Cancel RTVs
Retailer and Supplier users with Approval permission can cancel RTVs.
To cancel RTVs:
- If a RTV is in Approved status, a user can review the RTV and decide to cancel it.
- From the side menu, choose Return to Vendor.
On the RTV Home screen, select one or more RTVs to cancel and then click Cancel.
A confirmation dialog box is displayed.
- Click Cancel RTV.
- A dialog box is displayed to select the reason and add a comment for the cancellation. Comments are only mandatory if the Reason is Other.
- Click Submit.
Alternatively, a RTV can also be canceled on the Create or Edit RTV screen while viewing a specific return to vendor.
Canceled RTVs cannot be updated.
