Maintain Rules
Rule creation and deletion is currently unavailable, so the associated actions are not available. Users can only view existing rules and make limited updates (such as descriptions or status).
To maintain rules:
  1. From the side menu, choose Configuration Management and then choose Rule Engine Configuration.
  2. Perform the required action:
    • To delete the rule, select the rule to be removed. Click the – icon. A dialog box is displayed to confirm the deletion.This image shows the Delete Rule dialog box.
      • If the user clicks Delete, the rule is deleted.
      • If the user clicks Cancel, the dialog box closes and the rule is not deleted.
      There are validations preventing some rules from being deleted. To remove rules, all data needs to be removed. Alternatively, users can inactivate rules.
    • To update a rule:
      • Header: Click the link in the header table. The Manage Rule dialog box is displayed to update some of the fields:
        • Rule Key (Not Editable)
        • Rule Name (Editable)
        • App Alias (Not Editable)
        • Rule Mode (Not Editable)
        • Status (Editable)
      • Details: Select a rule and update the detail tables. All the fields are editable.
Rules available in the Quality Control
For Quality Control, the following rules are available:
The user is able to add and update this or other rules.
Rule Trigger
Rule Rule Description Trigger Process Status
1 PO ASN Received
Purchase Orders ASN received since the last execution:
  • Trigger only in the first receipt of the ASN for specific location and supplier.
For each time the trigger is enabled, create a new job with the following description:
  • Inspection for PO ASN [ASN ID]
Active
Inactive
Rule Parameters
Rule Rule Description Parameter Parameter Description Paramater Value
1 PO ASN Received APPLY_TEMPLATE_TYPE Indicates if it is required to apply the template type PO/ASN in the Job to be created. Y/N (Default: Y)
