4 Schedule Customization
All retail applications that run batch cycles in POM maintain a standard batch schedule with full list of jobs, pre-defined dependencies, job parameters, and so on.
As a part of the implementation, customers can customize those settings based on their needs.
POM supports modifying the following attributes of a schedule:
Enable/Disable a job based on the functional use-case
Modify the job parameters
Modify the job dependencies
Enable/Disable the hourly cycles
Customizations can be set up in the Batch Administration screen or through the Export/Import feature of POM (see Export/Import Schedule Configuration). If the plan is to set up a new non-Oracle-provided schedule, see Custom Schedules.
