View/Edit Shipment
Until the ASN is received, users are able to change/edit the ASN.
To edit the ASN:
- From the side menu, choose Procure to Pay.
- In the Shipments tab, select the ASN to be edited.
- In the Create/Edit ASN screen, click Edit.
- Apply the changes required. It is possible to:
- Add/Remove POs.
- Add/Remove items.
- Amend item quantities.
- Amend containers.
- Click Submit.
- In the Submit Changes dialog box, provide the Reason and Comments. Then click Submit.
