Approve/Reject Cost Changes
If a Cost Change is in New or Changes Proposed status, a user can review the Cost Changes and decide to Approve/Reject it. A user with Approval permissions can:
- From the side menu, choose Cost Changes Management.
- In the Cost Changes Management screen, select one or more Cost Changes to Approve/Reject.
- Click Approve/Reject.
Alternatively, the same actions can be done on the Create and Edit Cost Change Screen while viewing a Cost Change.
An Approved Cost Change can be canceled by rejecting the approved Cost Change. A Rejected Cost Change can be updated and submitted again.
