1 Feature Summary
The enhancement below is included in this update.
Column Definitions
| SMALL SCALE: These UI or process-based features are typically comprised of minor field, validation, or program changes. Therefore, the potential impact to users is minimal. |
| LARGER SCALE: These UI or process-based features have more complex designs. Therefore, the potential impact to users is higher. |
| CUSTOMER ACTION REQUIRED: Indicates if you must take action before these features can be used. These features are delivered disabled and you choose if and when to enable them. |
CUSTOMER |
| SYSTEM MANAGEMENT ENHANCEMENTS | |||
| Enhanced Performance of Order Broker Processes |
SMALL |
None |
With this update, we enhanced the performance of the BROKER and BROKER_ORD integration layer processes.
Parent topic: Feature Summary
