Activities Option
To navigate to the activities you need to complete, select the Activities option. When you select this option, a tab opens with a default list view of Activities for which you have been assigned as being Responsible. For each activity, the following information is shown:
Proposed End Date
Activity Name
Process Title
Description
Process
Sequence
Proposed Start Date
Actual Start Date
Duration
Status
Sub Status
Critical Path
Key
Gate
The following actions are available on this page:
View: Select an activity from the list. The Activity record opens in read only mode.
Edit: Select an activity from the list. The Activity record opens in edit mode.
Change Status and Exit
There are two ways to update the status for activities:
Select multiple entries in the list. Select the Change Status and Exit action by either right-clicking or selecting it from the Actions menu. Then, select the status change from the list.
Open an activity in edit mode. Select the Change Status and Exit action by either right-clicking or selecting it from the Actions menu. Then, select the status change from the list.
To navigate to the activities you need to complete, you can select Assignments on the Workspace page. For more information, see the Oracle Retail Supplier Evaluation Workspace User Guide.
