2 getDSOrders Request Message
Overview: Use the getDSOrders request message to request new purchase orders for fulfillment.
Limit batch size?: The getDSOrders request
message can use the batchSize
value to specify a
maximum number of purchase orders to include in the response message
if the criteriaType
is "item
" or
"all PO
". If the criteriaType
is
"PO
", then the response includes only the specific
purchase order.
Endpoint and resource:
The endpoint for this message is https://<SERVER>:<PORT>
, where <SERVER>
is the name of the server and <PORT>
is the port.
The resource for this message is /Locate/adws/DSOrders/getDSOrders.
In this chapter:
For more information: See:
Vendor Integration Overview for background.
getDSOrders Response Message for information on the response message generated to the getDSOrder request message and the causes of possible errors.
Sample getDSOrder Request Message
All purchase orders: The following sample requests all new purchase orders assigned for fulfillment.
getDSOrders Request Message Contents
Message Element or Attribute | Alpha/Numeric | Description |
messageHeader Example: |
datetime |
datetime |
Standard datetime format ( |
version |
alphanumeric |
Indicates the current version of Oracle Retail Order Orchestration. Must be set to 4.5 or higher. Required. |
source |
alphanumeric |
The external system originating the request. Required. |
destination |
alphanumeric |
The name of the Oracle Retail Order Orchestration database. Must match the Account value specified at the Tenant - Admin screen; however, not case-sensitive. Normally set to locate. |
Identifying Information Example: |
vendorCd |
alphanumeric |
A code identifying the vendor to fulfill the purchase order. Required. |
vendorSystemCd |
alphanumeric |
A code identifying the default vendor system for the organization (not the system originating the purchase orders). Required. |
batchSize |
numeric |
The maximum number of purchase orders to include in the response. The batchSize is used only when the criteriaType is All PO or item. Also, the number of purchase orders returned does not exceed the threshold defined in the CTL_APP_CONFIG database table, regardless of the batchSize specified; this threshold is set to 500 by default. |
Criteria Example: |
criteriaType |
alphanumeric |
Controls how to select the purchase orders to include in the response. Possible types:
criteriaValue |
alphanumeric |
The value that the purchase orders returned in the response need to match. If the criteriaType is:
