Cancel Appointment
To perform a cancellation of an Appointment, a user with Approval or Edit permissions is required. These actions can be performed using the Appointment List page or from the View Appointment screen. Appointments can be canceled while the receipt process has not started:
- From the side menu, choose Appointments Management.
- In the Appointment List screen, select one or more Appointments to cancel.
- Click Cancel.
- In the Cancel Reason dialog box, select a reason and/or add comments. The appointment status will be updated to Cancel status.
Appointments can only be canceled while in New and Approved status.
