Address Validation Integration
Order Administration supports the latest API formats with Experian Data Quality and has introduced Type-Ahead Address Lookup.
Order Administration supports the following integrations for address validation:
  • Experian Data Quality (EDQ) Address Validate API using the RESTful format. This is also referred to as QAS.
  • Generic RESTful Address Validation API that can be leveraged to integrate to an external address verification provider.
Order Administration supports the following integrations for type-ahead address lookup:
  • Experian Data Quality (EDQ) Address Search API
  • Generic RESTful Address Search API that can be leveraged to integrate to an external address search provider.
Setup Requirements
The following will need to be configured to enable Address Validation and/or Address Lookup unless indicated that it’s only used for one of the integrations:
  • Populate the 3-digit ISO Country Code in Work with Countries (WCTY)
    • Only countries where the region (or state code) is either empty or has a 2-character code are supported. For example: Canada (CAN), United Kingdom (GBR), United States (USA) and Australia (AUS) are all supported.
  • Address Service Authorization Token (B66) system control value
  • Address Validation Service Endpoint URL (B67) system control value. This URL is only used for Address Validation.
  • Address Type-Ahead Service Endpoint URL (B68) system control value. This URL is only used for Address Lookup.
  • Address Interface (I67) system control value. This setting is only used for Address Validation.
    • Must select QAS (Experian) or GENERIC to indicate the type of Address Service Interface.
