1 Feature Summary
The enhancements below are included in this release.
Column Definitions
| Small: These UI or process-based features are typically comprised of minor field, validation, or program changes. Therefore, the potential impact to users is minimal. |
| Larger: These UI or process-based features have more complex designs. Therefore, the potential impact to users is higher. |
| Customer Action Required: Indicates if you must take action before these features can be used. These features are delivered disabled and you choose if and when to enable them. |
Customer |
| Customer Engagement Enhancements | |||
| Customer Engagement Shared Customer Number |
larger |
Optionally, change message versions to include new tags |
| Customer Engagement Customer Service Enhancements |
smaller |
None |
| Customer and Purchase History from Customer Engagement in Modern View |
larger |
Optionally, select the new Use Oracle Retail Customer Engagement Customer Number on Search setting in WWCC if the ORCE Customer Integration (L37) system control value is set to INTERACT |
| Including Currency in the POSlog Message to Customer Engagement |
smaller |
Optionally, set the Local Currency Code (A55) system control value if this system control value and the Multi Currency by Offer (E03) system control value are both blank. |
| Fulfillment Enhancements | |||
| Canceling Backorders through the Generic Pick In API |
smaller |
Optionally, include the new bo_cancel_reason tag in the CWPickIn message |
| Import and Export Enhancements | |||
| Marketing Download Extract Enhancements |
smaller |
Optionally, set the parameter for the MDEXPRT periodic function to 2 |
| Delete Duplicate Invoice Out Triggers |
smaller |
Optionally, select the new DELETE_DUPLICATE_INVOICE_OUT_OUT_TRIGGERS property |
| Order Broker Enhancements | |||
| Create Invoice when Ship-for-Pickup Order is In Transit |
smaller |
Optionally, select the new Invoice Ship For Pickup Order Once Intransit (M73) system control value |
| Payment Method Enhancements | |||
| Handling Encryption Failure in the Order API |
smaller |
Work with orders in the error batch when encryption fails |
| Web Service Enhancements | |||
| CWEmailRequest |
smaller |
Optionally, use the message in REST |
| System Management Enhancements | |||
| New Active Procedures |
smaller |
None |
| Modern View Enhancements | |||
| Default Delivery Type Required for Contact Center Order Entry |
smaller |
Select the default delivery type in the system control value if one is not already defined |
| Customer Creation in Contact Center Order Entry and Duplicate Customer Check |
smaller |
None |
