14 RPASCE Test Automation
This chapter describes an RPASCE utility called "rpac" (RPASCE Pluggable Automation Component). It can be used to perform various tests on an existing application, based on a set of test cases contained in XML files.
This appendix contains the following sections:
Introduction
The rpac utility is used to run highly customizable automated test suites for the RPASCE server. The XML-based framework allows rapid development of tests and ensures that test cases can be quickly copied across locations. The flexible XML schema allows the user to test a large number of RPASCE features, such as writing data to PDS, building a workbook, running custom menu options, and verifying the results.
The XML framework also introduces consistency, accuracy, and reproducibility in the test results. To reproduce a test case, all that is needed is the XML file and a copy of PDS.
Note that rpac operates directly against the PDS itself and therefore does not test any Client/Server interactions.
RPAC in Batch Framework
The rpac utility is supported for use with enterprise deployments. RPAC tests are specified in XML-format text files and cover a range of RPASCE PDS and Workbook activities. In order to support the validation of a newly installed or patched environment, in the context of configured daily or weekly batch operations, RPAC for Cloud deployments are supported through new entries in the EE Batch task catalog. These tasks allow a pre-production PDS to be set to a known state through a combination of dimension load and fact load files; then both application and Workbook measures can then be compared to known values represented either directly in the test XML files or in data comparison files (similar to a measure data load file, but used only for comparison rather than for loading).
Three types of collateral files are involved in the RPAC testing process:
Input data file set: a group of hierarchy (.dat) and measure (.ovr, .clr, or .rpl) data files that should be loaded into the PDS before any RPAC tests are run. Uploaded to Object Storage in the rpac directory as input.zip.
Test file set: one or more .xml files where tests and test suites are defined using the available set of RPAC tags and attributes. Uploaded to Object Storage in the rpac directory as tests.zip.
Comparison data file set: an optional way to efficiently validate that one or more measures currently contain an expected set of values. Uploaded to Object Storage in the rpac directory as compare.zip.
Each of these collateral file archives, once uploaded to Object Storage, will be kept internally to be used every time an RPAC-enabled batch execution sequence is run. Updates to the collateral files can be uploaded to Object Storage before the next call of the initrpac batch task and will be brought into the active environment at that time. Note that when any of the collateral file archives is updated, the previous contents are entirely removed from the internal storage area, so the replacement archive file must be a complete set of files of that type. (This prevents stale test scripts or data files from being left in the environment.)
The two EE Batch tasks, initrpac and runrpac, are detailed in the batch task catalog in "Initialize Testing Environment: initrpac" and "Execute Automated Tests: runrpac" in the Implementation Guide. The initrpac task is expected to be run once, at the start of the RPAC-enabled batch exec sequence; the runrpac task can be called multiple times, including at separate points during the batch exec sequence, if needed. Here is an example batch execution sequence that shows how an existing weekly batch specification might be augmented with RPAC tests:
# Standard Weekly Batch Cycle weekly | unpack | weekly_sales.zip~ftp weekly | hierload | prod~14~N weekly | hierload | loc~14~N weekly | measload | load_oo_list weekly | calc | batch_fcst weekly | autobuild | # RPAC-enhanced Batch Cyle validate | initrpac | validate | hierload | prod~14~N validate | hierload | loc~14~N validate | measload | load_oo_list validate | runrpac | RPAC_Tests~Tests.xml validate | calc | batch_fcst validate | runrpac | RPAC_Workbook_Tests~WorkbookTests.xml
The first section, labeled "weekly", represents a weekly batch sequence that might run at midnight every Saturday. Note that updated hierarchy and measure data files for the week are uploaded to Object Storage in an archive file named "weekly_sales.tar.gz" using the unpack task.
The second section shows how the weekly batch sequence has been augmented with RPAC tests and named "validate". Note that the unpack task from the weekly sequence has been left out, and in its place initrpac is called to place the test data input files into the PDS. If new or updated RPAC test collateral files have been uploaded to Object Storage, they will be brought in at this point and used.
There are two sets of RPAC tests in this sequence, specified by the runrpac task entries. The first runs immediately after the hierarchy and measure files are loaded, and validates expected values in the PDS. The second test set is executed after some further calculations have been run, and builds one or more workbooks, then validates values within them as well.
When RPAC-enabled batch sequences are run, the primary log file (available through the Online Administration dashboard as well as through the log archive package uploaded to Object Storage) will show a brief summary of test results. Full test details and log files are available in the complete log archive package from the batch exec run, available in Object Storage once the execution has completed.
Note that the latest version of this guide specifies which RPAC features are available for Cloud deployments. Due to Cloud security constraints, some RPAC features, primarily the <SHELL> tag, have been disabled; however, inclusion of RPAC tests as a step in existing batch execution sequences should fully compensate for this restriction.
Writing Test Cases
The structure of an rpac test script is defined by the following tags.
Table 14-1 Test Case Tags
| Tag | Description |
<testscript> |
The outermost tag for the test script. This tag contains one or more <testsuite> tags. |
<testsuite> |
This tag defines a suite of tests that are designed to run together. Each suite contains its own <setup>, <teardown>, <testcase>, and <workbook-operations> tags. This tag has a name attribute that can be used with the -suite command line attribute to specify which suites are executed in this run. |
<once> |
The once tag contains tag elements used to set up the environment once before the first test case is executed. It is a tag like setup, but only happens once at the start of a test suite. The once tag has been added to allow a set of measures to be backed up once during the run of the test suite. |
<finalize> |
The finalize tag contains tag elements used to restore the environment after the final test case is executed. |
<setup> |
This tag sets the preconditions that are common to all test cases. Operations inside this tag are run before every test case is executed. Example operations:
<teardown> |
This tag contains cleanup code that is run after all test cases. Operations inside this tag are run after every test case is executed. This is used to restore PDS or a workbook to its default state to remove dependencies between independent test cases. Example operations:
<testcase> |
This tag is where the code to perform each test goes. It should perform operations, then use the assert tags to verify the results. The name of this tag is used in the output to log timing results and success/failure. Note: Code in the <setup> tag is executed prior to each test case, and code in the <teardown> tag is executed after each test case. |
Some tags handle access to an Oracle SQL database. These tag require an access role name.The tag testsuite has an optional attribute role used to set the database access role. Valid database role values are data_mart, patch, batch, dimload, factload, hiermgr, wkbk, rdonly, etl, report, and bdi.
The role assigned to the testsuite tag affects all test cases, and if no role is assigned to once, setup, and teardown, the role assigned to the testsuite tag will affect these tags as well. A role assigned to the once tag is applied to the tags contained in once, and if no role is assigned to setup and teardown, then this role will apply to these tags as well. A role assigned to the setup tag is applied to the tags contained in setup, and if no role is assigned to teardown, then this role will apply to teardown as well. A role assigned to the teardown tag only applies to the tags contain in teardown.
If a role is required for a test suite and the test suite does not have a valid role attribute, then RPAC will throw an error.
It is recommended that the teardown section restore the application to its previous state. This removes dependencies between test cases and ensures consistency from one run to the next.
The tags once, setup, and teardown are unique. Only the first occurrence of each of these tags is used. These tags can appear in any order under the testsuite tag, and all of these tags are optional. The code contained in these tags is executed at a set point during the run of unit test code. However, for the tag testcase, the order of occurrence in the testsuite is the order of execution.
Example
This section provides a sample XML file that contains some rpac tests that run against an MFP application. This test illustrates how the setup and teardown methods work, as well as how to use the various workbook operations.
The first test case demonstrates building the workbook. The test makes the wizard selections and builds the workbook. Once the workbook is built, an assertion verifies that the load rules correctly set the workbook value.
Once this test case is complete, the teardown code is executed, along with the setup code for the next test case. The test verifies that the teardown code correctly set the workbook's measure value to false and then issues a commit. Once the workbook is committed, the measure value is checked to see if it was properly updated. Once again, the teardown code is executed and the setup code is run at the beginning of the next test case.
For the third test case, the setup code should have initialized the measure value back to true, and the workbook value back to false. The test case verifies these operations, then performs a workbook refresh and verifies that the workbook value has been correctly set to true.
After that, the workbook is closed and the test suite is complete.
Because the teardown code modifies workbook data, the workbook close step cannot be encapsulated inside of a test case. If it was, the teardown code would try to modify a workbook that was no longer there and produce a failing result.
<testsuite name="Workbook Operations Tags" role="wkbk">
<once>
<rpas-today>20070122</rpas-today>
</once>
<finalize>
<close/>
</workbook-operations>
</finalize>
<!-- Setup executed at the beginning of every testcase -->
<setup>
<set-application-measure name="[MEAS]" namedkeys="[NKEY]" value="true"/>
</setup>
<!-- Teardown executed at the end of every testcase -->
<teardown>
<edit-workbook-measure name="[MEAS]" namedkeys="[NKEY]" value="false"/>
</teardown>
<testcase name="Workbook Build">
<!-- Build Merch Plan workbook -->
<build template-name="MP_WB" label="Merch Plan" user="adm">
<wizard-page-settings id="wiz_MP_WBhalf">
<set-tree-selections control-name="tree1" dim-name="half" rollup-name="half">
h1_2022
</set-tree-selections>
</wizard-page-settings>
<wizard-page-settings id="wiz_MP_WBchnl">
<set-tree-selections control-name="tree1" dim-name="chnl" rollup-name="chnl">
1
<wizard-page-settings id="wiz_MP_WBdept">
<set-tree-selections control-name="tree1" dim-name="dept" rollup-name="dept" >
300
</build>
<!-- Validate the load rule worked correctly -->
<assert-workbook-measure-value-eq name="[MEAS]" namedkeys="[NKEY]" value="true"/>
</testcase>
<!-- Commit the workbook and assert the measure values in pds-->
<testcase name="Enable OP Approval Workbook: Commit">
<assert-application-measure-value-eq name="[MEAS]" namedkeys="[NKEY]" value="true"/>
<assert-workbook-measure-value-eq name="[MEAS]" namedkeys="[NKEY]" value="false"/>
<commit type ="now" template-name="EnableOp" user="adm"/>
<!-- Validate the commit rule worked correctly -->
<assert-application-measure-value-eq name="[MEAS]" namedkeys="[NKEY]" value="false"/>
</testcase>
<!-- Refresh the workbook and assert measure values in workbook and pds-->
<testcase name="Enable OP Approval Workbook: Refresh">
<refresh user="adm"/>
<!-- Validate the refresh rule worked correctly -->
</testcase>
</testsuite>
</testsuite>Output
The rpac command now has a switch to create an HTML document of its tags and their usage. The HTML document rpac.html for RPAC is contained in the RPAS_HOME/doc/rpac directory.
When RPAC executes, it prints the status of the current execution to the console. Once all the test cases are complete, the summary of test cases is stored in unittest.log and unittest.xml under the current directory. The content of this simple text file unittest.log for a working example will be:
ran 3 tests: 0 skips: 0 errors, 0 failures in 1 minute 9.92 seconds for RPAC (LDIP): RPAS_UT Tests
And for unittest.xml:
<unittest elapsedTime="1 minute 9.92 seconds" name="RPAC (LDIP): RPAS_UT Tests" os="Windows" runcount="3" timestamp="2018-11-16 11:17:29" version="18.0.002.00.001"> </unittest>
If something goes wrong the output for unittest.log will be:
ran 3 tests: 0 skips: 1 errors, 0 failures in 1 minute 9.20 seconds for RPAC (LDIP): RPAS_UT Tests Errors: TestName: MFP RPAC Test 11.Enable OP Approval Workbook: Commit Exception: TestCase got OciNamedException: Test/testcases/rpac.xml at line 19 for suite 'MFP RPAC Test 11'. throw at line 414 of file 'd:\usr\rpas\edgetrunk\rpas\11\libraries\rpassql\rpas\private\sqlsession.cpp' Location: 90 'testcases/rpac.xml'
<unittest elapsedTime="1 minute 9.20 seconds" name="RPAC (LDIP): RPAS_UT Tests" os="Windows" runcount="3" timestamp="2018-11-16 12:01:03" version="18.0.002.00.001">
<errorlist>
<error>
<testname>MFP RPAC Test 11.Enable OP Approval Workbook: Commit</testname>
<exception>TestCase got OciNamedException: Test/testcases/rpac.xml at line 19 for suite 'MFP RPAC Test 11'.
throw at line 414 of file 'd:\usr\rpas\edgetrunk\rpas\11\libraries\rpassql\rpas\private\sqlsession.cpp'</exception>
<file>testcases/rpac.xml</file>
<line>90</line>
</error>
</errorlist>
</unittest>Schema
This section provides schema details.
RPAC Attributes, Values, and Variables
All HTML tags may contain attributes and values. RPAC does an initial processing of the attributes and tag value strings. This initial processing replaces any occurrence of the string enclosed with square brackets with the current variable matching the enclosed string. For example the string "Rpas Today is [RPAS_TODAY]" would be replace with "Rpas Today is 20180802" if either the process environmental variable "RPAS_TODAY" had the value of "20180802" or the RPAC tag "set-environment-variable" had been used to set the variable "RPAS_TODAY" to the value of "20180802".
There are environment variables internal to RPAC "[RPAC_DATE]", "[RPAC_DATA]", "[RPAC_WORK]", "[RPAC_TEST_SUITE]", "[RPAC_TEST_CASE]", "[PLATFORM]", "[PDS_PATH]", "[PDS_NAME]", "[PDS_ID]", "[SEGMENT_ID]", "[WORKBOOK_NAME]" and "[TASK_ID]".
These internal environment variables cannot be change using the RPAC tag set-environment-variable. And these variables are not normally exported to any processes RPAC is requested to start. For a process that RPAC is requested to start to see any internal RPAC variables use the set-environment-variable. For example:
<set-environment-variable name="RPAC_PDS_PATH" value="[PDS_PATH]" export="true"/>
This tag will export the internal "PDS_PATH" to the environmental variable "RPAC_PDS_PATH".
The internal environment variable "[RPAC_DATE]" always returns the current date/time as a string value. The format of the data time string can be changed using the RPAC tag "set-date-format". The default format is "%Y%m%d".
The internal environment variable "[RPAC_DATA]" is the location of the input directory known to RPAC.
The internal environment variable "[RPAC_WORK]" is the location of the output directory known to RPAC.
The internal environment variable "[RPAC_TEST_SUITE]" is name of the current test suite.
The internal environment variable "[RPAC_TEST_CASE]" is name of the current test case.
The internal environment variable "[PDS_PATH]" is the location of the PDS directory.
The internal environment variable "[PDS_NAME]" is the application name for PDS.
The internal environment variable "[PDS_ID]" is the application id for PDS.
The internal environment variable "[DEPLOY_ID]" is the deploy id for PDS.
The internal environment variable "[PLATFORM]" contains either the string "Windows" or the string "Linux" base on the platform RPAC is running on.
The internal environment variable "[SEGMENT_ID]" is segment id of the last workbook build.
The internal environment variable "[WORKBOOK_NAME]" is name of the current workbook or blank if there is no current workbook.
The internal environment variable "[TASK_ID]" is the current task Id of the last task started.
The internal variables "[WORKBOOK_NAME]", and "[SEGMENT_ID]" will be updated after workbook "build" tag is executed.
The internal variables "[TASK_ID]" will be updated after RPAC starts any tasks.
The "set-environment-variable" can be used to copy one environment variable into another environment variable.
1. RPAC Structure Tag
This section provides details about the top-level parent tag.
1.2 testsuite
The testsuite contains setup, teardown, and testcase tag elements.
Table 14-2 Testsuite
| Attribute | Required | Description |
name |
Yes |
Name of the test suite |
role |
No |
Role of the test suite |
category |
No |
Category name; light, normal, intense, performance, or debug |
stop-on-failure |
No |
Boolean to indicate if test suite should exit when error or failure occurs (Defaults to false) |
skip |
No |
Skip this tag if true (defaults to false) |
stop |
No |
Stop rpac execution if true (defaults to false) |
debug |
No |
Wait for debugger if true (defaults to false) |
1.3 testcase
The testcase contains a list of tag elements to be executed.
Table 14-3 Testcase
name |
Yes |
Name of the test case |
category |
No |
exception |
No |
Expected exception |
role |
No |
Role of the contain tags (defaults to role of testSuite) |
skip |
No |
stop |
No |
debug |
No |
1.4 once
Table 14-4 Once
role |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="DBPATH" value="data/rpacTest"/> </once>
1.5 finalize
Table 14-5 Finalize
role |
No |
skip |
No |
stop |
No |
debug |
No |
1.6 setup
The setup tag contains tag elements used to set up the environment before each test case is executed.These can include initializing measure values, setting the date, or running batch scripts to prepare the application.
Table 14-6 Setup
role |
No |
skip |
No |
stop |
No |
debug |
No |
1.7 teardown
The teardown tag contains tag elements used to restore the environment to a default state after each test case is executed. This can include returning measures to their default values or running batch scripts to clean up the application.
Table 14-7 Teardown
role |
No |
skip |
No |
stop |
No |
debug |
No |
2. Application Measure Tags
This section provides details about application measure tags.
2.1 assert-application-measure-exists
This tag asserts an application measure exists.
Table 14-8 assert-application-measure-exists
name |
Yes |
Application measure name |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-exists name="[mpwpgmmx]"/>
2.2 assert-application-measure-intx
This tag asserts a application measure base intersection matches an expected value.
Table 14-9 assert-application-measure-intx
name |
Yes |
intx |
Yes |
Intersection string to compare with |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-intx name="[mpwpgmmx]" intx="chnlscls"/>
2.3 assert-application-measure-value-eq
This tag asserts a application measure value is equal to an expected value.
Table 14-10 assert-application-measure-value-eq
name |
Yes |
value |
No |
Expected value of application measure. (Defaults to NA). Date value must be provided in one of six formats '%Y%m%d%H%M%S', '%Y%m%d%H%M', '%Y%m%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', or '%m/%d/%Y'. For boolean measure valid values are 't' or 'true' of any case while all other values are false. |
precision |
No |
The number of decimal places to be considered for assertion |
namedkeys |
No |
List of colon separated position names |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<assert-application-measure-value-eq name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
</testcase>2.4 assert-application-measure-value-ge
This tag asserts a application measure value is greater than or equal to an expected value.
Table 14-11 assert-application-measure-value-ge
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-value-ge name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" val
2.5 assert-application-measure-value-gt
This tag asserts a application measure value is greater than an expected value.
Table 14-12 assert-application-measure-value-gt
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-value-gt name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
2.6 assert-application-measure-value-le
This tag asserts a application measure value is less than or equal to an expected value.
Table 14-13 assert-application-measure-value-le
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-value-le name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
2.7 assert-application-measure-value-lt
This tag asserts a application measure value is less than an expected value.
Table 14-14 assert-application-measure-value-lt
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-value-lt name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
2.8 assert-application-measure-value-ne
This tag asserts a application measure value is not equal to an expected value.
Table 14-15 assert-application-measure-value-ne
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-measure-value-ne name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000"/>
2.9 assert-application-measures-match
This tag asserts application measures have matching content. The content of this tag can limit the comparison to a sub-set of the measure data. The format is DimName0:dim0pos0,dim0pos1,dim0pos3|DimName1:dim1pos0. Which is N number of dimension/positions lines with a vertical bar separator. Each dimension/positions lines has a dimension name followed by a colon separator and N position names with a comma separator between each name. This is an optional value.
Table 14-16 assert-application-measures-match
lhs-measure |
Yes |
LHS measure used for comparison |
rhs-measure |
Yes |
RHS measure used for comparison |
output-file |
No |
Output file name containing list of differences (Defaults to unique name base on tag line number and xml file name containing tag). |
max-diffs |
No |
Maximum number of differences allow before stopping match (defaults to 32) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<assert-application-measures-match lhs-measure="rm1" rhs-measure="rm2">
week:w45_2009,w46_2009,w47_2009|sku:sku_22200001,sku_22200002
</assert-application-measures-match>
<assert-application-measures-match lhs-measure="rm1" rhs-measure="rm2"/>
</testcase>2.10 assert-application-popcount-value-eq
This tag asserts a application pop count is equal to an expected value.
Table 14-17 assert-application-popcount-value-eq
name |
Yes |
pop-count |
No |
Expected popcount (Defaults to zero) |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-eq name="r_ex_demoa" pop-count="1"/>
2.11 assert-application-popcount-value-ge
This tag asserts a application pop count is greater than or equal to an expected value.
Table 14-18 assert-application-popcount-value-ge
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-ge name="r_ex_demoa" pop-count="1"/>
2.12 assert-application-popcount-value-gt
This tag asserts a application pop count is greater than an expected value.
Table 14-19 assert-application-popcount-value-gt
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-gt name="r_ex_demoa" pop-count="1"/>
2.13 assert-application-popcount-value-le
This tag asserts a application pop count is less than or equal to an expected value.
Table 14-20 assert-application-popcount-value-le
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-le name="r_ex_demoa" pop-count="1"/>
2.14 assert-application-popcount-value-lt
This tag asserts a application pop count is less than an expected value.
Table 14-21 assert-application-popcount-value-lt
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-lt name="r_ex_demoa" pop-count="1"/>
2.15 assert-application-popcount-value-ne
This tag asserts a application pop count is not equal to an expected value.
Table 14-22 assert-application-popcount-value-ne
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-application-popcount-value-ne name="r_ex_demoa" pop-count="1"/>
2.16 set-application-measure
This tag set the value of a application measure based on provided attributes.
Table 14-23 set-application-measure
name |
Yes |
value |
No |
Value to set application measure value to. (Defaults to NA). Date value must be provided in one of six formats '%Y%m%d%H%M%S', '%Y%m%d%H%M', '%Y%m%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', or '%m/%d/%Y'. For boolean measure valid values are 't' or 'true' of any case while all other values are false. |
keyint |
No |
Intersection of namedKey attribute if not provided intersection of namedKey is base intersection of the measure. |
namedkeys |
No |
List of colon separated position specs. There must be one position specs for each dimension of the measure. A position specs is a comma separate list of sub-specs. A sub-spec can be a position name, a range of position names like 'w01_1997-w18_1997', or an asterisk. An asterisk '*' indicates all positions of the given dimension will be used. A position name can be replace with a position index. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-application-measure name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/> <set-application-measure name="r_ex_demob" namedkeys="w02_2009-w04_2009:dept03:str1000" value="10"/> <set-application-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1000" value="10"/> <set-application-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1001"/> </testcase>
2.17 register-measure
This tag registers a measure with the provided properties to the current store either a workbook or application PDS table.
Table 14-24 register-measure
name |
Yes |
Measure name |
type |
No |
Type of measure (Defaults to real). Acceptable values are int, real, string, date, or boolean. |
intx |
No |
Base intersection |
defagg |
No |
Default aggregation method |
naval |
No |
Value to set the measure NaValue. (Defaults to NA). Date value must be provided in one of six formats '%Y%m%d%H%M%S', '%Y%m%d%H%M', '%Y%m%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', or '%m/%d/%Y'. For boolean measure valid values are 't' or 'true' of any case while all other values are false. |
fnhbi |
No |
Force non HBI measure (Defaults to false) |
dbpath |
No |
Database path of measure (Defaults to 'data/rpac') |
basestate |
No |
Base state of measure (Defaults to none) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="MEAS0" value="tst_int"/> <set-environment-variable name="MEAS1" value="tst_real"/> <set-environment-variable name="MEAS2" value="tst_string"/> <set-environment-variable name="MEAS3" value="tst_date"/> <set-environment-variable name="MEAS4" value="tst_boolean"/> <set-environment-variable name="INTX" value="str_week"/> <register-measure name="[MEAS0]" type="int" intx="[INTX]" basestate="write" naval="0"/> <register-measure name="[MEAS1]" type="real" intx="[INTX]" basestate="write" naval="0"/> <register-measure name="[MEAS2]" type="string" intx="[INTX]" basestate="write" naval="Test"/> <register-measure name="[MEAS3]" type="date" intx="[INTX]" basestate="write"/> <register-measure name="[MEAS4]" type="boolean" intx="[INTX]" basestate="write"/> </testcase>
2.18 unregister-measure
This tag unregisters a measure from the current store either a workbook or from the application PDS meta table.
Table 14-25 unregister-measure
name |
Yes |
Measure name |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="MEAS0" value="tst_int"/> <set-environment-variable name="MEAS1" value="tst_real"/> <unregister-measure name="[MEAS0]"/> <unregister-measure name="[MEAS1]"/> <unregister-measure name="test_measure"/> </testcase>
2.19 unregister-measures
This tag unregisters a list of measures from the current store either a workbook or from the application PDS meta table.
Table 14-26 unregister-measures
name |
Yes |
List of measure names |
skip |
No |
stop |
No |
debug |
No |
2.20 get-measure-property
This tag gets property for given measure. Valid properties are ('factname', 'factgroup', 'facttable', 'baseintx', 'aggMethod', 'navalue', 'rpastype', or 'materialized'). Any property that is an empty string will be show as the string constant 'Blank'.
Table 14-27 get-measure-property
measure-name |
Yes |
Name of measure to get property for |
property |
Yes |
Name of property to get fetch valid values ('factname', 'factgroup', 'facttable', 'baseintx', 'aggMethod', 'navalue', 'rpastype', or 'materialized') |
variable |
Yes |
Name of variable to update with property value |
skip |
No |
stop |
No |
debug |
No |
2.21 clear-application-measure-list
This tag clears a list of application measures of all data. Must provide either the attribute 'filename' where the list of measures is contain in a file. Or the attribute 'measures' where the value of the attribute is a comma separated list measures names.
Table 14-28 clear-application-measure-list
filename |
No |
Filename of file containing application measures names |
measures |
No |
Comma separated list of application measure names |
skip |
No |
stop |
No |
debug |
No |
Example:
<clear-application-measure-list measures="rm1,rm2"/>
2.22 clear-application-measure
This tag clears a application measure of all data.
Table 14-29 clear-application-measure
name |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<clear-application-measure name="r_ex_pick_real" />
2.23 backup-appl-measure
This tag backs up an application measure fact table data to the CSV backup file contained in the PDS directory.
Table 14-30 backup-appl-measure
measure-name |
Yes |
Measure name |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <backup-appl-measure measure-name="[MEAS1]"/> </testcase>
2.24 dump-appl-measure
This tag dumps an application measure data to a CSV file.
Table 14-31 dump-appl-measure
measure-name |
Yes |
Measure name |
csv-path |
Yes |
Path of CSV file to dump measure data into. A relative path value uses the RPAC work directory. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <dump-appl-measure measure-name="[MEAS1]" csv-path="measure1.csv"/> </testcase>
2.25 load-appl-measure
This tag loads an application measure data to a CSV file.
Table 14-32 load-appl-measure
measure-name |
Yes |
Measure name |
csv-path |
Yes |
overlay |
No |
When true overlay data into fact table. (defaults to false). |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <load-appl-measure measure-name="[MEAS1]" csv-path="measure1.csv"/> </testcase>
2.26 restore-all-appl-measure
This tag restores all application measures fact tables data from backup files contained in the PDS directory
Table 14-33 restore-all-appl-measure
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <restore-all-appl-measures/> </testcase>
3. Dimension Tags
This section provides details about the Dimension tags.
3.1 assert-hier-exists
This tag asserts a hierarchy exists.
Table 14-34 assert-hier-exists
name |
Yes |
Hierarchy name |
exists |
Yes |
If flag is true then check if hierachy exist (Defaults to true) |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-hier-exists name="prod" exists="true"/>
3.2 assert-dimension-contain
This tag asserts a dimension contains or does not contain a position name.
Table 14-35 assert-dimension-contain
name |
Yes |
Dimension name |
posname |
Yes |
List of comma separated position names |
containflag |
Yes |
If flag is true then position names are checked to see if they are contained in the dimension |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-dimension-contain name="scls" posname="10000001" containflag="true"/>
3.3 assert-dimension-exists
This tag asserts a dimension name exists.
Table 14-36 assert-dimension-exists
name |
Yes |
Hierarchy name |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-dimension-exists name="dim"/>
3.4 assert-dimension-size
This tag asserts a dimension size is between a minimum and a maximum value.
Table 14-37 assert-dimension-size
name |
Yes |
Dimension name |
min |
Yes |
Minimum value |
max |
Yes |
Maximum value |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-dimension-size name="dim" min="10" max="100"/>
4. Directory and File Tags
This section provides details about the Directory and File tags.
4.1 assert-directory-does-not-exists
This tag asserts that a directory does not exists.
Table 14-38 assert-directory-does-not-exists
path |
Yes |
Path of directory to verify does not exists |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-directory-does-not-exists path="[PDS_PATH]/emptyDir" />
4.2 assert-directory-exists
This tag asserts that a directory exists.
Table 14-39 assert-directory-exists
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="INPUT" value="[PDS_PATH]/input"/> <set-environment-variable name="PROCESSED" value="[INPUT]/processed"/> <assert-directory-exists path="[PROCESSED]"/></testcase>
4.3 assert-directory-is-empty
This tag asserts that a directory exists and contain no files.
Table 14-40 assert-directory-is-empty
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTDIR" value="[RPAC_WORK]/emptyDir"/> <assert-directory-is-empty path="[TESTDIR]"/> </testcase>
4.4 assert-directory-structure
This tag asserts that a directory exists and has a certain directory structure. The value of the tag contains the expected directory structure. Each line of the directory structure must use a vertical bar '|' between lines. The path attribute is the location of the directory structure.
Table 14-41 assert-directory-structure
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-directory-structure path="[RPAC_WORK]/rdm"> tasks/ | tasks/booking/ | tasks/pending/ | tasks/working/ | tasks/working/test.log </assert-directory-structure>
4.5 assert-file-contains
This tag asserts range of N:M occurrences of text are contain in a file. Must provide either 'text' attribute, 'text-from-file' attribute or tag value. If 'text' attribute is provided then the value of the attribute will be split base on the separator attribute. If 'text-from-file' attribute is provide then each line is a separate pattern. If tag value is provide then each line of the tag value will be a separate pattern.
Table 14-42 assert-file-contains
path |
Yes |
File path of file to search |
range |
Yes |
Range of number of occurrences to expect. IE 4:6 indicates at least four and up to and including six occurrences |
test |
No |
Text patterns to search for, if separator is provided the text string is split into different patterns |
text-from-file |
No |
File path containing text patterns to search for. Each line of the file being a pattern |
erase |
No |
Erase file if assert is valid (defaults to true) |
case-sensitive |
No |
Case sensitive (defaults to false) |
separator |
No |
Separator to use (defaults to "|"), use "none" if text does not need to be split |
skip |
No |
stop |
No |
debug |
No |
Example:
<testsuite name="example" role="batch">
<once>
<set-environment-variable name="PATTERNS1" value="[PLATFORM]/patterns1.txt"/>
<set-environment-variable name="MACE_CMD" value="mace -d [SANDBOX] -run -expression"/>
</once>
<testcase name="Test 1">
<shell unique-file="LOG_PATH">
[MACE_CMD] "rpacMeasure = if(rpacMaskMeasure, rand(123, 170), 0)"
</shell>
<assert-file-contains path="[LOG_PATH]" erase="false" range="1:1" text-from-file="[PATTERNS1]"/>
<assert-file-contains path="[LOG_PATH]" erase="true" range="1:8" text="IllegalParse"/>
</testcase>
</testsuite>4.6 assert-file-does-not-exists
This tag asserts that a file does not exists.
Table 14-43 assert-file-does-not-exists
path |
Yes |
Path of file to verify does not exists |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="INPUT" value="[PDS_PATH]/input"/> <set-environment-variable name="PROCESSED" value="[INPUT]/processed"/> <assert-file-does-not-exists path="[INPUT]/prod.dat"/> <assert-file-does-not-exists path="[PROCESSED]/users.xml"/> </testcase>
4.7 assert-file-exists
This tag asserts that a file exists.
Table 14-44 assert-file-exists
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="INPUT" value="[PDS_PATH]/input"/> <set-environment-variable name="PROCESSED" value="[INPUT]/processed"/> <assert-file-does-not-exists path="[INPUT]/prod.dat"/> <assert-file-does-not-exists path="[PROCESSED]/users.xml"/> <assert-directory-exists path="[PROCESSED]"/> <assert-file-exists path="[PROCESSED]/msgs.dat.20190822004042"/> </testcase>
4.8 assert-file-is-empty
This tag asserts that a file exists and contain no data.
Table 14-45 assert-file-is-empty
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTTXTFILE" value="[RPAC_WORK]/emptyDir/test.txt"/> <assert-file-is-empty path="[TESTTXTFILE]"/> </testcase>
4.9 assert-file-is-read-lock
This tag asserts the given file is read locked.
Table 14-46 assert-file-is-read-lock
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTLCKFILE" value="[RPAC_WORK]/emptyDir/test.lck"/> <read-lock-file path="[TESTLCKFILE]"/> <assert-file-is-read-lock path="[TESTLCKFILE]"/> </testcase>
4.10 assert-file-is-write-lock
This tag asserts the given file is write locked.
Table 14-47 assert-file-is-write-lock
path |
Yes |
skip |
No |
stop |
No |
debug |
No |
<testcase> <set-environment-variable name="TESTLCKFILE" value="[RPAC_WORK]/emptyDir/test.lck"/> <write-lock-file path="[TESTLCKFILE]"/> <assert-file-is-write-lock path="[TESTLCKFILE]"/> </testcase>
4.11 compare-file-content
This tag compares content of file to xml data.
Table 14-48 compare-file-content
path |
Yes |
Path of file content is to be compare with |
erase |
No |
Erase file if matches content (defaults to true) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<set-environment-variable name="MEAS" value="rpacMeasure %s NA NA"/>
<set-environment-variable name="DIM" value="week 0 %s 1"/>
<get-unique-file-path name="FILEPATH"/>
<shell>exportData -d [RPAC_DOMAIN] -meas "[MEAS]" -dim "[DIM]" -out [FILEPATH]</shell>
<compare-file-content path="[FILEPATH]">
"w02_2007Test1"|
"w03_2007Test2"|
"w04_2007Test3"
</compare-file-content>
</testcase>4.12 compare-files
This tag compares content of two files.
Table 14-49 compare-files
input |
Yes |
Path to input gold file |
output |
Yes |
Path to output file to compare to |
ignore-trailing-blank-line |
No |
Ignore blank lines at end of file (defaults to false) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase name="Verify working directory attribute works"> <set-environment-variable name="EXPECTED" value="[RPAC_DATA]/rpas_utilities.txt"/> <shell unique-file="[ACTUAL]">ls -l [RPAS_HOME]</shell> <compare-files input="[EXPECTED]" output="[ACTUAL]"/> </testcase>
4.13 copy-directory
This tag copy a directory.
Table 14-50 copy-directory
src-path |
Yes |
Path of directory to be copied |
dst-path |
Yes |
Path to copy directory to |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTDIR" value="[RPAC_WORK]/emptyDir"/> <copy-directory src-path="[TESTDIR]/testDir1" dst-path="[TESTDIR]/testDir2"/> </testcase>
4.14 copy-file
This tag copy a file.
Table 14-51 copy-file
src-path |
Yes |
dst-path |
Yes |
expand |
No |
Expand environmental variables (defaults to false) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTTXTFILE1" value="[RPAC_WORK]/emptyDir/test1.txt"/> <set-environment-variable name="TESTTXTFILE2" value="[RPAC_WORK]/emptyDir/test2.txt"/> <copy-file src-path="[TESTTXTFILE1]" dst-path="[TESTTXTFILE2]"/> </testcase>
4.15 create-directory
This tag creates a directory.
Table 14-52 create-directory
path |
Yes |
Path of directory to create |
create-parent |
No |
Create parent directory if true (defaults to false) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTDIR" value="[RPAC_WORK]/emptyDir"/> <create-directory path="[TESTDIR]"/> </testcase>
4.16 create-file
This tag creates a file.
Table 14-53 create-file
path |
Yes |
create-parent |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTTXTFILE" value="[RPAC_WORK]/emptyDir/test.txt"/> <create-file path="[TESTTXTFILE]">test</create-file> </testcase>
4.17 erase-file
This tag erases a file.
Table 14-54 erase-file
path |
Yes |
Path to output file to erase |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTTXTFILE" value="[RPAC_WORK]/emptyDir/test.txt"/> <erase-file path="[TESTTXTFILE]"/> </testcase>
4.18 rename-file
This tag renames a file or directory.
Table 14-55 rename-file
src-path |
Yes |
Old name of file or directory |
dst-path |
Yes |
New name of file or directory |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTTXTFILE1" value="[RPAC_WORK]/emptyDir/test1.txt"/> <set-environment-variable name="TESTTXTFILE2" value="[RPAC_WORK]/emptyDir/test2.txt"/> <rename-file src-path="[TESTTXTFILE1]" dst-path="[TESTTXTFILE2]"/> </testcase>
4.19 remove-directory
This tag removes a directory.
Table 14-56 remove-directory
path |
Yes |
Path of directory to remove |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTDIR" value="[RPAC_WORK]/emptyDir"/> <remove-directory path="[TESTDIR]"/> </testcase>
4.20 read-lock-file
This tag attempts to read lock the given file.
Table 14-57 read-lock-file
path |
Yes |
Path of file being check for lock status |
wait-for |
No |
Number of seconds to wait acquiring lock (Defaults to 2 minutes) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTLCKFILE" value="[RPAC_WORK]/emptyDir/test.lck"/> <read-lock-file path="[TESTLCKFILE]"/> </testcase>
4.21 write-lock-file
This tag attempts to write locks the given file.
Table 14-58 write-lock-file
path |
Yes |
wait-for |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTLCKFILE" value="[RPAC_WORK]/emptyDir/test.lck"/> <write-lock-file path="[TESTLCKFILE]"/> </testcase>
4.22 unlock-file
This tag attempts to unlock the given file.
Table 14-59 unlock-file
path |
Yes |
wait-for |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="TESTLCKFILE" value="[RPAC_WORK]/emptyDir/test.lck"/> <unlock-file path="[TESTLCKFILE]"/> </testcase>
4.23 assert-file-size-eq
This tag asserts the size of the file is equal to an expected value.
Table 14-60 assert-file-size-eq
path |
Yes |
Path of file to verify size of. |
value |
No |
File size to compare to. (Defaults to zero) |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check equal 0"> <assert-file-size-eq path="[PATH]" value="0"/> </testcase>
4.24 assert-file-size-ge
This tag asserts the size of the file is greater than or equal to an expected value.
Table 14-61 assert-file-size-ge
path |
Yes |
value |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check greater than or equal 0"> <assert-file-size-ge path="[PATH]" value="0"/> </testcase>
4.25 assert-file-size-gt
This tag asserts the size of the file is greater than an expected value.
Table 14-62 assert-file-size-gt
path |
Yes |
value |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check greater than 0"> <assert-file-size-gt path="[PATH]" value="0"/> </testcase>
4.26 assert-file-size-le
This tag asserts the size of the file is less than or equal to an expected value.
Table 14-63 assert-file-size-le
path |
Yes |
value |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check less than or equal 0"> <assert-file-size-le path="[PATH]" value="0"/> </testcase>
4.27 assert-file-size-lt
This tag asserts the size of the file is less than an expected value.
Table 14-64 assert-file-size-lt
path |
Yes |
value |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check less than 0"> <assert-file-size-lt path="[PATH]" value="0"/> </testcase>
4.28 assert-file-size-ne
This tag asserts the size of the file is not equal to an expected value.
Table 14-65 assert-file-size-ne
path |
Yes |
value |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="PATH" value="[RPAC_DATA]/measure1.csv"/> </once> <testcase name="Check not equal 0"> <assert-file-size-ne path="[PATH]" value="0"/> </testcase>
5. Sql Query Tags
This section describes the SQL Query tags.
5.1 assert-sql-query-eq
This tag asserts the SQL query value is equal to an expected value.
Table 14-66 assert-sql-query-eq
value |
Yes |
Expected value |
type |
Yes |
Must provide type of value as one of these strings 'string', 'slong32', or 'double' |
commit |
No |
True if the SQL query should be committed (defaults to false) |
nullable |
No |
True if the SQL query results could be null (defaults to false) |
bind-name |
No |
Provides a name for store procedure query like 'begin rp_xx_pkg.get_name(:name); end;'. For this call the parameter must be set to ':name'. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-eq">
<set-environment-variable name="QUERY" value="select count(*) from rp_g_scls_d where scls='10000001'"/>
<assert-sql-query-eq value="1" type="slong32">
[QUERY]
</assert-sql-query-eq>
</testcase>5.2 assert-sql-query-ge
This tag asserts the SQL query value is greater than or equal to an expected value.
Table 14-67 assert-sql-query-ge
value |
Yes |
Expected value |
type |
Yes |
commit |
No |
nullable |
No |
bind-name |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-ge eq case">
<assert-sql-query-ge value="1" type="slong32">
[QUERY]
</assert-sql-query-ge>
</testcase>5.3 assert-sql-query-gt
This tag asserts the SQL query value is greater than an expected value.
Table 14-68 assert-sql-query-gt
value |
Yes |
Expected value |
type |
Yes |
commit |
No |
nullable |
No |
bind-name |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-gt">
<assert-sql-query-gt value="0" type="slong32">
[QUERY]
</assert-sql-query-gt>
</testcase>5.4 assert-sql-query-le
This tag asserts the SQL query value is less than or equal to an expected value.
Table 14-69 assert-sql-query-le
value |
Yes |
Expected value |
type |
Yes |
commit |
No |
nullable |
No |
bind-name |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-le lt case">
<assert-sql-query-le value="2" type="slong32">
[QUERY]
</assert-sql-query-le>
</testcase>5.5 assert-sql-query-lt
This tag asserts the SQL query value is less than an expected value.
Table 14-70 assert-sql-query-lt
value |
Yes |
Expected value |
type |
Yes |
commit |
No |
nullable |
No |
bind-name |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-lt">
<assert-sql-query-lt value="2" type="slong32">
[QUERY]
</assert-sql-query-lt>
</testcase>5.6 assert-sql-query-ne
This tag asserts the SQL query value is not equal to an expected value.
Table 14-71 assert-sql-query-ne
value |
Yes |
Expected value |
type |
Yes |
commit |
No |
nullable |
No |
bind-name |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase
name="assert-sql-query-ne">
<assert-sql-query-ne value="2" type="slong32">
[QUERY]
</assert-sql-query-ne>
</testcase>5.7 call-rule-group
This tag execute a rule group contain in the PDS database.
Table 14-72 call-rule-group
rule-group |
Yes |
Name of rule group to execute |
skip |
No |
stop |
No |
debug |
No |
5.8 call-special-expression
This tag calls a special expression in the PDS database.
Table 14-73 call-special-expression
expression |
Yes |
Special expression to call |
lhs-measures |
Yes |
LHS comma separated list of measures |
rhs-measures |
Yes |
RHS comma separated list of measures |
skip |
No |
stop |
No |
debug |
No |
5.9 dump-database-tables
This tag dump one or more SQL tables to CSV text file given a list of SQL tables. The CSV test files created will be contain in the RPAC data directory unless the attribute dst-directory is used to specify the directory to contain these files. One and only one of these attributes 'sql-tables' and 'sql-tables-file' must be provided.
Table 14-74 dump-database-tables
sql-tables |
No |
List of SQL table names to dump to CSV text files. |
sql-tables-file |
No |
File containing list of SQL table names to dump to CSV text files. This path is relative to the RPAC data directory. |
dst-directory |
No |
Path of directory to contain the CSV text files. This path is relative to the RPAC data directory. If not provide the CSV text files will be written into the RPAC data directory. If the directory does not exists it will be created. |
sorted |
No |
Use the table keys to sort the rows (Defaults to false). |
skip |
No |
stop |
No |
debug |
No |
5.10 execute-bdi-extractor
This tag executes the request BDI extractor. The return control identifier is contain in the variable 'EXTRACTOR_CONTROL_ID'.
Table 14-75 execute-bdi-extractor
extractor |
Yes |
Extractor name |
job-context |
Yes |
Job context |
control-id |
No |
Control identifier (defaults to 0) |
skip |
No |
stop |
No |
debug |
No |
5.11 execute-bdi-importer
This tag executes the request BDI importer.
Table 14-76 execute-bdi-importer
importer |
Yes |
Importer name |
appl-name |
Yes |
Application name |
module |
Yes |
Name of module |
date-set-type |
Yes |
Data set type |
job-context |
Yes |
Job context |
data-set-id |
No |
Data set identifier (defaults to 0) |
skip |
No |
stop |
No |
debug |
No |
5.12 execute-sql-query
This tag executes the SQL query provied as the value of this tag.
Table 14-77 execute-sql-query
commit |
No |
True if the SQL query will be committed |
skip |
No |
stop |
No |
debug |
No |
Example:
<execute-sql-query>
DELETE FROM RP_G_STR_D WHERE STR IN
('1194s', '1195s', '1197s', '1198s', '1200s', '8888s', '1193s', '1196s', '9999s', '1199s')
</execute-sql-query>5.13 load-database-tables
This tag loads one or more tables from CSV text file given a list of text files or directories contain these files. Each file must have a '.csv' extension. The file path will be relative to the RPAC data directory. The table will be truncated before loading the data from the CSV text file.
Table 14-78 load-database-tables
csv-files |
Yes |
List of CSV text files or directories containing these files. Each file must have a '.csv' extension. The file path will be relative to the RPAC data directory. |
skip |
No |
stop |
No |
debug |
No |
5.14 set-database-role
This tag sets the role used to access the database.
Table 14-79 set-database-role
role |
Yes |
Role used to access the database |
skip |
No |
stop |
No |
debug |
No |
Example:
<set-database-role role="data_mart"/>
5.15 sql-start-trace
This tag enables tracing of SQL queries to a text file.
Table 14-80 sql-start-trace
trace-path |
No |
Text file path. (Defaults to 'trace.txt') |
skip |
No |
stop |
No |
debug |
No |
5.16 sql-stop-trace
This tag stops tracing SQL queries.
Table 14-81 sql-stop-trace
skip |
No |
stop |
No |
debug |
No |
5.17 truncate-database-tables
This tag truncates comma seperated list of database tables provided as the value of this tag.
Table 14-82 truncate-database-tables
skip |
No |
stop |
No |
debug |
No |
6. Workbook Measures Tags
This section describes the Workbook measures tags.
6.1 assert-workbook-measure-exists
This tag asserts a workbook measure exists.
Table 14-83 assert-workbook-measure-exists
name |
Yes |
Workbook measure name |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-exists name="mpwpslsr"/>
6.2 assert-workbook-measure-intx
This tag asserts a workbook measure base intersection matches an expected value.
Table 14-84 assert-workbook-measure-intx
name |
Yes |
intx |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-intx name="mpwpslsr" intx="chnlsclsweek"/>
6.3 assert-workbook-measure-value-eq
This tag asserts a workbook measure value is equal to an expected value.
Table 14-85 assert-workbook-measure-value-eq
name |
Yes |
value |
No |
Expected value of workbook measure. (Defaults to NA). Date value must be provided in one of six formats '%Y%m%d%H%M%S', '%Y%m%d%H%M', '%Y%m%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', or '%m/%d/%Y'. For boolean measure valid values are 't' or 'true' of any case while all other values are false. |
precision |
No |
namedkeys |
No |
intersection |
No |
Intersection to assert measure at (defaults to base intersection) |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-value-eq name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
6.4 assert-workbook-measure-value-ge
This tag asserts a workbook measure value is greater than or equal to an expected value
Table 14-86 assert-workbook-measure-value-ge
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
intersection |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-value-ge name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
6.5 assert-workbook-measure-value-gt
This tag asserts a workbook measure value is greater than an expected value
Table 14-87 assert-workbook-measure-value-gt
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
intersection |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-value-gt name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
6.6 assert-workbook-measure-value-le
This tag asserts a workbook measure value is less than or equal to an expected value
Table 14-88 assert-workbook-measure-value-le
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
intersection |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-value-le name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
6.7 assert-workbook-measure-value-lt
This tag asserts a workbook measure value is less than an expected value
Table 14-89 assert-workbook-measure-value-lt
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
intersection |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-measure-value-lt name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
6.8 assert-workbook-measure-value-ne
This tag asserts a workbook measure value is not equal to an expected value.
Table 14-90 assert-workbook-measure-value-ne
name |
Yes |
value |
No |
precision |
No |
namedkeys |
No |
intersection |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
Example<testcase>
<assert-workbook-measure-value-ne name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/>
</testcase>6.9 assert-workbook-measures-match
This tag asserts workbook measures have matching content. The content of this tag can limit the comparison to a sub-set of the measure data. The format is DimName0:dim0pos0,dim0pos1,dim0pos3|DimName1:dim1pos0. Which is N number of dimension/positions lines with a vertical bar separator. Each dimension/positions lines has a dimension name followed by a colon separator and N position names with a comma separator between each name. This is an optional value.
Table 14-91 assert-workbook-measures-match
lhs-measure |
Yes |
rhs-measure |
Yes |
output-file |
No |
max-diffs |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<assert-workbook-measures-match lhs-measure="rm1" rhs-measure="rm2">
</assert-workbook-measures-match>
<assert-workbook-measures-match lhs-measure="rm1" rhs-measure="rm2"/>
</testcase>6.10 assert-workbook-popcount-value-eq
This tag asserts a workbook pop count is equal to an expected value.
Table 14-92 assert-workbook-popcount-value-eq
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-eq name="mpwpslsr" pop-count="1"/>
6.11 assert-workbook-popcount-value-ge
This tag asserts a workbook pop count is greater than or equal to an expected value.
Table 14-93 assert-workbook-popcount-value-ge
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-ge name="mpwpslsr" pop-count="1"/>
6.12 assert-workbook-popcount-value-gt
This tag asserts a workbook pop count is greater than an expected value.
Table 14-94 assert-workbook-popcount-value-gt
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-gt name="mpwpslsr" pop-count="0"/>
6.13 assert-workbook-popcount-value-le
This tag asserts a workbook pop count is less than or equal to an expected value.
Table 14-95 assert-workbook-popcount-value-le
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-le name="mpwpslsr" pop-count="1"/>
6.14 assert-workbook-popcount-value-lt
This tag asserts a workbook pop count is less than an expected value.
Table 14-96 assert-workbook-popcount-value-lt
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-lt name="mpwpslsr" pop-count="1000"/>
6.15 assert-workbook-popcount-value-ne
This tag asserts a workbook pop count is not equal to an expected value.
Table 14-97 assert-workbook-popcount-value-ne
name |
Yes |
pop-count |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-workbook-popcount-value-ne name="mpwpslsr" pop-count="10"/>
6.16 set-workbook-measure
This tag sets the value of a workbook measure based on provided attributes.
Table 14-98 set-workbook-measure
name |
Yes |
value |
No |
Value to set workbook cell to. (Defaults to NA). Date value must be provided in one of six formats '%Y%m%d%H%M%S', '%Y%m%d%H%M', '%Y%m%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', or '%m/%d/%Y'. For boolean measure valid values are 't' or 'true' of any case while all other values are false. |
keyint |
No |
namedkeys |
No |
incremental |
No |
True if evaluation is to be incremental (Defaults to false) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-workbook-measure name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/> <set-workbook-measure name="r_ex_demob" namedkeys="w02_2009-w04_2009:dept03:str1000" value="10"/> <set-workbook-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1000" value="10"/> <set-workbook-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1001"/> <set-workbook-measure name="r_ex_demod" namedkeys="w02_2009-w04_2009:*:str1000" value="10" incremental="true"/> </testcase>
6.17 edit-workbook-measure
This tag edits the value of a workbook measure based on provided attributes.
Table 14-99 edit-workbook-measure
name |
Yes |
value |
No |
keyint |
No |
namedkeys |
No |
incremental |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <edit-workbook-measure name="[MEAS]" namedkeys="[KEY0]" value="Measure Analysis Test"/> <edit-workbook-measure name="r_ex_demoa" namedkeys="w02_2009,w03_2009,w04_2009:dept03:str1000" value="10"/> <edit-workbook-measure name="r_ex_demob" namedkeys="w02_2009-w04_2009:dept03:str1000" value="10"/> <edit-workbook-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1000" value="10"/> <edit-workbook-measure name="r_ex_democ" namedkeys="w02_2009-w04_2009:*:str1001"/> </testcase>
6.18 clear-workbook-measure-list
This tag clears a list of workbook measures of all data. Must provide either the attribute 'filename' where the list of measures is contain in a file. Or the attribute 'measures' where the value of the attribute is a comma separated list measures names.
Table 14-100 clear-workbook-measure-list
filename |
No |
Filename of file containing workbook measures names |
measures |
No |
Comma separated list of workbook measure names |
skip |
No |
stop |
No |
debug |
No |
Example:
<clear-workbook-measure-list measures="mpwpslsr,mtwpappstt"/>
6.19 clear-workbook-measure
This tag clears a workbook measure of all data.
Table 14-101 clear-workbook-measure
name |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<clear-workbook-measure name="mpwpslsr"/>
6.20 assert-measure-is-not-protected
This tag asserts a measures is not protected based on previous edited.
Table 14-102 assert-measure-is-not-protected
name |
Yes |
Name of workbook measure to assert is not protected |
variable |
No |
Name of RPAC or environment variable to true/false based on the status of the measure not being protected. If not provided, tag will report an error if the measure is protected. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testsuite name="Assert measure is not protected"> <testcase name="fails if measure is not protected"> <assert-measure-is-not-protected name="[MEAS]"/> </testcase> <testcase name="set variable MSG1 to false/true base on measure not being protected"> <assert-measure-is-not-protected name="[MEAS]" variable="MSG1"/> </testcase> </testsuite>
6.21 assert-measure-is-protected
This tag asserts a measures is protected based on previous edited.
Table 14-103 assert-measure-is-not-protected
name |
Yes |
variable |
No |
Name of RPAC or environment variable to true/false based on the status of the measure being protected. If not provided, tag will report an error if the measure is not protected. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testsuite name="Assert measure is protected"> <testcase name="fails if measure is not protected"> <assert-measure-is-protected name="[MEAS]"/> </testcase> <testcase name="set variable MSG1 to false/true base on measure being protected"> <assert-measure-is-protected name="[MEAS]" variable="MSG1"/> </testcase> </testsuite>
7. Workbook Operations Tags
This section describes the Workbook Operations tags.
7.1 assert-window-contain-measure
This tag asserts current workbook named window either contains or does not contain a list of measures.
Table 14-104 assert-window-contain-measure
name |
Yes |
Window name of current workbook |
measures |
No |
Comma separated list of measures names |
containflag |
No |
If true measures are expected to be contained in the current workbook windows. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <set-environment-variable name="WINNAME" value="chnlscls_W"/> <set-environment-variable name="MEAS1" value="mpwpgmmx"/> <assert-window-contain-measure name="[WINNAME]" containflag="true" measures="[MEAS1]"/> </testcase>
7.2 assert-window-exists
This tag asserts if a window exists in the current workbook
Table 14-105 assert-window-exists
name |
Yes |
Window name |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-window-exists name="MP_TB02_WS01"/>
7.3 assert-window-intersection
This tag asserts window intersection matches provided intersection.
Table 14-106 assert-window-intersection
name |
Yes |
Window name |
baseint |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-window-intersection name="MP_TB02_WS01" baseint="sclschnl"/>
7.4 assert-window-not-exists
This tag asserts if a window does not exist in the current workbook.
Table 14-107 assert-window-not-exists
name |
Yes |
Window name |
skip |
No |
stop |
No |
debug |
No |
Example:
<assert-window-not-exists name="MP_TB02_TEST"/>
7.5 build
This tag builds workbook based on provided tag data.
Note that this tag can only be used within the workbook-operations tag. This tag supports these subtag wizard-page-settings.
Table 14-108 build
template-name |
Yes |
Template name |
user |
Yes |
User used to access workbook |
label |
No |
Label for workbook (defaults to blank) |
skip |
No |
stop |
No |
debug |
No |
Example:
<build template-name="measureanalysis" label="MEAS AN" user="oci.admin">
<wizard-page-settings id="ExtraMeasuresPage">
<set-selections control-name="lb1">mpwpgmmx</set-selections>
<wizard-page-settings id="scls">
<set-tree-selections dim-name="scls" rollup-name="scls">10000001</set-tree-selections>
<wizard-page-settings id="chnl">
<set-tree-selections dim-name="chnl" rollup-name="chnl">1</set-tree-selections>
</build>
</workbook-operations>7.6 calc
This tag does workbook calc.
Table 14-109 calc
template-name |
Yes |
Template name |
user |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<workbook-operations> <calc template-name="measureanalysis" user="oci.admin"/> </workbook-operations>
7.7 close
This tag does workbook close.
Table 14-110 close
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<close/>
</testcase>7.8 commit
This tag does workbook commit.
Table 14-111 commit
template-name |
Yes |
Template name |
user |
Yes |
name |
No |
Name to use to refer to this commit ASAP (defaults to bank) |
wait-for |
No |
Number of seconds to wait for the commit to complete. (defaults to 8 hours) |
skip |
No |
stop |
No |
debug |
No |
Example:
<commit template-name="measureanalysis" user="oci.admin"/>
</workbook-operations>7.9 custom-menu
This tag handles a custom menu.
Table 14-112 custom-menu
template-name |
Yes |
Template name |
user |
Yes |
menu-label |
Yes |
Menu label for this custom menu |
menu-exist |
No |
Flag to set to 'true' or 'false' to enable throwing an exception if the menu item is or is not found |
skip |
No |
stop |
No |
debug |
No |
Example:
<calc template-name="MP_WB" user="oci.admin"/>
<custom-menu template-name="MP_WB" user="oci.admin" menu-label="menuItem10101"/>
</workbook-operations>7.10 set-hier-selection
This tag sets the selected of wizard page.
Note that this tag can only be used within the wizard-page-settings tag.
Table 14-113 set-hier-selection
control-name |
Yes |
Name of the control for a wizard page |
selection |
Yes |
Text for the selection operation |
dim-name |
Yes |
Dimension name for the tree selection |
skip |
No |
stop |
No |
debug |
No |
7.11 set-selected
Table 14-114 set-selected
control-name |
Yes |
selected |
Yes |
Text for the selected operation |
skip |
No |
stop |
No |
debug |
No |
7.12 set-selection
This tag set the selection of wizard page.
Table 14-115 set-selection
control-name |
Yes |
selection |
Yes |
skip |
No |
stop |
No |
debug |
No |
7.13 set-selections
This tag set the selections of wizard page.
Table 14-116 set-selections
control-name |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
</build>
</workbook-operations>7.14 set-text
This tag set the text of wizard page.
Table 14-117 set-text
control-name |
Yes |
text |
Yes |
Text for the operation |
skip |
No |
stop |
No |
debug |
No |
7.15 set-tree-selections
This tag set the tree selections of wizard page.
Table 14-118 set-tree-selections
rollup-name |
Yes |
Roll up name for the tree selection |
dim-name |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
</build>
</workbook-operations>7.16 wizard-page-settings
This tag contains the settings for a wizard page.
Note that this tag can only be used within the build tag. This tag support the following subtags: set-hier-selection, set-selected, set-selection, set-selections, set-text, set-tree-selections.
Table 14-119 wizard-page-settings
id |
Yes |
ID used to match up settings with wizard pages |
skip |
No |
stop |
No |
debug |
No |
Example:
</wizard-page-settings> </build>
</workbook-operations>7.17 workbook-operations
This tag contains the workbook operation to be executed.
Note that this tag support the following subtags: build, calc, close, commit, custom-menu, open, rebuild, refresh, update-dpm.
Table 14-120 workbook-operations
skip |
No |
stop |
No |
debug |
No |
7.18 open
This tag opens given workbook.
Table 14-121 open
workbook-name |
Yes |
Name of workbook |
user |
Yes |
User that created the workbook |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<open workbook-name="[NEW_WORKBOOK]" user="[USER]"/>
</testcase>7.19 rebuild
This tag rebuilds workbook base on segment Id of previous build of the workbook.
Table 14-122 rebuild
segment-id |
Yes |
Segment ID of workbook to rebuild |
user |
Yes |
User used to access the workbook |
label |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<rebuild segment-id="[NEW_SEGMENT]" user="[USER]" label="Translation Workbook"/>
</testcase>7.20 refresh
This tag does workbook refresh.
Table 14-123 refresh
user |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<refresh user="[USER]"/>
</testcase>7.21 delete-informal-position
This tag deletes the DPM data.
Table 14-124 delete-informal-position
user |
Yes |
skip |
No |
stop |
No |
debug |
No |
Example:
<delete-informal-position levelname="str" position="strdpm_ut2"/>
7.22 update-dpm
This tag updates the DPM data.
Table 14-125 update-dpm
skip |
No |
stop |
No |
debug |
No |
7.23 update-informal-positions
This tag updates the informal positions.
Note that this tag support this subtag: dpmposinfo.
Table 14-126 update-informal-positions
skip |
No |
stop |
No |
debug |
No |
Example:
<update-informal-positions>
<dpmposinfo lang="english">
<dpmposentry levelname="dstr" position="dstr34" isnewpos="false" label="34 SPAIN" oldposition="dstr34" type="0" count="1"/>
<dpmposentry levelname="str" position="strdpm_ut2" isnewpos="true" label="Store DPM UT 1" oldposition="" type="0" count="1"/>
</dpmposinfo>
</update-informal-positions>7.24 dpmposentry
DPM position Entry.
Note that this tag can only be used within the dpmposinfo tag.
Table 14-127 dpmposentry
levelname |
Yes |
Level Name |
isnewpos |
Yes |
True for new position and false for modify |
position |
Yes |
position name |
label |
No |
position label |
oldposition |
No |
old position name |
type |
No |
type |
count |
No |
count |
skip |
No |
stop |
No |
debug |
No |
Example:
</dpmposinfo>
</update-informal-positions>7.25 dpmposinfo
DPM position info.
Note that this tag can only be used within the update-informal-positions tag. This tag support this subtag: dpmposentry.
Table 14-128 dpmposinfo
lang |
Yes |
Language attribute |
skip |
No |
stop |
No |
debug |
No |
Example:
</dpmposinfo>
</update-informal-positions>8. Workbook Execute Expression Tag
This section describes the Workbook Execute Expression tag.
8.1 workbook-execute-expression
This tag executes an expression in a workbook.
Table 14-129 workbook-execute-expression
expression |
Yes |
The expression to execute/calculate |
skip |
No |
stop |
No |
debug |
No |
8.2 rule-debug-log
This tag logs a message to detail rule debug logging. Each occurrence of the message will be replaced with a new line.
Table 14-130 rule-debug-log
msg |
Yes |
Message to be logged. Each occurrence of the message will be replaced with a new line. |
skip |
No |
stop |
No |
debug |
No |
Example:
<testsuite name="Rule detail debug example"> <testcase name="Default path"> <rule-debug-start/> <rule-debug-log msg="This is a test This is line2 This is line3"/> <rule-debug-stop/> </testcase> <testcase name="Given path"> <rule-debug-start log-path="Larry"/> <rule-debug-log msg="This is the second test This is line2 This is line3"/> <rule-debug-stop/> </testcase> </testsuite>
8.3 rule-debug-start
This tag starts the detail rule debug log.
Table 14-131 rule-debug-start
log-path |
No |
The path which to send the detail rule logging. (This defaults to Rule_0000b00.log, where the first four zeros are replaced with the current line number and two zeros after the b are used to make the file name unique.) |
skip |
No |
stop |
No |
debug |
No |
Example:
8.4 rule-debug-stop
This tag closes the detail rule debug logging.
Table 14-132 rule-debug-start
skip |
No |
stop |
No |
debug |
No |
Example:
9. Processes, Tasks, Environment Variables, and DateTime Tags
This section describes the processes, tasks, environment variables, and DateTime tags.
9.1 task-log
Given a task id, a variable will be updated to the full path of the task log.
Table 14-133 task-log
task-id |
Yes |
Task ID of the log wanted |
name |
Yes |
Name of the variable to contain log file path |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <task-log task-id="[TASK_ID]" name="TASK_LOG"/> <assert-file-contains path="[TASK_LOG]" range="1:1" erase="true" text="[DATA]"/> </testcase>
9.2 task-start
This tag starts a task process with the command line provided as the value of this tag.
Table 14-134 task-log
is-script |
No |
Boolean to indicate that the process is a Task script (Defaults to false) |
no-wait |
No |
Boolean to determine if RPAC will wait for process to exit (Defaults to false) |
check-status |
No |
Boolean to determine if a non-zero return status will throw an exception (defaults to true) |
assert-status-equal |
No |
Assert return status equals provide value (value defaults to zero) |
assert-status-not-equal |
No |
Assert return status does not equals provide value (value defaults to zero) |
task-name |
No |
Name to use for task (defaults to blank string) |
task-label |
No |
Label to use for task (defaults to blank string) |
task-domain-access |
No |
Limit access (None, Restricted, Offline) Restricted allow other processes limited access, Offline only allows admin processes to monitor tasks (defaults to None) |
message |
No |
Message to use for either Full or Offline access (defaults to blank string) |
wait-for |
No |
Number of seconds to wait for the task to complete (defaults to 8 hours) |
timeout |
No |
Number of seconds to wait to access when using access modes Restricted or Offline(defaults to 2 hours) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<task-start
task-name ="Start domaininfo task"
task-label="Start domaininfo task"
wait-for ="120">
domaininfo -d [PDS_PATH] -domainversion
</task-start>
</testcase>9.3 task-wait
This tag waits for RPAC created task to exit.
Table 14-135 task-wait
task-id |
Yes |
Task id to wait for |
check-status |
No |
No |
No |
wait-for |
No |
Number of seconds to wait for (defaults to 8 hours) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase> <task-wait task-id="[TASK_ID]"/> </testcase>
9.4 sleep
This tag sleeps for 1 second or value provide with attributes.
Table 14-136 sleep
seconds |
No |
Number of seconds for sleep |
milliseconds |
No |
Number of milliseconds for sleep |
skip |
No |
stop |
No |
debug |
No |
Example:
<sleep seconds="1"/>
9.5 shell
This tag starts a shell process with the command provided as the value of this tag.
Table 14-137 shell
working-directory |
No |
Directory to use for shell, if not provided then the current working directory is used |
is-shell |
No |
Boolean to indicate that the process is a shell script |
check-status |
No |
append-to-log |
No |
Boolean to determine if process should append to output log |
remove-output |
No |
Boolean to determine if output is erase if there are no errors (defaults to true) |
No |
Assert return status equals provide value |
No |
Assert return status does not equals provide value |
output |
No |
File name to which shell command will redirect its output |
no-wait |
No |
Boolean to determine if RPAC will wait for process to exit |
wait-for |
No |
Number of seconds to wait for |
name |
No |
Name to use for process |
unique-file |
No |
Name of the environmental variable to contain unique file path. Output of process will be log to this file path. |
timer-file |
No |
File name to which process execution time will be appended to. |
skip |
No |
stop |
No |
debug |
No |
Example:
<shell check-status="true" is-shell="false">mkdir "[PDS_PATH]/emptyDir"</shell>
9.6 set-date-format
This tag sets the date/time format of that [RPAC_DATE] variable with use.
Table 14-138 set-date-format
| Attribute | Required | Description |
calue |
Yes |
Date/time format to use for [RPAC_DATE] variable |
skip |
No |
stop |
No |
debug |
No |
9.7 set-environment-variable
This tag sets the value of an environmental variable.
Table 14-139 set-environment-variable
name |
Yes |
Name of the environmental variable |
calue |
Yes |
Value of the environmental variable |
export |
No |
Boolean to determine if variable will be exported (defaults to false) |
normalize |
No |
Boolean to indicate variable is file path that should be normalize (defaults to false) |
skip |
No |
Skip this tag if true (defaults to false) |
stop |
No |
Stop rpac execution if true (defaults to false) |
debug |
No |
Wait for debugger if true (defaults to false) |
Example:
<testcase> <set-environment-variable name="INPUT" value="[PDS_PATH]/input"/> <set-environment-variable name="PROCESSED" value="[INPUT]/processed"/> <set-environment-variable name="MY_WORKBOOK" value="[WORKBOOK_NAME]" export="true"/> </testcase>
9.8 rpas-today
This tag sets the RpasToday environmental variable to value of this tag.
Table 14-140 rpas-today
skip |
No |
stop |
No |
debug |
No |
Example:
<rpas-today>20070101</rpas-today>
Where: the date is given in yyyymmdd format.
9.9 process-stop
This tag stops RPAC created process.
Table 14-141 process-stop
name |
Yes |
Name used for the process |
skip |
No |
stop |
No |
debug |
No |
9.10 process-wait
This tag waits for RPAC created process to exit.
Table 14-142 process-wait
name |
Yes |
wait-for |
No |
No |
No |
remove-output |
No |
Boolean to determine is output is erase if there is no error (defaults to true) |
throw-error |
No |
Boolean to determine if wait will throw an exception if process does not exit (defaults to true) |
skip |
No |
stop |
No |
debug |
No |
9.11 get-unique-file-path
This tag sets the value of an environmental variable to a unique file path.
Table 14-143 get-unique-file-path
name |
Yes |
Name of the environmental variable to contain unique file path |
export |
No |
extension |
No |
File extension to used (defaults to .log) (defaults to false) |
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase>
<shell>exportMeasure -rdm [PDS_PATH] -meas "[MEAS]" -out [FILEPATH]</shell>
"w02_2007Test1"|
"w03_2007Test2"|
"w04_2007Test3"
</testcase> 9.12 assert-numeric-value-eq
This tag asserts an RPAC or environment variable is equal to an expected value.
Table 14-144 assert-numeric-value-eq
name |
Yes |
Name of RPAC or the environmental variable. |
value |
No |
Expected value (defaults to 0) |
type |
No |
Must provide type of value as one of these strings slong32, or double (defaults to double). |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check equal 32"> <assert-numeric-value-eq name="VALUE1" value="32" type="slong32"/> </testcase> <testcase name="Check equal 3.145"> <assert-numeric-value-eq name="VALUE2" value="3.145" type="double"/> </testcase> <testcase name="Check equal 3.145"> <assert-numeric-value-eq name="VALUE2" value="3.145"/> </testcase>
9.13 assert-numeric-value-ge
This tag asserts an RPAC or environment variable is greater than or equal to an expected value.
Table 14-145 assert-numeric-value-ge
name |
Yes |
value |
No |
type |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check great than or equal 32"> <assert-numeric-value-ge name="VALUE1" value="32" type="slong32"/> </testcase> <testcase name="Check great than or equal 3.145"> <assert-numeric-value-ge name="VALUE2" value="3.145" type="double"/> </testcase> <testcase name="Check great than or equal 3.145"> <assert-numeric-value-ge name="VALUE2" value="3.145"/> </testcase>
9.14 assert-numeric-value-gt
This tag asserts an RPAC or environment variable is greater than an expected value.
Table 14-146 assert-numeric-value-gt
name |
Yes |
value |
No |
type |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check great than 32"> <assert-numeric-value-gt name="VALUE1" value="33" type="slong32"/> </testcase> <testcase name="Check great than 3.145"> <assert-numeric-value-gt name="VALUE2" value="3.146" type="double"/> </testcase> <testcase name="Check great than 3.145"> <assert-numeric-value-gt name="VALUE2" value="3.146"/> </testcase>
9.15 assert-numeric-value-le
This tag asserts an RPAC or environment variable is less than or equal to an expected value.
Table 14-147 assert-numeric-value-le
name |
Yes |
value |
No |
type |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check less than or equal 32"> <assert-numeric-value-le name="VALUE1" value="32" type="slong32"/> </testcase> <testcase name="Check less than or equal 3.145"> <assert-numeric-value-le name="VALUE2" value="3.145" type="double"/> </testcase> <testcase name="Check less than or equal 3.145"> <assert-numeric-value-le name="VALUE2" value="3.145"/> </testcase>
9.16 assert-numeric-value-lt
This tag asserts an RPAC or environment variable is less than an expected value.
Table 14-148 assert-numeric-value-lt
name |
Yes |
value |
No |
type |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check less than 32"> <assert-numeric-value-lt name="VALUE1" value="31" type="slong32"/> </testcase> <testcase name="Check less than 3.145"> <assert-numeric-value-lt name="VALUE2" value="3.14" type="double"/> </testcase> <testcase name="Check less than 3.145"> <assert-numeric-value-lt name="VALUE2" value="3.14"/> </testcase>
9.17 assert-numeric-value-ne
This tag asserts an RPAC or environment variable is not equal to an expected value.
Table 14-149 assert-numeric-value-ne
name |
Yes |
value |
No |
type |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check not equal 32"> <assert-numeric-value-ne name="VALUE1" value="33" type="slong32"/> </testcase> <testcase name="Check not equal 3.145"> <assert-numeric-value-ne name="VALUE2" value="3.146" type="double"/> </testcase> <testcase name="Check not equal 3.145"> <assert-numeric-value-ne name="VALUE2" value="3.146"/> </testcase>
9.18 assert-string-value-contains
This tag asserts an RPAC or environment variable contains an expected value.
Table 14-150 assert-string-value-contains
name |
Yes |
value |
No |
case-sensitive |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE" value="Alpha"/> </once> <testcase name="Check equal Alpha"> <assert-string-value-contains name="VALUE" value="Alpha"/> </testcase> <testcase name="Check equal ALPHA"> <assert-string-value-contains name="VALUE" value="ALPHA" case-sensitive="true"/> </testcase>
9.19 assert-string-value-does-not-contain
This tag asserts an RPAC or environment variable does not contain an expected value.
Table 14-151 assert-string-value-does-not-contain
name |
Yes |
value |
No |
Expected value (defaults to 0). |
case-sensitive |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE" value="Alpha"/> </once> <testcase name="Check equal Alpha"> <assert-string-value-does-not-contain name="VALUE" value="Alpha"/> </testcase> <testcase name="Check equal ALPHA"> <assert-string-value-does-not-contain name="VALUE" value="ALPHA" case-sensitive="true"/> </testcase>
9.20 assert-string-value-equal
Table 14-152 assert-string-value-equal
name |
Yes |
value |
No |
case-sensitive |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE" value="Alpha"/> </once> <testcase name="Check equal Alpha"> <assert-string-value-equal name="VALUE" value="Alpha"/> </testcase> <testcase name="Check equal ALPHA"> <assert-string-value-equal name="VALUE" value="ALPHA" case-sensitive="true"/> </testcase>
9.21 assert-string-value-not-equal
Table 14-153 assert-string-value-not-equal
name |
Yes |
value |
No |
case-sensitive |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE" value="Alpha"/> </once> <testcase name="Check equal Alpha"> <assert-string-value-not-equal name="VALUE" value="Alpha"/> </testcase> <testcase name="Check equal ALPHA"> <assert-string-value-not-equal name="VALUE" value="ALPHA" case-sensitive="true"/> </testcase>
9.22 if-numeric-value-eq-then-set
This tag asserts if an RPAC or environment variable is equal to an expected value then update RPAC variable to set value.
Table 14-154 if-numeric-value-eq-then-set
name |
Yes |
Name of RPAC or the environmental variable to test. |
variable |
Yes |
Name of RPAC or environment variable to set when comparison is true. |
type |
No |
Must provide type of value as one of these strings slong32 or double (defaults to double). |
value |
No |
set-value |
No |
Value to assign to given variable if comparison is true (Defaults to true). |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check equal 32"> <if-numeric-value-eq-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check equal 3.145"> <if-numeric-value-eq-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check equal 3.145"> <if-numeric-value-eq-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check equal 32"> <if-numeric-value-eq-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.23 if-numeric-value-ge-then-set
This tag asserts if an RPAC or environment variable is greater than or equal to an expected value then update RPAC variable to set value.
Table 14-155 if-numeric-value-ge-then-set
name |
Yes |
variable |
Yes |
type |
No |
value |
No |
set-value |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check greater than or equal 32"> <if-numeric-value-ge-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check greater than or equal 3.145"> <if-numeric-value-ge-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check greater than or equal 3.145"> <if-numeric-value-ge-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check greater than or equal 32"> <if-numeric-value-ge-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.24 if-numeric-value-gt-then-set
This tag asserts if an RPAC or environment variable is greater than an expected value then update RPAC variable to set value.
Table 14-156 if-numeric-value-gt-then-set
name |
Yes |
variable |
Yes |
type |
No |
value |
No |
set-value |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check greater than 32"> <if-numeric-value-gt-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check greater than 3.145"> <if-numeric-value-gt-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check greater than 3.145"> <if-numeric-value-gt-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check greater than 32"> <if-numeric-value-gt-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.25 if-numeric-value-le-then-set
This tag asserts if an RPAC or environment variable is less than or equal to an expected value then update RPAC variable to set value.
Table 14-157 if-numeric-value-le-then-set
name |
Yes |
variable |
Yes |
type |
No |
value |
No |
set-value |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check less than or equal 32"> <if-numeric-value-le-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check less than or equal 3.145"> <if-numeric-value-le-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check less than or equal 3.145"> <if-numeric-value-le-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check less than or equal 32"> <if-numeric-value-le-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.26 if-numeric-value-lt-then-set
This tag asserts if an RPAC or environment variable is less than an expected value then update RPAC variable to set value.
Table 14-158 if-numeric-value-lt-then-set
name |
Yes |
variable |
Yes |
type |
No |
value |
No |
set-value |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check less than 32"> <if-numeric-value-lt-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check less than 3.145"> <if-numeric-value-lt-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check less than 3.145"> <if-numeric-value-lt-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check less than 32"> <if-numeric-value-lt-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.27 if-numeric-value-ne-then-set
This tag asserts if an RPAC or environment variable is not equal to an expected value then update RPAC variable to set value.
Table 14-159 if-numeric-value-ne-then-set
name |
Yes |
variable |
Yes |
type |
No |
value |
No |
set-value |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="32"/> <set-environment-variable name="VALUE2" value="3.145"/> </once> <testcase name="Check not equal 32"> <if-numeric-value-ne-then-set name="VALUE1" variable="VALUE3" value="32" type="slong32"/> </testcase> <testcase name="Check not equal 3.145"> <if-numeric-value-ne-then-set name="VALUE2" variable="VALUE4" value="3.145" type="double"/> </testcase> <testcase name="Check not equal 3.145"> <if-numeric-value-ne-then-set name="VALUE2" variable="VALUE5" value="3.145"/> </testcase> <testcase name="Check not equal 32"> <if-numeric-value-ne-then-set name="VALUE1" variable="VALUE6" value="32" type="slong32" set-value="Value is 32"/> </testcase>
9.28 if-string-value-contains-then-set
This tag asserts if an RPAC or environment variable contains an expected value then update the RPAC variable to set value.
Table 14-160 if-string-value-contains-then-set
name |
Yes |
variable |
Yes |
value |
No |
Expected value (defaults to empty string) |
set-value |
No |
Value to assign to given variable if comparison is true (defaults to true). |
case-sensitive |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="Alpha"/> </once> <testcase name="Assign Value2="true" if VALUE1 contains Alpha"> <if-string-value-contains-then-set name="VALUE1" variable="VALUE2" value="Alpha"/> </testcase> <testcase name="Assign Value3="Is Alpha" if VALUE1 contains Alpha"> <if-string-value-contains-then-set name="VALUE1" variable="VALUE3" value="Alpha" set-value="Is Alpha"/> </testcase> <testcase name="Assign Value4="true" if VALUE1 contains alpha"> <if-string-value-contains-then-set name="VALUE1" variable="VALUE4" value="alpha" case-sensitive="false"/> </testcase>
9.29 if-string-value-does-not-contain-then-set
This tag asserts if an RPAC or environment variable does not contain an expected value then update the RPAC variable to set value.
Table 14-161 if-string-value-does-not-contain-then-set
name |
Yes |
variable |
Yes |
value |
No |
set-value |
No |
case-sensitive |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="Alpha"/> </once> <testcase name="Assign Value2="true" if VALUE1 does not contain Alpha"> <if-string-value-does-not-contain-then-set name="VALUE1" variable="VALUE2" value="Alpha"/> </testcase> <testcase name="Assign Value3="Is Alpha" if VALUE1 does not contain Alpha"> <if-string-value-does-not-contain-then-set name="VALUE1" variable="VALUE3" value="Alpha" set-value="Is Alpha"/> </testcase> <testcase name="Assign Value4="true" if VALUE1 does not contain alpha"> <if-string-value-does-not-contain-then-set name="VALUE1" variable="VALUE4" value="alpha" case-sensitive="false"/> </testcase>
9.30 if-string-value-equal-then-set
This tag asserts if an RPAC or environment variable is equal to an expected value then update the RPAC variable to set value.
Table 14-162 if-string-value-equal-then-set
name |
Yes |
variable |
Yes |
value |
No |
set-value |
No |
case-sensitive |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="Alpha"/> </once> <testcase name="Assign Value2="true" if VALUE1 equal Alpha"> <if-string-value-equal-then-set name="VALUE1" variable="VALUE2" value="Alpha"/> </testcase> <testcase name="Assign Value3="Is Alpha" if VALUE1 equal Alpha"> <if-string-value-equal-then-set name="VALUE1" variable="VALUE3" value="Alpha" set-value="Is Alpha"/> </testcase> <testcase name="Assign Value4="true" if VALUE1 equal alpha"> <if-string-value-equal-then-set name="VALUE1" variable="VALUE4" value="alpha" case-sensitive="false"/> </testcase>
9.30 if-string-value-not-equal-then-set
This tag asserts if an RPAC or environment variable is not equal to an expected value then update the RPAC variable to set value.
Table 14-163 if-string-value-not-equal-then-set
name |
Yes |
variable |
Yes |
value |
No |
set-value |
No |
case-sensitive |
No |
export |
No |
skip |
No |
stop |
No |
debug |
No |
Example:
<once> <set-environment-variable name="VALUE1" value="Alpha"/> </once> <testcase name="Assign Value2="true" if VALUE1 not equal Alpha"> <if-string-value-not-equal-then-set name="VALUE1" variable="VALUE2" value="Alpha"/> </testcase> <testcase name="Assign Value3="Is Alpha" if VALUE1 not equal Alpha"> <if-string-value-not-equal-then-set name="VALUE1" variable="VALUE3" value="Alpha" set-value="Is Alpha"/> </testcase> <testcase name="Assign Value4="true" if VALUE1 equal not alpha"> <if-string-value-not-equal-then-set name="VALUE1" variable="VALUE4" value="alpha" case-sensitive="false"/> </testcase>
10. Misc Tags
This section describes the miscellaneous tags.
10.1 clear-all-measures
This tag clears all measures changed since starting RPAC.
Table 14-164 clear-all-measures
skip |
No |
stop |
No |
debug |
No |
Example:
<testcase name="clear all measures"> <clear-all-measures/> </testcase>
10.2 fail
This tag creates a failure message.
Table 14-165 fail
msg |
No |
Message to used in failure text |
skip |
No |
stop |
No |
debug |
No |
10.3 log
This tag logs a message to the console.
Table 14-166 log
msg |
No |
Message to be logged to the console |
level |
No |
Level to log message at |
skip |
No |
stop |
No |
debug |
No |
Example:
<log level="basic" msg="Testing log tag"/>
10.4 reset-seq-generator
This tag restarts a SQL sequence generator back to 1.
Table 14-167 reset-seq-generator
skip |
No |
stop |
No |
debug |
No |
