Replacing a Team
If a different set of users is required for a process, you can replace the team. Open the Teams page. On the Teams page, select the Replace Team action from the main actions menu. The Select Team dialog box opens. Select a team from the available teams, click Ok, and then save the process:
  • All current users are replaced with the users specified by the selected team. However, current users assigned to user roles not contained within the selected team are retained.
  • If you add or remove a user, the user is added or removed from all the underlying activities of the process.
