup Notifications for more information.
DTLS errors:
Ineligible for Store Pick= The order does not meet the requirements for a store pickup order, such as an invalid pay type; see Store Pickup Order Creation Overview -
Store Fulfillment Loc Msg= Included if there is nostore_codespecified -
Store Fulfillment Subscription= Included if the order included a subscription item -
Store Fulfillment Membership= Included if the order included a membership item
If there are any errors on the order, Order Administration does not submit it to Order Orchestration. You can use batch order entry to correct the errors and submit the order for store pickup.
Order type change: The order type does not change to the Store Pickup Order Type (L33) until after the order is submitted for online authorization.
For more information: See:
Generic Order Interface (Order API)
Reviewing a Store Pickup Order in Order Inquiry
Identifying a store pickup order in order inquiry: The following information identifies a store pickup order in order inquiry:
Order properties: The Delivery type at the Display Order Properties Screen and the Display Order Broker Details Screen is Store Pickup.
Order detail: The line is flagged with a status of SPU at the Order Inquiry Detail Screen, and the Printed quantity is the same as the ordered quantity. You can select D/S Status for a single line at the Order Inquiry Detail Screen to advance to the Display Order Broker Details Screen, where you can review details and history for the order line.
Order type: The order Type on the Order Inquiry Header Screen matches the Order Type for Retail Pickup Orders Brokered to OROMS (K92).
Order ship to address: The ship-to name and address at the Display Alternate Address Screen defaults from the Store Cross Reference record for the selected store location.
Broker detail and history: Use the Display Order Broker Details Screen to review Order Broker Detail and Order Broker History.
Reviewing Order Transaction History messages: The following table provides sample Order Transaction History messages and their explanations. You can review these messages at the Display Order History Screen.
| Order Transaction History Message(s) | Explanation |
Communication with Order Orchestration is not available, or the Order Orchestration application is not active. Order Administration saves the information about the order in the Store Pickup tables, and attempts to submit the order to Order Orchestration the next time you start the BROKER_ORD process. |
Order Administration submitted the order to Order Orchestration. |
Order Orchestration created the order and responded with the request ID. NOTE: A similar message is included for each line on the order. |
Order Orchestration responded to a status inquiry and indicated that the selected location has accepted the order. NOTE: A similar message is included for each line on the order. |
Order Administration generated the store pickup notification email to the customer, indicating that the order is ready for pickup at the designated store location. The email address may be truncated if the entire message exceeds 30 positions. See Store Pickup Notifications for more information. |
Order Administration could not generate the store pickup notification. Possible reasons are:
If Order Administration could not generate the store pickup notification for any other reason (for example, if the order is closed or canceled), no Order Transaction History message is written. NOTE: This notification is not used by the Store Connect module. See Store Pickup Notifications for more information. |
Order Orchestration responded to a status inquiry and indicated that the customer has picked up part of the order from the selected location. NOTE: A similar message is included for each line on the order. Order Orchestration does not indicate which line(s) have been picked up and which have not. |
Order Orchestration responded to a status inquiry and indicated that the customer has picked up the entire order from the selected location. NOTE: The first message line is included for each line on the order. |
Order Orchestration responded to a status inquiry and indicated that the selected location has rejected the order. In this situation, Order Administration cancels the order, using the Cancel Reason (Rejected Store Pickup Orders) (G11). NOTE: The last message line is included for each line on the order. |
Order Orchestration responded to a status inquiry and indicated that the selected location has rejected the order; however, the Cancel Reason (Rejected Store Pickup Orders) (G11) system control value is blank, so Order Administration could not cancel the order. |
Order Orchestration responded to a status inquiry and indicated that the order has been canceled at an external location, typically the location selected for pickup. In this situation, Order Administration cancels the order, using the Cancel Reason (Rejected Store Pickup Orders) (G11). NOTE: The last message line is included for each line on the order. |
You canceled the order in order maintenance, and the status update message was sent to and acknowledged by Order Orchestration. NOTE: The last message line is included for each line on the order. |
Order Orchestration was not able to create the order, because the selected location was not set up correctly in Order Orchestration. In this situation, Order Administration cancels the order, using the Cancel Reason (Rejected Store Pickup Orders) (G11). |
Order Orchestration was not able to create the order, because the SubmitOrder request message from Order Administration to create the order did not specify a valid location associated with a valid system code in Order Orchestration. Check the System Code, if any, from the Store Cross Reference record, or the Name in OROB for Point of Sale (L09), and confirm that the code sent to Order Orchestration is a valid system code associated with the store location code. |
You can also review information about the order through the Working with Order Broker (WOBR) option.
Canceling a store pickup order in order maintenance: You cannot maintain a store pickup order, although you can cancel it in order maintenance if you have authority under the Cancel Order Broker Lines (B19) secured feature:
If you do not have authority under the secured feature, when you select a store pickup order for maintenance a pop-up window indicates:
Not authorized to maintain brokered order. -
If you have authority under the secured feature, when you select a store pickup order for maintenance a pop-up window indicates:
This is a Store Pickup order and can only be canceled!-
If you click OK, you advance directly from this pop-up window to the Confirm Cancel window.
If you click OK at the Confirm Cancel window, you advance to the Enter Cancel Reason Window.
If you complete the Enter Cancel Reason window, Order Administration cancels the order.
Hold reason(s) removed: When you cancel a store pickup order, Order Administration removes the hold reason(s), if any, on the order.
Notification to Order Orchestration: After you cancel a store pickup order, Order Administration changes the Order Orchestration record’s status to Pending Cancel, and then to Canceled once the BROKER_ORD job has sent the status update message to Order Orchestration and received the response. The status update includes the cancel reason you entered at the Enter Cancel Reason window. When it processes the response, Order Administration writes Order Transaction History messages such as:
Order was maintained
A line-specific message such as in the above sample is written for each line on the order.
See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for a sample.
Notification timing: The BROKER_ORD process in Working with Integration Layer Processes (IJCT) uses its Outbound delay time to determine how often to “wake up” and start evaluating Order Orchestration records. If it finds orders in Pending Cancel status, it generates the status update immediately and does not wait for the entire Order Broker Status Update Interval (K10).
Example: The Outbound delay time for the BROKER_ORD process is 60 seconds. When you start the process, it sends status updates for any orders in Pending Cancel status, then evaluates whether to send any other request messages based on the Order Broker Status Update Interval (K10). Once it has evaluated all orders in all companies, it then waits 60 seconds before restarting the process of checking for orders in Pending Cancel status and evaluating whether to send inquiry request messages for orders in other statuses.
Order Administration does not verify the pickup order’s current status in Order Orchestration before processing the cancellation.
Although the BROKER_ORD process generates the submit order requests (and cancellation requests, if needed), the BROKER process handles other requests to Order Orchestration.Receiving a Store Pickup Cancellation from Order Orchestration
If the customer cancels the order, or an item on the order, at a retail location, Order Administration receives the cancel status update when it sends a periodic status inquiry list request and receives the response. In this situation, Order Administration cancels the order or item using the Cancel Reason (Rejected Store Pickup Orders) (G11); also, it writes Order Transaction History such as:
Web cancel request processed.
Ln#: 1 Canceled by Store
A line-specific message such as in the above sample is written for each canceled line on the store pickup order.
The Cancel Reason (Rejected Store Pickup Orders) (G11) system control value must specify a valid cancel reason in order to correctly cancel an order or item based on messages received from Order Orchestration.
Canceling individual lines is supported only if the Use Split Order (L56) system control value is selected, and the corresponding preference is selected in Order Orchestration. See Order Orchestration Configuration and the Order Orchestration online help for background.
| Issue or Note | Explanation or Solution |
Merchandise locator searching: errors |
Optionally, you can:
The postal code or location specified at the search window were not found in the Order Orchestration proximity database. |
This item is not flagged as OROB eligible. If multiple items on the order are not flagged as OROB eligible, the error message lists just the first one on the order. |
The Order Orchestration application is not active. |
Merchandise locator searching: things to note |
The item is listed as available in a particular location in Order Orchestration, but the location is not included at the search results screen |
Can occur if:
Note: The Merchandise Locator option for individual order lines does not require a Store Cross Reference record in order to include a location at its search results screen. As a result, if you use both options there is a possible discrepancy between the results listed at the Merchandise Locator Search Results Screen and those available for selection at the Store Pickup Search Results Screen. |
Order acceptance: errors |
The Work with Order/Recap screen displays this error if there are any payment methods on the order are not credit cards. |
The Work with Order/Recap screen displays this error if any items have been added to the order since you selected a store location at the Store Pickup Search Results Screen. To correct, go back to the Work with Order Lines screen and select Store Pickup again. |
There is no email address specified for the customer, or the associated opt-in/out setting is not O1 (all emails) or O2 (order-related emails). The email address and opt-in/out setting are required so that Order Administration can generate the store pickup notification email when the order is ready for pickup at the designated store location. See Store Pickup Notifications for more information. |
Order creation and acceptance: things to note |
If the Order Orchestration record is not created immediately after order acceptance |
This situation
can occur if communication with Order Orchestration is interrupted
or if the Order Orchestration application is inactive. In this
case, Order Administration creates a record in the Store Pickup
tables to use as a trigger for each store pickup order that it needs
to submit to Order Orchestration when the connection is restored.
Order Administration also writes an Order Transaction History
message such as |
If Order Orchestration cannot create the order |
If the selected store location was not created correctly in Order Orchestration--for example, if it was not assigned to the System Code, if any, for the Store Cross Reference record, or the Name in OROB for Point of Sale (L09)--then Order Orchestration responds to the SubmitOrder request indicating that it cannot create the order. In this case, Order Administration cancels the order using the Cancel Reason (Rejected Store Pickup Orders) (G11) and writes Order Transaction History messages such as the following:
If the order is held |
Order Administration uses its regular credit-checking routine at order acceptance of a store pickup order, and may put the order on hold. A held order status does not prevent Order Administration from submitting the store pickup order to Order Orchestration, although Order Administration does select the order’s Under Review flag if the order is held and the Payment at POS for Store Pickup (M16) system control value is unselected. However, Order Administration removes the hold reason(s), if any, when the order is canceled for any reason (cancellation in Order Administration or Order Orchestration, an error in Order Orchestration, or rejection by the selected store) or is fulfilled. If a store pickup order was submitted with the Under Review flag selected, and the order is subsequently released from hold, Order Administration sends Order Orchestration an order update message indicating to clear the Under Review flag. See the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for a sample message. |
Free gifts or promotional inserts |
Once an order is flagged for store pickup, Order Administration does not add free gifts or promotional inserts when you accept the order. To prevent Order Administration from adding free gifts or promotional inserts, select the Store Pickup option before attempting repricing. |
Batch order entry |
When you work with store pickup orders in batch order entry, you might need to change or add individual order lines that are in error. After you do so, use the Store Pickup option and select a location where the customer can pick up the order. |
Alternate Shipping Charges by Via Window still opens |
Even if the Calculate Freight for Store Pickup Orders (L32) system control value is unselected, this window still opens in order entry. In this case, exit out of the window without making a selection. |
Creating the Order Ship To Address record |
Order Administration creates the Order Ship To Address record using the description and address from the Store Cross Reference record for the selected store. |
Separate Order Orchestration record for each order line |
There is a separate Order Orchestration record for each order line sent to Order Orchestration; however, the entire order has a single request ID, and creates a single order in Order Orchestration. |
Entering a negative quantity |
Although
Order Administration does not prevent you from creating a store
pickup order with a negative quantity, the order creates an error
in Order Orchestration and cannot be processed normally. The
error ( |
System control value setting requirements for order API |
If the order API receives a store pickup order, but the required system control values are not set correctly, the API creates the order and ignores the store pickup information in the CWOrderIn messages. To create a store pickup order through the order API, as in interactive order entry, the Use Merchandise Locator (I38) system control value must be selected and the Store Pickup Order Type (L33) system control value must specify an order type. |
After order creation: things to note |
If the order remains open rather than canceled when the selected location rejects the order or if Order Orchestration cannot create the order |
If you have not specified a Cancel Reason (Rejected Store Pickup Orders) (G11), then the system cannot cancel the order, and the order remains open if it cannot be fulfilled through Order Orchestration. |
Maintenance prohibited |
You cannot maintain a store pickup after creation except to cancel it (although you can use batch order entry to correct an order received through the order API if there are any errors). See Canceling a Store Pickup Order for more information. |
Returns prohibited |
You cannot process a return in Order Administration against a store pickup order. |
Email notifications for store pickup orders |
You can select the different types of email notifications to generate from Order Administration based on the Cancel Reason (Rejected Store Pickup Orders) (G11). The Email notification flag for this order type must be selected in order to generate the store pickup notification to the customer when the order is ready for pickup. Also, the opt-in/out setting for the email address on the order must be O1 (all emails) or O2 (order-related emails). |
Skipped by Process Auto Soldouts |
The Process Auto Soldouts program ignores lines on store pickup orders. See Processing Auto Soldout Cancellations (MASO), |
Troubleshooting the Order Orchestration Integration
See the Order Orchestration Web Services Guide on https://support.oracle.com (ID 2953017.1) for information on possible errors returned by Order Orchestration and additional troubleshooting information.
See also:
Things to Note about Retail Pickup (including Ship-for-Pickup) and Delivery Orders
Reauthorization and Under Review Hold Scenarios for Orders Fulfilled through Order Orchestration
Credit card authorization reversals: Authorization reversals take place when the Order Orchestration status is:
C (Closed): The request was canceled before submission to Order Orchestration.
E (Error): Order Orchestration returned an error response.
J (Rejected): The order was rejected by the pickup location. Reversal takes place only for a pickup order.
U (Unfulfillable): Order Orchestration cannot fulfill the order or line.
Y (Pending Cancel): A request to cancel the order or line has been sent to Order Orchestration.
Z (Canceled): Order Orchestration has confirmed that the order or line was canceled.
See Order Orchestration Status Summary Table for more information on Order Orchestration statuses.
Use the Order Broker Lines option at the Batch Job Statistics page in Modern View to check the total number of Order Broker lines in the currently selected company, broken out by current status.
| Problem | Possible Explanation |
No fulfilling location is displayed at the Work with Order Broker Screen |
Is the Order Orchestration request’s status E (error), U (unfulfillable), C (Closed) or Z (canceled)? In this case, the order line will not be fulfilled through Order Orchestration. |
The status of the Order Orchestration request is Closed, but there have not been any shipments |
Order Administration changes the status of a brokered backorder request to C (closed) if you cancel it before it has been submitted to Order Orchestration (when its status is R (ready)). |
A backordered order line is not being submitted to Order Orchestration for fulfillment |
I created a ship-for-pickup order, but it is not listed at the Work with Order Broker Screen or on the Order Inquiry screen in Order Orchestration |
If the Use OROB for Ship for Pickup Fulfillment Assignment (M34) system control value is set to NEVER, Order Administration does not send ship-for-pickup orders to Order Orchestration until you generate the pick slip. See Ship-for-Pickup Orders for an overview. |
Order Orchestration returned an error |
The error is displayed at the Display Order Broker History Screen.
See the Order Orchestration Web Services Guide on My Oracle Support (ID 2953017.1) for a list of possible errors that Order Orchestration might return to a Submit Order request. |
Will there be Order Orchestration records in error if the Order Orchestration application is not running? |
If Order Administration includes orders in a status inquiry list request and does not receive a response from Order Orchestration, the Order Orchestration records remain in their current status. |
Where are messages logged between Order Administration and Order Orchestration? |
If specified in the XML Logging setting at the Event Logging screen in Order Orchestration, Order Orchestration logs the messages. |
Retail pickup and delivery orders not created in Order Administration |
If the Send Inventory by Warehouse to OROB (L06) system control value is selected, Order Administration does not send fulfillments requests to Order Orchestration unless an OROB location is specified for the warehouse. |
Ship-for-pickup orders are not created |
An OROB_MESSAGE_VERSION of 16.0 or higher is required to use the Ship-for-Pickup Orders integration with Order Orchestration. Note that this property cannot be set higher than 19.9 for integration with Order Broker 19.x, or higher than 21.1 for integration with Order Broker 22.2.301.0 or higher, or Order Orchestration. |
Status updates are not generated when ship-for-pickup orders are in transit |
The Order Type for Retail Pickup Orders Brokered to OROMS (K92) and Order Type for Orders Brokered for Delivery (K91) system control values must be populated to generate the status update message when a ship-for-pickup order is in transit. |
Order initially created in Order Administration in error status, then put on hold after error corrected |
Canceled by originating system? If an order is initially created in Order Administration in error status and then corrected, Order Administration sends an inquiry request to Order Orchestration before changing the order’s status to open. If the response from Order Orchestration indicates that the originating system has canceled the order, Order Administration then puts the order on hold and writes an order transaction history message, such as: Order held - line[s] canceled in Order B. |
Tax is not calculated correctly for the invoice on a fulfilling order, while it is calculated correctly on the originating order |
Select the Tax on Freight (B14) system control value if this issue occurs. |
Multiple invoices are created for the lines on a single order that was fulfilled on the same day |
The invoice is consolidated for order lines that were previously in the same status and confirmed as fulfilled in the same status inquiry response from Order Orchestration, even if your company is not configured to consolidate invoices. Example: A line on the order is set to fulfilled in Order Orchestration at 9:00, and the other line at 9:02:
NOTE:
An order received from Order Orchestration is created in error status because the Price Override Limit Percent (E55) was exceeded |
This situation can occur if the order includes a free or low-priced item, such as through a BOGO promotion. A possible solution to prevent this error is to set the Order Broker Price Override (K95) to a price override reason code whose Override item offer price flag is selected. |
Delivery orders are in G (Resend Fulfilled) status, or ship-for-pickup orders are in H (Resend Intransit) status |
Orders can be in these statuses if the order status update request message, generated to set their statuses to Complete (delivery order) or Intransit (ship-for-pickup order), did not receive a response from Order Orchestration. This might occur if, for example, message authentication failed or communication is down. In this case, the BROKER_ORD job resends the request the next time it runs. |
Checking status in pick slip generation: A retail pickup or delivery order is put on AU (Broker Order Under Review) hold when:
Pick slip generation sends a status list request to Order Orchestration, and
The response message indicates that the order is under review.
Checking if under review through the BROKER process: When the BROKER integration layer process sends the status list request to Order Orchestration and receives a response indicating that an order is not under review, it removes the AU hold, if any, on the order. However, if the response from Order Orchestration indicates that the order is now canceled, the order is put on hold using the Order Broker Hold Reason (Cancel) (L02). If that system control value is blank, the order remains on AU hold.
If there are other holds on the order, they are not automatically removed.When an originating order is put on AR hold: When both an originating and fulfilling order exist, the holds applied work as follows:
A ship-for-pickup order or brokered backorder that originated in Order Administration was assigned by Order Orchestration to Order Administration for fulfillment, and Order Administration created a new fulfilling order.
The originating order’s initial authorization expired.
The attempt to reauthorize the originating order through the REAUTH periodic function failed, and the originating order was put on AR hold.
In this case, the system:
Applies the AU hold reason to the fulfilling order.
Voids any pending pick slips that have expired authorizations. Also, writes an order transaction history record such as: Pick #### voided due to expired auth.
Writes an order transaction history message such as SYS-HLD - BROKER ORDER UNDER REVIEW, where BROKER ORDER UNDER REVIEW is the description of the hold reason code.
If the Generic Pick Out API is in use, generates a trigger for a CWPickout message indicating that the pick slip was voided.
Drop ship pick slips or purchase orders, including those fulfilled through supplier direct fulfillment in Order Orchestration, are not updated when the reauthorization fails. You need to monitor these orders separately.If the reauthorization is declined after shipment through the fulfilling order: It is possible, based on the timing of the REAUTH job and billing, that the REAUTH job can attempt to reauthorize the originating order after the fulfilling order has made the shipment. In this case, the system still sends the order update to Order Orchestration indicating to put the order under review, even though the order may already be closed in Order Orchestration. If the order is already closed, no additional automatic updates take place.
Releasing Orders from AR or AU Holds
Restrictions: Orders on AR (Declined Credit Card Authorization) or AU (Broker Order Under Review) system holds can only be released under the following conditions:
AR: You cannot release an order on AR system hold unless the order has a valid authorization for the balance of the order. Otherwise, you can cancel the order.
AU: You cannot release an order on AU hold through a screen in Classic or Modern View. Instead, based on the response received from Order Orchestration through the BROKER integration layer process, the AU hold is removed automatically if the response indicates that the order is no longer under review. Also, the order can be canceled based on the response received through the BROKER process.
