Measure Filters and Attribute Filters
You can apply measure filters along with attribute filters which helps you focus on a sub-set of data in the planning process. You can apply attribute filters and measure filter on top of each other as per your requirements. For example, you can filter Product SKUs for a brand and then apply a measure filter to products that have sales whose cost is greater than and equal to 7,000. A combination of measure filtering and attribute filters provides multiple options to place emphasis on a smaller data set during planning. Figure 17-11 shows an example of using a combination of attribute filters and measure filters.
Figure 17-11 Attribute Filters and Measure Filters
![Attribute Filters and Measure Filters Attribute Filters and Measure Filters](img/fg17-11.jpg)
