2 Retailer Users
This chapter describes how the Process options are used by Retailer users. For information on each option, see the following section:
For users with Administrator access for Process, see the Oracle Retail Supply Chain Collaboration Cloud Service Administration Guide.
The list views have the following options in the View Selector drop-down list:
Associated: You can select to see entries for which you have been assigned as Owner, Responsible, or Viewer.
Owner: You can select to see only the entries for which you have been assigned as Owner.
Responsible: You can select to see only the entries for which you have been assigned as Responsible.
Some lists include Key and Gate columns. These are used within an Activity to force completion of previous activities so that the activities adhere to the critical path. An Activity Gate can be locked, that is, cannot be completed without previous Activity (key or keys) being completed.
Table 2-1 describes the icons in those columns.
Table 2-1 Icons for Key and Gate Columns
| Icons | Description |
Indicates this is a Process record. |
Indicates this is an End Process record. |
Indicates the Activity Key field is set to Yes. |
Indicates that the Activity Gate field is set to Yes and preceding keys are complete. |
Indicates that the Activity Gate field is set to Yes and preceding keys are not all complete. |
