Reviewing Invoices
Display Invoices Screen
Purpose: Use the invoice function from within standard Order Inquiry to review and print invoice detail on shipments. As you build an order, the system keeps a record of each shipment you make against the order. Similarly, the system creates a record of each credit against the order for returns, cancellations, and overpayments.
The Display Invoices screen lists the invoices or credits the system has generated for the order you are reviewing and provides access to each additional invoice-related screen.
Consolidate invoice? The Consolidated Invoice (B49) system control value indicates whether to consolidate multiple shipments for an order on the same system date under the same Invoice Header number. The Invoice Consolidation Method (E29) controls whether the system consolidates invoices for each separate ship-to for an order, or for the order as a whole.
Invoice consolidation does not apply when you express-bill an order or create a credit invoice.
Important:
In Order Management System 21.0 or higher, or Order Administration, you cannot select the Consolidated Invoice system control value if it is not already selected. If the system control value is currently selected (set to Y) and you deselect it (change it to N or blank), you cannot then change it back to selected. The option to consolidate invoices will be removed at a later date.Also, if a billing or shipping address changes between shipments and the Capture Addresses for Invoice (J24) system control value is selected, this can prevent the invoice from consolidating. Even if the invoice is consolidated, there is a separate entry at this screen for each unique billing address/shipping address combination if the Capture Addresses for Invoice (J24) system control value is selected.
For more information: See the Invoice Consolidation Method (E29) system control value for a discussion.
On orders subject to VAT and tax-inclusive pricing, the invoice screens described in this section display the tax-inclusive price that the customer sees; in other words, the hidden tax amount is not visible. You can review the hidden tax amount for an item by advancing to the Invoice Detail Charges Screen.Invoice creation for ship-for-pickup orders: If the Invoice Ship For Pickup Order Once Intransit (M73) system control value is selected, the invoice is created for an item on a ship-for-pickup order once the system receives notification from Order Broker that the order line is in transit from the sourcing location to the pickup location, has been received at the pickup location, or has been fulfilled. See that system control value for more information.
How to display this screen: Select Display Invoices at the Order Inquiry Header Screen or Order Inquiry Detail Screen.
| Field | Description |
| Order # |
The number the system has assigned to this order. Numeric, 7 positions, display-only. |
| Ship-to |
The number of the ship-to address on the order. The number of the ship-to you were displaying when you selected Invoices defaults in this field, but you can also review invoices for the other ship-to records on the order from this screen. Numeric, 3 positions; optional. |
| Invoice # |
The number the system assigns to a customer's bill or credit. The system generates an invoice during billing. The Consolidated Invoice (B49) system control value selected controls whether two shipments to the same billing and shipping addresses on the same billing date are consolidated into the same Invoice Ship To record, producing a single entry on this screen. Multiple entries for same invoice: The system uses the same invoice number for separate shipments that occur on the same billing date if the Consolidated Invoice system is selected, and,
When consolidating invoices as described above, the system creates a single Invoice Header record (and a single invoice number), but separate Invoice Ship To records. See the Invoice Consolidation Method (E29) for a discussion and examples. Note: In Order Management System 21.0 or higher, or Order Administration, you cannot select the Consolidated Invoice system control value if it is not already selected. If the system control value is currently selected (set to Y) and you deselect it (change it to N or blank), you cannot then change it back to selected. The option to consolidate invoices will be removed at a later date.Assigned when? If the Generate Invoice Number at Pick Gen (H80) or Generate Invoice # at Pick Gen without Address Match (K81) system control value is selected, the system assigns the invoice number at pick slip generation if the order is eligible; otherwise, it assigns the invoice number at billing. Invoice address? If the Capture Addresses for Invoice (J24) system control value is selected, the shipping and billing addresses for each Invoice Ship To are stored in the Invoice Address table; you can use the Display Invoice Address Screen (Billing Address) and Display Invoice Address Screen (Shipping Address) to review them. Numeric, 7 positions; optional. |
| Date |
The date the invoice record was created by billing. This is the Start date for the billing async job. Numeric, 6 positions (in user date format); display-only. |
| Type (Invoice type) |
Indicates the type of invoice:
The system does not consolidate credit invoices with other credits or with debit invoices. Alphanumeric, 1 position; display-only. |
| Total |
The total of the invoice. Credit invoice amounts include a minus sign. Numeric, 20 positions with a 2-place decimal; display-only. |
| Net Bill |
Indicates whether the invoice is currently pending Credit Card Net Exchange Billing.
| Date Printed |
The date the invoice was printed. Numeric, 6 positions (in user date format); display-only. |
| Screen Option | Procedure |
Display invoice header |
Select Invoice for an invoice to advance to the Display Invoice Header Screen. |
Display payment methods records |
Select Pay Methods for an invoice to advance to the Display Invoice Pay Methods Screen. |
Display invoice details for particular items |
Select Details for an invoice to advance to the First Display Invoice Detail Screen. |
Display the billing address for an invoice |
Select Billing Address for an invoice to advance to the Display Invoice Address Screen (Billing Address). |
Display the shipping address for an invoice |
Select Shipping Address for an invoice to advance to the Display Invoice Address Screen (Shipping Address). |
Display invoice payment summary information |
Select Invoice Pay Summary to advance to the Invoice Pay Summary Screen. |
Print an order receipt for each ship-to on the order |
Select Order Receipt. See the Order Receipt for more information.
Purpose: Use this screen to review the basic elements of the invoice, such as the tax, handling, additional charges, hidden freight and gross profit.
How to display this screen: At the Display Invoices Screen, select Invoice for an invoice.
| Order # |
The number the system has assigned to this order. The ship-to number is separated from the order number by a hyphen. Order number: numeric, 7 positions, display-only. Ship-to number: numeric, 3 positions; display-only. |
| Invoice # |
The number the system assigns to a customer's bill. Assigned when? If the Generate Invoice Number at Pick Gen (H80) or Generate Invoice # at Pick Gen without Address Match (K81) system control value is selected, the system assigns the invoice number at pick slip generation if the order is eligible; otherwise, it assigns the invoice number at billing. Numeric, 7 positions; display-only. |
Represents the type of invoice. Valid values are:
Display-only. |
| Invoice print date |
The date you printed the invoice or credit memo. Numeric, 6 positions (in user date format); display-only. |
| Merchandise |
The total value of the merchandise. Merchandise amount does not include tax, handling, additional charges, or freight. Numeric, 20 positions with a 2-place decimal; display-only. |
| Cost |
The actual cost of the merchandise billed on this invoice. Note: The secured feature Display Invoice Cost in O/I (A36) controls whether this screen displays the cost.Numeric, 20 positions with a 2-place decimal; display-only. |
| Freight |
The freight charges for the invoice. This amount may not be equal to the total of all the line-level freight charges. Numeric, 20 positions with a 2-place decimal; display-only. |
| G/M (Gross profit margin) |
The amount of the merchandise price that exceeds the total cost. You can use gross margin to determine the profit of an order based on each item's selling price. See Determining Gross Profit for more information. The Display Gross Margin (A65) secured feature controls whether this field displays in order entry, maintenance, inquiry and item availability. Numeric, 20 positions with a 2-place decimal; display-only. |
| G/M% (Gross profit margin percentage) |
The percentage of the merchandise price that exceeds the total cost. You can use gross margin to determine the profit of an order based on each item's selling price. See Determining Gross Profit for more information. The Display Gross Margin (A65) secured feature controls whether this field displays in order entry, maintenance, inquiry and item availability. Numeric, 5 positions with a 2-place decimal; display-only. |
| Tax |
The sales tax for the invoice. This field includes GST and PST, if any. This field does not include hidden tax; see the Invoice Detail Charges Screen. Numeric, 20 positions with a 2-place decimal; display-only. |
| GST |
The Canadian Goods and Services Tax, if any. This field displays only if there is a GST charge or credit on the invoice. Numeric, 20 positions with a 2-place decimal; display-only. |
| PST |
The Canadian Provincial Services Tax, if any. This field displays only if there is a PST charge or credit on the invoice. Numeric, 20 positions with a 2-place decimal; display-only. |
| Handling (Handling charge) |
The cost of any special handling on the order, such as personalizing, monogramming, or engraving, and any gift wrapping charges. Any duty charges on the invoice are included in this total. See First Display Invoice Detail Screen for information on duty charges on an invoice. Numeric, 20 positions with a 2-place decimal; display-only. |
| Add'l charges (Additional charges) |
The total charges exceeding standard charges on the current order. The system validates additional charges, which are entered manually or automatically assigned against the Additional Charges table during Order Entry. Additional charges may include: Additional source code charge: An additional charge for services that apply to the source code or offer. These charges apply if you have set up a service charges table for the source code or offer. The system applies the additional charge to the order based on the total value of the merchandise. Additional shipper/item charge: An additional charge that applies to the item, depending on the shipper you select to deliver the item. Such charges may apply when the item exceeds established shipping rate charges. For example, delivery of an oversized item may incur an additional shipper/item charge. Additional shipper/item charges apply when defined for the shipper. Ad hoc charge: An additional charge, such as a charge for a gift box, that you assign at order entry. You initially define ad hoc charges in the Additional Charges table. Dollar discount: An additional charge (credit) that is applied based on the total value of the merchandise. Note: The Add'l charges field in standard Order Inquiry corresponds to the Chg field on Order Entry.Numeric, 20 positions with a 2-place decimal; display-only. |
| Add'l freight (Additional freight charges) |
The total amount for freight charges exceeding the order's base freight charge. This is a shipper-level charge directly associated with the order, as opposed to the line item. Additional freight is defined for the shipper in the Ship Via table. Examples of additional freight charges that might apply include charges for overnight shipping, second day delivery, padded van, etc. Additional freight charges may include the standard freight charges, depending on how you have set up the shipper. In this case, the Freight field is blank. Note: The Add'l freight field in standard Order Inquiry corresponds to the Frt+ field in Order Entry.Numeric, 20 positions with a 2-place decimal; display-only. |
| Total |
The total amount billed or credited, including all related merchandise charges, freight, tax, handling, additional charges, and additional freight. Numeric, 20 positions with a 2-place decimal; display-only. |
| Discount amount |
The difference between the actual price charged for items and the offer prices. Comparing this amount to the original offer price gives you an indication of the amount that the order varied from the original offer price. A negative amount in Indicates a charge greater than the original offer price. Price overrides: When you override the price of an item, the system uses the following rules in determining what portion of the selling price constitutes a discount: |
Example: The price override amount entered was $10.00 and an additional discount coupon of $1.00 was applied; the discount amount is $1.00.
Example: The item offer price is $15.00, the price override amount entered was $10.00, and an additional coupon discount of $1.00 was applied; the discount amount is $6.00.
Example: The price override amount entered was $10.00 and an additional coupon discount of $1.00 was applied; the discount amount is -$9.00. |
See Overriding the Item/SKU Offer Price for an overview. Note: The setting of the Override item offer price field has no effect on orders you receive through the order API. If there is a price override reason code in the inbound order message, the system always processes these orders as if the field is unselected.Numeric, 20 positions with a 2-place decimal; display-only. |
| Hidden freight |
The amount of the merchandise charge that represents hidden freight. Hidden freight, defined at the Item Offer level, is a freight charge that you want to track but not reveal to the customer. Note: Hidden freight will not appear on this screen if you override an item price in Order Entry.Numeric, 13 positions with a 2-place decimal; display-only. |
Purpose: Use this screen to review the distribution of payment methods on an order invoice, and to select a specific payment method for detailed review.
How to display this screen: At the Display Invoices Screen, select Pay Methods for an invoice.
How to use this screen: Use this screen to review summary information on invoice payment method records; in addition, you can review a payment method by selecting Display for it.
See Display Invoice Payment Method Screen (Reviewing Detail) for field descriptions.
Purpose: Use this screen to review detailed information, including unpaid balances, for a specific payment method used on the order.
How to display this screen: At the Display Invoice Pay Methods Screen, select Display for a payment method.
| Order # |
A number the system assigns to uniquely identify an order. Numeric, 8 positions; display-only. |
| Invoice # |
A number the system assigns to uniquely identify an invoice. Numeric, 7 positions; display-only. |
| Pay method |
Represents the method of payment on the order. Pay method codes are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Numeric, 2 positions; display-only. |
| Description |
The description of the payment method code. Alphanumeric, 30 positions; display-only. |
| Merchandise |
The total value of the merchandise. Merchandise amount does not include tax, handling, additional charges, duty or freight. Numeric, 20 positions with a 2-place decimal; display-only. |
| Merchandise balance |
The unpaid portion of the merchandise total. Numeric, 20 positions with a 2-place decimal; display-only. |
| Freight |
The freight charges for the invoice assigned to the payment method. Numeric, 20 positions with a 2-place decimal; display-only. |
| Freight balance |
The unpaid portion of the freight. Numeric, 20 positions with a 2-place decimal; display-only. |
The total amount for freight charges exceeding the order's base freight charge. Additional freight reflects charges that are specific to the carrier, as defined for the shipper in the Ship Via table. See Working with Ship Via Codes (WVIA). Example: Additional freight charges that might apply include charges for overnight shipping, second day delivery, padded van, etc. Additional freight charges may include the standard freight charges, depending on how you have set up the shipper. Numeric, 20 positions with a 2-place decimal; display-only. |
| Additional freight balance |
The unpaid portion of the additional freight balance charge. Numeric, 20 positions with a 2-place decimal; display-only. |
The total charges exceeding standard charges on the current order. The system validates additional charges against the Additional Charges table during Order Entry. See Establishing Additional Charge Codes (WADC). Numeric, 20 positions with a 2-place decimal; display-only. |
| Additional charges balance |
The unpaid portion of the additional charges. Numeric, 20 positions with a 2-place decimal; display-only. |
The cost of any special handling on the order, such as personalizing, monogramming, or engraving, and any gift wrapping charges. This field includes the duty charges, if any, for the payment method. Numeric, 20 positions with a 2-place decimal; display-only. |
| Handling balance |
The unpaid portion of the handling charge and/or duty charge, if any. Numeric, 20 positions with a 2-place decimal; display-only. |
| Tax |
The total sales tax that applies to the shipment on this payment method. This total does not include any hidden tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Tax balance |
The unpaid portion of the taxes on the shipment on this payment method, excluding hidden tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Total |
The total for the pay method, including merchandise, freight, additional freight, additional charges, handling and tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| GST (Goods and Services tax) |
The Canadian federal Goods and Services tax that applies to the shipment on this payment method. Numeric, 20 positions with a 2-place decimal; display-only. |
| GST balance |
The unpaid portion of the Canadian federal Goods and Services tax on the shipment on this payment method. Numeric, 20 positions with a 2-place decimal; display-only. |
| PST (Provincial Services Tax) |
A Canadian provincial services tax that applies to the shipment on this payment method. Numeric, 20 positions with a 2-place decimal; display-only. |
| PST balance |
The unpaid portion of the Canadian provincial services tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Order level freight |
Freight charges that apply to the total shipment. Numeric, 20 positions with a 2-place decimal; display-only. |
The unpaid portion of the order level freight balance charged on the shipment. Numeric, 20 positions with a 2-place decimal; display-only. |
| Order level freight tax |
The total freight tax on the shipment, excluding hidden tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Order level freight tax balance |
The unpaid portion of the order level tax charged on the shipment, excluding hidden tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Deposit created |
The date the deposit was created. Numeric, 6 positions (in user date format); display-only. |
| Adjusted Amt |
The adjusted deposit amount after performing Credit Card Net Exchange Billing. Numeric, 20 positions with a 2-place decimal; display-only. |
| Deposit To Date |
The total amount deposited for the pay method, including merchandise, freight, additional freight, additional charges, handling and tax. Numeric, 20 positions with a 2-place decimal; display-only. |
| Suppress deposit |
Indicates whether the system will include this invoice payment method when you run Processing Auto Deposits (SDEP). Valid values are:
The system determines how to set this flag based on the setting of the Suppress deposit flag at the Display Order Pay Type Screen (1 of 2). This field can be selected if:
Only credit card payment methods can have this flag selected. This flag is selected only for the first time that you bill against the payment method; afterward, the system resets the flag for the payment method to Unselected. |
Purpose: Use this screen to review the invoice details for each item on the order that has been billed, and to select a detail for review.
How to display this screen: At the Display Invoices Screen, select Details for an invoice.
| Ln # (Line number) |
The number of the invoice line on which the item appears. Numeric, 3 positions; display-only. |
| Item # (Item code) |
Represents a unit of inventory. Item codes are defined in and validated against the Item table. See Performing Initial Item Entry (MITM). Alphanumeric, 12 positions; display-only. |
| SKU (Stock keeping unit) |
A code that defines an item's special characteristics, such as size and color. SKU codes are defined in and validated against the SKU table. Alphanumeric, three 4-position fields; display-only. |
| Ship qty (Shipped quantity) |
The shipped quantity of the invoiced item. The quantity is negative in the case of a return. Numeric 5 positions; display-only. |
| Price |
The actual unit price of the shipped or returned item. Numeric, 13 positions with a 2-place decimal; display-only. |
| Ship date |
The date the invoice line shipped or the return was processed. This is the Start date from the billing async job. Numeric, 6 positions (in user date format); display-only. |
| Return qty (Return quantity) |
The quantity of the item billed on this invoice that the customer has returned. Numeric, 5 positions; display-only. |
| Return date |
The most recent date when the customer returned any quantity of the item billed on this invoice. Numeric, 6 positions (in user date format); display-only. |
Display invoice detail for an item |
Select Display for an item to advance to the Second Display Invoice Detail Screen. |
Display payment methods for an item |
Select Display pay methods for an item to advance to the Display Invoice Detail Pay Methods Screen. |
Display invoice detail charges for an item, such as duty |
Select Detail charges for an item to advance to the Invoice Detail Charges Screen. |
Purpose: Use this screen to review the charges for particular items on the invoice.
How to display this screen: Select Display for an invoice at the First Display Invoice Detail Screen.
| Pick control # |
A number the system assigns to uniquely identify a pick slip. Numeric, 7 positions; display-only. |
| Qty shipped (Quantity shipped) |
The total quantity of the item you have shipped to the customer. The shipment date appears to the right. Quantity: numeric, 5 positions; display-only. Date: numeric, 6 positions (in user date format); display-only. |
| Qty returned (Quantity returned) |
The total quantity of the item returned by the customer. The return date appears to the right. Quantity: numeric, 5 positions; display-only. Date: numeric, 6 positions (in user date format); display-only. |
| Qty credited (Quantity credited) |
The total quantity of the item for which you have credited the customer. The system does not track the credit date. Quantity: numeric, 5 positions; display-only. |
| Price |
The unit price of the item. Numeric, 13 positions with a 2-place decimal; display-only. |
| Cost |
The unit cost of the item. Numeric, 13 positions with a 4-place decimal; display-only. |
| Freight |
The total extended freight charge for all units of this item. Only line-level freight charges appear on this screen. Numeric, 20 positions with a 2-place decimal; display-only. |
| Discount |
The total extended discount amount applied to all units of this item. Price overrides: When you override the price of an item, the system uses the following rules in determining what portion of the selling price constitutes a discount: |
The price override amount entered was $10.00 and an additional coupon discount of $1.00 was applied; the discount amount is -$9.00. See Overriding the Item/SKU Offer Price for an overview. Numeric, 13 positions with a 2-place decimal; display-only. |
| Tax |
The tax amount for the units of the item on the invoice. If a tax override amount is defined for the order line and you process multiple shipments against the line, the system prorates the tax override amount across the units shipped on the order line to determine the new tax override amount and the tax amount to apply to each shipment. Example: If the tax override amount for the order line is 9.00 and the order quantity is 3, the system charges 3.00 if you ship 1 unit of the item and then charges 6.00 if you ship the remaining 2 units of the item. Numeric, 20 positions with a 5-place decimal; display-only. |
| Handling |
The total extended handling charges for all units of this item. Note: This handling total does not include any duty charges for the item.Numeric, 20 positions with a 2-place decimal; display-only. |
Purpose: Use this screen to review information about the payment methods associated with the item shipment/invoice. This information differs from the Display Invoice Payment Method Screen (Reviewing Detail) in that it shows how payment types are applied to shipments of individual items on the order.
The system does not create invoice detail pay method records for returns that you process through Order Maintenance; it creates these records only for returns that you process by entering a negative quantity in Order Entry.How to display this screen: Select Display pay methods for an invoice at the First Display Invoice Detail Screen.
About this screen: This screen displays how a payment method was charged for the shipment of an item.
See Display Invoice Payment Method Screen (Reviewing Detail) for descriptions of the fields on this screen.
The Handling field on this screen includes any duty charges for the item and payment method.Invoice Detail Charges Screen
Purpose: Use this screen to review any duty, shipper/item, or hidden tax charges for an item.
How to display this screen: Select Detail charges for an item at the First Display Invoice Detail Screen.
| Charge type |
The type of charge on the invoice detail. The description of each charge appears to the right. Valid values are:
Display-only. |
| Amount |
The amount of the charge for the item. The method for calculating duty charges is indicated in the fields to the right. Numeric, 13 positions with a 2-place decimal; display-only. |
| Duty rate percent |
The percentage the system used to calculate the duty amount. The system multiplies this percentage by the extended item price. Numeric, 5 positions with a 2-place decimal; display-only. |
| Duty rate amount |
The flat rate the system used to calculate the duty amount. The system multiplies this amount by the total unit quantity. Numeric, 20 positions with a 2-place decimal; display-only. |
The Invoice Cost Detail screen is not currently implemented.Display Invoice Address Screen (Billing Address)
Purpose: Use this screen to review the billing address associated with an invoice.
Where does the billing address come from? Depending on how you create the order, the billing address can be:
- the name and address from the Customer Bill to table, if there is a bill-to account associated with the order; otherwise,
- the name and address of the Customer Sold To who placed the order. This customer might differ from a Customer Sold To who receives the order.
How to display this screen: Select Billing address for an invoice at the Display Invoices Screen.
This screen is available only if the Capture Addresses for Invoice (J24) system control value was selected at the time that the system generated the invoice. See that system control value for more information.| Field | Description |
| Order # |
| Invoice # |
| Type |
Set to Billing Address. Alphanumeric, 15 positions; display-only. |
| Name |
The company name and name for the billing address. Alphanumeric, 41 positions; display-only. |
| Address |
Up to four lines of address information. Alphanumeric, 32 positions each; display-only. |
| Apt/Suite |
The apartment, suite, rural route, or floor number for the billing address. Alphanumeric, 10 positions; display-only. |
| City/State/Zip |
The city, state code, and zip or postal code for the billing address. City: 25 positions; display-only. State: 2 positions; display-only. Zip: 10 positions; display-only. |
Purpose: Use this screen to review the shipping address associated with an invoice.
Where does the shipping address come from? Depending on how you create the order, the shipping address can be:
- the order-level shipping address, as set up through Assigning an Order Shipping Address
- a permanent shipping address for the customer, as set up through Using a Permanent Shipping Address in Order Entry
- a recipient customer, as set up through Adding a Recipient Order in Order Entry
How to display this screen: Select Shipping address for an invoice at the Display Invoices Screen.
| Order # |
| Invoice # |
| Type |
Set to Shipping Address. Alphanumeric, 15 positions; display-only. |
| Name |
The company name and name for the shipping address. Alphanumeric, 41 positions; display-only. |
| Address |
| Apt/Suite |
The apartment, suite, rural route, or floor number for the shipping address. Alphanumeric, 10 positions; display-only. |
| City/State/Zip |
The city, state code, and zip or postal code for the shipping address. City: 25 positions; display-only. State: 2 positions; display-only. Zip: 10 positions; display-only. |
| Delivery code |
A code representing the type of delivery address for a postal code. Valid values are:
Some shippers, such as UPS, charge different rates based on the type of delivery address on an order. For example, shipping to a business address is cheaper than shipping to a residential address. You can define the delivery code for a postal area to insure that the best possible rate is charged for shipping an order. Alphanumeric, 1 positions; display-only. |
Purpose: Use this screen to review invoice payment information, such as:
- the payment plan associated with the invoice, if any
- the total amount deposited to date for each invoice
- the total amount to deposit for each invoice
- the date the deposit is available for processing
How to display this screen: Select Invoice Pay Summary at the Display Invoices Screen.
An error message indicates if the Deferred and Installment Billing (F51) system control value is unselected:
Deferred/Installment Billing feature required for this function
| Order # |
A number the system assigns to uniquely identify the order. Numeric, 8 positions; display-only. |
| Invoice # |
The number the system assigns to a customer's bill or credit. Numeric, 7 positions; optional. |
| Pay type |
Represents the method of payment on the order. Pay methods are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Numeric, 2 positions; display-only. |
| Date (Invoice date) |
The date you billed the merchandise. Numeric, 6 positions; display-only. |
| I/D (Payment plan type) |
A value that identifies whether the invoice payment method is associated with a deferred or installment payment plan. Valid values are:
| CC/C status (Credit card credit status) |
A value that indicates the credit status of the return. A value only displays in this field if the invoice payment method is associated with a return or exchange. The system does not process a credit card credit against an installment or deferred billing order before the deposit has been processed. This ensures that you do not credit the customer's credit card before the card has been charged. Valid values are:
blank = Refund deposited. This field is also blank if the invoice payment method is not associated with a return or exchange. Alphanumeric, 1 position; display-only. |
| To date (Deposit to date) |
The total amount deposited to date. When you process a deposit for an installment payment plan, the system updates this field by the deposit amount. Example: You have an installment payment plan assigned to the order for 3 installments of $30.00 on the 15th of every month.
Numeric, 20 positions with a 4-place decimal; display-only. |
| Total (Total amount to deposit) |
The total amount that needs to be deposited in order for the invoice to be completely deposited. An error message indicates if you try to change an invoice payment method that has been completely deposited: Invoice (399) has been completely deposited and cannot be changed. Numeric, 20 positions with a 4-place decimal; display-only. |
| Rel date (Deposit release date) |
This date indicates when the invoice is eligible for deposit. If this date is equal to or prior to the current date, the invoice payment is eligible for deposit. The system updates this field when a deposit is confirmed with the next deposit release date if there is a remaining amount to deposit, for example, in installment billing. Regular (non-payment plan) Orders: For regular orders, the deposit release date is the same as the invoice date. The deposit is eligible for processing immediately after billing. |
Deferred Orders: For orders containing a deferred payment plan, the deposit release date is either a fixed date or is based on a specific interval. If the date is based on an interval, the interval can be calculated based on order date or invoice date. If the deposit release date is a fixed date, the system compares the fixed date against the invoice date:
If the deposit release date is based on an interval and is calculated based on invoice date, the system adds the interval number of days to the invoice date and compares this date against the expiration date:
Installment Orders: For orders using an installment payment plan, the deposit release date is either the next fixed day of the month or is based on a specific interval. If the deposit release date is based on an interval, the system calculates the next installment interval by adding the interval number of days to the current date. If the deposit release date is a fixed date:
Credit Invoices: For a credit invoice payment method, the deposit release date associated with the original invoice is used as long as that date is on or after the current date. If the deposit release date of the original invoice is earlier than the current date, the deposit release date of the credit invoice is updated with the current date. This ensures that the customer is not credited until he has been billed; but if the customer has been billed, the credit is released immediately. Numeric, 6 positions (in user date format); display-only. |
Change Invoice Pay Method |
Select Change for an invoice payment method to advance to the Change Invoice Pay Method Screen. Error messages: The Change Invoice Pay Method screen might display these error messages when you Select Change for an invoice payment method: Pay category must be credit card. This message indicates that the invoice payment is not a credit card payment type. Invoice (397) has been completely deposited and cannot be changed. This message indicates that the invoice payment associated with a deferred or installment payment plan has been completely deposited. Not authorized to change invoice payment information. This error message indicates that you do not have authority to the Change Invoice Payment Information (A82) secured feature. |
Display Invoice Pay Method |
Select Display for an invoice payment method to advance to the Display Invoice Pay Method Screen (Reviewing Deposit Information). |
Display Deposit History |
Select Deposit History for an invoice payment method to advance to the Display Deposit History Screen. |
Display Order Payment History |
Select Payment History for an invoice payment method to advance to the Display Order Payment History Screen. |
Purpose: Use this screen to:
- Review deposit information, such as the total amount to deposit, the amount already deposited and the amount remaining to deposit.
- Review or change the deposit release date, installment information or credit card information.
- Apply a prepaid check or cash payment.
Typically, you use this screen when you receive a rejected deposit for an invoice associated with a deferred or installment payment plan, and you need to change the credit card information before resending the deposit to the service bureau.
How to display this screen: Select Change for an invoice payment method at the Invoice Pay Summary Screen. You can also advance to this screen by selecting Change for a rejected deposit in Submit Rejected Deposits. See Processing Auto Deposits (SDEP).
| Order # |
| Invoice # |
The number the system assigns to a customer's bill or credit. Numeric, 7 positions; display-only. |
| Pay method |
The code and description that represents the method of payment on the order. You can change the payment method associated with this invoice payment method by selecting Change Card Number at the Change Invoice Pay Method screen, for example, the customer's credit card was stolen or the credit card was declined. See Changing Credit Card Information for an Invoice Payment Method. Pay methods are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Numeric, 2 positions; display-only. |
| Invoice date |
The date you shipped and billed the merchandise. Numeric, 6 positions; display-only. |
| Total amount (Total amount to deposit) |
The total amount to deposit in order for the invoice to be completely deposited. Numeric, 20 positions with a 2-place decimal. |
| Adjustment (Deposit adjustment amount) |
The amount of the deposit that has been changed or is in transition. The system updates the deposit adjustment amount with this information:
| Amount deposited (Deposit to date) |
The total amount deposited to date. When a deposit is confirmed, the system updates this field by the deposit amount. Example: You have an installment payment plan assigned to the order for 3 installments of $30.00 on the 15th of every month. The first installment updates this field to $30.00. The second installment updates this field to $60.00. The third installment updates this field to $90.00. When a deposit is confirmed, the system updates this field with the amount deposited. Numeric, 20 positions with a 2-place decimal; display-only. |
| Remaining (Deposit remaining amount) |
The amount remaining to deposit. The system uses this calculation to determine the deposit remaining amount: deposit amount - amount deposited to date - prepaid amount - adjustment amount = deposit remaining amount Numeric, 20 positions with a 2-place decimal; display-only. |
| Card Number |
The credit card number the customer used on the order. Information will be provided by Oracle at a later date. You can change the credit card number on the Change Credit Card window. See Changing Credit Card Information for an Invoice Payment Method. Alphanumeric, 20 positions; display-only. |
| Authorization # |
The number used to authorize the credit card payment. The original authorization number from pick slip generation is retained and displays for a payment plan order, even after you receive a full authorization for the deposit. You can change the authorization number on the Change Credit Card window. See Changing Credit Card Information for an Invoice Payment Method. Numeric, 16 positions; display-only. |
| Expiration date |
The date the credit card is no longer active. Information will be provided by Oracle at a later date. Numeric, 4 positions (MMYY format); display-only. |
| Authorization date |
The date you manually authorize a payment method, or the date the payment method receives an authorization from the authorization service. You can change the authorization date on the Change Credit Card window. See Changing Credit Card Information for an Invoice Payment Method. Numeric, 6 positions (in user date format); display-only. |
| Issue # |
An incremental issue number, assigned by some banks when they replace a card because it is lost or stolen. Debit cards might require a start date, an issue number, both, or neither. The Require issue # flag for the pay type controls whether an issue number is required or optional. You can change the issue number at the Change Credit Card for window. See Changing Credit Card Information for an Invoice Payment Method. Alphanumeric, 2 positions; display-only. |
| Start date |
The first date when the card is effective. The Require start date flag for the pay type controls whether the start date is required or optional. Numeric, 4 positions; display-only. |
| Deposit release date |
This date indicates when the invoice is eligible for deposit. If this date is on or earlier than the current date, the invoice payment is eligible for deposit. The system updates this field when a deposit is confirmed with the next deposit release date if there is a remaining amount to deposit, for example, in installment billing. Regular (non-payment plan) OrdersFor regular orders, the deposit release date is the same as the invoice date. The deposit is eligible for processing immediately after billing. |
Deferred Orders: For orders using a deferred payment plan, the deposit release date is either a fixed date or is based on a specific interval. If the date is based on an interval, the interval can be calculated based on order date or invoice date. If the deposit release date is a fixed date, the system compares the fixed date against the invoice date:
Installment Orders: For orders containing an installment payment plan, the deposit release date is either the next fixed day of the month or is based on a specific interval.
Credit Invoices: For a credit invoice payment method, the deposit release date associated with the original invoice is used as long as that date is on or after the current date. If the deposit release date of the original invoice is earlier than the current date, the deposit release date of the credit invoice is updated with the current date. You might want to change the deposit release date associated with a credit invoice to allow the credit invoice to process before the debit invoice. This ensures that the customer is not credited until he has been billed. Error Messages: An error message indicates if you enter a date that is later than the expiration date associated with the credit card: Deposit Release Date 110199 greater than Expiration Date 599. An error message indicates if you enter a date that is earlier than today's date: Date entered must not be less than today's date Numeric, 6 positions (in user date format); required. |
| Rejected deposit (Rejected deposit pending) |
An informational message informing you a deposit amount has been rejected by the authorization service. When a deposit amount is rejected, the system:
Alphanumeric, 25 positions; display-only. |
| Rejected (Rejected amount) |
The deposit amount that has been rejected by the authorization service. Numeric, 20 positions with a 2-place decimal; display-only. |
| Resubmit |
Indicates whether you wish to resubmit the rejected deposit amount for authorization and deposit. Valid values are:
| Write off |
This flag indicates whether you wish to write-off the total amount to deposit for this invoice payment method, for example, there is no chance of collecting the money from the customer. Valid values are:
Note: When you write-off a deposit amount, the amount is written off immediately. |
| Amt (Write off deposit amount) |
The rejected deposit amount you wish to write off. The system removes the invoice payment method from the Resubmit Reject Deposits screen in Submit Rejected Deposits when you write off a rejected deposit. See Processing Auto Deposits (SDEP). Note: When you select OK to write off a rejected deposit, the write off occurs immediately.Numeric, 20 positions with a 2-place decimal; optional. |
| Delete |
This flag indicates whether you wish to delete the rejected deposit. Valid values are:
| # of installments |
The total number of installments assigned to this invoice payment method. Installment billing allows you to break the payment evenly into installments (for example, 3 payments on the 1st of each month). This field is used with an installment payment plan only. Numeric, 3 positions; display-only. |
| # remaining installment |
The number of installments remaining. This number is the same as the number of installments when the invoice payment method record is first created and reduces by one each time an installment is sent for deposit. This field is used with an installment payment plan only. Numeric, 3 positions; display-only. |
| Installment interval |
The number of days between installments. The system uses this interval number to determine the next deposit release date if you are basing installment dates on intervals, for example, 3 installments in 30 day intervals. The system determines the installment dates based on the order date. For example, if the order date is 09/01/06, the first installment date would be 09/01/06. The system would determine the next installment date by adding 30 days to the first installment date: 09/01/06 + 30 = 10/01/06. Numeric, 3 positions; display-only. |
| Fixed installment day |
The day of the month when an installment is billed. The system uses the fixed installment date if you have defined a fixed date for each installment. For example, if 15 is defined here, each installment would be due on the 15th of every month. Numeric, 2 positions; display-only. |
| Pay type |
Represents a method of payment on the order. You can enter a prepaid amount by entering a cash/check pay type in this field and entering the amount you wish to prepay in the Prepaid amount field. An error message indicates if you enter a pay type other than pay type 1 (cash/check): Pay category must be '1' Cash/Check. Pay types are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Numeric, 2 positions; optional. |
| Prepaid amount |
The amount you wish to prepay for this pay method, for example, the customer's credit card was rejected and the customer decides to send you a check instead. If you enter an amount in this field, the system subtracts the amount from the Deposit amount remaining field. Example: Deposit amount remaining = 130.75 Prepaid amount = 5.00 130.75 - 5.00 = 125.75 (this is the remaining amount to deposit) Numeric, 14 positions; optional. |
| Prepaid to date |
The total amount prepaid to date. Numeric, 20 positions with a 2-place decimal. |
Work with rejected deposits |
Change credit card information |
Select Change Card Number. See Changing Credit Card Information for an Invoice Payment Method. |
Working with Rejected Deposits
From the Change Invoice Pay Method Screen you can also resubmit, write off or delete a rejected deposit amount.
To resubmit a rejected deposit:
Select the Resubmit field and select OK. The system sends the rejected deposit amount back to the authorization service for reauthorization. The Rejected amount, Resubmit, Write off, Write off amount and Delete fields are cleared from the screen.
The Change Invoice Payment Method screen displays this error message if you try to reenter the screen and the deposit amount that you have resubmitted completely deposits the amount for the invoice payment:
Invoice has been completely deposited and cannot be changed.
This message displays even if the submitted deposit amount has not been confirmed by the authorization service.
The system also writes an order payment history record indicating the deposit amount was resubmitted.
When you select OK to resubmit, the deposit amount is resubmitted the next time you process deposits.To write off a rejected deposit:
Select the Write off field and:
- If you wish to write off the remaining amount to deposit for this invoice payment method, select OK. You return to the Invoice Pay Summary screen.
- If you wish to write off a specific amount, enter this amount in the Write off amount field and select OK. The Confirm Accept window prompts you for confirmation.
When you write off a deposit amount:
- The system updates the Adjustment field with the rejected deposit amount. If you did not enter a specific write off amount, this is the amount remaining to deposit. If you entered a specific write off amount, this is the amount you entered in the Write off amount field.
- The system updates the Remaining field with the amount remaining to deposit. The system determines the remaining amount to deposit using this calculation:
total amount to deposit - write off amount = remaining amount to deposit
For a deferred payment plan:
If the invoice payment method is associated with a deferred payment plan, the system updates the Adjustment field with the write off amount and updates the Remaining field with the remaining amount to deposit, if any.
Example:
Total amount to deposit = 69.00
Rejected deposit amount = 69.00
Write off amount = 30.00
In this situation, the system updates the Adjustment amount field to 30.00 (the write off amount) and updates the Remaining field with 39.00 using this calculation:
total amount to deposit (69.00) - write off amount (30.00) = remaining amount to deposit (39.00)
When you receive an authorization for the deposit, the system updates:
- the Amount deposited field to 39.00
- the Remaining field to .00
- the Adjustment field remains at 30.00 (this is the write off amount)
For an installment payment plan:
If the invoice payment method is associated with an installment payment plan, the system updates the Adjustment field with the write off amount and updates the Remaining field with the remaining amount to deposit, if any. If there is a remaining amount to deposit, the system redistributes the amount remaining across the remaining installment intervals.
Example:
Number of installments = 3
Installment amount = 23.00
Rejected deposit amount = 23.00
The system also updates the Installment amount for the remaining installment intervals to 19.50 using this calculation:
remaining amount to deposit (39.00) / the number of remaining installments (2) = installment amount (19.50)
When you receive an authorization for the deposit, the system:
- updates the Amount deposited field to 19.50
- updates the Remaining field to 19.50 (this is the amount of the next installment)
- decreases the Number of remaining installments field by 1
- leaves the Adjustment field at 30.00 (this is the write off amount)
If you write off the remaining amount to deposit for this invoice payment method, the system updates the Adjustment field with the amount remaining to deposit plus the rejected deposit amount and updates the Remaining field with the rejected deposit amount.To delete a rejected deposit:
Select the Delete field. The system deletes the rejected deposit amount and displays the message Deleted. No further deposits. at the Change Invoice Pay Method screen.
Purpose: You can change credit card information at the Change Credit Card window. A history message is written, indicating Card Number has been changed. You can review this history at the Display Order Payment History Screen.
How to display this window: Select Change Card Number at the Change Invoice Pay Method Screen. Additional information will be provided by Oracle at later date.
| Pay method |
The code and description that represents the method of payment on the order. Error messages: If you entered a payment method other than a credit card: Pay category must by credit card. If you entered a pay method that is associated with a credit card authorization and deposit service different from the original credit card: Auth Service Code must match Original Service Code. Pay methods are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Numeric, 2 positions; required. |
| Card Number |
The credit card number the customer used on the order. Information will be provided by Oracle at a later date. Alphanumeric, 20 positions; required. |
| Expiration date |
The date the credit card is no longer active. The Require expiration date flag for the pay type controls whether an expiration date is required. For example, a stored value card credit card type typically does not require an expiration date. See Types of Credit Cards for more information. Numeric, 4 positions (MMYY format); required or optional. |
| Issue # |
An incremental issue number, assigned by some banks when they replace a card because it is lost or stolen. Debit cards might require a start date, an issue number, both, or neither. The Require issue # flag for the pay type controls whether an issue number is required or optional. It is important to enter the issue number exactly as it appears on the card. For example, an issue number of 1 is different from an issue number of 01; also, an issue number of 0 is different from a blank issue number. Each bank has its own requirements and conventions regarding issue number. If an issue number is required but not entered in order entry or order maintenance, the system displays an error message: Credit card issue# () is not valid. Note: An entry of 00 (two zeros) is not considered a valid issue number.Alphanumeric, 2 positions; required or optional. |
| Start date |
The first date when the card is effective. The Require start date flag for the pay type controls whether the start date is required or optional. You might use a start date for a debit card to indicate the first date when the card is effective. If a start date is required but not entered, the system displays an error message in order entry or maintenance: Credit card start date (0) is not valid.
Numeric, 4 positions; required or optional. |
| Authorization # |
The number used to authorize the credit card payment. The original authorization number from pick slip generation is retained and displays for a payment plan order, even after you receive a full authorization for the deposit. Numeric, 16 positions; optional. |
The date you manually authorize a payment method, or the date the payment method receives an authorization from the authorization service. Numeric, 6 positions (in user date format); optional. |
Purpose: Use this screen to review:
- deposit information, such as the total amount to deposit, the amount already deposited and the amount remaining to deposit
- the deposit release date, installment information or credit card information
- the prepaid check or cash payment
How to display this screen: Select Display for an invoice payment method at the Invoice Pay Summary Screen.
Field descriptions: See Change Invoice Pay Method Screen for a description of the other fields on this screen.
| Installment (Installment amount) |
The amount due for the next installment. This field displays only for invoice payment methods associated with an installment payment plan. Numeric, 20 positions with a 2-place decimal; display-only. |
| Schedule (Installment scheduled date) |
The deposit date for the next installment. This date indicates when the invoice is eligible for deposit. If this date is equal to or prior to the current date, the invoice payment is eligible for deposit. The system updates this field when a deposit is confirmed with the next deposit date if there is a remaining amount to deposit. The system updates this field to 99/99/99 when a deposit amount is rejected. This field displays only for invoice payment methods associated with an installment payment plan. Numeric, 6 positions (in user date format); display-only. |
Purpose: Use this screen to review invoice deposit attempts and responses.
How to display this screen: Select Deposit History for an invoice payment method at the Invoice Pay Summary Screen or the Display Order Payment Methods Screen.
| Order # |
| Pay type |
| Issue # |
An incremental issue number, assigned by some banks when they replace a card because it is lost or stolen. Debit cards might require a start date, an issue number, both, or neither. The Require issue # flag for the pay type controls whether an issue number is required or optional. It is important to enter the issue number exactly as it appears on the card. For example, an issue number of 1 is different from an issue number of 01; also, an issue number of 0 is different from a blank issue number. Each bank has its own requirements and conventions regarding issue number. If an issue number is required but not entered in order entry or order maintenance, the system displays an error message: Credit card issue# () is not valid. Note: Debit cards might require a start date, an issue number, both, or neither. Even if a start date or an issue date are not required, you can still enter this information in order entry if it is available.Alphanumeric, 2 positions; display-only. |
| Start date |
The first date when the card is effective. The Require start date flag for the pay type controls whether the start date is required or optional. You might use a start date for a debit card to indicate the first date when the card is effective. Numeric, 4 positions; display-only. |
| Card Number |
The credit card number the customer used on the order. Information will be provided by Oracle at a later date. Alphanumeric, 20 positions; display-only. |
| Exp date |
The date the credit card is no longer active. The expiration date may be zero, depending on the setting of the Require expiration date flag for the pay type. For example, a stored value card credit card type typically does not require an expiration date. See Types of Credit Cards for more information. You can change the expiration date on the Change Credit Card window. See Changing Credit Card Information for an Invoice Payment Method. Numeric, 4 positions (MMYY format); display-only. |
| Invoice # |
The number the system assigns to a customer's bill or credit. The system generates an invoice during billing. Numeric, 7 positions; display-only. |
| Type (Transaction type) |
Indicates the type of deposit. Valid values are:
| Date (Deposit created date) |
The date when this deposit history record was created. This is the date when the invoice pay method was deposited. The deposit created date ensures that the deposit is not sent again. Numeric, 6 positions (in user date format); display-only. |
| Amount (Deposit amount) |
The amount deposited. The system uses this calculation to determine the amount to deposit: For deferred payment plans: prepaid amount - adjustment amount - total amount deposited to date = deposit amount For installment payment plans: prepaid amount - adjustment amount - total amount deposited to date / intervals remaining = deposit amount Numeric, 20 positions with a 2-place decimal; display-only. |
| Status (Deposit status) |
The status of this deposit:
Display-only. |
| Response (Vendor response code) |
A code assigned by the authorization service that identifies whether the credit card deposit was authorized and approved or declined, and the reason for the authorization decline. Vendor response codes are defined in and validated against the Authorization Service Vendor Response table. See Defining Vendor Response Codes. Alphanumeric, 10 positions; display-only. |
| Bill mthd (Flexible payment bill method) |
A code that identifies whether this deposit is related to a deferred or installment payment plan. Valid values:
The system uses this code to sort deposit records. Alphanumeric, 1 position; display-only. |
Display deposit history detail |
Select Details for a deposit to advance to the Display Deposit History Detail Screen. |
Purpose: Use this screen to review the deposit history details, such as the action code and the deposit service associated with this deposit. Additional information will be provided by Oracle at a later date.
How to display this screen: Select Details for a deposit at the Display Deposit History Screen.
| Order # |
| Invoice # |
| Merchant ID (Merchant identification code) |
The account number assigned by the service bureau to identify transmissions to and from your company. Alphanumeric, 20 positions; display-only. |
| Issue # |
| Start date |
| Card Number |
The credit card number sent to be deposited. Additional information will be provided by Oracle at a later date. You can change the credit card number on the Change Credit Card window. See Changing Credit Card Information for an Invoice Payment Method. Alphanumeric, 20 positions; display-only. |
| Exp date |
| Deposit amount (Deposit amount) |
The amount deposited or the amount sent to be deposited. The system uses this calculation to determine the amount to deposit: For deferred payment plans: prepaid amount - adjustment amount - total amount deposited to date = deposit amount For installment payment plans: prepaid amount - adjustment amount - total amount deposited to date / intervals remaining = deposit amount Numeric, 20 positions with a 2-place decimal; display-only. |
| Deposit date (Deposit created date) |
The date when this deposit history was created. This is the date when the invoice pay method was deposited. The deposit created date ensures that the deposit is not sent again. Numeric, 6 positions (in user date format); display-only. |
| Transaction type (Transaction type) |
| Response code (Vendor response code) |
A code assigned by the authorization service that identifies whether the credit card deposit was authorized and approved or declined, and the reason for the authorization decline. Vendor response code are defined in and validated against the Authorization Service Vendor Response table. See Defining Vendor Response Codes. Note: In order to see the full vendor response code description, a Description must be defined for the response code on the Work with Vendor Response Screen.Alphanumeric, 10 positions; display-only. |
| Action code |
A code set to the deposit service indicating the action to take for reauthorization. Valid values are:
| Authorization code |
The authorization code sent with this deposit. This code indicates that the amount to charge for this credit card has been authorized manually or through a credit card authorization service. Alphanumeric, 16 positions; display-only. |
| Billing method (Flexible payment bill method) |
The system uses this code to sort deposit records. Display-only. |
| Deposit service |
A code for the service bureau that performs credit card deposits for this pay type. Alphanumeric, 3 positions; display-only. |
| Deposit status |
The status of this deposit. Valid values are:
Display-only. |
Purpose: Use this screen to review messages written by the system describing changes in payment and invoice activity for the order. The system records all activity associated with the order payment method or invoice payment method defined for the order on this screen, such as:
- deposits made
- invoices netted against each other
- changes made by users
- deactivation of a pay type
- adding, changing, or deleting the payment plan associated with the payment type on the order
How to display this screen: Select Payment History for a payment at the Invoice Pay Summary Screen or the Display Order Payment Methods Screen.
| Order # |
| Invoice # |
The number the system assigns to a customer's bill or credit. This is the invoice number associated with an invoice payment method that has been updated. Numeric, 7 positions; display-only. |
| Pay type |
The code and description of the pay type assigned to this order. Pay type codes are defined in and validated against the Pay Type table. See Working with Pay Types (WPAY). Pay type code: numeric, 2 positions; display-only. Pay type description: alphanumeric, 30 position; display-only. |
| Date |
The date when the transaction occurred. Numeric, 6 positions (in user date format); display-only. |
| Typ (Transaction type) |
Indicates the type of transaction that occurred. Valid values are:
| Note (Transaction note) |
A system-generated description of the transaction. Alphanumeric, 40 positions; display-only. |
| Invoice |
The invoice number associated with an updated invoice payment method. Numeric, 7 positions; display-only. |
| User |
The user ID of the operator responsible for the transaction. Alphanumeric, 10 positions; display-only. |
| Screen Option | Description |
Switch views between order and invoice payment history and invoice payment history only |
Select Payment History. The system displays order and invoice payment history records or invoice payment history records only. When you review invoice history records only, the system displays a message to the right of the Invoice number field: Invoice Notes Only. |
