Caching
Cache: A store of information that will be required in the future, and can be retrieved quickly. Order Administration uses caching to store recently used information from the Order Administration database in a place where it can be accessed quickly, rather than accessing the database, in order to improve performance. Caching occurs across all Order Administration companies; if you use multiple application servers, you can specify which servers share the same cache. For example, you should have all of your test servers share the same cache and all of your production servers share a cache that is different from the cache assigned to your test servers.
Order Administration stores certain information in a cache so that it can be retrieved quickly. If a screen created using the Google Web Toolkit (GWT), such as Work with Accounting Periods (WACP) or Streamlined Order Inquiry (DORI), does not display correctly, or if you have changed an image and the updated image does not display, you must clear your cache to remove the information from your cache so that the screen or image can display correctly.
My Cache Screen
Purpose: Use the My Cache screen to determine which servers share the same cache and to determine which caches currently contain data.
How to display this screen: If you have Advanced Commands authority, select Advanced Commands from the Document Management screen (My Docs), Job Management screen (My Jobs) or Forms Management screen (My Forms) to advance to the Commands screen; then, select My Cache.
| Field | Description |
You are connected to Server |
The name of the Order Administration application server that you are currently logged into. |
Servers in Cluster A list of the servers that share the same cache as the server you are currently logged into. The system does not display a server that shares the same cache until a user logs into Order Administration using that server. The server information remains on the My Cache screen until the server is restarted or the connection times out due to lack of activity. |
Example: SERVER1 and SERVER2 share the same cache. User A logs into SERVER1. At this point, the Servers in Cluster section of the My Cache screen does not display any server information because no one has logged into SERVER2. User B logs into SERVER2. At this point, SERVER1 displays server information for SERVER2 in the Servers in Cluster section of the My Cache screen and SERVER2 displays server information for SERVER1 in the Servers in Cluster section of the My Cache screen. User B restarts SERVER2 and logs into SERVER1. At this point, the Servers in Cluster section of the My Cache screen no longer displays server information because no one has logged back into SERVER2. Note: If a user changes a record in a table that is associated with a cache, the system does not clear the records in the cache and does not remove the cache from this screen. |
Host Name |
The name of a server that shares the same cache as the server you are currently logged into. The server you are currently logged into is also displayed. |
Current Cache A list of the caches that currently contain records. |
When does a cache display on this screen? A cache displays on the My Cache screen if it contains a record. When a Order Administration process or a user changes a table that is associated with a cache, the system clears the records in the cache and removes the cache from this screen until a new record is added to the cache. How many records are in the cache? The Live objects represents the number of records that are in the cache. The system continues to update the Live objects until the cache is cleared or the maximum number of records for the cache is reached. How many times has a record been retrieved from the cache? The Hit count represents the number of times the system retrieved data from the cache instead of the database. The system continues to update the Hit count until you stop and restart Order Administration. |
Cache Name |
The name of a cache that currently contains records. |
Live Objects |
The number of records in the cache. For example, if two additional charge code records exist in the ADDL.CHARGE.CACHE, the Live Objects is 2. Note: This number continues to increment until the cache is cleared. |
Hit Count |
The number of times the system retrieved data from the cache instead of the database. For example, if records for additional charge code A and additional charge code B exist in the ADDL.CHARGE.CACHE, and the system retrieved additional charge code A from the cache 7 times and retrieved additional charge code B from the cache 2 times, the Hit count is 9. Note: This number continues to increment until you stop and restart Order Administration. If the system clears a cache, when the cache reappears on the screen, the Hit count will still be from the last time Order Administration was restarted. |
Which Order Administration Tables are Cached?
Purpose: The dbtablecachemapping.properties file indicates which Order Administration tables are cached.
DBTableCacheMapping Properties File
The dbtablecachemapping.properties file controls which tables are cached and the name of the cache associated with the table so that the system knows which cache to clear when a Order Administration process updates the information in a table.
This file provides the table name of each Order Administration table that is cached and the corresponding cache name.
Important:
Staff should not change the information in the dbtablecachemapping.properties file.
Location of file: This file is normally saved on the application server at the following location, where domain is the WebLogic domain directory for Order Administration:
/domain/conf/cwdirectcpproperties/ dbtablecachemapping.properties
| Table Name | View Name | Cache Name |
accitm |
Accompanying Item |
ACCOMPANYING_ITEM_CACHE |
acenty |
Entity |
ENTITY_CACHE |
ccpt00 |
CC Paytype Cross Ref |
PAY_TYPE_CACHE |
ccvnrs |
CC Vendor Response |
CC_VENDOR_RESPONSE_CACHE |
cscanr |
Cancel Reason |
CANCEL_REASON_CACHE |
cscscl |
Customer Class |
CUSTOMER_CLASS_CACHE |
csprfx |
Prefix Code |
PREFIX_CODE_CACHE |
csprod |
Profile Data |
PROFILE_CACHE |
csprof |
Profile |
PROFILE_CACHE |
dolofr |
Dollar Chart by Offer |
DOLLAR_CHART_BY_OFFER_CACHE |
flshrt |
Shipping Rate |
SHIPPING_RATE_CACHE |
frgofr |
Free Gift by Offer/Source |
FREE_GIFT_CACHE |
ftfefep |
Freight Exemption |
FRT_EXEMPT_CACHE |
ftftdp |
Freight Table Detail |
FREIGHT_TABLE_DETAIL_CACHE |
inabcv |
ABC/Velocity |
ITEM_MISC_CACHE |
infreq |
Frequency |
ITEM_MISC_CACHE |
inhzrd |
Hazard |
ITEM_MISC_CACHE |
inicls |
Item Class |
ITEM_CLASS_CACHE |
inictg |
Item Category |
ITEM_CLASS_CACHE |
inicty |
Item Coordinate Type |
ITEM_MISC_CACHE |
iniofr |
Item Offer |
ITEM_OFFER_CACHE |
iniskg |
Item SKU Group |
ITEM_DETAIL_CACHE |
inists |
Item Status |
ITEM_DETAIL_CACHE |
inisvo |
Item Ship Via Override |
ITEM_SHIP_VIA_OVERRIDE_CACHE |
inlcls |
Location Class |
ITEM_DETAIL_CACHE |
inldvp |
Long SKU Division |
ITEM_CLASS_CACHE |
inlobp |
Line of Business |
ITEM_MISC_CACHE |
inloc |
Location |
LOCATION_CACHE |
inlskc |
Long SKU Class |
ITEM_CLASS_CACHE |
inlskd |
Long SKU Department |
LONG_SKU_DEPARTMENT_CACHE |
insecf |
Secure Feature |
SECURED_FEATURE_CACHE |
insetd |
Set Detail |
SET_DETAIL_CACHE |
inskeo |
SKU Element 1 |
ITEM_DETAIL_CACHE |
insket |
SKU Element 3 |
ITEM_DETAIL_CACHE |
inskew |
SKU Element 2 |
ITEM_DETAIL_CACHE |
insldo |
Soldout Control |
SOLDOUT_CONTROL_CACHE |
insubs |
Item Subscription |
ITEM_SUBSCRIPTION_CACHE |
inprpp |
Prep Code |
ITEM_MISC_CACHE |
inuom |
Unit Of Measure |
ITEM_MISC_CACHE |
inwrhs |
Warehouse |
WAREHOUSE_CACHE |
inloba |
Line of Business Assignment |
LOB_ASSIGNMENT_CACHE |
msaocp |
Add On Code |
ITEM_MISC_CACHE |
msaucf |
Auth User Class Feature |
USER_CACHE |
msausf |
Auth User Feature |
USER_CACHE |
mscfrd |
Miscellaneous Fraud |
FRAUD_CACHE |
mscnte |
Country Extended |
STATE_COUNTRY_CACHE |
mscnty |
Country |
mscoad |
Company Address |
COMPANY_ADDRESS_CACHE |
msctle |
Entity System Control Val |
ENTITY_SCV_CACHE |
msctlv |
System Control Value |
SCV_CACHE |
mscurr |
Currency |
CURRENCY_CACHE |
msdiv |
Division |
DIVISION_CACHE |
msilpr |
Integration Layer Process |
INTEGRATION_PROCESS_CACHE |
msoffr |
Offer |
OFFER_CACHE |
msscf |
SCF |
SCF_CACHE |
msscfe |
SCF Extended |
SCFEXTENDED_CACHE |
msscft |
SCF Tax Rate |
TAX_RATE_CACHE |
msseas |
Season |
ITEM_MISC_CACHE |
msshfd |
Special Format |
SPECIAL_FORMAT_CACHE |
msshpv |
Ship Via |
SHIP_VIA_CACHE |
mssta |
State |
mssvwp |
Ship Via Weight Charge |
SHIP_VIA_WEIGHT_CHARGE_CACHE |
msudep |
User Defined Exit Point |
USER_CACHE |
oeadch |
Additional Charge |
ADDL_CHARGE_CACHE |
oeauct |
Auth Service Country |
oeausv |
Authorization Service |
AUTH_SERVICE_CACHE |
oeauex |
Authorization Service Ext |
oebogo |
Promotion BOGO |
PROMOTION_CACHE |
oeexrs |
Exchange Reason |
EXCHANGE_REASON_CACHE |
oeicrc |
Item Class Restr by Cust |
ITEM_CLASS_RESTRICTION_CACHE |
oeicrs |
Item Class Restr by SpclH |
oeicsp |
Item Restr by Country/State |
ITEM_RESTRICTION_CACHE |
oeirct |
Item Class Restr by City |
oeitxx |
Item Tax Exempt |
ITEM_TAX_EXEMPT_CACHE |
oepaye |
Pay Type Extended |
PAY_TYPE_EXTENDED_CACHE |
oepayt |
Pay Type |
PAY_TYPE_CACHE |
oepnck |
Order Pending Check |
FRAUD_CACHE |
oepore |
Price Override Reason Ext |
PRICE_OVERRIDE_REASON_ EXTENSION_CACHE |
oeprcu |
Promotion Customer |
PROMOTION_LIST_CACHE |
oeprex |
Promotion Item Exclusion |
oepric |
Promotion Item Category |
PROMOTION_CACHE |
oeprom |
Promotion |
PROMOTION_CACHE |
oepror |
Price Override Reason |
PRICE_OVERRIDE_REASON_CACHE |
oeprsr |
Promotion Source |
PROMOTION_CACHE |
oertrs |
Return Reason |
RETURN_REASON_CACHE |
oesfrc |
Dollar Chart by Source |
DOLLAR_CHART_BY_SOURCE_CACHE |
oeshim |
Shipper/Item |
SHIPPER_ITEM_CACHE |
oetype |
Order Type |
ORDER_TYPE_CACHE |
oezpct |
Zip/City/State Tax Rate |
TAX_RATE_CACHE |
oezpsv |
Zip Ship Via |
ZIP_SHIP_VIA_CACHE |
oezrcp |
Zone Reservation |
ITEM_MISC_CACHE |
povend |
Vendor |
VENDOR_CACHE |
povia |
PO Ship Via |
ITEM_MISC_CACHE |
rtndis |
Return Disposition |
RETURN_DISPOSITON_CACHE |
scfvia |
SCF Ship Via |
SCF_VIA_CACHE |
scuser |
User |
USER_CACHE |
users |
N/A |
JENASYS_USER_CACHE |
Ehcache
Purpose: Order Administration uses Ehcache to manage caching. Ehcache is a widely used open source Java cache. For more information about Ehcache, visit the ehcache web site (http://ehcache.sourceforge.net/).
Note: Ehcache copyright Luck Consulting Pty Ltd.
Ehcache.xml File
The Ehcache.xml file is used to configure how caching works in Order Administration.
A separate Ehcache.xml file should exist on each Order Administration application server.
Location of file: This file is normally saved on the Order Administration application server at the following location, where domain is the WebLogic domain directory for Order Administration.
/domain/conf/ehcache.xml
The settings that staff may wish to review for troubleshooting purposes are described below.
| Setting | Description |
cacheManagerPeerProviderFactory |
Description below. |
peerDiscovery |
automatic = Indicates the system detects which Order Administration application servers share the same cache by checking the multicastGroupAddress and multicastGroupPort defined for each application server. |
multicastGroupAddress |
The multicast group address assigned to each server that shares a cache. Valid multicast group addresses must be within the range of 224.0.0.1 to 238.000.000.000. The default setting is 235.0.0.1. Note: This is not the IP address of the server; you can enter any number as the group address as long as it is between the range of 224.0.0.1 and 238.000.000.000. |
multicastGroupPort |
The port number assigned to each server that shares a cache. The port number can be any number, as long as each server is assigned the same multicast group port number. |
timeToLive |
Indicates the level at which multiple application servers can share the same cache. 0 = Share the same host. 1 = Share the same subnet. 32 = Share the same site. 64 = Share the same region. 128 = Share the same continent. 255 = Unrestricted. Note: Order Administration is configured to share the same cache at the subnet level (timeToLive is 1). If you need to configure a higher level at which multiple Order Administration application servers share the same cache, contact your Order Administration representative. |
