Receive Appointments
To perform a manual receipt of an Appointment, a user Retailer with Approval permissions is required. These actions can be performed using Appointment List page or from the View Appointment screen:
- From the side menu, choose Appointments Management.
- In the Appointment List screen, select one or more Appointments to receive.
- Click Receive. Appointments are set to Receive status.
Appointments can only be received while in Approved and Checked-in status. This will not perform any receipt in MFCS, only manually updates the status. The status will be automatically changed to Received once an ASN is received in MFCS.
