3 User Roles
Roles are used to classify users based on job responsibilities and actions to be performed in the Oracle Retail Process Orchestration and Monitoring application (POM). Using roles, a user's access can be restricted to specific areas or functions within the application. In POM, users must be associated with at least one job role in order to access the application.
The following topics are covered in this chapter:
Roles
POM comes available with a set of pre-defined roles described in the table below. In addition to the roles, the table contains an alias for each role which is used in the next section for easier reading.
Table 3-1 Roles
| Role | Alias | Description |
BATCH_ADMINISTRATOR_JOB |
Administrator |
Users within this role are retailer administrators with full access to all POM actions. They monitor, maintain and configure the batch schedules. They may also maintain POM application configurations for efficient operations. They troubleshoot batch issues and work with Oracle support personnel to address those issues. Finally, they may apply batch schedule patches and upgrades. Additionally, users assigned this role are given access to the Oracle AMS Utilities screen. |
BATCH_VIEWER_JOB |
Viewer |
Users within this role are retailer business users responsible for just monitoring batch. They have view access to all POM screens except AMS Utilities. |
BATCH_SCHEDULE_CONFIGURATION_MANAGER_JOB |
Schedule Config Mgr |
Users within this role are typically retailer administrators responsible for just monitoring batch and configuring external dependencies and callbacks into the Company's systems. They have view access to all POM screens except AMS Utilities. |
BATCH_SCHEDULE_ADMINISTRATOR_JOB |
Schedule Admin |
Users within this role are typically retailer administrators responsible for maintaining, monitoring and executing batch. They have view access to all POM screens except AMS Utilities. They can perform select activities on the Batch Monitor screen to move the schedule along. They also have update access to the Batch Administration screen. They can also configure some application properties and can configure a new schedule |
BATCH_ORACLE_AMS_ADMINISTRATOR_JOB |
AMS Admin |
Users within this role are typically Oracle AMS administrators who monitor, maintain and configure the batch schedules. They also maintain POM application configurations for efficient operations. They troubleshoot batch issues and work with other Oracle development and support personnel to address those issues. Finally they apply POM and batch schedule patches and upgrades. |
Functional Access by Role
This section lists all roles that have update access for each functional aspect of every screen. It is organized by screen, except for the first two tables.
Table 3-2 External Integration
| Feature | Roles (aliases) with access |
Invoking batch execution from an external system Requesting the status of a batch execution Releasing dependency on an external process |
Schedule Admin Administrator AMS Admin |
Table 3-3 POM Task Menu
Show Batch Monitoring task |
Administrator Viewer Schedule Config Mgr Schedule Admin AMS Admin |
Show System Configuration task |
Show Batch Administration task |
Show Scheduler Administration task |
Administrator Schedule Admin AMS Admin |
Show Schedule Maintenance task |
Show AMS Utilities task |
AMS Admin |
Table 3-4 Screen: Batch Monitoring
| Feature | Roles (aliases) with update access |
Buttons for Create Schedule, Close Schedule and Restart Schedule |
Jobs table on Batch Monitoring screen - Buttons for Run, Rerun, Hold, Release, Skip, Release Skip, and action for Add Comments |
Jobs table Actions menu on Batch Monitoring screen - Edit Parameters (for selected job) |
Job Details screen - Enable/Disable External Dependencies |
Administrator Schedule Config Mgr Schedule Admin AMS Admin |
Job Details screen - Retry Schedule Link button |
Job Details screen - Retry Callback button |
Execution Engine display Configuration |
Download Job Log |
All authenticated users |
Download Cycle Summary |
Scheduler Tasks Monitoring and actions |
Table 3-5 Screen: System Configuration
System tab - Update actions |
Schedule tab - Update actions for general & environment settings |
Schedule tab - Job agent system options dialog |
Schedule tab - Update actions for MDF configuration |
Schedule tab - Update actions for job agent throttling configuration |
System tab - Update actions for external configurations |
Global Edit - Settings updates |
Global Edit - External Configuration updates |
Configure New Schedule |
Table 3-6 Screen: Batch Administration
Export Config and Import Config buttons |
Enable/disable switch on each of the Recurring Flows and Jobs within each Flow |
Jobs table on main UI - Edit and Enable/Disable actions |
Batch Job Details - Enable/Disable Dependencies |
Batch Job Details - Create/Enable/Disable/Delete Inter-Schedule Dependencies |
Batch Job Details - Create/Enable/Disable/Delete Schedule links |
Batch Job Details - Create/Enable/Disable/Delete External Dependencies |
Create/Edit/Delete Custom Adhoc Entities |
Table 3-7 Screen: Scheduler Administration
All Functions on the Scheduler Administration screen |
Table 3-8 Screen: Schedule Maintenance
All actions: Import Latest Schedule button, Upgrade, Retry buttons in table row Download Configuration and download POM seed data |
Table 3-9 Screen: AMS Utilities
Manual Job Run Override Job Status Override Execution Request Status View Audit Events Align Business Dates Skip Recurring Flow(s) |
Table 3-10 Screen: Application Properties
Application Properties |
