Setting Up Application Areas
Purpose: Application areas and application groups are used to group similar menu options, system control values and secured features.
Application areas categorize related functions, such as all functions that relate to the Purchase Order application area, Inventory application area, Order Entry application area, etc.
Application groups further define the functions within an application area. An example of an application area may be O/E (Order Entry); an example of an application group within the O/E application area may be FRE (freight).
When the software is delivered to you, Order Administration will have assigned application areas and application groups to menu options, system control values, and secured features in an effort to group these parameters and options by functional area.
Example: If you enter O/E in the Appl Area field and FRT in the Appl Group field, all options included within the Order Entry application area that relate to freight appear on the screen.
In this topic:
Setting up application areas is not required to use the system. Application areas are helpful in sorting the many options the system provides by related function.Work with System/Values Feature Screen
Purpose: Use this screen to review some of the application areas delivered with the system.
How to display this screen: Enter WSYS in the Fast path field at the top of a menu or select Work with System Values/Features from a menu.| Field | Description |
Code |
A code for the application area. Alphanumeric, 3 positions; optional. |
Description |
The application area description. Alphanumeric, 30 positions; optional. |
| Screen Options | Procedure |
Create an application area |
Select Create to a advance to Create Application Area Screen |
Change an application area |
Select Change for an application area to advance to the Change Application Area screen. At this screen, you can only change the application area code description. See Create Application Area Screen for field descriptions. |
Delete an application area |
Select Delete for an application area to delete it. |
Display an application area |
Select Display for an application area to advance to the Display Application Area screen. You cannot change any information on this screen. See Create Application Area Screen for field descriptions. |
Work with system control values |
Select Control Values for an application area to advance to the Work with System Control Values Screen. |
Work with secured features |
Select Secured Features for an application area to advance to the Work with Secure Features Screen. |
Work with application groups |
Select Application Group for an application area to advance to the Work with Application Group Screen. |
Work with menu options |
Select Menu Options for an application area to advance to the Work with Menu Options Screen. |
Work with system control values by SCV code |
Select SCV/Code to a advance to the Work with System Control Values by Code Screen |
Purpose: Use this screen to create an application area.
How to display this screen: Select Create on the Work with System Values/Features Screen.| Field | Description |
Code |
The code that identifies this application area. This code can be used to sort menu options, system control values, and secured features. Example: O/E has been defined as the application area for Order Entry. Alphanumeric, 3 positions; required. |
Area description |
The description of this application area. Alphanumeric, 30 positions required. |
