Integration Tracker
The Integration Tracker enables advanced administrators to check the integration status of entity types in the application.
Integration Tracker
The supported entity types are:
  • Costs
  • Items
  • Purchase Orders
After an entity type is selected, the page displays badges that provide statistics for that entity and a grid used to track the entity integration status.
The page supports the following actions:
  • Download the induction file for an entity that has been published.
  • Download the integration report for the selected entity type.
  • Review why an entity might not be showing on the screen.
  • Filter by status and ID.
