Create Invoice from PO
In addition to starting an Invoice by inputting all details, it is possible to create a Merchandise Invoice directly from one or more POs, using the PO data to default to the invoice:
- From the side menu, choose Procure to Pay.
- In the Purchase Orders tab, select the POs to be invoiced.
- Click Create Invoice.
- In the Create Invoice dialog box, enter the Document ID and Document Date. Then click Create.
- In Create or Edit Document, review that all the data is correct.
- If available, upload an attachment (for example, PDF) containing the Invoice from the supplier.
- If necessary, the user can edit the Invoice Quantity and Invoice Cost.
- Click Submit.
