Check in Appointments
To perform the check in of an Appointment, a user with Approval or Edit permission is required. These actions can be performed using the Appointment List page or from the View Appointment screen:
  1. From the side menu, choose Appointments Management.
  2. In the Appointment List screen, select one or more Appointments to check in.
  3. Click Check-in. Appointments will be set to Check-in status.
Appointments can only be checked in while in Approved status.
