Working With the OTHR_ASYNC Job
The Other ASYNC function updates the system tables with purchase order information when purchase orders are entered, maintained, or received.
When purchase orders are entered, maintained, or received, records are sent to the Other data queue for processing. If the Other ASYNC (OTHR_ASYNC) function is active, the records will be processed immediately. If the function is not active when the records are sent, they will be processed as soon as the OTHR_ASYNC function becomes active again. All records are processed in the sequence in which they were sent to the data queue.
If any errors exist, processing for that record stops at the error point. The system begins processing the next record in sequence. The records in error are listed on the P/O Background Job Error Listing, which is printed when the ASYNC jobs are ended. OTHR_ASYNC will continue processing the record when the error has been corrected. You should correct any errors that exist as soon as possible so that your system tables are updated properly. See Working with OTHR_ASYNC Status Messages.
The status of each record in the data queue can be viewed at any point by displaying the Display PO Header Data Queue Screen.
For more information: See Troubleshooting the Async Jobs for more information on the steps you should take if you suspect the async jobs are not running correctly.
In this topic:
Display Asynchronous Job Screen (Displaying the Other ASYNC Job)
Purpose: Use this screen to display the job attributes for each background ASYNC job, including the OTHR_ASYNC job. This screen displays descriptive information about the ASYNC job.
How to display this screen: Select Display for the OTHR_ASYNC job at the Work with Background Jobs Screen
| Field | Description |
Process name |
The name of the process for this ASYNC job. The name of the OTHR_ASYNC data queue is OTHERDATAQ. Alphanumeric, 10 positions; display-only |
Job name |
The name of the ASYNC job. Alphanumeric, 10 positions; display-only |
Description |
The description of the ASYNC job. Alphanumeric, 40 positions; display-only. |
Start |
The date and time the ASYNC job was last started and the User ID of the person who started it. (Date): Numeric, 6 positions; display-only. (Time): Numeric, 6 positions; display-only. (User ID): Alphanumeric; 10 positions; display-only. |
End |
The date and time the ASYNC job was last ended and the User ID of the person who ended it. (Date): Numeric, 6 positions; display-only. (Time): Numeric, 6 positions; display-only. (User ID): Alphanumeric, 10 positions; display-only. |
Controlling job? |
A flag indicating whether this function controls other ASYNC functions. The controlling ASYNC function starts and ends other ASYNC functions. Valid values are:
The CNTL_ASYNC job is the only controlling ASYNC job. |
System Option? |
A flag indicating whether this function is a system function that cannot be deleted by the user. Valid values are: Selected - This function cannot be deleted by the user. Unselected - This function can be deleted by the user. |
Status |
The current status of the function. Valid status codes are:
Display-only |
Purpose: This screen displays the records that have been sent to the data queue for processing since the last time the ASYNC function was ended. Records are sent to the data queue when the inventory level for an item is increased.
The status of each record, which indicates if the record has been processed or if any errors exist, displays.
How to display this screen: Select Display Data Queue for the OTHR_ASYNC job on the Display Asynchronous Job Screen (Displaying the Other ASYNC Job)
Cmp (Company) |
The number of the company for which the transaction was processed. If you are running operations for more than one company, transactions for all companies are submitted to the same data queue. Numeric, 3 positions; display-only. |
Date |
The date on which the transaction was submitted to the data queue for processing. Numeric, 6 positions (in user date format); display-only. |
Time |
The time at which the transaction was submitted to the data queue for processing. Note: The number of seconds might exceed 59 if the ASYNC job processed 60 or more records in a minute. Numeric, 6 position (HH:MM:SS format); display-only. |
User |
The User ID of the person who entered the transaction. Alphanumeric, 10 positions; display-only. |
B/A |
A code indicating whether the record represents a before image or an after image for the transaction. After records are written for all transactions; before records are written for order maintenance transactions. Valid codes are:
Alphanumeric, 1 position; display-only. |
Processed |
The status of the record. The record is either not processed, in process, in error, or processed. A status message displays for each step. Alphanumeric, 30 positions; display-only. |
PO# |
The number of the purchase order for which the record is being processed. Numeric, 7 positions; display-only. |
Trans |
A code that identifies the function where the transaction originated. Valid status codes are:
Alphanumeric, 2 positions, display-only. |
Purpose: The status of each data queue record can be viewed by displaying the data queue. If an error exists, the message will print on the P/O Background Jobs Error Listing that is printed when the ASYNC jobs are ended. The error must be corrected before the transaction can be fully processed.
OTHR_ASYNC status messages: This table lists the status messages that you may see when displaying the PO Header Data Queue, or when reviewing the P/O Background Job Error Listing. The Error Reason/Action Required section of the table below is incomplete as of this writing.
| Message | Message ID | Error Reason/Action Required |
Processing has begun |
None. |
All updates complete |
None. The record was fully processed. |
Error updating buyers |
OA21759 |
Error updating Item/Warehouse |
OA21760 |
Error updating PO Dtl audit |
OA21915 |
Error updating PO Hdr audit |
OA21916 |
Error creating PO layering |
OA21897 |
Error changing PO layering |
OA21920 |
OA21918 |
Error deleting PO layering |
OA21919 |
Error updating SKU Offer |
OA21758 |
Error updating threshold value |
OA22968 |
Error updating vendor |
OA21732 |
Error updating vendor history |
OA21733 |
Error updating vendor items |
OA21766 |
Purpose: This report prints when the background ASYNC jobs are ended. The report lists the records that could not be processed and the reason for the error. The record will be processed when the error is corrected.
See Working with OTHR_ASYNC Status Messages for a complete description of the error messages you may encounter and the steps necessary to correct the error.
Order #: The order number for which the error occurred.-
Ship to: The ship-to suffix of the order for which the error occurred.
Order date: The date on which the order was entered.
User: The User ID of the operator who entered the order.
Update area: The message describing the reason for the error. See Working with OTHR_ASYNC Status Messages.
Error ID: The ID number assigned to the error. See Working with OTHR_ASYNC Status Messages.
Updates During Background Processing
Purpose: The system performs the following field and table updates during the OTHR_ASYNC procedure:
| Function | Field |
Update the SKU/Offer table |
Threshold values include:
Update the Item/Warehouse table |
On order quantity |
Update PO Layering table |
PO Maintenance + PO Receipts |
Creates the record Open quantity |
PO Receipts |
Status Note: If you receive inventory into a pending putaway warehouse, the system keeps the PO layering record in an open status until the inventory is moved out of the pending putaway warehouse. See Pending Putaway Overview. |
Warehouse |
Due date |
Update the Vendor/Item table |
PO Receipts |
Shipments - LTD |
Elapsed days - LTD |
Late days - LTD |
Number of late shipments |
Defects - LTD |
Underships |
Overships |
Units received - LTD |
PO Maintenance |
Dollar value purchased - LTD |
Units purchased - LTD |
Update Vendor table |
Dollar value cancelled |
Dollar value held |
Dollar value open |
Number of POs - LTD |
Number of open POs |
Update Vendor History table |
Dollar value purchase orders |
Number of purchase orders |
Update the Buyer table |
Dollar value POs - LTD |
Number of purchase orders - LTD |
Update Vendor Extended table |
Dollar value on order |
Update IL Outbound Trigger Table |
PO Maintenance |
Creates ITW outbound trigger records when you create a purchase order or maintain an open purchase if the Include PO Updates (J93) system control value is selected. See Generic Inventory Download API for an overview and details. For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) |
