Browse Probability Rules
Purpose: Use the Browse Probability Rules window to review probability rules you have set up through the Probability Rule Wizard.
Used for the Routing Engine module.
For more information: For a brief overview of probability rules, see Using Probability Rules; and for more details, see Probability Rule Overview.
Rule not eligible Inventory Quantity Export Calculation: A message indicates if the rule cannot apply to the inventory quantity export, since the records are created without being associated with an order. This message is displayed for rules that are based on express carrier, order type, originating system, last updated date, today, or requested quantity as a condition. See the Inventory Quantity Export for more information.
How to display this window: Click a probability rule once at the Probability Rules screen.
Available if Use Routing Engine is selected at the Tenant screen. Only users with Probability Rules authority can display this screen. See the Role Wizard for more information.Options at this window
| Option | Procedure |
| edit the displayed probability rule |
Click Edit to advance to the Probability Rule Wizard screen. |
| review the next probability rule |
Click the next icon ( |
| review the previous probability rule |
Click the previous icon ( |
Fields at this window
| Field | Description |
| Name |
The description of the probability rule. The name can be up to 40 positions, and can include spaces and special characters. |
| Rule details |
The details of the rule you created through the Probability Rule Wizard. |
