Adding Users
If additional users are required for a process, you can add them. Open the Teams page. On the Teams page, select the Add Team action from the main actions menu. The Select Team dialog box opens. Select a team, click Ok, and then save the process:
  • If you select a team that contains additional users to those users already in your process, these users are added to the relevant role within your process.
  • If you add a team which does not contain roles used by your process, there is no effect on the process.
  • If you add or remove a user, the user is added or removed from all the underlying activities of your process.
