Avalara AvaTax Interface
Purpose: The Avalara AvaTax Interface provides a bridge between Order Administration and the Avalara AvaTax system to calculate the tax information on your orders at strategic points:
- order entry
 - order maintenance
 - pick slip preparation
 - billing
Order Administration communicates with AvaTax files to determine the appropriate tax rate at each stage of the order's life cycle. AvaTax determines the appropriate tax rate based on the “ship-from” and “ship-to” addresses on the order.
The AvaTax system stores the tax rates for each taxing jurisdiction in the United States and Canada, and provides the necessary reporting for each jurisdiction in which you sell or operate.
If you use the AvaTax interface, you don't need to keep current with the tax rates and reporting requirements of each taxing jurisdiction, and you no longer have to maintain these rates on Order Administration. Also, the system does not consider any item tax exemptions set up through Working with Item Tax Exemptions (WITX) or Working with GST Tax Exemption Status (MGTX). Instead, you should use AvaTax to set up any tax exemptions for items.
You cannot use both AvaTax and tax-inclusive pricing (VAT) in the same company; you must use separate companies for regular tax and VAT. See Tax Included in Price (E70) for more information on VAT.Compatibility: Order Management System version 17.0 or later, or Order Administration, is compatible with Avalara AvaTax REST API v2.
For more information: See Avalara AvaTax Setup for information on setting up Order Administration to support communication with AvaTax. Also, see your AvaTax documentation for detailed information on setup requirements within AvaTax.
In this topic:
Tax Calculation Processing Overview
Overview: The AvaTax Interface passes order and tax information between Order Administration and AvaTax at various points in the order cycle (from order entry to billing).
AvaTax evaluates and calculates the tax amount on the order at each phase and updates transactions appropriately.
Communication between Order Administration and AvaTax: When Order Administration needs tax information during order entry or maintenance, pick slip preparation, or billing, it sends a tax request message to AvaTax using web services. The TAX_INT integration layer job defines the wsdl (Web Services Definition Language) file that controls the integration.
For troubleshooting purposes, Order Administration writes the tax request message to the Trace Log. Additional processing is logged to the Application Log.
For more information: See Avalara AvaTax Setup for more information on configuring the integration.
What is taxed? Based on its current data on tax rules for the shipping address on the order and the additional rules that you define for customer or item exceptions, AvaTax indicates the tax amounts for merchandise, freight (order-level or line-level), handling charges, duty, shipper-item charges, and additional freight.
Tax Overrides, Customer Exemptions, and Item or Class Exceptions
Tax override: You can set the Tax override flag in the Order Detail table to Y when you create an order through the generic order API. If this flag is set to Y, AvaTax does not calculate the tax amount for the item at any point in the order cycle and just uses the specified tax override amount; however, if there are any line-level freight, handling, or gift wrap charges, these charges may be subject to tax even if the order detail line has a tax override.
Similarly, you can override tax on freight through the order API
by specifying a freight_tax_amount and setting the freight_tax_override to Y.
- There is no way to set the Tax override flag through interactive order entry.
 - The system does not set the Tax override flag in the Order Detail table unless there is a tax amount specified in the inbound order message. As a result, you cannot use this setting to create an order line with no tax amount in interactive order entry. The only way to exempt an order line from tax is to set up an item exception in Working with Tax Product Code Cross References (WTPC).
For more information: See the Send Tax to Tax Interface as Quote Not Invoice (L11) system control value for a discussion on how the system sends different request types to AvaTax based on the setting of this system control value and whether the tax is overridden.
Customer tax exemptions: If a customer is flagged as tax exempt in Order Administration and has a tax-exempt Tax identification number, the merchandise and charges on the customer’s orders are not taxable. Order Administration passes the exemption tax identification number to AvaTax. Although Order Administration does not pass the customer’s tax exempt Expiration date, order entry does not let you create an order flagged as tax-exempt if the customer’s Expiration date has passed.
Item or item class exceptions: When you use AvaTax, you need to set up item exceptions in Working with Tax Product Code Cross References (WTPC). For example, if you have two item classes that are not normally taxable, you can map these item classes to tax product codes in AvaTax.
Even if an item on an order is not subject to tax, AvaTax still calculates tax for any freight, handling charges, and gift wrap charges if the order is otherwise subject to tax.Order Orchestration fulfilling orders: Invoice request messages are not sent to AvaTax for orders created to fulfill orders that originated in Order Administration, were submitted to Order Orchestration, and then submitted to Order Administration because Order Orchestration selected the Order Administration warehouse for fulfillment or sourcing. See Order Orchestration Integration for background.
AvaTax Processing
When Order Administration needs to calculate tax for an order and you are using the AvaTax interface, the system uses the AvaTax REST API v2 web service to communicate with the AvaTax system via HTTP POST.
- Order Administration generates a Tax Request Message (CWTaxRequest), maps the information in the Tax Request message to the AvaTax Request message, and sends the AvaTax Request message to AvaTax for tax calculation.
 - AvaTax calculates the tax and sends an AvaTax Response message to Order Administration.
 - Order Administration maps the information in the AvaTax Response message to the Tax Response Message (CWTaxResponse) and uses the information in the Tax Response message to apply tax to the order.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Tax Request Maps
Order Administration maps the generic tax messages (Tax Request Message (CWTaxRequest) and Tax Response Message (CWTaxResponse)) to the AvaTax message format to pass tax information to and from AvaTax.
Reviewing messages: You can review the messages passed between Order Administration and AvaTax in the Trace Log if its Logging Level is set to DEBUG or ALL. Use this log to help troubleshoot the AvaTax integration.
License key authentication: The AvaTax integration uses RESTful web services and supports basic HTTP authentication, passing the account and license defined in the AvaTax Values by Company Properties File to AvaTax.
For more information: See:
Tax Calculation Processing Overview for an overview of the AvaTax process.
Generic Tax API for more information on the generic tax API, including information on the Tax Request Message (CWTaxRequest) and Tax Response Message (CWTaxResponse).
