Invoice Orders
If Customer Order Fulfillment is the entry point of the supplier-sourced customer orders then a user, if given permissions, will be able to invoice one or multiple customer orders at the same time. Once a customer order has been dispatched, the invoice can be created:
- From the side menu, choose Customer Order Fulfillment.
- Choose one or more dispatched customer orders.
Click Create Invoice.
A dialog box is displayed to choose the Document ID to be used.
Click Create. A new page is displayed with the invoice details.
The Invoice data is pre-populated with the selected customer order data. On the Item Details screen, it is possible to adjust the Cost and Quantity if required.
- Once ready, click Submit to create the invoice.
- Once submitted, the user is redirected to the Homepage. The status of the customer orders is changed to Processing Invoice while the invoice is integrated.
