Caching
Cache: A store of information that will be required in the future, and can be retrieved quickly. Order Administration uses caching to store recently used information from the Order Administration database in a place where it can be accessed quickly, rather than accessing the database, in order to improve performance. Caching occurs across all Order Administration companies; if you use multiple application servers, you can specify which servers share the same cache. For example, you should have all of your test servers share the same cache and all of your production servers share a cache that is different from the cache assigned to your test servers.
Order Administration stores certain information in a cache so that it can be retrieved quickly. If a screen created using the Google Web Toolkit (GWT), such as Work with Accounting Periods (WACP) or Streamlined Order Inquiry (DORI), does not display correctly, or if you have changed an image and the updated image does not display, you must clear your cache to remove the information from your cache so that the screen or image can display correctly.
My Cache Screen
Purpose: Use the My Cache screen to determine which servers share the same cache and to determine which caches currently contain data.
How to display this screen: If you have Advanced Commands authority, select Advanced Commands from the Document Management screen (My Docs), Job Management screen (My Jobs) or Forms Management screen (My Forms) to advance to the Commands screen; then, select My Cache.
Field Description
You are connected to Server
The name of the Order Administration application server that you are currently logged into.
Servers in Cluster
A list of the servers that share the same cache as the server you are currently logged into. The system does not display a server that shares the same cache until a user logs into Order Administration using that server. The server information remains on the My Cache screen until the server is restarted or the connection times out due to lack of activity.
Example:  SERVER1 and SERVER2 share the same cache. User A logs into SERVER1. At this point, the Servers in Cluster section of the My Cache screen does not display any server information because no one has logged into SERVER2.
User B logs into SERVER2. At this point, SERVER1 displays server information for SERVER2 in the Servers in Cluster section of the My Cache screen and SERVER2 displays server information for SERVER1 in the Servers in Cluster section of the My Cache screen.
User B restarts SERVER2 and logs into SERVER1. At this point, the Servers in Cluster section of the My Cache screen no longer displays server information because no one has logged back into SERVER2.
Note:  If a user changes a record in a table that is associated with a cache, the system does not clear the records in the cache and does not remove the cache from this screen.
Host Name
The name of a server that shares the same cache as the server you are currently logged into. The server you are currently logged into is also displayed.
Current Cache
A list of the caches that currently contain records.
When does a cache display on this screen?
A cache displays on the My Cache screen if it contains a record. When a Order Administration process or a user changes a table that is associated with a cache, the system clears the records in the cache and removes the cache from this screen until a new record is added to the cache.
How many records are in the cache?
The Live objects represents the number of records that are in the cache. The system continues to update the Live objects until the cache is cleared or the maximum number of records for the cache is reached.
How many times has a record been retrieved from the cache?
The Hit count represents the number of times the system retrieved data from the cache instead of the database. The system continues to update the Hit count until you stop and restart Order Administration.
Cache Name
The name of a cache that currently contains records.
Live Objects
The number of records in the cache.
For example, if two additional charge code records exist in the ADDL.CHARGE.CACHE, the Live Objects is 2.
Note:  This number continues to increment until the cache is cleared.
Hit Count
The number of times the system retrieved data from the cache instead of the database.
For example, if records for additional charge code A and additional charge code B exist in the ADDL.CHARGE.CACHE, and the system retrieved additional charge code A from the cache 7 times and retrieved additional charge code B from the cache 2 times, the Hit count is 9.
Note:  This number continues to increment until you stop and restart Order Administration. If the system clears a cache, when the cache reappears on the screen, the Hit count will still be from the last time Order Administration was restarted.
Which Order Administration Tables are Cached?
Purpose: The dbtablecachemapping.properties file indicates which Order Administration tables are cached.
DBTableCacheMapping Properties File
The dbtablecachemapping.properties file controls which tables are cached and the name of the cache associated with the table so that the system knows which cache to clear when a Order Administration process updates the information in a table.
This file provides the table name of each Order Administration table that is cached and the corresponding cache name.
Important:
Staff should not change the information in the dbtablecachemapping.properties file.
Location of file: This file is normally saved on the application server at the following location, where domain is the WebLogic domain directory for Order Administration:
/domain/conf/cwdirectcpproperties/ dbtablecachemapping.properties
Table Name View Name Cache Name
accitm
Accompanying Item
ACCOMPANYING_ITEM_CACHE
acenty
Entity
ENTITY_CACHE
ccpt00
CC Paytype Cross Ref
PAY_TYPE_CACHE
ccvnrs
CC Vendor Response
CC_VENDOR_RESPONSE_CACHE
cscanr
Cancel Reason
CANCEL_REASON_CACHE
cscscl
Customer Class
CUSTOMER_CLASS_CACHE
csprfx
Prefix Code
PREFIX_CODE_CACHE
csprod
Profile Data
PROFILE_CACHE
csprof
Profile
PROFILE_CACHE
dolofr
Dollar Chart by Offer
DOLLAR_CHART_BY_OFFER_CACHE
flshrt
Shipping Rate
SHIPPING_RATE_CACHE
frgofr
Free Gift by Offer/Source
FREE_GIFT_CACHE
ftfefep
Freight Exemption
FRT_EXEMPT_CACHE
ftftdp
Freight Table Detail
FREIGHT_TABLE_DETAIL_CACHE
inabcv
ABC/Velocity
ITEM_MISC_CACHE
infreq
Frequency
ITEM_MISC_CACHE
inhzrd
Hazard
ITEM_MISC_CACHE
inicls
Item Class
ITEM_CLASS_CACHE
inictg
Item Category
ITEM_CLASS_CACHE
inicty
Item Coordinate Type
ITEM_MISC_CACHE
iniofr
Item Offer
ITEM_OFFER_CACHE
iniskg
Item SKU Group
ITEM_DETAIL_CACHE
inists
Item Status
ITEM_DETAIL_CACHE
inisvo
Item Ship Via Override
ITEM_SHIP_VIA_OVERRIDE_CACHE
inlcls
Location Class
ITEM_DETAIL_CACHE
inldvp
Long SKU Division
ITEM_CLASS_CACHE
inlobp
Line of Business
ITEM_MISC_CACHE
inloc
Location
LOCATION_CACHE
inlskc
Long SKU Class
ITEM_CLASS_CACHE
inlskd
Long SKU Department
LONG_SKU_DEPARTMENT_CACHE
insecf
Secure Feature
SECURED_FEATURE_CACHE
insetd
Set Detail
SET_DETAIL_CACHE
inskeo
SKU Element 1
ITEM_DETAIL_CACHE
insket
SKU Element 3
ITEM_DETAIL_CACHE
inskew
SKU Element 2
ITEM_DETAIL_CACHE
insldo
Soldout Control
SOLDOUT_CONTROL_CACHE
insubs
Item Subscription
ITEM_SUBSCRIPTION_CACHE
inprpp
Prep Code
ITEM_MISC_CACHE
inuom
Unit Of Measure
ITEM_MISC_CACHE
inwrhs
Warehouse
WAREHOUSE_CACHE
inloba
Line of Business Assignment
LOB_ASSIGNMENT_CACHE
msaocp
Add On Code
ITEM_MISC_CACHE
msaucf
Auth User Class Feature
USER_CACHE
msausf
Auth User Feature
USER_CACHE
mscfrd
Miscellaneous Fraud
FRAUD_CACHE
mscnte
Country Extended
STATE_COUNTRY_CACHE
mscnty
Country
STATE_COUNTRY_CACHE
mscoad
Company Address
COMPANY_ADDRESS_CACHE
msctle
Entity System Control Val
ENTITY_SCV_CACHE
msctlv
System Control Value
SCV_CACHE
mscurr
Currency
CURRENCY_CACHE
msdiv
Division
DIVISION_CACHE
msilpr
Integration Layer Process
INTEGRATION_PROCESS_CACHE
msoffr
Offer
OFFER_CACHE
msscf
SCF
SCF_CACHE
msscfe
SCF Extended
SCFEXTENDED_CACHE
msscft
SCF Tax Rate
TAX_RATE_CACHE
msseas
Season
ITEM_MISC_CACHE
msshfd
Special Format
SPECIAL_FORMAT_CACHE
msshpv
Ship Via
SHIP_VIA_CACHE
mssta
State
STATE_COUNTRY_CACHE
mssvwp
Ship Via Weight Charge
SHIP_VIA_WEIGHT_CHARGE_CACHE
msudep
User Defined Exit Point
USER_CACHE
oeadch
Additional Charge
ADDL_CHARGE_CACHE
oeauct
Auth Service Country
STATE_COUNTRY_CACHE
oeausv
Authorization Service
AUTH_SERVICE_CACHE
oeauex
Authorization Service Ext
AUTH_SERVICE_CACHE
oebogo
Promotion BOGO
PROMOTION_CACHE
oeexrs
Exchange Reason
EXCHANGE_REASON_CACHE
oeicrc
Item Class Restr by Cust
ITEM_CLASS_RESTRICTION_CACHE
oeicrs
Item Class Restr by SpclH
oeicsp
Item Restr by Country/State
ITEM_RESTRICTION_CACHE
oeirct
Item Class Restr by City
oeitxx
Item Tax Exempt
ITEM_TAX_EXEMPT_CACHE
oepaye
Pay Type Extended
PAY_TYPE_EXTENDED_CACHE
oepayt
Pay Type
PAY_TYPE_CACHE
oepnck
Order Pending Check
FRAUD_CACHE
oepore
Price Override Reason Ext
PRICE_OVERRIDE_REASON_
EXTENSION_CACHE
oeprcu
Promotion Customer
PROMOTION_LIST_CACHE
oeprex
Promotion Item Exclusion
oepric
Promotion Item Category
PROMOTION_CACHE
oeprom
Promotion
PROMOTION_CACHE
oepror
PRICE_OVERRIDE_REASON_CACHE
oeprsr
Promotion Source
PROMOTION_CACHE
oertrs
Return Reason
RETURN_REASON_CACHE
oesfrc
Dollar Chart by Source
DOLLAR_CHART_BY_SOURCE_CACHE
oeshim
Shipper/Item
SHIPPER_ITEM_CACHE
oetype
Order Type
ORDER_TYPE_CACHE
oezpct
Zip/City/State Tax Rate
TAX_RATE_CACHE
oezpsv
Zip Ship Via
ZIP_SHIP_VIA_CACHE
oezrcp
Zone Reservation
ITEM_MISC_CACHE
povend
Vendor
VENDOR_CACHE
povia
PO Ship Via
ITEM_MISC_CACHE
rtndis
Return Disposition
RETURN_DISPOSITON_CACHE
scfvia
SCF Ship Via
SCF_VIA_CACHE
scuser
User
USER_CACHE
users
N/A
JENASYS_USER_CACHE
Ehcache
Purpose: Order Administration uses Ehcache  to manage caching. Ehcache is a widely used open source Java cache. For more information about Ehcache, visit the ehcache web site (http://ehcache.sourceforge.net/).
Note: Ehcache copyright Luck Consulting Pty Ltd.
Ehcache.xml File
The Ehcache.xml file is used to configure how caching works in Order Administration.
A separate Ehcache.xml file should exist on each Order Administration application server.
Location of file: This file is normally saved on the Order Administration application server at the following location, where domain is the WebLogic domain directory for Order Administration.
/domain/conf/ehcache.xml
The settings that staff may wish to review for troubleshooting purposes are described below.
Setting Description
cacheManagerPeerProviderFactory
Description below.
peerDiscovery
automatic = Indicates the system detects which Order Administration application servers share the same cache by checking the multicastGroupAddress and multicastGroupPort defined for each application server.
The multicast group address assigned to each server that shares a cache.
Valid multicast group addresses must be within the range of 224.0.0.1 to 238.000.000.000. The default setting is 235.0.0.1.
Note:  This is not the IP address of the server; you can enter any number as the group address as long as it is between the range of 224.0.0.1 and 238.000.000.000.
multicastGroupPort
The port number assigned to each server that shares a cache.
The port number can be any number, as long as each server is assigned the same multicast group port number.
timeToLive
Indicates the level at which multiple application servers can share the same cache.
0 = Share the same host.
1 = Share the same subnet.
32 = Share the same site.
64 = Share the same region.
128 = Share the same continent.
255 = Unrestricted.
Note:  Order Administration is configured to share the same cache at the subnet level (timeToLive is 1). If you need to configure a higher level at which multiple Order Administration application servers share the same cache, contact your Order Administration representative.
