3 Noteworthy Resolved Issues
This following table highlights specific key fixes that are included in this release. In some cases, only a percentage of the overall fixed defects are listed.
| Affected Component | Defect Number | Summary |
Batch Monitoring |
35334352 |
POM WITHOUT UI OPTION TO MONITOR THE LOGS. The Batch Jobs table on the Batch Monitoring screen is enhanced with an option to monitor the live log of a job execution in progress. See the View Live Log entry above in the “Scheduled Noteworthy Enhancements” section. |
Batch Monitoring |
35847995 |
POM DOES NOT ALLOW MULTIPLE JOB UPDATES AT THE SAME TIME ON THE BATCH MONITORING SCREEN. The Batch Jobs table on the Batch Monitoring screen was enhanced with an option to multiselect job rows and perform actions on them such as Hold, Release, Skip, Run, Rerun, and Kill. See the Multi-Row Selection and Action entry above in the “Scheduled Noteworthy Enhancements” section. |
Skip Recurring Flow(s) Batch Monitoring |
36030534 |
SELF SERVICE OPTION FOR CUSTOMER - TO SKIP HOURLY. The Skip Recurring Flow(s) screen under AMS Utilities was added to provide the ability to skip an hourly flow or all remaining hourly cycles for the day. Additionally, the Batch Jobs table on the Batch Monitoring screen was enhanced with the ability to skip a job from an hourly cycle for the currently selected recurring cycle or for all subsequent recurring cycles. See the Option to Skip Hourly entry above in the “Scheduled Noteworthy Enhancements’ section. |
Nightly Batch Summary |
35918631 |
ISSUE IN NIGHTLY BATCH SUMMARY - BATCH TIMING FORMAT ISSUES. The naming of months on the Nightly Batch Summary screen was modified so that the format is uniform. |
Notification |
35212413 |
MERCHAPI_EXT_MERCH_HIER_ADHOC_JOB BATCH FAILURE. The Scheduler task failure notification was modified to have a better, meaningful message. |
Scheduler Administration |
36043050 |
POM SCHEDULER ADMINISTRATION ISSUE IN STANDALONE CYCLE. Adhoc jobs that are scheduled to recur at a shorter frequency (for example, 5 minutes) were enhanced so that none of the executions are missed. |
POM Proxy Selection |
36074534 |
UNABLE TO REACH THE EXTERNAL CALLBACK URL FROM FRA REGION TO ABU DHABI REGION. The POM proxy selection logic was enhanced to check the regions for URLs ending with .oraclecloud.com to determine whether to bypass the proxy. If a region of the target host and the POM host match, the target host proxy will be bypassed. Otherwise, it will be routed through the proxy. If POM is unable to fetch the region, a manual step with the help of Oracle support is required to re-patch POM. The Oracle internal provisioning tool needs to be used to correct the hostname and indicate on the Additional Parameters screen that the proxy needs to be bypassed. The key is NON_PROXY_HOSTS_INTERNAL. |
