Promotion Upload
Purpose: Use the promotion upload to create or delete promotions and related tables based on the information in the Promotion Upload table.
You can process the upload by:
- Creating a Promotion Upload text file. See below for information on file contents.
- Populating the Promotion Upload table with the contents of the
file by:
Using the File Storage API to upload the file contents to the FILE_STORAGE table, and then running the UPPROMO Upload Promotion Code File (Program name PFR0134, Parameter PRMUPLD) periodic function to populate the Promotion Upload table, or
Using the Work with File Uploads (WUPL) menu option to upload the records in the file to the Promotion Upload table.
See Fields Used in the Promotion Upload by Record Type for a sample record of each type of promotion you can upload.
- Using the contents of the Promotion Upload table to create or
update promotions by:
selecting Upload at the Work with Promotions screen in Working with Promotions (WPRO), or
submitting the PRMOUPL Create or Delete Promotions periodic function (Program name PRMOUPL). See How to Schedule a Job for information on how to schedule when the system executes a periodic process.
When you submit the update to the promotion records:
- For each Promotion Upload record that is not in error, the upload creates the specified record in the Promotion or related table and deletes the Promotion Upload record.
- For each Promotion Upload record in error, the upload sets the Processed Flag to E and updates the Error Desc field.
The upload does not delete records in error from the table or attempt to process them again unless the Processed Flag and Error Desc fields are cleared.- The upload generates the Promotion Upload Error Records Report regardless of whether there are any errors.
- The upload then clears the PROMOTION_CACHE, which caches Promotion BOGO, Promotion Item Category, and Promotion Source tables. It does not clear the PROMOTION_LIST_CACHE, which caches the Promotion Customer and Promotion Item Exclusion tables. See Caching for background.
The discussion of the promotion upload in this topic includes:
- General Rules for Promotion Uploads
- Promotion Upload Table (PRMUPLD)
- Fields Used in the Promotion Upload by Record Type
- Promotion Upload Errors
- Promotion Upload Error Records Report
Creation: You can use the upload to create a record in the Promotion table or any of the related tables:
- Promotion BOGO: see Promotion Creation (PRM)
- Promotion BOGO by Price Code: see Promotion BOGO Creation (PRB)
- Promotion Customer: see Promotion BOGO by Price Code Creation (PBP)
- Promotion Discount: see Promotion Discount Creation (PMD)
- Promotion Item Category: see Promotion Item Category Creation (PIC)
- Promotion Item Exclusion: see Promotion Item Exclusion Creation (PIE)
- Promotion Source: see Promotion Source Creation (PRS)
Deletion: You can use the upload to delete a record in the Promotion table and all its related records. The upload does not provide an option to delete a record in a related table without deleting the Promotion record itself.
Update: It is not possible to update a record through the upload.
To leave any field in the upload file blank, pass a space in an alphanumeric field and a 0 in a numeric field so that the file can be processed without errors. Leaving a field with no space or 0 is interpreted as null in the database and causes errors.Promotion Upload Table (PRMUPLD)
The following is a complete list of the fields in the Promotion Upload table. The table includes fields used for all possible record types, creating records in the Promotion table and all related tables.
For more information: See:
| Field | Attributes | Description |
| Company |
numeric, 3 positions |
The company where the record should be created or deleted. Defined in and validated against the Company table; see Working with Companies (WCMP) for background. Used for record type: All. Conditions: Required. Error: Invalid Company: the company specified is not valid; however, the record is not listed on the Promotion Upload Error Records Report. |
| Record Type |
alphanumeric, 3 positions |
The table where the record should be created or deleted. Used for record type: All. Conditions: Required.
See General Rules for Promotion Uploads. Error: Record type not found: the record type does not match one of the values listed above, or is blank. The record type is case-sensitive, so lowercase entries are invalid. |
| Request Type |
alphanumeric, 1 position |
Indicates whether to add a record, or delete a promotion and all related records. Used for record type: All. Conditions: Required. Valid values: A = add a promotion or a related record type D = delete a promotion and all its related records. This setting is valid only for a record type of PRM (Promotion). To delete any other record type, you can use the screens in Working with Promotions (WPRO) or use the upload to delete the promotion and all its related records. Errors:
| Sequence # |
numeric, 9 positions (CYYMMDD format) |
A unique number to identify a record in the Promotion Upload table. Used for record type: All. Conditions: Optional; however, required to upload multiple related records for the same promotion and record type at the same time (for example, multiple Promotion Source records for the same promotion). |
| Record Date |
numeric, 7 positions (CYYMMDD format) |
The date when the record was added. Used for record type: All. Conditions: Required. Error: Invalid Date: no record date is specified. |
| Processed Flag |
The upload sets this flag to E when the record is in error. |
| Promotion Code |
alphanumeric, 7 positions |
If the Record Type is PRM, this is the promotion to create or delete; otherwise, this is the promotion associated with the related record, such as a Promotion Source. Used for record type: All. Conditions: Required. Errors:
| Description |
alphanumeric, 30 positions |
The description of the promotion. Used for record type: PRM. Conditions: Required. Error: Missing Description: the Record Type is PRM and there is no description. |
| Start Date |
The first date when the promotion is effective. Used for record type: PRM. Conditions: Required. Error: Invalid Start Date: the Record Type is PRM and there is no start date specified, or the date specified is not valid. |
| End Date |
The last date when the promotion is effective. Must be on or later than the Start Date. Used for record type: PRM. Conditions: Required. Error: Invalid End Date: the Record Type is PRM and:
| Popup 1-4 |
alphanumeric, 30 positions each |
The text to display in a pop-up window in order entry. See Pop up window messages 1-4 for background. Used for record type: PRM. Conditions: Optional. |
| Priority |
The priority in which the system evaluates whether this promotion applies to an order. See Priority for background. Used for record type: PRM. Conditions: Required. Error: Invalid Priority: the Record Type is PRM and the priority is 0. |
| Promotion Type |
The type of discount to apply to orders that qualify for this promotion. Used for record type: PRM. Conditions: Required if you define any order promotion values. Possible settings are: A = Additional freight B = BOGO C = Item Category F = Freight O = Order T = Tiered discount blank = a message-only promotion See About Messaging Promotions or About Discount Promotions for background. Error: Invalid Promotion Type: the Record Type is PRM and the promotion type specified is not one of the values listed above. The promotion type is case-sensitive, so lowercase entries are invalid. |
| Promotion ID |
alphanumeric, 7 position |
A code used to identify or group promotion codes for reporting and analysis. Used for record type: PRM. Conditions: Optional. |
| Qualify Amount |
numeric, 13 positions with a 2-place decimal |
Optionally, specify the total merchandise amount required for the order to qualify for the promotion. See the Qualifying $ amount (Qualifying dollar amount) for a discussion. Used for record type: PRM. Conditions: Valid only for an order, freight, additional freight, or item category promotion (Promotion Type is A, C, F, or O). Optional. Errors:
| Free Freight |
Set to Y if freight is free of charge with this promotion; otherwise set this field to N. See Free freight for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is F (freight) and there is not a Freight override, PRM Dollar Discount, or PRM Percent Discount specified; a freight promotion must specify only one type of discount. Errors:
Note: This field is optional when you create a promotion; however, if it is blank instead of set to N, you will not be able to apply the promotion to an order. The error message displayed in order entry is Qualifying criteria not met for this promotion. To update the field and prevent the error from occurring after you initially create the promotion, you can select Change for the promotion at the Work with Promotions Screen and then click OK at the Change Promotion screen. |
| Freight Override |
The override amount to charge for freight with this promotion. See Freight override amount for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is F (freight). Cannot be selected if Free freight, PRM Dollar Discount, or PRM Percent Discount is also selected; a freight promotion must specify only one type of discount. Errors:
| PRM Dollar Discount |
The dollar discount to apply for an order, item category, freight, or additional freight promotion. See Discount amount for a discussion. Used for record type: PRM. Conditions: Used only when Promotion Type is A, C, or O (additional freight, item category, or order). Cannot be specified in combination with another discount. Optional. Errors:
Note: If a dollar discount is specified for a freight promotion, the Additional Charge field should specify a valid additional charge code. |
| PRM Percent Discount |
numeric, 5 positions with a 2-place decimal |
Specify the percentage discount to apply for an order, item category, freight, or additional freight promotion. See Discount percent for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A, C, F, or O (additional freight, item category, freight, or order). Cannot be specified in combination with another discount. Optional. Errors:
Note: If a percentage discount is specified for a freight promotion, the Additional Charge field should specify a valid additional charge code. |
| From SCF |
The first (lowest) SCF eligible for a ship via override). Used for record type: PRM. Conditions: Used only when the Promotion Type is A, C, F, or O (additional freight, item category, freight, or order). Valid entry only if there is a Ship Via Override specified; in this case, the From SCF and To SCF are required. Errors:
| To SCF |
The last (highest) SCF eligible for a ship via override). See To SCF for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A, C, F, or O (additional freight, item category, freight, or order). Valid entry only if there is a Ship Via Override specified; in this case, the From SCF and To SCF are required. Errors:
| Discount Receipt |
Not currently implemented. Error: Fields Not In Use: this field is populated. |
| Customer Pct Discount |
| Qualify Qty |
numeric, 5 positions |
The total unit quantity required for an order to qualify for the promotion. See Qualifying quantity for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is NOT B or T (tiered or BOGO). Optional. Error: Qualifier Not Valid for Promotion Type: this is a BOGO or tiered promotion (the Promotion Type is B or T). |
| US Only |
Set this field to Y to restrict a freight or additional freight promotion discount, or ship via override, to states in the continental U.S.A; otherwise set it to N. See Continental USA only for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A or F (additional freight or freight). Valid entry only if there is a Ship Via Override specified. Optional. Errors:
| Additional Charge |
alphanumeric, 2 positions |
The additional charge to use when adding a non-prorated discount to an order. See Additional charge code for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A, F, or O (additional freight, freight, or order). Optional. Not case-sensitive. Errors:
| Offer Number |
The offer that must be associated with the source code on the order header for the order to qualify for the promotion. You cannot specify both an offer and a source code as a promotion qualifier. See Qualifying offer for a discussion. Not case-sensitive. Used for record type: PRM. Conditions: Optional. Errors:
| Pay Type |
The pay type that must be used on the order for the order to qualify for the promotion. See Qualifying pay type for a discussion. Used for record type: PRM. Conditions: Optional. Error: Invalid Pay Type: The pay type specified is not valid. |
| Ship Via Override |
The ship via to replace the current ship via on an order as part of the promotion. See Ship Via Override for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A, F, or O (additional freight, freight, or order). Optional, but required if the record specifies an Override Country. Errors:
| Override Country |
The country eligible to receive the ship via override. See Ship via override and Ship via country for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is A, F, or O (additional freight, freight, or order). Optional, but required if the record specifies a Ship Via Override. Errors:
Note: This field is not case-sensitive; however, if the override country is lower case, you will not be able to apply the promotion to an order. The error message displayed in order entry is Qualifying criteria not met for this promotion. To update the field and prevent the error from occurring after you initially create the promotion, you can select Change for the promotion at the Work with Promotions Screen, correct the Ship via country, and then click OK at the Change Promotion screen. |
| Source Code |
alphanumeric, 9 positions |
The source code that must be on the order header for an order to qualify for the promotion. You cannot specify both a source code and an offer as qualifiers. See Qualifying source for a discussion. Used for record type: PRM. Conditions: Optional. Errors:
Note: This field is not case-sensitive; however, if the source code is lower case, you will not be able to apply the promotion to an order. The error message displayed in order entry is Qualifying criteria not met for this promotion. To update the field and prevent the error from occurring after you initially create the promotion, you can select Change for the promotion at the Work with Promotions Screen, click OK to advance to the Work with Qualifying Source Codes Screen, and use that screen to delete and re-add the source code. |
| Required Entry |
Set this field to Y to require entry of this promotion in order entry, and to require that it must be included in the order message for the order API; otherwise, set this field to N if the promotion should apply automatically to qualifying orders. See Required entry for a discussion. Used for record type: PRM. Conditions: Optional. Note: This field is optional when you create a promotion; however, if it is blank instead of set to N, you will not be able to apply the promotion to an order. The error message displayed in order entry is Qualifying criteria not met for this promotion. To update the field and prevent the error from occurring after you initially create the promotion, you can select Change for the promotion at the Work with Promotions Screen and then click OK at the Change Promotion screen. |
| First Buyer |
Set this field to: O = to restrict the promotion to customers who have not previously placed any orders S = to restrict the promotion to customers who have not previously had an order shipped to them See First time buyer for a discussion. Used for record type: PRM. Conditions: Optional. Error: Invalid First Time Buyer: The field is set to any character other than O or S. This field is case-sensitive, so a lowercase entry causes an error. |
| Qualify Code |
Set this field to: O = to include all order lines in the qualifiers for the promotion I = to include only items in a specified item category as qualifiers for the promotion See Qualifying $ amount type for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is C (item category). Optional. Errors:
| Ship Via Priority |
The priority that must be assigned to the ship via on the order header for the order to qualify for the promotion. See Qualifying via priority for a discussion. Used for record type: PRM. Conditions: Optional. |
| Special Price |
The price to apply to qualified items for an item category promotion. See Item category special price for a discussion. Used for record type: PRM. Conditions: Used only when the Promotion Type is C (item category). Optional, but you need to specify either a PRM Dollar Discount, PRM Percent Discount, or Special Price for an item category promotion. Error:
| Max Qty |
The maximum number of units an order can include to qualify for the promotion. See Max qty for a discussion. Used for record type: PRM. Conditions: Optional. |
The fields that are labeled PRB update the Promotion BOGO table. This table is used only if the BOGO Grouping by Price Code or Category (L62) system control value is set to CATEGORY. See the Work with BOGO Discount Screen (Item Category or Item) for background. |
| PRB Item Cgy |
alphanumeric, 4 positions |
An item category that qualifies for the BOGO promotion. See the Item category field at the Work with BOGO Discount Screen (Item Category or Item) for a discussion. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional, but you need to specify either a PRB Item Cgy or PRB Item for an item category promotion. Errors:
| PRB Item |
alphanumeric, 12 positions |
An item that qualifies for the BOGO promotion. See the Item field at the Work with BOGO Discount Screen (Item Category or Item) for a discussion. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional, but you need to specify either a PRB Item or PRB Item Cgy. Errors:
Note: If you set the PRB Free field to A to automatically add an item, you should either use the PRB Item field to specify a non-SKU’d item, or use both the PRB Item and PRB SKU fields to specify the particular SKU of a SKU’d item. |
| PRB SKU |
alphanumeric, 14 positions |
A SKU that qualifies for the BOGO promotion. See theItem field at the Work with BOGO Discount Screen (Item Category or Item) for a discussion. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional. Errors:
| PRB Required Qty |
The quantity of the item category, item, or SKU required for the BOGO promotion. Updates the Req qty (required quantity) field for the BOGO Promotion. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Required. Error: Missing Required Qty: No required quantity is specified. |
| PRB BOGO Qty |
The quantity of the item to receive the discount, to be set to no charge, or to be added at no charge. Updates the BOGO qty field for the BOGO Promotion. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Required. Error: Missing BOGO Qty: No BOGO quantity is specified. |
| PRB Discount Pct |
Specify the percentage discount to apply to the BOGO order line. Updates the Disc % at the Work with BOGO Discount Screen (Item Category or Item). If you do not set the PRB Free field to Y (free) or A (Free Auto Add), you can specify either a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional. |
| PRB Discount Amt |
Specify the discount amount to apply to the BOGO order line. Updates the Disc $ at the Work with BOGO Discount Screen (Item Category or Item). If you do not set the PRB Free field to Y (free) or A (Free Auto Add), you can specify either a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional. |
| PRB Spc Price |
Specify the special price to apply to the BOGO order line. Updates the Price at the Work with BOGO Discount Screen (Item Category or Item). If you do not set the PRB Free field to Y (free) or A (Free Auto Add), you can specify either a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional. |
| PRB Multiple Allowed |
Set this field to Y to allow the BOGO discount to apply multiple times to an order, or set it to N to allow the discount to apply just once per order. See the Allow mult (allow multiples) field for background. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Optional (but if you leave this field blank, the system treats it as a setting of N when evaluating the BOGO promotion for an order). Case-sensitive. Error: Invalid Multiple Allowed: The setting was not N, Y, or blank. |
| PRB Free |
Use this field to indicate whether the BOGO order line is discounted, changed to no charge, or added automatically at no charge. Valid values: N = The item already on the order is discounted. You need to specify either a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price. Y = The item already on the order is changed to no charge. With this setting, you should not specify a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price. A = The promotion adds the PRB Item (and PRB SKU, if the item has SKU’s) to the order at no charge. With this setting, you should not specify a PRB Discount Pct, PRB Discount Amt, or PRB Spc Price, and you should use the PRB Item and PRB SKU fields to specify a valid non-SKU’d item or a particular SKU of a SKU’d item. Used for record type: PRB. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to CATEGORY. Required. Error: Required for Record Type: This field is not set to N, Y, or A for a PRB record. |
The fields that are labeled PBP update the Promotion BOGO by Price Code table. This table is used only if the BOGO Grouping by Price Code or Category (L62) system control value is set to PRICE CODE. See the Work with BOGO Discounts by Item/Price Code Screen for more information. |
| PBP Price Code |
The price code required to qualify for the promotion. Updates the Price code at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. The promotion can use either a price code or an item as a qualifier. Required if there is no PBP Item specified. Errors:
| PBP Item |
The item required to qualify for the promotion. Updates the Item at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. The promotion can use either a price code or an item as a qualifier. Required if there is no PBP Price Code specified. Not case-sensitive. Errors:
| PBP Sku |
The SKU required to qualify for the promotion. Updates the SKU at the Work with BOGO Discounts by Item/Price Code Screen Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE, and the PBP Item is a SKU’d item. Optional, even if the PBP Item has SKU’s. Error: Invalid SKU:
| PBP Required Amount |
The dollar value total required for the PBP Required Qty to qualify for the promotion. Updates the Req Amt at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. Required if there is no PBP Required Qty; otherwise, optional (you can specify both a required quantity and a required amount). Error: Missing Bogo Qualifier: No PBP Required Qty or PBP Required Amount is specified. |
| PBP Required Qty |
The total quantity required of the PBP Price Code or PBP Item to qualify for the promotion. Updates the Req Amt at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. If there is also a PBP Required Amount, then the number of units specified here must meet or exceed the PBP Required Amount; however, if the PBP Required Qty is 99999, that means that a quantity of 1 or more meets the requirement for the promotion. Required if there is no PBP Required Amount; otherwise, optional (you can specify both a required quantity and a required amount). Error: Missing Bogo Qualifier: No PBP Required Qty or PBP Required Amount is specified. |
| PBP BOGO Prc |
The price code eligible for the promotion discount or special price. Updates the BOGO price code at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. With this setting, the PBP Free flag should be set to N, no PBP Auto Add item or PBP Add SKU should be specified, and the PBP BOGO Qty and a discount (either the PBP Discount Pct, PBP Discount Amount, or PBP Special Price) are required. Optional. Errors:
| PBP BOGO Qty |
The quantity of the item to receive the discount percentage, discount amount, or special price. Updates the BOGO qty at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. With this setting, the PBP Free flag should be set to N, no PBP Auto Add item or PBP Add SKU should be specified, and the PBP BOGO Prc (price code) and a discount (either the PBP Discount Pct, PBP Discount Amount, or PBP Special Price) are required. Required if the PBP Free setting is not Y or A. Errors:
| PBP Discount Pct |
The percentage discount to apply to the PBP BOGO Qty. Updates the Disc % at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE, and the PBP Free setting is N; in this case, either the PBP Discount Pct, PBP Discount Amount, or the PBP Special Price is required. Errors:
| PBP Discount Amount |
The discount amount to the PBP BOGO Qty. Updates the Disc $ at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE, and the PBP Free setting is N; in this case, either the PBP Discount Pct, PBP Discount Amount, or the PBP Special Price is required. Errors:
| PBP Special Price |
The special price to apply to the PBP BOGO Qty. Updates the Price at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE, and the PBP Free setting is N; in this case, either the PBP Discount Pct, PBP Discount Amount, or the PBP Special Price is required. Errors:
| PBP Prorate Disc |
Set this flag to N to apply the total discount amount to the discounted or free item, or set it to Y to prorate the discount across the required quantity and the BOGO quantity. Updates the Prorate flag at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. Case-sensitive. Required. Error: Prorate Discount Invalid: The PBP Prorate Disc flag is not set to Y or N. |
| PBP Multiple Allowed |
Set this flag to N if the promotion can apply just once to an order, or set it to Y if the promotion can apply multiple times when there is a sufficient quantity of the specified item or price code. Updates the Allow mult flag at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. Case-sensitive. Required. Error: Invalid Allow Multiples Value: The PBP Multiple Allowed flag is not set to Y or N. |
| PBP Free |
Indicates the type of benefit for the promotion: A = Free Auto Add: Add the PBP Auto Add item to the order automatically. N = No: There is no auto-add item. Apply a discount or a special price to the BOGO quantity. Y = Free: There is no auto-add item. Set the BOGO quantity to no charge. Updates the Free field at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO) and the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE. Case-sensitive. Required. Errors:
| PBP Auto Add |
Indicates the item to add to the order. Updates the Auto add item field at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62) is set to PRICE CODE, and the PBP Free flag is set to A. Required if the PBP Free flag is set to A. Case-sensitive only for non-SKU’d items. Errors:
| PBP Add SKU |
The SKU of the PBP Auto Add item to add to the order. Updates the SKU for the Auto add item at the Work with BOGO Discounts by Item/Price Code Screen. Used for record type: PBP. Conditions: Used only when the promotion type is B (BOGO), the BOGO Grouping by Price Code or Category (L62)is set to PRICE CODE, and the PBP Free flag is set to A. Required if the PBP Free flag is set to A and the PBP Auto Add item has SKU’s. Not case-sensitive. Errors:
The fields that are labeled PMD update the Promotion Discount table. This table is used only if for tiered promotions. See the Work with Promotion Discounts Screen for background. |
| PMD Discount Pct |
The percentage to discount the order when it meets the requirement for this tier but not the next. See the Percent discount field on the Work with Promotion Discounts Screen for a discussion. Used for record type: PMD. Conditions: Used only when the promotion type is T (tiered). You can specify either the PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s) for each record. Optional. Errors:
| PMD Discount Amt |
The amount to discount the order when it meets the requirement for this tier but not the next. See the Dollar discount field on the Work with Promotion Discounts Screen for a discussion. Used for record type: PMD. Conditions: Used only when the promotion type is T (tiered). You can specify either the PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s) for each record. Optional. Errors:
| PMD Dollars |
The merchandise total required for the order to qualify for the tier. See the Merch amount field on the Work with Promotion Discounts Screen for a discussion. Used for record type: PMD. Conditions: Used only when the promotion type is T (tiered). Required. Errors:
| PMD Item |
The item to add to the order when it meets the requirement for this tier but not the next. See the Free item field on the Work with Promotion Discounts Screen for a discussion. Used for record type: PMD. Conditions: Used only when the promotion type is T (tiered). You can specify either the PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s) for each record. Optional. The PMD SKU is required if this is a SKU’d item. Errors:
| PMD SKU |
The SKU of the PMD item to add to the order. See the Free item field on the Work with Promotion Discounts Screen for a discussion. Used for record type: PMD. Conditions: Used only when the promotion type is T (tiered), and there is a PMD Item specified. You can specify either the PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s) for each record. Optional. Errors:
The following field updates the Promotion Source table. You can create one or more Promotion Source records for any promotion type. The Source Code field, used in the PRM record type, also creates a record in the Promotion Source table. |
| PRS Source |
A source code that qualifies an order for the promotion if the source is on the order header. If you specify a source code in this field, it creates a record in the Promotion Source table. See Qualifying source for a discussion. Used for record type: PRS. Conditions: Required. Errors:
The following fields that are labeled PRC update the Promotion Customer table. You can create one or more Promotion Customer records for any promotion type. See the Work with Qualifying Customer/Price Groups Screen for background. |
| PRC Cust Num |
A customer who is eligible for the promotion. See the Work with Qualifying Customer/Price Groups Screen for a discussion. Used for record type: PRC. Conditions: Either the PRC Cust Num or the PRC Cust Group is required. Errors:
| PRC Cust Group |
A customer price group that is eligible for the promotion. See the Work with Qualifying Customer/Price Groups Screen for a discussion. Used for record type: PRC. Conditions: Either the PRC Cust Num or the PRC Cust Group is required. Errors:
The following field updates the Promotion Item Category table. You can create one or more Promotion Item Category records for an item category promotion. See the Work with Qualifying Item Categories Screen for background. |
| PIC Item Cgy |
An item category that is eligible for the promotion. See the Work with Qualifying Item Categories Screen for a discussion. Used for record type: PIC. Conditions: Required. Errors:
The following fields that are labeled PIE update the Promotion Item Exclusion table. You can create one or more Promotion Item Exclusion records for any promotion type. See the Work with Item/Category Exclusions Screen for background. |
| PIE Item |
An item that is ineligible for the promotion. See the Work with Item/Category Exclusions Screen for a discussion. Used for record type: PIE. Conditions: Either the PIE Item or the PIE Item Cgy is required. Errors:
| PIE Item Cgy |
An item category that is ineligible for the promotion. See the Work with Item/Category Exclusions Screen for a discussion. Used for record type: PIC. Conditions: Either the PIE Item or the PIE Item Cgy is required. Errors:
| The upload updates the following field if the upload record is in error. | ||
| Error Desc |
alphanumeric, 45 positions |
The description of the error. See Promotion Upload Errors for a list. |
In this topic:
- Promotion Creation (PRM)
- Promotion Deletion
- Promotion BOGO Creation (PRB)
- Promotion BOGO by Price Code Creation (PBP)
- Promotion Discount Creation (PMD)
- Promotion Source Creation (PRS)
- Promotion Customer Creation (PRC)
- Promotion Item Category Creation (PIC)
- Promotion Item Exclusion Creation (PIE)
Use a Record Type of PRM to create or update a record in the Promotion table. See the Create Promotion Screen for background on the fields in this table.
The required and optional fields vary based on the Promotion Type.
For details, see:
- Order Promotion Fields
- Freight Promotion Fields
- Additional Freight Promotion Fields
- Item Category Promotion Fields
- Tiered Promotion Fields
- BOGO Promotion Fields
Required fields:- Company
- Record Type: PRM
- Request Type: A or D
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: O
- PRM Dollar Discount OR PRM Percent Discount
- Popup 1-4
- Promotion ID
- Qualify Amount
- From SCF
- To SCF
- Qualify Qty
- US Only
- Additional Charge
- Offer Number OR Source Code
- Pay Type
- Ship Via Override
- Override Country
- Required Entry
- First Buyer
- Ship Via Priority
- Max Qty
Sample PRM Order promotion upload record:
7|PRM|A|1|1150414||PUORDER|PUORDER PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 1|POPUP WINDOW MESSAGE 2|POPUP WINDOW MESSAGE 3|POPUP
WINDOW MESSAGE 4|1|O|PROMOID|5.95||.00|||||1||OA|WEB|4|4|US||N|O||1|.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|5.00|.00
Additional uploads for an order promotion: You can also upload one or more Promotion Source, Promotion Customer, and Promotion Item Exclusion records for an order promotion. See Promotion Source Creation (PRS), Promotion Customer Creation (PRC), and Promotion Item Exclusion Creation (PIE) for more information.
- Record Type: PRM
- Request Type: A
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: F
- Free Freight OR Freight Override OR PRM Dollar Discount OR PRM Percent Discount (with Additional Charge required for PRM Dollar Discount OR PRM Percent Discount)
- Popup 1-4
- Promotion ID
- Qualify Amount
- From SCF
- To SCF
- Qualify Qty
- US Only
- Pay Type
- Ship Via Override
- Override Country
- Required Entry
- First Buyer
- Ship Via Priority
- Max Qty
Sample PRM Freight promotion upload record:
7|PRM|A|2|1150414||PUFRT|PUFRT PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|2|F|PROMOID|6.95|Y|.00|||||1|Y||WEB|4|4|US||N|O||1|.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
Additional uploads for a freight promotion: You can also upload one or more Promotion Source or Promotion Customer records for a freight promotion. See Promotion Source Creation (PRS) and Promotion Customer Creation (PRC) for more information.
- Record Type: PRM
- Request Type: A
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: A
- Popup 1-4
- Promotion ID
- Qualify Amount
- From SCF
- To SCF
- Qualify Qty
- US Only
- Pay Type
- Ship Via Override
- Override Country
- Required Entry
- First Buyer
- Ship Via Priority
- Max Qty
Sample PRM Additional Freight promotion upload record:
7|PRM|A|3|1150414||PUADLFR|PUADLFR PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|3|A|PROMOID|5.00||.00|||||1|Y|A|WEB|4|4|US||N|O||1|.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
Additional uploads for an additional freight promotion: You can also upload one or more Promotion Source or Promotion Customer records for an additional freight promotion. See Promotion Source Creation (PRS) and Promotion Customer Creation (PRC) for more information.
- Record Type: PRM
- Request Type: A
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: C
- PRM Dollar Discount OR PRM Percent Discount OR Special Price
- Popup 1-4
- Promotion ID
- Qualify Amount
- Qualify Qty
- Pay Type
- Required Entry
- First Buyer
- Qualify Code
- Max Qty
Sample PRM Item Category promotion upload record:
7|PRM|A|4|1150414||PUITMCT|PUITMCT PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|4|C|PROMOID|5.95||.00|||||1|||WEB|4|0|||N|O|O|1|10.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
Additional uploads for an item category promotion: An item category promotion also requires one or more Promotion Item Category records; see Promotion Item Category Creation (PIC) for more information.
You can also upload one or more Promotion Source or Promotion Customer records for an item category promotion. See Promotion Source Creation (PRS) and Promotion Customer Creation (PRC) for more information.
- Record Type: PRM
- Request Type: A
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: T
Sample PRM Tiered promotion upload record:
7|PRM|A|5|1150414||PUTIERD|PUTIERD PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|5|T|PROMOID|0||.00|||||0||||0|0||||||1|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
Additional uploads for a tiered promotion: A tiered promotion also requires one or more Promotion Discount records; see Promotion Discount Creation (PMD) for more information.
You can also upload one or more Promotion Source, Promotion Customer, and Promotion Item Exclusion records for a tiered promotion. See Promotion Source Creation (PRS) Promotion Customer Creation (PRC), and Promotion Item Exclusion Creation (PIE) for more information.
- Record Type: PRM
- Request Type: A
- Record Date
- Promotion Code
- Description
- Start Date
- End Date
- Priority
- Promotion Type: B
Sample PRM BOGO promotion upload record:
7|PRM|A|6|1150414||PUBOGO|PUBOGO PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|6|B|PROMOID|0.00||.00|||||0|||WEB|4|0|||N|O||1|.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
Additional uploads for a BOGO promotion: Depending on the setting of the BOGO Grouping by Price Code or Category (L62) system control value, a BOGO promotion also requires:
- one or more Promotion BOGO records if the system control value is set to CATEGORY; see Promotion BOGO Creation (PRB) for more information.
- one or more Promotion BOGO by Price Code records if the system control value is set to PRICE CODE; see Promotion BOGO by Price Code Creation (PBP) for more information.
You can also upload one or more Promotion Source, Promotion Customer, and Promotion Item Exclusion records for a tiered promotion. See Promotion Source Creation (PRS), Promotion Customer Creation (PRC), and Promotion Item Exclusion Creation (PIE) for more information.
Promotion Deletion
To delete a promotion and all its related records:
Required fields:Any records for the promotion in the following tables are deleted:
- Promotion BOGO
- Promotion Source
Sample PRM Delete promotion upload record:
7|PRM|D|7|1150414||PUDELTE|PUDELTE PROMOTION DESCRIPTION|1150401|1150601|POPUP
WINDOW MESSAGE 4|7||PROMOID|5.00||.00|||||1|Y|N|WEB|4|4|US|SOURCE7|N|O|O|1|.00|10||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
You can create one or more Promotion BOGO records for a BOGO promotion. The system uses this table only if the BOGO Grouping by Price Code or Category (L62) system control value is set to CATEGORY; otherwise, the system uses the Promotion BOGO by Price Code table when evaluating and applying BOGO promotions.
See the Work with BOGO Discount Screen (Item Category or Item) for background on BOGO promotions that use these records.
Setting the BOGO Grouping by Price Code or Category (L62) system control value to PRICE CODE does not prevent you from creating records in the Promotion BOGO table; however you cannot advance to the Work with BOGO Discount Screen (Item Category or Item) with this setting, and the system does not use the Promotion BOGO records to evaluate or apply BOGO promotions.All fields required except where indicated:
- Company
- Record Type: PRB
- Request Type: A
- Record Date
- Promotion Code
- PRB Item Cgy OR PRB Item (PRB SKU is optional)
- PRB Required Qty
- PRB BOGO Qty
- PRB Discount Pct OR PRB Discount Amt OR PRB Spc Price
- PRB Free
- PRB Multiple Allowed is optional
Sample PRB BOGO promotion upload record:
7|PRB|A|8|1150414||BOGO1|PUBOGOB PROMOTION DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||SKU|RED|1|1|5.00|.00|.00|Y|N|0|||.00|0|0|0|.00|.00|.00||||||.00|.00||||0||||||0|.00|.00|.00
You can create one Promotion BOGO by Price Code record for a BOGO promotion. The system uses this table only if the BOGO Grouping by Price Code or Category (L62) system control value is set to PRICE CODE; otherwise, the system uses the Promotion BOGO table when evaluating and applying BOGO promotions.
See the BOGO Discount by Item/Price Code Screen for background on BOGO promotions by price code.
Setting the BOGO Grouping by Price Code or Category (L62) system control value to CATEGORY does not prevent you from creating records in the Promotion BOGO by Price Code table; however you cannot advance to the BOGO Discount by Item/Price Code Screen with this setting, and the system does not use the Promotion BOGO by Price Code records to evaluate or apply BOGO promotions.All fields required except where indicated:
- Company
- Record Type: PBP
- Request Type: A
- Record Date
- Promotion Code
- PBP Price Code OR PBP Item and PBP Sku (optional)
- PBP Required Amount or PBP Required Qty, or both
- if PBP Free is set to N or Y:
- PBP BOGO Prc and PBP BOGO Qty
- PBP Discount Pct OR PBP Discount Amount OR PBP Special Price
- if PBP Free is set to A:
- PBP Auto Add and PBP Add SKU (required if the PBP Auto Add item has SKU’s)
- PBP Prorate Disc
- PBP Multiple Allowed
- PBP Free
Sample PBP BOGO by Price Code promotion upload record:
7|PBP|A|9|1150414||BOGO1|PUBOGOP PROMOTION DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||101|||50.00|1|101|1|5.00|.00|.00|N|Y|N|||.00|.00||||0||||||0|.00|.00|.00
You can create one or more Promotion Discount records for a tiered promotion. At least one record is required. See the Work with Promotion Discounts Screen for more information.
Required fields:
- Company
- Record Type: PMD
- Request Type: A
- Record Date
- Promotion Code
- PMD Discount Pct OR PMD Discount Amt OR PMD Item (and PMD SKU if the PMD Item has SKU’s)
- PMD Dollars
Sample PMD Discount promotion upload record:
7|PMD|A|10|1150414||TG|TG TIER PROMOTION DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||0.00|.00|SKU|PINK||0||||||25.00|.00|.00|.00
You can create Promotion Source records for any promotion type. See the Work with Qualifying Source Codes Screen for more information.
The Source Code field, used in the PRM record type, also creates a record in the Promotion Source table.Required fields:
Sample PRS Source promotion upload record:
7|PRS|A|11|1150414||OP|OPSORCS PROMOTION DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||0.00|.00|||SOURCE7|0||||||0|.00|.00|.00
You can create Promotion Customer records for any promotion type. See the Work with Qualifying Customer/Price Groups Screen for more information.
Required fields:
Sample PRC Customer promotion upload record:
7|PRC|A|12|1150414||OP|OPCUSTC PROMOTION DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||0.00|.00||||55||||||0|.00|.00|.00
You can create Promotion Item Category records for item category promotions. See the Work with Qualifying Item Categories Screen for more information.
Required fields:
Sample PIC Item Category promotion upload record:
7|PIC|A|13|1150414||ITMCATP|PUITMC PROMO DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||0.00|.00||||0||DFLT||||0|.00|.00|.00
You can create Promotion Item Exclusion records for any promotion type except for freight and additional freight. See the Work with Item/Category Exclusions Screen for background.
Required fields:
Sample PIE Item Exclusion promotion upload record:
7|PIE|A|14|1150414||ITMCATP|PUITMX PROMO DESCRIPTION|0|0|||||0|||0.00||.00|||||0||||0|0||||||0|.00|0||||0|0|.00|.00|.00|||0|||.00|0|0|0|.00|.00|.00||||||0.00|.00||||0||0||DFLT||0|.00|.00|.00
The errors possible through the promotion upload are listed below. See the Promotion Upload Table (PRMUPLD) and Fields Used in the Promotion Upload by Record Type for background.
| Error | Record Types | Description |
Additional Charge Code Required |
PRM |
There is no Additional Charge specified for a freight promotion. |
Auto Add Not Selected |
PBP |
No PBP BOGO Qty is specified, and the PBP Free flag is not set to A. |
BOGO Discount Conflict |
PBP, PRB |
PBP: More than one of the required discounts (PBP Discount Pct, PBP Discount Amount, or PBP Special Price) is specified. PRB: More than one of the required discounts (PRB Discount Pct, PRB Discount Amt, PRB Spc Price, or PRB Free) is specified. |
Customer/CPG Conflict |
PRC |
Both a PRC Cust Num and a PRC Cust Group are specified. |
Discount conflict |
PRM |
Discount required |
PRM |
No PRM Dollar Discount or PRM Percent Discount is specified for an additional freight, item category, or order promotion. |
Duplicate Promotion Code |
PRM |
The Promotion Code specified already exists. |
Either Source code or offer |
PRM, PRS |
Fields Not In Use |
PRM |
A Discount Receipt or Customer Pct Discount is specified. |
Invalid Add'l Chg Code |
PRM |
The Additional Charge code specified does not exist. |
Invalid Allow Multiples Value |
PBP |
Invalid Auto Add SKU |
PBP |
A PBP Add SKU is specified, but the PBP Auto Add item does not have SKU’s. |
Invalid BOGO Price Code |
PBP |
The PBP BOGO Prc specified is not valid. |
Invalid Company |
any |
The Company specified is not valid. Note: When the company, is invalid, the record is not listed on the Promotion Upload Error Records Report. |
Invalid Continental USA Only Flag |
PRM |
The US Only flag is not set to Y or N for a freight or additional freight promotion (the Promotion Type is A or F). This field is case-sensitive, so a lowercase entry causes an error. |
Invalid Customer Number |
PRC |
The PRC Cust Num specified is invalid. |
Invalid Date |
any |
No Record Date is specified. |
Invalid Discount Item |
PMD |
The PMD Item specified is invalid. |
Invalid End Date |
PRM |
There is no end date specified; or the End Date is earlier than the Start Date; or the date specified is not valid. |
Invalid First Time Buyer |
PRM |
The First Buyer setting is not O or S. This field is case-sensitive, so a lowercase entry causes an error. |
Invalid From SCF |
PRM |
Invalid Item |
PBP. PIE, or PRB |
Invalid Item Category |
PIC or PRB |
The PIC Item Cgy or PRB Item Cgy is not valid. |
Invalid Multiple Allowed |
PRB |
The PRB Multiple Allowed setting was not N, Y, or blank. |
Invalid Offer |
PRM |
The Offer Number specified is not valid. |
Invalid Pay Type |
PRM |
The Pay Type specified is not valid. |
PBP |
The PBP Price Code specified is invalid. |
Invalid Priority |
PRM |
The Priority is 0. |
Invalid Promotion Code |
any except PRM |
The Promotion Code specified is invalid. |
Invalid Promotion Type |
PRM |
The promotion type specified is not one of the values listed under Promotion Type. The promotion type is case-sensitive, so lowercase entries are invalid. |
Invalid Qualifier for Tier Promotion |
PRM |
There is a Qualify Amount specified and the Promotion Type is T. |
Invalid Request Type |
any |
The Request Type is D and the Record Type is PRS, PIC, PRC, PMD; or the Request Type specified is not A or D. The request type is case-sensitive. |
Invalid Ship Via Override |
PRM |
The Ship Via Override specified is not valid. |
Invalid Ship Via Override Country |
PRM |
The Override Country specified is not valid. |
Invalid SKU |
PBP or PRB |
PBP: The PBP Item is not a SKU’d item, but a PBP Sku is specified; or the PBP Sku specified is not valid for the PBP Item. PRB: The PRB SKU is invalid, or specified for a non-SKU’d PRB Item. |
Invalid Source Code |
PRM or PRS |
PRM: The Source Code specified is not valid. PRS: The PRS Source specified is not valid. |
Invalid Start Date |
PRM |
There is no Start Date specified, or the date specified is not valid. |
Item Cat or Item as Qualifier |
PRB |
Both PRB Item Cgy and the PRB Item are specified. |
Item Category Not Valid for Auto Add |
PRB |
The PRB Free field is set to A, and PRB Item Cgy is specified as a qualifier. |
Item\Item Category Conflict |
PIE |
Both the PIE Item or the PIE Item Cgy are specified. |
Missing Auto Add SKU |
PBP |
No PBP Add SKU is specified, and the PBP Auto Add item has SKU’s. |
Missing Bogo Discount |
PBP |
None of the required discounts (PBP Discount Pct, PBP Discount Amount, or the PBP Special Price) is specified; or, the PBP Free field is set to N, but a PBP Auto Add item is specified. |
Missing BOGO Qty |
PRB |
No PRB BOGO Qty is specified. |
Missing Bogo Qualifier |
PBP |
Missing Customer/CPG |
PRC |
Neither a PRC Cust Num or a PRC Cust Group is specified. |
Missing Description |
PRM |
There is no Description specified. |
Missing Item |
PBP or PRB |
Missing Item Category |
PIC |
No PIC Item Cgy is specified. |
Missing Item\Item Category |
PIE |
Neither the PIE Item or the PIE Item Cgy is specified. |
Missing Item or Item Cat |
PRB |
Neither the PRB Item Cgy or the PRB Item are specified. |
Missing PMD Dollars |
PMD |
No PMD Dollars amount is specified. |
Missing Promotion Code |
any |
The Promotion Code is blank. Note: If the promotion code is blank for a delete request (the Request Type is D), the upload record is flagged as an error, but the Error Desc remains blank. |
Missing Required Qty |
PRB |
No PRB Required Qty is specified. |
Missing Source |
PRS |
No PRS Source is specified. |
Missing Tier Discount |
PMD |
The record did not include one of the following: PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s). |
Only Valid for Freight Promotion |
PRM |
Free Freight is specified, but the Promotion Type is not F. |
Override Option Not Valid for Promo Type: |
PRM |
A Ship Via Override is specified, and the promotion type is not A, F, or O (additional freight, freight, or order). |
Price Code or Item as Benefit |
PBP |
The PBP Free field is set to A (auto-add), but there is also a PBP BOGO Qty specified; or there is no PBP Auto Add item specified; or the PBP Add SKU is not a valid SKU for the PBP Auto Add item. |
PBP |
Both the PBP Price Code and the PBP Item are specified; or neither is specified; or a PBP BOGO Prc is specified and the PBP Free flag is set to A. |
Prorate Discount Invalid |
PBP |
Promotion Type Conflict |
any except PRM |
Promotion/Record Type Mismatc |
PIE |
The Promotion Code specified for a PIE Record Type is a freight or additional freight promotion. |
Qualifier Not Valid for Free Freight |
PRM |
The Free Freight field was not set to Y, N, or blank for a freight promotion. The field is case-sensitive, so lowercase values are invalid. |
Qualifier Not Valid For Promo Type |
PRM |
Qualifier Not Valid for Promotion Type |
PRM |
Qualify Code required |
PRM |
No Qualify Code is specified, but there is a Qualifying $ amount type specified for an item category promotion. |
Record Already Exists |
PIE, PRB, PRS, PMD |
Record type not found |
N/A |
The record type does not match one of the values listed under Record Type. The record type is case-sensitive, so lowercase entries are invalid. |
Required Field For This Type |
PBP |
The PBP Free field is not set to A, N, or Y. |
Required for Record Type |
PRB |
This PRB Free field is not set to N, Y, or A. |
Ship Via Override Required |
PRM |
The upload record specifies an Override Country but no Ship via override. |
Special Price Not Valid |
PRM |
A Special Price is specified even though the promotion type is not C. |
Tier Discount Conflict |
PMD |
The record includes more than one of the following: PMD Discount Pct, PMD Discount Amt, or PMD Item (and PMD SKU if the item has SKU’s). |
