Execute Jobs Using Upload
If given permission, users are able to execute jobs using upload:
- Navigate to Quality Control and search for the jobs to execute.
- Select one or more jobs on the Interactive Grid.
- Click Download. The selected jobs are downloaded.
- Make the necessary changes to the downloaded file.
Upload the document by clicking Upload.
The file is uploaded. The id of the upload process is displayed to the user in the right top corner.
- From the side menu, choose Upload and Download. Then, select the Data Loading tab.
- The user can check the status of the upload by searching for the previous ID displayed to the user:
- If processed successfully, all the actions were applied to the job.
If processed with errors or in error, select the line of the upload process. Click View Issues.
Fix the issues on the spreadsheet and repeat the process from the Step 5.
The upload is only available to create, submit, or cancel jobs and create or update the item job checks.
The upload has limited actions that need to be performed directly in the screen:
- The action of complete
- The action of update fields in the table of the items
- The Action of Release Items
- The action of attach files to the item checks
