Creating and Maintaining Item Warehouses
Purpose: Work with Item Warehouses is used to change, delete, display, or create item warehouse records. An item warehouse record must exist for each item/SKU that is stocked in the warehouse. These records also provide the ability to capture inventory history for each item/SKU in the warehouse.
Item warehouse records are created automatically during item setup using the Work with Items function or the SKU Generator if you specify a warehouse for the item/SKU. Use the Work with Item Warehouse function to assign an item to a warehouse manually, if the item was not stocked in the warehouse at the time of setup.
In this topic:
Reset On-Order PO Quantity Periodic Function
You can use the PORST periodic function to reset the open PO quantities in the Item Warehouse table based on purchase order detail lines that are open or held, or received into suspense or into a pending putaway warehouse location.
Sample setup: Enter the following at the Create Periodic Function Screen:
  • Function: PORST
  • Description: PO On Order Reset
  • Company parameter: Y
  • Appl area: ALL
  • Program name: OER1018
Add to periodic process: You can, optionally, add this periodic function to a periodic process at the Work with Periodic Processes Screen, select Functions.
You can also run the on-order reset through the Unlock Purchase Order (MUPO) menu option.
Inventory Extract Periodic Function
Use the Inventory Extract INVEXT periodic function (program name URR0003) to create records in the Inventory Extract table for each item location in your company. You can use the Inventory Extract table to determine the on-hand inventory for each item/SKU in your company.
No on-hand quantity: If all of the item locations for an item/SKU have an on-hand quantity equal to or less than zero, the system creates only 1 record in the Inventory Extract table for the item/SKU. This 1 record indicates that the item/SKU does not have any on-hand inventory.
  • The location for this inventory extract record is the primary primary location for the item.
  • If a primary primary location has not been defined for the item, the location for this inventory extract record is blank.
The “primary primary” location is stored in the Primary location field in the SKU table.
Records remain in the Inventory Extract table until they are downloaded to another system. It is your responsibility to delete the records in the Inventory Extract table. Each time you run the On-Hand by Location Extract program, the system appends records to this table; because of this, duplicate records may exist in the table.
Work with Item Warehouse Screen
Purpose: Use this screen to create, change, delete, or display records that define the items that are stocked in the warehouse. An item/warehouse record must exist for each item/SKU in the warehouse.
How to display this screen:
Field Description
Item
The number of the item assigned to the warehouse.
Alphanumeric, 12 positions; optional.
SKU
The Split SKU codes associated with the item.  The three elements (color, size, and width) are used to further identify the item.
The SKU elements are defined in the System Control table.
Alphanumeric, three 4-position fields; optional.
On-hand
The number of units of this item across all locations in the warehouse.
Numeric, 7 positions; optional.
On order
The total quantity of this item in this warehouse that is due to be received through purchase orders.
Protected
An amount of inventory that cannot be reserved using immediate or batch reservation for this item or SKU across all locations in this warehouse.
Reservation freeze
Indicates whether the item or SKU in this warehouse is on hold, or frozen.
Valid values are:
  • Selected = The item/SKU warehouse is frozen.
  • Unselected = The item/SKU warehouse is not frozen.
If an item or SKU warehouse is frozen:
Screen Option Procedure
Create an item warehouse record
Select Create to advance to the Create Item Warehouse Screen.
Change item warehouse information
Select Change for an Item Warehouse record to advance to the Change Item Warehouse Screen. See the Create Item Warehouse Screen for field descriptions.
Delete item warehouse information
Select Delete for an Item Warehouse to delete it.
You cannot delete an item warehouse record if there are any on-hand quantities, open purchase order quantities, or backordered or reserved quantities for the item in the selected warehouse. If there are any Item Location records or Item Warehouse History records associated with this item and warehouse, the system will display a warning message:
Deleting this warehouse will also delete any dependent records.
Display item warehouse information
Select Display for an Item Warehouse record to advance to the Display Item Warehouse Screen.
Work with locations
Select Locations for an Item Warehouse record to advance to the Work with Item Locations Screen.
Display Pending Put away Details
Select Pend Putaway for an Item Warehouse record to advance to the Display Pending Putaway Details Screen.
Purpose: Use this screen to create an item warehouse.
The Work with Items function and the SKU generator automatically create Item Warehouse records if you enter a warehouse code, and Item Location records if you enter a location code during item setup. See Creating Item Warehouse/Locations (MIWL).
How to display this screen: At the initial Work with Item Warehouse Screen, select Create.
Field Description
Item
The item number you are assigning to the warehouse. The item number is validated against the Item/SKU table.
Alphanumeric, 12 positions.
Create screen: required.
Change screen: display-only.
Colo/Styl/Size
The Split SKU codes associated with the item. The three elements (color, style, and size) are used to further identify the item. The SKU codes entered are validated against the SKU tables.
The SKU elements are defined in the System Control Table.
Alphanumeric, three 4-position fields.
Create screen: required, if applicable.
Reservation freeze
Valid values are:
Protected qty
An amount of inventory that cannot be reserved (using immediate or batch reservation) for this item/ SKU across all locations in this warehouse. The system will only use this inventory in Interactive Reservation.
Min qty
The least amount of inventory on hand for this item/ SKU.
An error message indicates if you try to enter a minimum quantity and you do not have authority to the Maintain Item Warehouse Minimum/Maximum Quantity (A92) secured feature:
Not authorized to change.
Protect min/max (Protect minimum and maximum quantities)
This field is not currently implemented.
This field is included only if the Use Store File (G15) system control value is selected.
An error message indicates if you try to change this value and you do not have authority to the Maintain Item Warehouse Minimum/Maximum Quantity (A92) secured feature:
Max qty
The maximum amount of inventory on hand for this item/SKU.
An error message indicates if you try to enter a maximum quantity and you do not have authority to the Maintain Item Warehouse Minimum/Maximum Quantity (A92) secured feature:
Economic order qty
The recommended optimum ordering quantity for this item/SKU, based on a set of criteria such as cost. Used for inventory reporting purposes.
Reorder qty
Defines the quantity of this item/ SKU that should be ordered when the item/ SKU reaches the minimum stock level.
Original retail price
The original price of this item in the retail store.  You can use this field to track the original retail price for the item if the warehouse represents a retail store.
An error message indicates if you try to enter a price and you do not have authority to the Maintain Item Warehouse Retail Price (A91) secured feature:
Numeric, 13 positions with a 2-place decimal; optional.
Protect price (Protect current price)
An error message indicates if you try to change this value and you do not have authority to the Maintain Item Warehouse Retail Price (A91) secured feature:
Current retail price
The current price of this item in the retail store.  You can use this field to track the current retail price for the item if the warehouse represents a retail store.
User field 1
An informational field where you can enter additional item warehouse information.
Alphanumeric, 10 positions; optional.
User field 2
To display: Select Display for an item warehouse at the Work with Item Warehouse Screen to advance to the Display Item Warehouse screen. You cannot change any fields on this screen.
Field Description
Item
The item number assigned to the warehouse.
SKU
The SKU associated with the item.
Warehouse
The code and description of the warehouse where the item is located.
Code: Numeric, 3 positions.
Description: Alphanumeric, 30 positions.
Reservation freeze
Indicates whether the item or SKU in the warehouse is on hold, or frozen.
Valid values are:
Economic order qty
Numeric, 7 positions.
Backorder qty
The quantity of the item/SKU in this warehouse that is currently on open orders but not available in your warehouse.
Protected qty
The amount of inventory that cannot be reserved (using immediate or batch reservation) for this item/ SKU across all locations in this warehouse. The system will only use this inventory in Interactive Reservation.
Min qty
Max qty
Reorder qty
Defines the quantity of this item/SKU that should be ordered when the item/ SKU reaches the minimum stock level.
Reserve quantity
The quantity of this item/SKU in this warehouse that is reserved for existing orders. This total increases through immediate, batch, and interactive reservation, and decreases through confirmation or pick void/reprint.
On hand quantity
The number of units of this item in all locations in this warehouse.
On order quantity
The total quantity of this item in this warehouse that is due to be received on open purchase orders. This quantity increases when you enter a purchase order and decreases when you receive a purchase order.
If you receive purchase orders into suspense, the suspended quantity remains in this total until you place the suspended stock.
S/H reserve qty
The quantity of this item/SKU in this warehouse that is reserved for existing orders and requires special handling. This total increases through immediate, batch, and interactive reservation, and decreases through confirmation or pick void/reprint.
Reserve transfer qty
The quantity of this item/SKU in this warehouse that is set to be transferred to another warehouse through replenishment.
Protect min/max
Cost of goods
The total cost of units shipped from this warehouse, based on the defined unit cost of the item or SKU.
The Display Cost in Inventory (A38) secured feature controls the display of this field.
Numeric, 13 positions with a four-place decimal.
Picks generated
Dollars returned
The total dollar value of units returned to this warehouse, based on the actual selling price of each unit.
Numeric, 20 positions with a 2-place decimal.
Units returned
The total number of units returned to this warehouse by customers.
Numeric, 9 positions.
Dollars sold
The total dollar value of units shipped and billed from this warehouse, based on the actual selling price of each unit.
Units sold
The total number of units shipped and billed from this warehouse.
Numeric, 13 positions with a 2-place decimal.
Protect price
User field 1
Alphanumeric, 10 positions.
User field 2
Purpose: Use this screen to create, change, delete, or display a location for an item/SKU within a warehouse. Essential user-defined and system-updated quantity information is kept at the item/SKU location level.
How to display this screen: At the Work with Item Warehouse Screen, select Locations for an item warehouse.
Field Description
Location
A code that identifies a location for an item/SKU within the warehouse.
On-hand
The number of units for this item in this location.
Pending
The quantity of an item for which a batch inventory transaction has been entered, but not processed.
A negative quantity in this field indicates component items picked from this location for a finished good work order. This field is cleared once you process the work order. See Finished Good Work Order Processing (WWOR).
Min
The least amount of units to stock in this location.
Max
The maximum amount of units to stock in this location.
Reservation freeze
Indicates whether the item location or SKU location is frozen.
Valid values are:
  • Selected = The item/SKU location is frozen.
  • Unselected = The item/SKU location is not frozen.
Even though a pick slip does not print for an item from a frozen item location, the system still reserves the item on the Order Lines Fields in Order Entry.
Create an item location
Select Create to advance to the Create Item Location Screen.
Change an item location
Select Change for an item location to advance to the Change Item Location Screen.
Delete an item location
Select Delete for an item location to delete it.
The system will prevent you from deleting Item Locations if the quantity on-hand for the item in this location is greater than zero, or if there are any pending Inventory Transactions for the item in this location.
Display an item location
Select Display for an item location to advance to the Display Item Location Screen. You cannot change any information at this screen. See the Change Item Location Screen for field descriptions.
Purpose: Use this screen to create an item location.
Temporary location: If the item is assigned to a temporary location, the system automatically deletes the location when the on-hand quantity reaches zero. Order Administration does not allocate merchandise from a temporary location even if the location is defined as pickable. In order to allocate stock, you must move the merchandise to a non-temporary, pickable location.
Field Description
Location
The code representing the area within the warehouse that contains the item or SKU.
An error message indicates if you enter a location whose location class does not match the location class for the item and the Allow Location Class Edit in Inventory Transaction (F86) system control value is selected: Item is not compatible with Location.
Typically the location code is composed of a single alphanumeric character for Zone, and two numbers each for Aisle, Shelf, and Bin. For instance, the location A010201 indicates:
Zone Aisle Shelf Bin
A    01    02    01
Free-form location codes can also be used. The location code entered is validated against the Location table.
Alphanumeric, 7 positions; required.
Reservation freeze
Valid values are:
  • Unselected= The item/SKU location is not frozen.
Min qty
The desired least amount of inventory on hand for this item/SKU in this warehouse location.
Max qty
The desired highest amount of inventory on hand for this item or SKU in this warehouse location.
Purpose: Use this screen to change the item location’s reservation freeze status, minimum quantity and maximum quantity, and to view inventory transaction information.
How to display this screen: Select Change for an item location at the Work with Item Locations Screen.
See the Create Item Location Screen for the field descriptions not shown below.
Field Description
On-hand quantity
The number of units of the item in this location.
Alphanumeric, 7 position; display-only.
Pending transfer quantity
The quantity of an item for which an inventory transaction has been entered, but not processed.
A positive quantity reflects that inventory is in the process of being transferred to this location while a negative quantity indicates inventory is in the process of being transferred from this location. Reflects an adjustment, transfer, or finished good work order, and is not included in the on-hand quantity.
Numeric, 7 positions; display-only.
Printed quantity
The number of units currently “allocated” for the item in this location, determined by the total quantity of the item on printed pick slips.
When determining the locations from which to reserve items during pick slip generation, the printed quantity is subtracted from the on-hand quantity in the location to determine the quantity available for reservation.
Placement date
The date when you first placed the item in this location, for example through purchase order receiving, customer returns, transfers, or adjustments.
Numeric, 6 positions (user date format); display-only.
Item transfer pending
Indicates whether an inventory transaction is pending for the item in this location.
For example, the system selects this field if you enter a finished good work order, but do not approve or process the request. See Finished Good Work Order Processing (WWOR).
