Order Administration Application Configuration
Purpose: Use the Application Properties File to define configuration settings for Order Administration.
For more information: See:
Admin Properties: See Working with Admin Properties (CPRP) for more information on the properties that an administrator would update.
Customer Properties: See Working with Customer Properties (PROP) for more information on the properties that a user would update.
The system updates this file with settings on the application server; you would typically not change the settings in this file.
| Setting | Description |
name |
The name of the application without any version information included. |
path |
The location of the application folder. |
version |
The version information of the product not including the patch level. |
patch |
The patch level of the application. |
