1 Feature Summary
This chapter describes the feature enhancements in this release.
Noteworthy Enhancements
This guide outlines the information you need to know about new or improved functionality in the Oracle Retail Order Management System update and describes any tasks you might need to perform for the update. Each section includes a brief description of the feature, the steps you need to take to enable or begin using the feature, any tips or considerations that you should keep in mind, and the resources available to help you.
Column Definitions
  • Feature: Provides a description of the feature being delivered.
  • Module Impacted: Identifies the module impacted associated with the feature, if any.
  • Scale: Identifies the size of the feature. Options are:
    • Small: These UI or process-based features are typically comprised of minor field, validation, or program changes. Therefore, the potential impact to users is minimal.
    • Medium: These UI or process-based features are typically comprised of field, validation, or program changes. Therefore, the potential impact to users is moderate.
    • Large: These UI or process-based features have more complex designs. Therefore, the potential impact to users is higher.
  • Delivered: Is the new feature available for use immediately after upgrade or must the feature be enabled or configured? If no, the feature is non-disruptive to end users and action is required (detailed steps below) to make the feature ready to use.
  • Customer Action Required: You must take action before these features can be used. These features are delivered disabled and you choose if and when to enable them.
Feature Module Impacted Scale Delivered Customer Action Required?
Retain Error Order Records
Order Management Integrations
Small
Yes
No
Removed System Control Values
Order Management
Small
No
No
With this update, for Order API orders, error records for error orders in the phone error table are retained regardless of the Delay Order API Edit (I56) system control value setting. The errors on an order will be kept in the phone error table until they are resolved, or the order is deleted.
Before this update, if the order has an error, the errors are only retained in the phone error table if Delay Order API Edit (I56) system control value was set to Y.
The following system control values have been removed in this update as they are no longer used:
  • CSF Comm Protocol.CDE (H37)
  • Additional Charge Group Code For Freight (I29)
  • Amazon FTP Download Script (I87)
  • G/L Detail Purge Days (M17)
