Delete Duplicate Invoice Out Triggers
Created a new DELETE_DUPLICATE_INVOICE_OUT_OUT_TRIGGERS property (PROP) to control whether to delete duplicate invoice trigger records. This new property applies only when the Consolidate Invoice (B49) SCV is selected:
If you consolidate invoices and do not run the INVOICE_OUT job all day, you should set this property to Y to remove duplicate trigger records.
If you consolidate invoices and run the INVOICE_OUT job all day, you should leave this property set to N to prevent sending incomplete invoice data.
Otherwise, if you do not consolidate invoices, this property is not used.
If you change the setting of this property, the new setting is effective immediately.
